PTE7100-33DC-0E200BN
    SENSATA(森萨塔)
    Cylinder,Threaded
    INDUSTRIAL HERMETIC PRESSURE SEN
PTE7100-33DC-0E200BN 数据手册
| PTE7100 SERIES HERMETIC ANALOG PRESSURE SENSOR The PTE7100 pressure sensor is the ideal solution for customers with challenging measuring requirements for general industrial applications in the mid and high pressure ranges. Utilizing Sensata’s automotive leading Micro Silicon Strain Gauge with best-in-class accuracy, the PTE7100 features a wide range of ports, connectors, and analog electrical outputs for ease of integration in various industrial applications. The PTE7100’s high quality stainless steel design features a hermetic port with no internal o-ring seals making it compatible with most media and suitable for harsh environments. With extreme shock and vibration capabilities, a wide operating temperature range, and high proof and burst pressures; the PTE7100 is ideal for industrial applications including injection molding, CO2 HVAC systems, and other hydraulic or pneumatic applications. Features • Measuring range from 0-50 bar to 0-600 bar (0-725 to 0-8700 psi) • High accuracy • Wide range of ports, connectors, and electrical outputs • Stainless steel design with hermetic port • Storage and operating media temperature -40-125°C; Operating ambient temp. range -40-100°C • Snubber option for dampening of pressure spikes due to hammer and cavitation • REACH/RoHS/CE compliant Applications • Hydraulics and Pneumatics • Mobile Hydraulics and Off-Highway Vehicles • Pumps and Compressors • Air Conditioning and Refrigeration Systems • Plant Engineering and Automation SPECIFICATIONS Electrical Pressure Ranges Pressure Reference Supply Voltage/Output Output Load 0-50 to 0-600 bar (0-725 to 0-8700 psi) Gauge 8-32VDC for 4-20mA output 5±0.25VDC for 0.5-4.5VDC output 8-32VDC for 0-5VDC output 12-32VDC for 0-10VDC output 8-32VDC for 1-5VDC output 8-32VDC for 0.5-4.5VDC output ≥ 4.7 kΩ for voltage output ≤ (Vsup-8)/20mA for current supply Output Response Time Overvoltage Protection Reverse Voltage Protection Short Circuit Protection Insulation Resistance EMC Dielectric Strength Enhanced Radiated Immunity 100 MΩ at 500V IEC 61326-1 and EN 61326-2-3 500 VAC 100V/m (80~200MHz) 200V/m (200~2700MHz) Page 1 Copyright © 2021 Sensata Technologies, Inc. www.sensata.com Physical Proof Pressure Burst Pressure 2X full scale pressure(1) Random Vibration Mechanical Shock Drop (any Axis) Ingress Protection Media Compatibility IEC 60068-2-6, 30g (10…2000Hz) 20X for full scale pressure = 50-100 bar 10X for full scale pressure = 101-400 bar 4000 bar for full scale pressure = 401-600 bar EN 60068-2-27, 500g 1m IP65 - IP67 (see Connector Options) Fluids and Gases compatible with 17-4PH stainless steel Performance Accuracy (Best Fit Straight Line)(2) Accuracy (Total Error Band)(3) Operating Endurance Operating Ambient Temperature Operating Media Temperature Storage Temperature ±0.25%FS @25°C +/-1.5%FS @-20° to 85°C >10M cycles -40° to +100°C -40° to +125°C -40° to +125°C (4) DIMENSIONS All dimensions are in millimeters Pressure Port OVERALL DIMENSIONS G1/4A DIN 3852-E 7/16-20 UNF-2A (MALE) 1/4-19 PT (R1/4) 13 11.2 18.9 15.6 1/4-18 NPTF 5 21 9.25 14 13 2 2 23 13 HEX24 Page 2 Copyright © 2021 Sensata Technologies, Inc. www.sensata.com Electrical Connector M12x1 4-POLE PIN 1 PIN 4 PIN 2 PIN 3 IP67 28 16 PIN 1 PIN B PIN A DEUTSCH DT04-3P A: DIN 175301-803 FORM A(18mm) IP65 IP67 24 IP67 24 PACKARD METRI-PACK 150 PIN A PIN 4 PIN 3 PIN C PIN C PIN B PIN 2 Output Type PIN A PIN B PIN C Output Type PIN 1 PIN 2 PIN 3 PIN 4 Output Type PIN 1 PIN 2 PIN 3 PIN 4 Output Type PIN A PIN B PIN C Voltage V- V+ Vout Voltage V+ ... V- Vout Voltage V+ V- Vout ... Voltage V+ V- Vout Current Iout V+ ... Current V+ ... Iout ... Current V+ Iout ... ... Current V+ Iout ... FLY LEAD WITH HARNESS IP67 27 AWG18 WIRE, WITH PVC SHELL TEMPERATURE RANGE -40~105 C Output Type RED BLACK WHITE Voltage V+ V- Vout Current V+ Iout ... Page 3 Copyright © 2021 Sensata Technologies, Inc. www.sensata.com Example : PTE7100-31AA-1A250BS ORDERING OPTIONS PTE7100 with G1/4A thread with external FKM o-ring seal, DIN A connector, 4-20 PTE7100 - XX* A A - 1 A 250B S Family PTE7100 Pressure Port A: G1/4A DIN 3852-E B: 1/4-19PT (R1/4) C: 7/16-20 UNF-2A (MALE) D: 1/4-18NPT Electrical Connector A: DIN 175301-803 Form A(18mm) B: M12 4-POLE C: Packard Metri-Pack 150 D: Fly-Lead 3 pole harness E: DEUTSCH DT04-3P External Sealing 