MX7B Cold Cathode Ionization Active Gauge
Part Number: 2-8940-XXX
Operating Specifications
Operating Range
Display
Digital Communications
Analog Output
Programmable Set Points
Set Point 1
Set Point 2
Supply Voltage
Maximum Power
Calibration Medium
Overpressure
Digital Output Resolution
Analog Output Resolution
Operating Temperature
Storage Temperature
Bakeout Temperature
Response Time
Accuracy
1x10-7 to 1x10-3 Torr
Analog Output
Display Readable Distance
1x10-8 Torr to 1x10-3 Torr
OLED
RS-485, USB (micro)
Configurable 0 to 10 V DC
2
Open collector
Relay
22 V DC to 26 V DC
8W
Dry air or nitrogen
150 PSI
3 significant digits with exponent
16-bits
0 °C to 50 °C
-20 °C to 60 °C
120 °C
≤ 150 ms
Description
The Televac® MX7B Active Gauge utilizes a cleanable 7B Penning magnetron cold cathode. It has a variety of features including a wide range
of measurement from 10-8 to 10-3 Torr, RS-485 digital communications,
a micro-USB port, two programmable set points, a configurable analog
output, and a bright color OLED display. The unit also features 4 capacitive touch controls, making all features accessible through the display.
±30% of reading
±10 mV
3 m (10 ft)
Ordering Information
MX7B Active Gauge
¾” NPT Brass
¾” Straight Brass
1” Straight Brass
1-1/4” Straight Brass
NW25 (DN25 ISO-KF) Stainless Steel
Part Number
2-8940-NPT
2-8940-075
2-8940-100
2-8940-125
2-8940-KF25
Replacement Sensors
¾” NPT Brass
¾” Straight Brass
1” Straight Brass
Part Number
2-2171-NPT
2-2171-075
2-2171-100
2-2171-125
2-2171-KF25
D-Sub 6 Conductor Cable (flying leads)
20 ft (6 m)
50 ft (15 m)
100 ft (30 m)
Part Number
2-9873-020
2-9873-050
2-9873-100
D-Sub 15 Conductor Cable (flying leads)
20 ft (6 m)
50 ft (15 m)
100 ft (30 m)
Custom Lengths
Part Number
2-9858-020
2-9858-050
2-9858-100
2-9858-000
Wall Power Supply
100-240 V AC/47-63 Hz, plug types A, C, G, I
Part Number
2-7900-097
Related Products
Name
Operating Range
MX2A
1x10-4 to 1000 Torr
MX4A
1x10-4 to 1000 Torr
EthernetIP Gateway
sales@frederickscompany.com
Part Number
2-8910-1XX
2-8930-1XX
2-8900-100
+1 215 947 2500
The selection of fittings, simplicity of use, ease of sensor cleaning, and
low cost of the MX7B make it an excellent choice for a variety of vacuum applications and industries. This gauge is designed for use with
the MX2A and MX4A active gauges to provide full range vacuum measurement from 10-8 to 10-3 Torr.
When combined with the MX2A or MX4A, the MX7B will provide full
range vacuum measurement from 10-8 to 1000 Torr. This is an optimal solution for heat treat and vacuum furnaces where calibration
frequency requirements vary between rough vacuum (MX2A and
MX4A) and high vacuum (MX7B) gauges. EthernetIP communications can be enabled by integrating the MX7B with the EthernetIP
Gateway.
Applications and Industries
Heat treatment and vacuum furnaces
Thin film deposition and coating processes
Benefits
Low cost with a compact design and color OLED display
Reliable Penning magnetron cold cathode technology
Easily cleaned for extended sensor lifetime
Excellent customer service and support
Rapid turn-around for calibration and service
Ratings and Compliance
Certified to UL 61010-1
CE certified to EN 61010-1, EN 61236-1, EN 55011
Certified to CAN/CSA C22.2 No. 61010-1-12
EAC certified
RoHS Compliant
IP40
www.frederickscompany.com
form mx7b_ds rev F
page 1 of 2
Electrical Connections
Pin
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
Materials Exposed to Vacuum
Brass
Stainless Steel
Tophet
Kovar
Ceramic
Glass
Fluoropolymer Elastomer
Nickel
Solder
Description
Analog Output (Ground)
RS-485 A (-)
SP2 NC
SP2 NO
SP1 Open Drain
Do not connect
Do not connect
Supply Voltage (+)
Analog Out (0 to 10 V)
RS-485 B (+)
SP2 Com
SP1 Source
Sensor Voltage Control (Ground)
Sensor Voltage Control (+)
Supply Voltage (Ground)
Company Information
Set Points
The MX7B has two set points. Set point 1 is an N-Channel 60 V
MOSFET open collector. It has a maximum current rating of 1 A. The
data sheet can be found here:
www.vishay.com/docs/69958/si2308bd.pdf
Set point 2 is a relay with a maximum switching voltage of 220 V DC
(250 V AC) and a maximum switching current of 2 A. The data sheet
can be found here:
www.te.com/catalog/pn/en/1393788-3
Physical Characteristics
Enclosure
Weight with Sensor
Weight without Sensor
Dimensions
Aluminum
1 kg (2 lbs)
0.3 kg (0.6 lbs)
See dimensional drawing
Dimensional Drawing
High performance products designed and manufactured with pride For over 80 years Televac has been a global provider and U.S. manufacturer and designer of high performance vacuum measurement
products. Built to last, our products are made with state-of-the-art
sensing technology, proven processes, and an intrinsic passion for the
trade. Offering simple integration and quality and safety benchmarks,
our customers benefit not just from standard-setting reliability, but
from our commitment to competitive pricing and performance.
A partnership that prioritizes uptime, lead time, and service Televac guarantees customer satisfaction and our ‘not too big, not
too small’ operation is what enables us to offer a true partnership
experience. Our dedicated representatives and engineers offer exceptionally responsive service and some of the fastest lead times in
the industry, knowing that uptime is the key to your success. With
anytime-access to our leadership team and solutions that enhance
your products, you will feel the Televac difference.
Vacuum measurement tools built for the toughest jobs - Televac’s
world-class vacuum sensors, gauges, and control instrumentation are
engineered for the most demanding applications and environments.
Our Televac® and ETI vacuum brands feature cold-cathode technology, thermocouple and convection gauges, and precisionmanufactured hot ionization gauges. Dedicated solely to vacuum
gauging and calibration services, we provide industrial heating, national laboratories, cryogenics, and industrial gas applications, among
many others, with fast lead times and industry-leading performance.
Covering the entire practical vacuum range, our products deliver
rapid response vacuum readings and superior sensitivity.
Contact Us
Televac® - The Fredericks Company
2400 Philmont Avenue
Huntingdon Valley, PA 19006
email: sales@frederickscompany.com
web: www.frederickscompany.com
tel: +1 215 947 2500
fax: +1 215 947 7464
Disclaimer: Specifications subject to change without notice. The Fredericks Company assumes no responsibility for inaccuracies in product specifications or any liability arising from product use.
© 2020 The Fredericks Company
+1 215 947 2500
form mx7b_ds rev F
page 2 of 2
很抱歉,暂时无法提供与“2-8940-NPT”相匹配的价格&库存,您可以联系我们找货
