X28C010FI-15
X28C010FI-15
    ROCHESTER(罗切斯特)
    CFlatpack-32
    EEPROM, 128KX8, 150NS, PARALLEL,
X28C010FI-15 数据手册
X28C010, X28HT010 ESIGNS R N E W D NT O F D E D N EM E COMME RE PL AC D E N OT R E r at D N OMME ort Cente sc uppSheet S l NO R E C a /t ic Data m n o h tersil.c our Tec contact ERSIL or www.in T 1-888-IN February 12, 2007 5V, Byte Alterable EEPROM Features The Intersil X28C010/X28HT010 is a 128K x 8 EEPROM, fabricated with Intersil's proprietary, high performance, floating gate CMOS technology. Like all Intersil programmable non-volatile memories, the X28C010/X28HT010 is a 5V only device. The X28C010/X28HT010 features the JEDEC approved pin out for byte-wide memories, compatible with industry standard EEPROMs. • Access time: 120ns FN8105.1 • Simple byte and page write - Single 5V supply - No external high voltages or VPP control circuits - Self-timed • No erase before write • No complex programming algorithms • No overerase problem The X28C010/X28HT010 supports a 256-byte page write operation, effectively providing a 19µs/byte write cycle and enabling the entire memory to be typically written in less than 2.5 seconds. The X28C010/X28HT010 also features DATA Polling and Toggle Bit Polling, system software support schemes used to indicate the early completion of a write cycle. In addition, the X28C010/X28HT010 supports Software Data Protection option. • Low power CMOS - Active: 50mA - Standby: 500µA • Software data protection - Protects data against system level inadvertent writes • High speed page write capability • Highly reliable Direct Write™ cell - Endurance: 100,000 write cycles - Data retention: 100 years Intersil EEPROMs are designed and tested for applications requiring extended endurance. Data retention is specified to be greater than 100 years. • Early end of write detection - DATA polling - Toggle bit polling • X28HT010 is fuly functional @ +175°C Pinouts 32 1 31 VCC WE A1 13 A0 14 CE I/O1 VSS I/O4 I/O7 16 18 20 23 24 A3 11 OE A10 26 25 A5 2 3 30 NC A2 12 A12 A7 4 29 5 28 A14 A13 A4 10 A6 A5 6 27 7 26 A4 A3 8 A2 A1 10 23 11 22 A0 I/O0 12 21 13 20 I/O1 I/O2 14 19 15 18 I/O5 I/O4 VSS 16 17 I/O3 9 25 24 A8 A9 8 A11 OE 6 A6 A12 9 7 5 4 A10 CE X28C010 (Bottom View) A7 A15 A 16 NC 2 NC 3 VCC NC 36 34 NC 1 WE 35 A11 27 A9 28 A8 29 A 13 30 NC 32 A 14 31 NC 33 4 3 2 A7 A6 A5 A4 A3 A2 A1 A0 I/O 0 WE NC A12 A15 A16 NC VCC I/O0 I/O2 I/O 3 I/O5 I/O6 15 17 19 21 22 A16 A15 X28C010 EXTENDED LCC 32 31 30 1 5 6 7 8 9 10 11 12 13 X28C010 (Top View) 29 28 27 26 25 24 23 22 21 A14 A13 A8 A9 A11 OE A10 CE I/O7 14 15 16 17 18 19 20 I/O4 I/O5 I/O6 NC PGA I/O1 I/O2 VSS I/O3 CERDIP Flat Pack SOIC (R) I/O7 I/O6 1 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. 1-888-INTERSIL or 1-888-468-3774 | Intersil (and design) is a registered trademark of Intersil Americas Inc. Copyright Intersil Americas Inc. 2005, 2007. All Rights Reserved All other trademarks mentioned are the property of their respective owners. X28C010, X28HT010 Ordering Information PART NUMBER PART MARKING ACCESS TIME TEMP RANGE (°C) PACKAGE PKG. DWG # X28C010D-12 X28C010D-12 120ns 0 to +70 32-Ld Cerdip F32.6 X28C010D-15 X28C010D-15 150ns 0 to +70 32-Ld Cerdip F32.6 X28C010DI X28C010DI - -40 to +85 32-Ld Cerdip F32.6 X28C010DI-12 X28C010DI-12 120ns -40 to +85 32-Ld Cerdip F32.6 X28C010DI-15 X28C010DI-15 150ns -40 to +85 32-Ld Cerdip F32.6 X28C010DM X28C010DM - -55 to +125 32-Ld Cerdip F32.6 X28C010DM-12 X28C010DM-12 120ns -55 to +125 32-Ld Cerdip F32.6 X28C010DM-15 X28C010DM-15 150ns -55 to +125 32-Ld Cerdip F32.6 X28C010DMB-12 C X28C010DMB-12 120ns MIL-STD-883 32-Ld Cerdip F32.6 X28C010DMB-15 C X28C010DMB-15 150ns MIL-STD-883 32-Ld Cerdip F32.6 X28C010DMB-20 C X28C010DMB-20 200ns MIL-STD-883 32-Ld Cerdip X28C010FI-12 X28C010FI-12 120ns -40 to +85 32-Ld Flat Pack X28C010FI-15 X28C010FI-15 150ns -40 to +85 32-Ld Flat Pack X28C010FI-20 X28C010FI-20 200ns -40 to +85 32-Ld Flat Pack X28C010FM X28C010FM - -55 to +125 32-Ld Flat Pack X28C010FM-12 X28C010FM-12 120ns -55 to +125 32-Ld Flat Pack X28C010FMB-12 C X28C010FMB-12 120ns MIL-STD-883 32-Ld Flat Pack X28C010FMB-15 C X28C010FMB-15 150ns MIL-STD-883 32-Ld Flat Pack X28C010K-25 X28C010K-25 250ns 0 to +70 