PTE7100-43CC-2E400BN 数据手册
| PTE7100 SERIES
HERMETIC ANALOG PRESSURE SENSOR
The PTE7100 pressure sensor is the ideal solution for customers with challenging measuring requirements for general industrial applications in the mid and
high pressure ranges. Utilizing Sensata’s automotive leading Micro Silicon Strain Gauge with best-in-class accuracy, the PTE7100 features a wide range of
ports, connectors, and analog electrical outputs for ease of integration in various industrial applications.
The PTE7100’s high quality stainless steel design features a hermetic port with no internal o-ring seals making it compatible with most media and suitable
for harsh environments. With extreme shock and vibration capabilities, a wide operating temperature range, and high proof and burst pressures; the
PTE7100 is ideal for industrial applications including injection molding, CO2 HVAC systems, and other hydraulic or pneumatic applications.
Features
• Measuring range from 0-50 bar to 0-600 bar (0-725 to 0-8700 psi)
• High accuracy
• Wide range of ports, connectors, and electrical outputs
• Stainless steel design with hermetic port
• Storage and operating media temperature -40-125°C; Operating ambient temp. range -40-100°C
• Snubber option for dampening of pressure spikes due to hammer and
cavitation
• REACH/RoHS/CE compliant
Applications
• Hydraulics and Pneumatics
• Mobile Hydraulics and Off-Highway Vehicles
• Pumps and Compressors
• Air Conditioning and Refrigeration Systems
• Plant Engineering and Automation
SPECIFICATIONS
Electrical
Pressure Ranges
Pressure Reference
Supply Voltage/Output
Output Load
0-50 to 0-600 bar (0-725 to 0-8700 psi)
Gauge
8-32VDC for 4-20mA output
5±0.25VDC for 0.5-4.5VDC output
8-32VDC for 0-5VDC output
12-32VDC for 0-10VDC output
8-32VDC for 1-5VDC output
8-32VDC for 0.5-4.5VDC output
≥ 4.7 kΩ for voltage output
≤ (Vsup-8)/20mA for current supply
Output Response Time
Overvoltage Protection
Reverse Voltage Protection
Short Circuit Protection
Insulation Resistance
EMC
Dielectric Strength
Enhanced Radiated Immunity
100 MΩ at 500V
IEC 61326-1 and EN 61326-2-3
500 VAC
100V/m (80~200MHz)
200V/m (200~2700MHz)
Page 1
Copyright © 2021 Sensata Technologies, Inc.
www.sensata.com
Physical
Proof Pressure
Burst Pressure
2X full scale pressure(1)
Random Vibration
Mechanical Shock
Drop (any Axis)
Ingress Protection
Media Compatibility
IEC 60068-2-6, 30g (10…2000Hz)
20X for full scale pressure = 50-100 bar
10X for full scale pressure = 101-400 bar
4000 bar for full scale pressure = 401-600 bar
EN 60068-2-27, 500g
1m
IP65 - IP67 (see Connector Options)
Fluids and Gases compatible with 17-4PH stainless steel
Performance
Accuracy (Best Fit Straight Line)(2)
Accuracy (Total Error Band)(3)
Operating Endurance
Operating Ambient Temperature
Operating Media Temperature
Storage Temperature
±0.25%FS @25°C
+/-1.5%FS @-20° to 85°C
>10M cycles
-40° to +100°C
-40° to +125°C
-40° to +125°C (4)
DIMENSIONS
All dimensions are in millimeters
Pressure Port
OVERALL DIMENSIONS
G1/4A DIN 3852-E
7/16-20 UNF-2A (MALE)
1/4-19 PT (R1/4)
13
11.2
18.9
15.6
1/4-18 NPTF
5
21
9.25
14
13
2
2
23
13
HEX24
Page 2
www.sensata.com
Electrical Connector
M12x1 4-POLE
PIN 1
PIN 4
PIN 2
PIN 3
IP67
28
16
PIN 1
PIN B
PIN A
DEUTSCH DT04-3P
A: DIN 175301-803 FORM A(18mm)
IP65
IP67
24
IP67
24
PACKARD METRI-PACK 150
PIN A
PIN 4
PIN 3
PIN C
PIN C
PIN B
PIN 2
Output
Type
PIN A
PIN B
PIN C
Output
Type
PIN
1
PIN
2
PIN
3
PIN
4
Output
Type
PIN
1
PIN
2
PIN
3
PIN
4
Output
Type
PIN
A
PIN
B
PIN
C
Voltage
V-
V+
Vout
Voltage
V+
V-
Vout
Voltage
V+
V-
Vout
Voltage
V+
V-
Vout
Current
Iout
V+
Current
V+
Iout
Current
V+
Iout
Current
V+
Iout
FLY LEAD WITH HARNESS
IP67
27
AWG18 WIRE, WITH PVC SHELL
TEMPERATURE RANGE -40~105 C
Output
Type
RED
BLACK
WHITE
Voltage
V+
V-
Vout
Current
V+
Iout
Page 3
www.sensata.com
Example : PTE7100-31AA-1A250BS
ORDERING OPTIONS
PTE7100 with G1/4A thread with external FKM o-ring seal, DIN A connector, 4-20
PTE7100
XX*
A
A
1
A
250B
S
Family
PTE7100
Pressure Port
A: G1/4A DIN 3852-E
B: 1/4-19PT (R1/4)
C: 7/16-20 UNF-2A (MALE)
D: 1/4-18NPT
A: DIN 175301-803 Form A(18mm)
B: M12 4-POLE
C: Packard Metri-Pack 150
D: Fly-Lead 3 pole harness
E: DEUTSCH DT04-3P
External Sealing
0: No o-ring