0: No o-ring 1: FKM (Viton) o-ring (only for G1/4 pressure port) 2: HNBR o-ring (only for 7/16-20 UNF-2A MALE pressure port) Electrical Output/Input A: 4-20ma / 8-32Vdc B: 0.5-4.5Vdc / 5±0.25Vdc C: 0-5Vdc / 8-32Vdc D: 0-10Vdc / 12-32Vdc E: 1-5Vdc/8-32Vdc F: 0.5-4.5Vdc / 8-32VDC Pressure Range 050B: 0-50bar 060B: 0-60bar 100B: 0-100bar 160B: 0-160bar 200B: 0-200bar 250B: 0-250bar 350B: 0-350bar 400B: 0-400bar 500B: 0-500bar 600B: 0-600bar Mating Connector & Snubber (5) N: No snubber and no mating connector S: No mating connector, snubber with 0.5 damping hole M: No snubber, with mating connector A: Mating connector and snubber with 0.5 damping hole *Factory Specified AGENCY APPROVALS & CERTIFICATIONS Page 4 Copyright © 2021 Sensata Technologies, Inc. www.sensata.com GENERAL NOTES Full Scale Pressure = Pmax - Pmin Best fit straight line accuracy includes errors from non-linearity, non-repeatability, and hysteresis (3) Total error band accuracy includes errors from non-linearity, non-repeatability, hysteresis, zero offset, full span offset, and thermal effects (4) PVC flying leads are rated for storage of -40° to +105°C (5) Mating connector only available with DIN A connector (1) (2) WARNINGS RISK OF MATERIAL DAMAGE AND HOT ENCLOSURE • The product’s side panels may be hot, allow the product to cool before touching • Follow proper mounting instructions including torque values • Do not allow liquids or foreign objects to enter this product Failure to follow these instructions can result in serious injury, or equipment damage. HAZARD OF ELECTRIC SHOCK, EXPLOSION OR ARC FLASH • Disconnect all power before installing or working with this equipment • Verify all connections and replace all covers before turning on power Failure to follow these instructions can result in death or serious injury. Page 5 Sensata Technologies, Inc. (“Sensata”) data sheets are solely intended to assist designers (“Buyers”) who are developing systems that incorporate Sensata products (also referred to herein as “components”). Buyer understands and agrees that Buyer remains responsible for using its independent analysis, evaluation and judgment in designing Buyer’s systems and products. Sensata data sheets have been created using standard laboratory conditions and engineering practices. Sensata has not conducted any testing other than that specifically described in the published documentation for a particular data sheet. Sensata may make corrections, enhancements, improvements and other changes to its data sheets or components without notice. Buyers are authorized to use Sensata data sheets with the Sensata component(s) identified in each particular data sheet. HOWEVER, NO OTHER LICENSE, EXPRESS OR IMPLIED, BY ESTOPPEL OR OTHERWISE TO ANY OTHER SENSATA INTELLECTUAL PROPERTY RIGHT, AND NO LICENSE TO ANY THIRD PARTY TECHNOLOGY OR INTELLECTUAL PROPERTY RIGHT, IS GRANTED HEREIN. SENSATA DATA SHEETS ARE PROVIDED “AS IS”. SENSATA MAKES NO WARRANTIES OR REPRESENTATIONS WITH REGARD TO THE DATA SHEETS OR USE OF THE DATA SHEETS, EXPRESS, IMPLIED OR STATUTORY, INCLUDING ACCURACY OR COMPLETENESS. SENSATA DISCLAIMS ANY WARRANTY OF TITLE AND ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, QUIET ENJOYMENT, QUIET POSSESSION, AND NON-INFRINGEMENT OF ANY THIRD PARTY INTELLECTUAL PROPERTY RIGHTS WITH REGARD TO SENSATA DATA SHEETS OR USE THEREOF. All products are sold subject to Sensata’s terms and conditions of sale supplied at www.sensata.com SENSATA ASSUMES NO LIABILITY FOR APPLICATIONS ASSISTANCE OR THE DESIGN OF BUYERS’ PRODUCTS. BUYER ACKNOWLEDGES AND AGREES THAT IT IS SOLELY RESPONSIBLE FOR COMPLIANCE WITH ALL LEGAL, REGULATORY AND SAFETY-RELATED REQUIREMENTS CONCERNING ITS PRODUCTS, AND ANY USE OF SENSATA COMPONENTS IN ITS APPLICATIONS, NOTWITHSTANDING ANY APPLICATIONS-RELATED INFORMATION OR SUPPORT THAT MAY BE PROVIDED BY SENSATA. Mailing Address: Sensata Technologies, Inc., 529 Pleasant Street, Attleboro, MA 02703, USA. Copyright © 2021 Sensata Technologies, Inc. Rev:04/29/21 CONTACT US Americas +1 (800) 350 2727 sensors@sensata.com switches@sensata.com Europe, Middle East & Africa +359 (2) 809 1826 pressure-info.eu@sensata.com Asia Pacific sales.isasia@list.sensata.com China +86 (21) 2306 1500 Japan +81 (45) 277 7117 Korea +82 (31) 601 2004 India +91 (80) 67920890 Rest of Asia +886 (2) 27602006 ext 2808 www.sensata.com
PTE7100-33DC-0E200BN 价格&库存
很抱歉,暂时无法提供与“PTE7100-33DC-0E200BN”相匹配的价格&库存,您可以联系我们找货