36-Ld Pin Grid Array G36.760x760A X28C010KM-12 X28C010KM-12 120ns -55 to +125 36-Ld Pin Grid Array G36.760x760A X28C010KM-25 X28C010KM-25 250ns -55 to +125 36-Ld Pin Grid Array G36.760x760A X28C010KMB-12 C X28C010KMB-12 120ns MIL-STD-883 36-Ld Pin Grid Array G36.760x760A X28C010KMB-15 C X28C010KMB-15 150ns MIL-STD-883 36-Ld Pin Grid Array G36.760x760A X28C010NM-12 X28C010NM-12 120ns -55 to +125 32-Ld Extended LCC X28C010NM-15 X28C010NM-15 150ns -55 to +125 32-Ld Extended LCC X28C010NMB-12 C X28C010NMB-12 120ns MIL-STD-883 32-Ld Extended LCC X28C010NMB-15 C X28C010NMB-15 150ns MIL-STD-883 32-Ld Extended LCC X28C010RI-12 X28C010RI-12 120ns -40 to +85 32-Ld Ceramic SOIC (Gull Wing) X28C010RI-20 X28C010RI-20 200ns -40 to +85 32-Ld Ceramic SOIC (Gull Wing) X28C010RI-20T1 X28C010RI-20 200ns -40 to +85 32-Ld Ceramic SOIC (Gull Wing) X28C010RM-15 X28C010RM-15 150ns -55 to +125 32-Ld Ceramic SOIC (Gull Wing) X28C010RMB-25 C X28C010RMB-25 250ns MIL-STD-883 32-Ld Ceramic SOIC (Gull Wing) 200ns -40 to +175 X28HT010W 2 Wafer FN8105.1 February 12, 2007 X28C010, X28HT010 Block Diagram A8-A16 X Buffers Latches and Decoder EEPROM Array A0-A7 Y Buffers Latches and Decoder I/O Buffers and Latches CE OE WE 1Mbit Control Logic and Timing I/O0-I/O7 Data Inputs/Outputs VCC VSS Pin Descriptions Pin Names Addresses (A0-A16) The Address inputs select an 8-bit memory location during a read or write operation. SYMBOL DESCRIPTION A0-A16 Address Inputs Chip Enable (CE) I/O0-I/O7 Data Input/Output WE Write Enable CE Chip Enable OE Output Enable VCC +5V VSS Ground NC No Connect VBB* -3V The Chip Enable input must be LOW to enable all read/write operations. When CE is HIGH, power consumption is reduced. Output Enable (OE) The Output Enable input controls the data output buffers, and is used to initiate read operations. Data In/Data Out (I/O0-I/O7) Data is written to or read from the X28C010/X28HT010 through the I/O pins. *VBB applies to X28HT010 only. Write Enable (WE) Device Operation The Write Enable input controls the writing of data to the X28C010/X28HT010. Read Back Bias Voltage (VBB) (X28HT010 only) It is required to provide -3V on pin 1. This negative voltage improves higher temperature functionality. Read operations are initiated by both OE and CE LOW. The read operation is terminated by either CE or OE returning HIGH. This two line control architecture eliminates bus contention in a system environment. The data bus will be in a high impedance state when either OE or CE is HIGH. Write Write operations are initiated when both CE and WE are LOW and OE is HIGH. The X28C010/X28HT010 supports both a CE and WE controlled write cycle. That is, the address is latched by the falling edge of either CE or WE, whichever occurs last. Similarly, the data is latched internally by the rising edge of either CE or WE, whichever occurs first. A byte write operation, once initiated, will automatically continue to completion, typically within 5ms. 3 FN8105.1 February 12, 2007 X28C010, X28HT010 Page Write Operation The page write feature of the X28C010/X28HT010 allows the entire memory to be written in 5 seconds. Page write allows two to two hundred fifty-six bytes of data to be consecutively written to the X28C010/X28HT010 prior to the commencement of the internal programming cycle. The host can fetch data from another device within the system during a page write operation (change the source address), but the page address (A8 through A16) for each subsequent valid write cycle to the part during this operation must be the same as the initial page address. DATA Polling (I/O7) The page write mode can be initiated during any write operation. Following the initial byte write cycle, the host can write an additional one to two hundred fifty six bytes in the same manner as the first byte was written. Each successive byte load cycle, started by the WE HIGH to LOW transition, must begin within 100µs of the falling edge of the preceding WE. If a subsequent WE HIGH to LOW transition is not detected within 100µs, the internal automatic programming cycle will commence. There is no page write window limitation. Effectively the page write window is infinitely wide, so long as