CD74HCT4351E
CD74HCT4351E
    L3HARRIS
    DIP20
    SINGLE-ENDED MUX, 8 CHANNEL
CD74HCT4351E 数据手册
[ /Title (CD74 HC435 1, CD74 HCT43 51, CD74 HC435 2) /Subject (High Speed CMOS Logic Analog Multiplexers/De multiplexers with Latch) /Autho r () /Keywords (High Speed CMOS Logic CD54HC4351, CD74HC4351, CD74HCT4351, CD74HC4352 Data sheet acquired from Harris Semiconductor SCHS213C September 1998 - Revised July 2003 High-Speed CMOS Logic Analog Multiplexers/Demultiplexers with Latch Features CMOS technology to achieve operating speeds similar to LSTTL with the low power consumption of standard CMOS integrated circuits. • Wide Analog Input Voltage Range . . . . . . . . . ±5V (Max) • Low “On” Resistance - VCC - VEE = 4.5V. . . . . . . . . . . . . . . . . . . . . . 70Ω (Typ) - VCC - VEE = 9V . . . . . . . . . . . . . . . . . . . . . . . 40Ω (Typ) These analog multiplexers/demultiplexers are, in essence, the HC/HCT4015 and HC4052 preceded by address latches that are controlled by an active low Latch Enable input (LE). Two Enable inputs, one active low (E1), and the other active high (E2) are provided allowing enabling with either input voltage level. • Low Crosstalk Between Switches • Fast Switching and Propagation Speeds • “Break-Before-Make” Switching Ordering Information • Wide Operating Temperature Range . . . -55oC to 125oC • HC Types - 2V to 6V Operation, Control; 0V to 10V Switch - High Noise Immunity: NIL = 30%, NIH = 30% of VCC at VCC = 5V TEMP. RANGE (oC) PACKAGE CD54HC4351F3A -55 to 125 20 Ld CERDIP CD74HC4351E -55 to 125 20 Ld PDIP CD74HC4351M -55 to 125 20 Ld SOIC CD74HC4351M96 -55 to 125 20 Ld SOIC CD74HCT4351E -55 to 125 20 Ld PDIP CD74HC4352E -55 to 125 20 Ld PDIP PART NUMBER • HCT Types - 4.5V to 5.5V Operation, Control; 0V to 10V Switch - Direct LSTTL Input Logic Compatibility, VIL= 0.8V (Max), VIH = 2V (Min) - CMOS Input Compatibility, Il ≤ 1µA at VOL, VOH Description NOTE: When ordering, use the entire part number. The suffix 96 denotes tape and reel. The ’HC4351, CD74HCT4351, and CD74HC4352 are digitally controlled analog switches which utilize silicon-gate Pinouts CD54HC4351 (CERDIP) CD74HC4351 (PDIP, SOIC) CD74HCT4351 (PDIP) TOP VIEW A4 1 CD74HC4352 (PDIP) TOP VIEW 20 VCC B0 1 B2 2 19 A2 NC 3 18 A1 B COMMON 4 17 A COMMON 5 16 A0 A6 2 19 A2 B3 NC 3 18 A1 B1 6 15 A3 A COMMON 4 17 A0 E1 7 14 NC A7 5 16 A3 E2 8 13 S0 VEE 9 12 S1 GND 10 11 LE A5 6 15 S0 E1 7 14 NC E2 8 13 S1 VEE 9 12 S2 GND 10 11 LE CAUTION: These devices are sensitive to electrostatic discharge. Users should follow proper IC Handling Procedures. Copyright 20 VCC © 2003, Texas Instruments Incorporated 1 CD54HC4351, CD74HC4351, CD74HCT4351, CD74HC4352 Functional Diagram ’HC4351, CD74HCT4351 CHANNEL IN/OUT VCC 20 A7 A6 A5 A4 A3 A2 A1 A0 5 2 6 1 16 19 18 17 TG S0 15 TG S1 13 S2 