1: FKM (Viton) o-ring (only for G1/4 pressure port)
2: HNBR o-ring (only for 7/16-20 UNF-2A MALE pressure port)
Electrical Output/Input
A: 4-20ma / 8-32Vdc
B: 0.5-4.5Vdc / 5±0.25Vdc
C: 0-5Vdc / 8-32Vdc
D: 0-10Vdc / 12-32Vdc
E: 1-5Vdc/8-32Vdc
F: 0.5-4.5Vdc / 8-32VDC
Pressure Range
050B: 0-50bar
060B: 0-60bar
100B: 0-100bar
160B: 0-160bar
200B: 0-200bar
250B: 0-250bar
350B: 0-350bar
400B: 0-400bar
500B: 0-500bar
600B: 0-600bar
Mating Connector & Snubber (5)
N: No snubber and no mating connector
S: No mating connector, snubber with 0.5 damping hole
M: No snubber, with mating connector
A: Mating connector and snubber with 0.5 damping hole
*Factory Specified
AGENCY APPROVALS & CERTIFICATIONS
Page 4
www.sensata.com
GENERAL NOTES
Full Scale Pressure = Pmax - Pmin
Best fit straight line accuracy includes errors from non-linearity, non-repeatability, and hysteresis
(3)
Total error band accuracy includes errors from non-linearity, non-repeatability, hysteresis, zero offset, full span offset, and thermal effects
(4)
PVC flying leads are rated for storage of -40° to +105°C
(5)
Mating connector only available with DIN A connector
(1)
(2)
WARNINGS
RISK OF MATERIAL DAMAGE AND HOT ENCLOSURE
• The product’s side panels may be hot, allow the product to cool before touching
• Follow proper mounting instructions including torque values
• Do not allow liquids or foreign objects to enter this product
Failure to follow these instructions can result in serious injury, or equipment damage.
HAZARD OF ELECTRIC SHOCK, EXPLOSION OR ARC FLASH
• Disconnect all power before installing or working with this equipment
• Verify all connections and replace all covers before turning on power
Failure to follow these instructions can result in death or serious injury.
Page 5
Sensata Technologies, Inc. (“Sensata”) data sheets are solely intended to assist designers (“Buyers”) who are developing systems that
incorporate Sensata products (also referred to herein as “components”). Buyer understands and agrees that Buyer remains responsible
for using its independent analysis, evaluation and judgment in designing Buyer’s systems and products. Sensata data sheets have
been created using standard laboratory conditions and engineering practices. Sensata has not conducted any testing other than that
specifically described in the published documentation for a particular data sheet. Sensata may make corrections, enhancements,
improvements and other changes to its data sheets or components without notice.
Buyers are authorized to use Sensata data sheets with the Sensata component(s) identified in each particular data sheet. HOWEVER, NO
OTHER LICENSE, EXPRESS OR IMPLIED, BY ESTOPPEL OR OTHERWISE TO ANY OTHER SENSATA INTELLECTUAL PROPERTY RIGHT, AND
NO LICENSE TO ANY THIRD PARTY TECHNOLOGY OR INTELLECTUAL PROPERTY RIGHT, IS GRANTED HEREIN. SENSATA DATA SHEETS
ARE PROVIDED “AS IS”. SENSATA MAKES NO WARRANTIES OR REPRESENTATIONS WITH REGARD TO THE DATA SHEETS OR USE
OF THE DATA SHEETS, EXPRESS, IMPLIED OR STATUTORY, INCLUDING ACCURACY OR COMPLETENESS. SENSATA DISCLAIMS
ANY WARRANTY OF TITLE AND ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, QUIET
ENJOYMENT, QUIET POSSESSION, AND NON-INFRINGEMENT OF ANY THIRD PARTY INTELLECTUAL PROPERTY RIGHTS WITH REGARD
TO SENSATA DATA SHEETS OR USE THEREOF.
All products are sold subject to Sensata’s terms and conditions of sale supplied at www.sensata.com SENSATA ASSUMES NO LIABILITY
FOR APPLICATIONS ASSISTANCE OR THE DESIGN OF BUYERS’ PRODUCTS. BUYER ACKNOWLEDGES AND AGREES THAT IT IS SOLELY
RESPONSIBLE FOR COMPLIANCE WITH ALL LEGAL, REGULATORY AND SAFETY-RELATED REQUIREMENTS CONCERNING ITS PRODUCTS,
AND ANY USE OF SENSATA COMPONENTS IN ITS APPLICATIONS, NOTWITHSTANDING ANY APPLICATIONS-RELATED INFORMATION
OR SUPPORT THAT MAY BE PROVIDED BY SENSATA.
Mailing Address: Sensata Technologies, Inc., 529 Pleasant Street, Attleboro, MA 02703, USA.
Rev:04/29/21
CONTACT US
Americas
+1 (800) 350 2727
sensors@sensata.com
switches@sensata.com
Europe, Middle East & Africa
+359 (2) 809 1826
pressure-info.eu@sensata.com
Asia Pacific
sales.isasia@list.sensata.com
China +86 (21) 2306 1500
Japan +81 (45) 277 7117
Korea +82 (31) 601 2004
India +91 (80) 67920890
Rest of Asia +886 (2) 27602006
ext 2808
www.sensata.com