the host continues to access the device within the byte load cycle time of 100µs. The X28C010/X28HT010 features DATA Polling as a method to indicate to the host system that the byte write or page write cycle has completed. DATA Polling allows a simple bit test operation to determine the status of the X28C010/X28HT010, eliminating additional interrupt inputs or external hardware. During the internal programming cycle, any attempt to read the last byte written will produce the complement of that data on I/O7 (i.e., write data = 0xxx xxxx, read data = 1xxx xxxx). Once the programming cycle is complete, I/O7 will reflect true data. Note: If the X28C010/X28HT010 is in the protected state, and an illegal write operation is attempted, DATA Polling will not operate. Write Operation Status Bits Toggle Bit (I/O6) The X28C010/X28HT010 provides the user two write operation status bits. These can be used to optimize a system write cycle time. The status bits are mapped onto the I/O bus as shown in Figure 1. The X28C010/X28HT010 also provides another method for determining when the internal write cycle is complete. During the internal programming cycle, I/O6 will toggle from HIGH to LOW and LOW to HIGH on subsequent attempts to read the device. When the internal cycle is complete the toggling will cease and the device will be accessible for additional read or write operations. I/O DP TB 5 4 3 2 1 0 Reserved Toggle Bit DATA Polling FIGURE 1. STATUS BIT ASSIGNMENT DATA Polling I/O7 WE Last Write CE OE VIH VOH HIGH Z I/O7 VOL A0-A14 An An An X28C010 Ready An An An An FIGURE 2. DATA POLLING BUS SEQUENCE 4 FN8105.1 February 12, 2007 X28C010, X28HT010 DATA Polling can effectively halve the time for writing to the X28C010/X28HT010. The timing diagram in Figure 2 illustrates the sequence of events on the bus. The software flow diagram in Figure 3 illustrates one method of implementing the routine. Write Data No Writes Complete? Yes Save Last Data and Address Read Last Address IO7 Compare? No Yes X28C010 Ready FIGURE 3. DATA POLLING SOFTWARE FLOW The Toggle Bit I/O6 WE Last Write CE OE VOH I/O6 * HIGH Z VOL * X28C010 Ready * Beginning and ending state of I/O6 will vary FIGURE 4. TOGGLE BIT BUS SEQUENCE 5 FN8105.1 February 12, 2007 X28C010, X28HT010 Software Data Protection The X28C010/X28HT010 offers a software controlled data protection feature. The X28C010/X28HT010 is shipped from Intersil with the software data protection NOT ENABLED: that is the device will be in the standard operating mode. In this mode data should be protected during power-up/-down operations through the use of external circuits. The host would then have open read and write access of the device once VCC was stable. Last Write Load Accum From Addr N Compare Accum with Addr N No Compare Ok? The X28C010/X28HT010 can be automatically protected during power-up and power-down without the need for external circuits by employing the software data protection feature. The internal software data protection circuit is enabled after the first write operation utilizing the software algorithm. This circuit is nonvolatile and will remain set for the life of the device unless the reset command is issued. Once the software protection is enabled, the X28C010/X28HT010 is also protected from inadvertent and accidental writes in the powered-up state. That is, the software algorithm must be issued prior to writing additional data to the device. Yes Ready FIGURE 5. TOGGLE BIT SOFTWARE FLOW The Toggle Bit can eliminate the software housekeeping chore of saving and fetching the last address and data written to a device in order to implement DATA Polling. This can be especially helpful in an array comprised of multiple X28C010/X28HT010 memories that is frequently updated. Toggle Bit Polling can also provide a method for status checking in multiprocessor applications. The timing diagram in Figure 4 illustrates the sequence of events on the bus. The software flow diagram in Figure 5 illustrates a method for polling the Toggle Bit. Software Algorithm Selecting the software data protection mode requires the host system to precede data write operations by a series of three write operations to three