12 TG LATCHES TG BINARY TO 1 OF 8 DECODER WITH ENABLE LOGIC LEVEL CONVERSION LE 11 4 A COMMON OUT/IN TG TG E1 TG 7 TG E2 8 10 GND 9 VEE TRUTH TABLE ’HC4351, CD74HCT4351 INPUT STATES E1 E2 S2 S1 S0 (NOTE 1) “ON” SWITCHES LE = H L H L L L A0 H L L H A1 L H L H L A2 L H L H H A3 L H H L L A4 L H H L H A5 L H H H L A6 L H H H H A7 H L X X X None FROM SELECT LOGIC P P VCC VCC N N N N VEE FIGURE 1. DETAIL OF ONE HC/HCT4351 SWITCH H = High Voltage Level, L = Low Voltage Level, X = Don’t Care NOTE: 1. When LE is low S0-S2 data are latched and switches cannot change state. 2 A COMMON IN/OUT L An IN/OUT CD54HC4351, CD74HC4351, CD74HCT4351, CD74HC4352 Functional Diagram CD74HC4352 A CHANNELS IN/OUT VCC A3 A2 A1 A0 15 19 18 16 20 TG S0 13 S0 S0 LATCHES S1 12 LE TG S1 TG S1 BINARY TO 1 OF 4 DECODER WITH ENABLE LOGIC LEVEL CONVERSION 11 TG 17 A COMMON OUT/IN TG 4 B COMMON OUT/IN TG E1 7 E2 8 TG TG 10 9 GND 5 2 6 1 B0 B1 B2 B3 B CHANNELS IN/OUT VEE TRUTH TABLE CD74HC4352 An (Bn) IN/OUT INPUT STATES E1 E2 S1 S0 FROM SELECT LOGIC (NOTE 2) “ON” SWITCHES LE = H H L L A0, B0 L H L H A1, B1 L H H L A2, B2 L H H H A3, B3 H L X X None VCC N N N N VEE H = High Voltage Level, L = Low Voltage Level, X = Don’t Care NOTE: FIGURE 2. DETAIL OF ONE CD74HC4352 SWITCH 2. When Latch Enable is “Low” channel-select data is latched and switches cannot change state. 3 A COMMON (B COMMON) IN/OUT L P P VCC CD54HC4351, CD74HC4351, CD74HCT4351, CD74HC4352 Absolute Maximum Ratings Thermal Information DC Supply Voltage, VCC . . . . . . . . . . . . . . . . . . . . . . . . -0.5V to 7V DC Supply Voltage, VCC - VEE . . . . . . . . . . . . . . . . . . -0.5V to 10.5V DC Supply Voltage, VEE . . . . . . . . . . . . . . . . . . . . . . . . 0.5V to -7V DC Input Diode Current, IIK For VI < -0.5V or VI > VCC 0.5V. . . . . . . . . . . . . . . . . . . . . . . .±20mA DC Switch Diode Current, IOK For VI < VEE -0.5V or VI < VCC + 0.5V . . . . . . . . . . . . . . . . .±25mA DC Switch Current, IOK (Note 3) For VI > VEE -0.5V or VI < VCC + 0.5V . . . . . . . . . . . . . . . . .±20mA DC Output Diode Current, IOK For VO < -0.5V or VO > VCC + 0.5V . . . . . . . . . . . . . . . . . . . .±20mA DC Output Source or Sink Current per Output Pin, IO For VO > -0.5V or VO < VCC + 0.5V . . . . . . . . . . . . . . . . . . . .±25mA DC VCC or Ground Current, ICC . . . . . . . . . . . . . . . . . . . . . . . . .±50mA Thermal Resistance (Typical, Note 4) θJA (oC/W) E (PDIP) Package . . . . . . . . . . . . . . . . . . . . . . . . . . 69 M (SOIC) Package. . . . . . . . . . . . . . . . . . . . . . . . . . 58 Maximum Junction Temperature . . . . . . . . . . . . . . . . . . . . . . . 150oC Maximum Storage Temperature Range . . . . . . . . . .-65oC to 150oC Maximum Lead Temperature (Soldering 10s) . . . . . . . . . . . . . 300oC (SOIC - Lead Tips Only) Operating Conditions Temperature Range, TA . . . . . . . . . . . . . . . . . . . . . . -55oC to 125oC Supply Voltage Range, VCC HC Types . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .2V to 6V HCT Types . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .4.5V to 5.5V Supply Voltage Range, VCC - VEE HC, HCT Types (Figure 3) . . . . . . . . . . . . . . . . . . . . . . .2V to 10V Supply Voltage Range, VEE HC, HCT Types (Figure 4) . . . . . . . . . . . . . . . . . . . . . . . 0V to -6V DC Input or Output Voltage, VI . . . . . . . . . . . . . . . . . . . GND to VCC Analog Switch I/O Voltage, VIS . . . . . . . . . . . . . . . . . . . . . VEE (Min) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . VCC (Max) Input Rise and Fall Time, tr, tf 2V . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1000ns (Max) 4.5V. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 500ns (Max) 6V . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 400ns (Max) CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. NOTES: 3. In certain applications, the external load-resistor current may include both VCC and signal-line components. To avoid drawing VCC current when switch current flows into the transmission gate inputs, the voltage drop across the bidirectional switch must not exceed 0.6V (calculated from RON values shown in the DC Electrical Specifications table). No VCC current will flow through RL if the switch current flows into terminal 3 on the ’HC4351 and CD74HCT4351; terminals 3 and 13 on the CD74HC4352. 4. The package thermal impedance is calculated in accordance with JESD 51-7. Recommended Operating Area as a Function of Supply Voltage 8 6 VCC - GND (V) 4 8 6 VCC - GND (V) 4 HCT HC 2 0 HCT HC 2 0 2 0 4 6 8 10 12 VCC - VEE (V) FIGURE 3. 0 -2 -4 -6 -8 VEE - GND (V) FIGURE 4. 4 CD54HC4351, CD74HC4351, CD74HCT4351, CD74HC4352 DC Electrical Specifications PARAMETER -40oC TO 85oC 25oC TEST CONDITIONS -55oC TO 125oC SYMBOL VI (V) VIS (V) VEE (V) VCC (V) MIN TYP MAX MIN MAX MIN MAX UNITS VIH - - - 2 1.5 - - 1.5 - 1.5 - V 4.5 3.15 - - 3.15 - 3.15 - V 6 4.2 - - 4.2 - 4.2 - V 2 - - 0.5 - 0.5 - 0.5 V 4.5 - - 1.35 - 1.35 - 1.35 V 6 - - 1.8 - 1.8 - 1.8 V 0 4.5 - 70 160 - 200 - 240 Ω 0 6 - 60 140 - 175 - 210 Ω -4.5 4.5 - 40 120 - 150 - 180 Ω 0 4.5 - 90 180 - 225 - 270 Ω 0 6 - 80 160 - 200 - 240 Ω -4.5 4.5 - 45 130 - 162 - 195 Ω 0 4.5 - 10 - - - - - Ω 0 6 - 8.5 - - - - - Ω -4.5 4.5 - 5 - - - - - Ω 0 6 - - ±0.1 - ±1 - ±1 µA -5 5 - - ±0.2 - ±2 - ±2 µA 0 6 - - ±0.2 - ±2 - ±2 µA -5 5 - - ±0.4 - ±4 - ±4 µA HC TYPES High Level Input Voltage Low Level Input Voltage “ON” Resistance IO = 1mA Figure 9 VIL RON - VIH or VIL - VCC or VEE VCC to VEE Maximum “ON” Resistance Between Any Two Channels Switch On/Off Leakage Current 4 Channels (4352) ∆RON IIZ - VIH or