specific addresses. Refer to Figures 6 and 7 for the sequence. The three byte sequence opens the page write window enabling the host to write from one to two hundred fifty-six bytes of data. Once the page load cycle has been completed, the device will automatically be returned to the data protected state. Hardware Data Protection The X28C010/X28HT010 provides three hardware features that protect nonvolatile data from inadvertent writes. • Noise Protection—A WE pulse less than 10ns will not initiate a write cycle. • Default VCC Sense—All functions are inhibited when VCC is 3.5V. • Write inhibit—Holding either OE LOW, WE HIGH, or CE HIGH will prevent an inadvertent write cycle during powerup and power-down, maintaining data integrity. 6 FN8105.1 February 12, 2007 X28C010, X28HT010 Software Data Protection VCC (VCC) 0V Data Addr AA 5555 55 2AAA A0 5555 Writes Ok CE  tBLC MAX WE tWC Write Protected Byte or Page FIGURE 6. TIMING SEQUENCE—BYTE OR PAGE WRITE Regardless of whether the device has previously been protected or not, once the software data protection algorithm is used and data has been written, the X28C010/X28HT010 will automatically disable further writes unless another command is issued to cancel it. If no further commands are issued the X28C010/X28HT010 will be write protected during power-down and after any subsequent power-up. The state of A15 and A16 while executing the algorithm is don’t care. Write Data AA to Address 5555 Write Data 55 to Address 2AAA Note: Once initiated, the sequence of write operations should not be interrupted. Write Data A0 to Address 5555 Write Data XX to Any Address Optional Byte/Page Load Operation Write Last Byte Last Address After tWC Re-Enters Data Protected State FIGURE 7. WRITE SEQUENCE FOR SOFTWARE DATA PROTECTION 7 FN8105.1 February 12, 2007 X28C010, X28HT010 Resetting Software Data Protection VCC Data Addr AA 5555 55 2AAA 80 5555 AA 5555 55 2AAA 20 5555  tWC Standard Operating Mode CE WE FIGURE 8. RESET SOFTWARE DATA PROTECTION TIMING SEQUENCE System Considerations Write Data AA to Address 5555 Write Data 55 to Address 2AAA Write Data 80 to Address 5555 Write Data AA to Address 5555 Write Data 55 to Address 2AAA Write Data 20 to Address 5555 FIGURE 9. SOFTWARE SEQUENCE TO DEACTIVATE SOFTWARE DATA PROTECTION In the event the user wants to deactivate the software data protection feature for testing or reprogramming in an EEPROM programmer, the following six step algorithm will reset the internal protection circuit. After tWC, the X28C010/X28HT010 will be in standard operating mode. Because the X28C010/X28HT010 is frequently used in large memory arrays, it is provided with a two line control architecture for both read and write operations. Proper usage can provide the lowest possible power dissipation and eliminate the possibility of contention where multiple I/O pins share the same bus. To gain the most benefit, it is recommended that CE be decoded from the address bus and be used as the primary device selection input. Both OE and WE would then be common among all devices in the array. For a read operation this assures that all deselected devices are in their standby mode and that only the selected device(s) is outputting data on the bus. Because the X28C010/X28HT010 has two power modes, standby and active, proper decoupling of the memory array is of prime concern. Enabling CE will cause transient current spikes. The magnitude of these spikes is dependent on the output capacitive loading of the I/Os. Therefore, the larger the array sharing a common bus, the larger the transient spikes. The voltage peaks associated with the current transients can be suppressed by the proper selection and placement of decoupling capacitors. As a minimum, it is recommended that a 0.1µF high frequency ceramic capacitor be used between VCC and VSS at each device. Depending on the size of the array, the value of the capacitor may have to be larger. In addition, it is recommended that a 4.7µF electrolytic bulk capacitor be placed between VCC and VSS for each eight devices employed in the array. This bulk capacitor is employed to overcome the voltage droop caused by the inductive effects of the PC board traces. Note: Once initiated, the sequence of write operations should not be interrupted. 