VIL Switch On/Off Leakage Current 8 Channels (4351) - For Switch OFF: When VIS = VCC VOS = VEE; When VIS = VEE, VOS = VCC For Switch ON: All Applicable Combinations of VIS and VOS Voltage Levels - Control Input Leakage Current IIL VCC or GND - 0 6 - - ±0.1 - ±1 - ±1 µA Quiescent Device Current IO = 0 ICC VCC or GND When VIS = VEE, VOS = VCC, When VIS = VCC, VOS = VEE 0 6 - - 8 - 80 - 160 µA -5 5 - - 16 - 160 - 320 µA 5 CD54HC4351, CD74HC4351, CD74HCT4351, CD74HC4352 DC Electrical Specifications (Continued) SYMBOL VI (V) VIS (V) VEE (V) VCC (V) High Level Input Voltage VIH - - - Low Level Input Voltage VIL - - “ON” Resistance IO = 1mA Figure 9 RON VIH or VIL VCC or VEE PARAMETER -40oC TO 85oC 25oC TEST CONDITIONS -55oC TO 125oC MIN TYP MAX MIN MAX MIN MAX UNITS 4.5 to 5.5 2 - - 2 - 2 - V - 4.5 to 5.5 - - 0.8 - 0.8 - 0.8 V 0 4.5 - 70 160 - 200 - 240 Ω -4.5 4.5 - 40 120 - 150 - 180 Ω 0 4.5 - 90 180 - 225 - 270 Ω -4.5 4.5 - 45 130 - 162 - 195 Ω 0 4.5 - 10 - - - - - Ω -4.5 4.5 - 5 - - - - - Ω 0 6 - - ±0.1 - ±1 - ±1 µA -5 5 - - ±0.2 - ±2 - ±2 µA 0 6 - - ±0.2 - ±2 - ±2 µA -5 5 - - ±0.4 - ±4 - ±4 µA 0 5.5 - - ±0.1 - ±1 - ±1 µA 0 5.5 - - 8 - 80 - 160 µA -4.5 5.5 - - 16 - 160 - 320 µA - 4.5 to 5.5 - 100 360 - 450 - 490 µA HCT TYPES VCC to VEE Maximum “ON” Resistance Between Any Two Channels Switch On/Off Leakage Current 4 Channels (4352) ∆RON IIZ - VIH or VIL Switch On/Off Leakage Current 8 Channels (4351) Control Input Leakage Current Quiescent Device Current IO = 0 Additional Quiescent Device Current Per Input Pin: 1 Unit Load II VCC or GND ICC - For Switch OFF: When VIS = VCC VOS = VEE; When VIS = VEE, VOS = VCC For Switch ON: All Applicable Combinations of VIS and VOS Voltage Levels - Any When Voltage VIS = VEE, BeVOS = VCC, tween When VCC VIS = VCC, and VOS = VEE GND ∆ICC (Note 5) VCC -2.1 - NOTE: 5. For dual-supply systems theoretical worst case (VI = 2.4V, VCC = 5.5V) specification is 1.8mA. HCT Input Loading Table TYPE INPUT UNIT LOADS All E1, E2, Sn 0.5 (4351, 4352) LE 1.5 NOTE: Unit Load is ∆ICC limit specified in DC Electrical Table, e.g., 360µA max at 25oC. 6 CD54HC4351, CD74HC4351, CD74HCT4351, CD74HC4352 Switching Specifications Input tr, tf = 6ns -40oC TO 85oC 25oC PARAMETER -55oC TO 125oC SYMBOL TEST CONDITIONS VEE (V) VCC (V) MIN TYP MAX MIN MAX MIN MAX UNITS tPLH, tPHL CL = 50pF 0 2 - - 35 - 45 - 55 ns 0 4.5 - - 7 - 9 - 11 ns 0 6 - - 6 - 8 - 9 ns -4.5 4.5 - - 5 - 7 - 8 ns 0 2 - - 300 - 375 - 450 ns 0 4.5 - - 60 - 75 - 90 ns 0 6 - - 51 - 64 - 77 ns -4.5 4.5 - - 55 - 69 - 83 ns CL = 15pF - 5 - 27 - - - - - ns CL = 50pF 0 2 - - 350 - 440 - 525 ns 0 4.5 - - 70 - 88 - 105 ns 0 6 - - 60 - 75 - 90 ns -4.5 4.5 - - 60 - 75 - 90 ns CL = 15pF - 5 - 35 - - - - - ns CL = 50pF 0 2 - - 300 - 375 - 450 ns 0 4.5 - - 60 - 75 - 90 ns 0 6 - - 51 - 64 - 77 ns -4.5 4.5 - - 50 - 63 - 75 ns CL = 15pF - 5 - 27 - - - - - ns CL = 50pF 0 2 - - 375 - 470 - 565 ns 0 4.5 - - 75 - 94 - 113 ns 0 6 - - 64 - 80 - 96 ns -4.5 4.5 - - 55 - 69 - 83 ns CL = 15pF - 5 - 35 - - - - - ns CL = 50pF 0 2 - - 250 - 315 - 375 ns 0 4.5 - - 50 - 63 - 75 ns 0 6 - - 43 - 54 - 64 ns -4.5 4.5 - - 40 - 50 - 60 ns - 5 - 21 - - - - - ns HC TYPES Propagation Delay, Switch In to Switch Out Maximum Switch Turn “ON” Delay 4351 E1, E2, LE to VOS Maximum Switch Turn “ON” Delay 4352 E1, E2, LE to VOS Maximum Switch Turn “ON” Delay 4351 Sn to VOS Maximum Switch Turn “ON” Delay 4352 Sn to VOS Maximum Switch Turn “OFF” Delay 4351 E1 to VOS tPZH, tPZL tPZH, tPZL tPZH, tPZL tPZH, tPZL tPHZ, tPLZ CL = 50pF CL = 15pF 7 CD54HC4351, CD74HC4351, CD74HCT4351, CD74HC4352 Switching Specifications Input tr, tf = 6ns (Continued) -40oC TO 85oC 25oC PARAMETER Maximum Switch Turn “OFF” Delay 4351 E2 to VOS Maximum Switch Turn “OFF” Delay 4351 LE to VOS Maximum Switch Turn “OFF” Delay 4351 Sn to VOS Maximum Switch Turn “OFF” Delay 4352 E1, E2, LE to VOS Setup Time 4351 Sn to LE Hold Time 4351 and 4352 Sn to LE Pulse Width 4351 and 4352 LE Input (Control) Capacitance Power Dissipation Capacitance (Notes 6, 7) 4351 -55oC TO 125oC SYMBOL TEST CONDITIONS VEE (V) VCC (V) MIN TYP MAX MIN MAX MIN MAX UNITS tPHZ, tPLZ CL = 50pF 0 2 - - 250 - 315 - 375 ns 0 4.5 - - 50 - 63 - 75 ns 0 6 - - 43 - 54 - 64 ns -4.5 4.5 - - 40 - 50 - 60 ns CL = 15pF - 5 - 21 - - - - - ns CL = 50pF 0 2 - - 275 - 345 - 415 ns 0 4.5 - - 55 - 69 - 83 ns 0 6 - - 47 - 59 - 71 ns -4.5 4.5 - - 45 - 56 - 68 ns 0 2 - - 275 - 345 - 415 ns 0 4.5 - - 55 - 69 - 83 ns 0 6 - - 47 - 59 - 71 ns -4.5 4.5 - - 48 - 60 - 71 ns CL = 15pF - 5 - 21 - - - - - ns CL = 50pF 0 2 - - 275 - 345 - 415 ns 0 4.5 - - 55 - 69 - 83 ns 0 6 - - 47 - 59 - 71 ns -4.5 4.5 - - 50 - 63 - 75 ns CL = 15pF - 5 - 21 - - - - - ns CL = 50pF 0 2 - - 60 - 75 - 90 ns 0 4.5 - - 12 - 15 - 18 ns 0 6 - - 10 - 13 - 15 ns -4.5 4.5 - - 18 - 23 - 27 ns 0 2 5 - - 5 - 5 - ns 0 4.5 5 - - 5 - 5 - ns 0 6 5 - - 5 - 5 - ns -4.5 4.5 5 - - 5 - 5 - ns 0 2 100 - - 125 - 150 - ns 0 4.5 20 - - 25 - 30 - ns 0 6 17 - - 21 - 26 - ns -4.5 4.5 25 - - 31 - 38 - ns tPHZ, tPLZ tPHZ, tPLZ tPHZ, tPLZ tSU tH tW CL = 50pF CL = 50pF CL = 50pF CI - - - - - 10 - 10 - 10 pF CPD - - 5 - 50 - - - - - pF 8 CD54HC4351, CD74HC4351, CD74HCT4351, CD74HC4352 Switching Specifications Input tr, tf = 6ns (Continued) -40oC TO 85oC 25oC -55oC TO 125oC PARAMETER SYMBOL TEST CONDITIONS VEE (V) VCC (V) MIN TYP MAX MIN MAX MIN MAX UNITS Power Dissipation Capacitance (Notes 6, 7) 4352 CPD - - 5 - 74 - - - - - pF tPLH, tPHL CL = 50pF 0 4.5 - - 7 - 9 - 11 ns -4.5 4.5 - - 5 - 7 - 8 ns 0 4.5 - - 75 - 94 - 113 ns -4.5 4.5 - - 60 - 75 - 90 ns CL = 15pF - 5 - 35 - - - - - ns CL = 50pF 0 4.5 - - 75 - 94 - 113 ns -4.5 4.5 - - 60 - 75 - 90 ns CL = 15pF - 5 - 35 - - - - - ns CL = 50pF 0 4.5 - - 55 - 69 - 83 ns -4.5 4.5 - - 40 - 50 - 60 ns CL = 15pF - 5 - 23 - - - - - ns CL = 50pF 0 4.5 - - 60 - 75 - 90 ns -4.5 4.5 - - 50 - 63 - 75 ns CL = 15pF - 5 - 23 - - - - - ns CL = 50pF 0 4.5 - - 60 - 75 - 90 ns -4.5 4.5 - - 55 - 69 - 83 ns 0 4.5 - - 65 - 81 - 98 ns -4.5 4.5 - - 55 - 69 - 83 ns CL = 15pF - 5 - 23 - - - - - ns CL = 50pF 0 4.5 - - 12 - 15 - 18 ns -4.5 4.5 - - 14 - 18 - 21 ns 0 4.5 5 - - 5 - 5 - ns -4.5 4.5 5 - - 5 - 5 - ns 0 4.5 25 - - 31 - 28 - ns -4.5 4.5 25 - - 31 - 38 - ns HCT TYPES Propagation Delay, Switch In to Switch Out Maximum Switch Turn “ON” Delay 4351 E1, E2, LE to VOS Maximum Switch Turn “ON” Delay 4351 Sn to VOS Maximum Switch Turn “OFF” Delay 4351 E1 to VOS Maximum Switch Turn “OFF” Delay 4351 E2 to VOS tPZH, tPZL tPZH, tPZL tPHZ, tPLZ tPHZ, tPLZ Maximum Switch Turn “OFF” Delay 4351 LE to VOS tPHZ, tPLZ Maximum Switch Turn “OFF” Delay 4351 Sn to VOS tPHZ, tPLZ Setup Time 4351 Sn to LE Hold Time 4351 and 4352 Sn to LE Pulse Width 4351 LE Input (Control) Capacitance Power Dissipation Capacitance (Notes 6, 7) 4351 CL = 50pF CL = 50pF CL = 50pF tW CL = 50pF CI - - - - - 10 - 10 - 10 pF CPD - - 5 - 52 - - - - - pF NOTES: 6. CPD is used to determine the dynamic power consumption, per package. 7. PD = CPD VCC2 fi + Σ (CL + CS) VCC2 fo where fi = input frequency, fo = output frequency, CL = output load capacitance, CS = switch capacitance, VCC = supply voltage. 9 CD54HC4351, CD74HC4351, CD74HCT4351, CD74HC4352 Analog Channel Specifications PARAMETER Switch Input Capacitance Common Capacitance Minimum Switch Frequency Response at -3dB (Figure 6, 8) TA = 25oC SYMBOL TEST CONDITIONS TYPE VEE (V) VCC (V) HC/HCT UNITS CI All - - 5 pF CCOM 4351 - - 25 pF 4352 - - 12 pF 4351 - - 145 MHz 4352 -2.25 2.25 165 MHz fMAX Crosstalk Between Any Two Switches (Note 11) Sine-Wave Distortion E or S to Switch Feedthrough Noise Switch “OFF” Signal Feedthrough (Figure 6, 8) See Figure 11 (Notes 8, 9) See Figure 10 (Notes 9, 10) See Figure 12 See Figure 13 (Notes 9, 10) See Figure 14 (Notes 9, 10) NOTES: 8. Adjust input voltage to obtain 0dBm at VOS for, fin = 1MHz. 9. VIS is centered at (VCC - VEE)/2. 10. Adjust input for 0dBm. 11. Not applicable for ’HC4351 and CD74HCT4351. 10 4351 - - 180 MHz 4352 -4.5 4.5 185 MHz 4351 - - N/A dB 4352 -2.25 2.25 (TBE) dB 4351 - - N/A dB 4352 -4.5 4.5 (TBE) dB All -2.25 2.25 0.035 % All -4.5 4.5 0.018 % 4351 - - - mV 4352 -2.25 2.25 (TBE) mV 4351 - - - mV 4352 -4.5 4.5 (TBE) mV 4351 - - -73 dB 4352 -2.25 2.25 -65 dB 4351 - - -75 dB 4352 -4.5 4.5 -67 dB CD54HC4351, CD74HC4351, CD74HCT4351, CD74HC4352 Typical Performance Curves 0 0 VCC = 4.5V GND = -4.5V VEE = -4.5V RL = 50Ω PIN 12 TO 3 -2 -4 -40 dB dB VCC = 2.25V GND = -2.25V VEE = -2.25V RL = 50Ω PIN 12 TO 3 -6 VCC = 2.25V GND = -2.25V VEE = -2.25V RL = 50Ω PIN 12 TO 3 -20 -60 -8 VCC = 4.5V GND = -4.5V VEE = -4.5V RL = 50Ω PIN 12 TO 3 -80 -10 10K 100K 1M 10M FREQUENCY, f (Hz) -100 10K 100M FIGURE 5. CHANNEL ON BANDWIDTH (’HC4351, CD74HCT4351) 1M 10M FREQUENCY, f (Hz) 100M FIGURE 6. CHANNEL OFF FEEDTHROUGH (’HC4351, CD74HCT4351) 0 0 VCC = 4.5V GND = -4.5V VEE = -4.5V RL = 50Ω PIN 4 TO 3 -2 -4 -40 dB dB VCC = 2.25V GND = -2.25V VEE = -2.25V RL = 50Ω PIN 4 TO 3 -20 VCC = 2.25V GND = -2.25V VEE = -2.25V RL = 50Ω PIN 4 TO 3 -6 -60 VCC = 4.5V GND = -4.5V VEE = -4.5V RL = 50Ω PIN 4 TO 3 -80 -8 -10 10K 100K 100K 1M 10M FREQUENCY, f (Hz) -100 10K 100M 100K 1M 10M 100M FREQUENCY, f (Hz) FIGURE 7. CHANNEL ON BANDWIDTH (CD74HC4352) FIGURE 8. CHANNEL OFF FEEDTHROUGH (CD74HC4352) 11 CD54HC4351, CD74HC4351, CD74HCT4351, CD74HC4352 “ON” RESISTANCE, RON (Ω) Typical Performance Curves (Continued) 130 120 110 100 90 80 70 60 50 40 30 20 10 VCC - VEE = 4.5V VCC - VEE = 6V VCC - VEE = 9V 0 1 0 2 3 4 5 6 7 8 9 INPUT SIGNAL VOLTAGE, VIS (V) FIGURE 9. TYPICAL ON RESISTANCE vs INPUT SIGNAL VOLTAGE Analog Test Circuits VIS 0.1µF VCC VCC SWITCH ON VIS R VOS1 R R C VOS2 SWITCH OFF R VCC/2 VCC/2 C dB METER VCC/2 fIS = 1MHz SINEWAVE R = 50Ω C = 10pF FIGURE 10. CROSSTALK BETWEEN TWO SWITCHES TEST CIRCUIT VCC VCC 0.1µF VIS SINE WAVE 10µF VIS VOS SWITCH ON 50Ω VCC/2 VIS SWITCH ON VI = VIH VOS 10kΩ 10pF dB METER VCC/2 50pF DISTORTION METER fIS = 1kHz TO 10kHz FIGURE 11. FREQUENCY RESPONSE TEST CIRCUIT FIGURE 12. TOTAL HARMONIC DISTORTION TEST CIRCUIT 12 CD54HC4351, CD74HC4351, CD74HCT4351, CD74HC4352 Analog Test Circuits (Continued) E VCC 600Ω VCC/2 SWITCH ALTERNATING ON AND OFF tr, tf ≤ 6ns fCONT = 1MHz 50% DUTY CYCLE VCC VP-P VOS 0.1µF 600Ω 50pF VCC/2 SCOPE FIGURE 13. CONTROL-TO-SWITCH FEEDTHROUGH NOISE TEST CIRCUIT fIS ≥ 1MHz SINEWAVE R = 50Ω C = 10pF VOS SWITCH OFF VIS VOS VC = VIL R R VCC/2 VCC/2 C dB METER FIGURE 14. SWITCH OFF SIGNAL FEEDTHROUGH 13 CD54HC4351, CD74HC4351, CD74HCT4351, CD74HC4352 Test Circuits and Waveforms tWL + tWH = tfCL trCL tWL + tWH = trCL = 6ns tfCL = 6ns 50% 10% 10% 2.7V CLOCK 50% 50% 1.3V 0.3V 0.3V GND 1.3V 1.3V GND tWH tWL tWH tWL I fCL 3V VCC 90% CLOCK I fCL NOTE: Outputs should be switching from 10% VCC to 90% VCC in accordance with device truth table. For fMAX, input duty cycle = 50%. NOTE: Outputs should be switching from 10% VCC to 90% VCC in accordance with device truth table. For fMAX, input duty cycle = 50%. FIGURE 15. HC CLOCK PULSE RISE AND FALL TIMES AND PULSE WIDTH FIGURE 16. HCT CLOCK PULSE RISE AND FALL TIMES AND PULSE WIDTH tr = 6ns tf = 6ns 90% 50% 10% INPUT GND tTLH 90% INVERTING OUTPUT tPHL FIGURE 17. HC TRANSITION TIMES AND PROPAGATION DELAY TIMES, COMBINATION LOGIC trCL VCC 90% GND tH(H) 3V 2.7V 1.3V 0.3V GND tH(H) tH(L) VCC DATA INPUT DATA INPUT 50% tH(L) 3V 1.3V 1.3V 1.3V GND tSU(H) tSU(H) tSU(L) tTLH 90% OUTPUT tTHL 90% 50% 10% tTLH 90% 1.3V OUTPUT tREM 3V SET, RESET OR PRESET GND tTHL 1.3V 10% FIGURE 19. HC SETUP TIMES, HOLD TIMES, REMOVAL TIME, AND PROPAGATION DELAY TIMES FOR EDGE TRIGGERED SEQUENTIAL LOGIC CIRCUITS tPHL 1.3V GND IC CL 50pF GND 90% tPLH 50% IC tSU(L) tPHL tPLH tREM VCC SET, RESET OR PRESET tfCL CLOCK INPUT 50% 10% tPLH FIGURE 18. HCT TRANSITION TIMES AND PROPAGATION DELAY TIMES, COMBINATION LOGIC tfCL trCL tTLH 1.3V 10% tPLH tPHL GND tTHL 90% 50% 10% INVERTING OUTPUT 3V 2.7V 1.3V 0.3V INPUT tTHL CLOCK INPUT tf = 6ns tr = 6ns VCC CL 50pF FIGURE 20. HCT SETUP TIMES, HOLD TIMES, REMOVAL TIME, AND PROPAGATION DELAY TIMES FOR EDGE TRIGGERED SEQUENTIAL LOGIC CIRCUITS 14 CD54HC4351, CD74HC4351, CD74HCT4351, CD74HC4352 Test Circuits and Waveforms 6ns (Continued) 6ns OUTPUT DISABLE tr VCC 90% 50% 10% OUTPUTS ENABLED OUTPUT HIGH TO OFF 50% OUTPUTS DISABLED FIGURE 21. HC THREE-STATE PROPAGATION DELAY WAVEFORM OTHER INPUTS TIED HIGH OR LOW OUTPUT DISABLE IC WITH THREESTATE OUTPUT GND 1.3V tPZH 90% OUTPUTS ENABLED OUTPUTS ENABLED 0.3 10% tPHZ tPZH 90% 3V tPZL tPLZ OUTPUT LOW TO OFF 50% OUTPUT HIGH TO OFF 6ns GND 10% tPHZ tf 2.7 1.3 tPZL tPLZ OUTPUT LOW TO OFF 6ns OUTPUT DISABLE 1.3V OUTPUTS DISABLED OUTPUTS ENABLED FIGURE 22. HCT THREE-STATE PROPAGATION DELAY WAVEFORM OUTPUT RL = 1kΩ CL 50pF VCC FOR tPLZ AND tPZL GND FOR tPHZ AND tPZH NOTE: Open drain waveforms tPLZ and tPZL are the same as those for three-state shown on the left. The test circuit is Output RL = 1kΩ to VCC, CL = 50pF. FIGURE 23. HC AND HCT THREE-STATE PROPAGATION DELAY TEST CIRCUIT 15 PACKAGE OPTION ADDENDUM www.ti.com 6-Feb-2020 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan Lead/Ball Finish MSL Peak Temp (2) (6) (3) Op Temp (°C) Device Marking (4/5) CD54HC4351F3A ACTIVE CDIP J 20 1 TBD Call TI N / A for Pkg Type -55 to 125 CD54HC4351F3A CD74HC4351E ACTIVE PDIP N 20 20 Pb-Free (RoHS) NIPDAU N / A for Pkg Type -55 to 125 CD74HC4351E CD74HC4351EE4 ACTIVE PDIP N 20 20 Pb-Free (RoHS) NIPDAU N / A for Pkg Type -55 to 125 CD74HC4351E CD74HC4351M ACTIVE SOIC DW 20 25 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 HC4351M CD74HC4351M96 ACTIVE SOIC DW 20 2000 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 HC4351M CD74HC4352E ACTIVE PDIP N 20 20 Pb-Free (RoHS) NIPDAU N / A for Pkg Type -55 to 125 CD74HC4352E CD74HCT4351E ACTIVE PDIP N 20 20 Pb-Free (RoHS) NIPDAU N / A for Pkg Type -55 to 125 CD74HCT4351E (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may reference these types of products as "Pb-Free". RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption. Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
CD74HCT4351E 价格&库存
很抱歉,暂时无法提供与“CD74HCT4351E”相匹配的价格&库存,您可以联系我们找货