8 FN8105.1 February 12, 2007 X28C010, X28HT010 Active Supply Current vs. Ambient Temperature 18 VCC = 5V ICC WR (mA) 16 14 12 10 -55 +35 -10 +80 +125 Ambient Temperature (°C) Standby Supply Current vs. Ambient Temperature 0.3 VCC = 5V ISB (mA) 0.25 0.2 0.15 0.1 0.05 -55 +35 -10 +80 +125 Ambient Temperature (°C) ICC (RD) by Temperature Over Frequency 60 5.0 VCC ICC RD (mA) 50 -55°C +25°C 40 +125°C 30 20 10 0 3 6 9 12 15 Frequency (MHz) 9 FN8105.1 February 12, 2007 X28C010, X28HT010 Absolute Maximum Ratings Recommended Operating Conditions Temperature under bias X28C010 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .-10°C to +85°C X28C010I . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .-65°C to +135°C X28C010M . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .-65°C to +135°C X28HT010 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .-55°C to +175°C Storage temperature . . . . . . . . . . . . . . . . . . . . . . . .-65°C to +150°C Voltage on any pin with respect to VSS . . . . . . . . . . . . . . -1V to +7V D.C. output current. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5mA Lead temperature (soldering, 10 seconds) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . +300°C Commercial . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0°C to +70°C Industrial . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .-40°C tp +85°C Military . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .-55°C to +125°C Supply Voltage. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .5V ±10% High Temperature . . . . . . . . . . . . . . . . . . . . . . . . . .-40°C to +175°C CAUTION: Stresses above those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions (above those indicated in the operational sections of this specification) is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. DC Electrical Specifications SYMBOL Over the recommended operating conditions, unless otherwise specified. PARAMETER TEST CONDITIONS MIN MAX UNIT ICC VCC Current (Active) (TTL Inputs) CE = OE = VIL, WE = VIH, All I/O’s = Open, Address Inputs = 0.4V/2.4V Levels @ f = 5MHz 50 mA ISB1 VCC Current (Standby) (TTL Inputs) CE = VIH, OE = VIL, All I/O’s = Open, Other Inputs = VIH 3 mA ISB2 VCC Current (Standby) (CMOS Inputs) CE = VCC - 0.3V, OE = VIL, All I/O’s = Open, Other Inputs = VCC 500 µA Input Leakage Current VIN = VSS to VCC 10 µA VIN = VSS to VCC (Note 2) 20 µA ILI ILO Output Leakage Current VOUT = VSS to VCC, CE = VIH 10 µA VOUT = VSS to VCC, CE = VIH (Note 2) 20 µA -1 0.8 V (Note 2) -1 0.6 V 2 VCC + 1 V (Note 2) 2.2 VCC + 1 V IOL = 2.1mA 0.4 V IOL = 1mA (Note 2) 0.5 V VlL (Note 1) Input LOW Voltage VIH (Note 1) Input HIGH Voltage VOL VOH IBB Output LOW Voltage Output HIGH Voltage Back Bias Current IOH = -400µA 2.4 V IOH = -400µA 2.6 V VBB = -3V ±10% (Note 2) 200 µA NOTE: 1. VIL min. and VIH max. are for reference only and are not tested. 2. X28HT010W Power-Up Timing SYMBOL PARAMETER MAX UNIT tPUR (Note 3) Power-up to Read operation 100 µs tPUW (Note 3) Power-up to Write operation 5 ms Capacitance TA = +25°C, f = 1MHz, VCC = 5V SYMBOL PARAMETER TEST CONDITIONS MAX UNIT CI/O (Note 3) Input/Output capacitance VI/O = 0V 10 pF CIN (Note 3) Input capacitance VIN = 0V 10 pF NOTE: 3. This parameter is periodically sampled and not 100% tested. 10 FN8105.1 February 12, 2007 X28C010, X28HT010 Endurance and Data Retention PARAMETER MIN MAX UNIT Endurance 10,000 Cycles per byte Endurance 100,000 Cycles per page 100 Years Data Retention Symbol Table A.C. Conditions of Test Input pulse levels 0V to 3V Input rise and fall times 10ns Input and output timing levels 1.5V WAVEFORM Mode Selection CE OE WE MODE I/O POWER L L H Read DOUT Active L H L Write DIN Active H X X Standby and Write Inhibit High Z Standby X L X Write Inhibit — — X X H Write Inhibit — — INPUTS OUTPUTS Must be steady Will be steady May change from LOW to HIGH Will change from LOW to HIGH May change from HIGH to LOW Will change from HIGH to LOW Don’t Care: Changes Allowed Changing: State Not Known N/A Center Line is High Impedance Equivalent A.C. Load Circuit 5V 1.92k Output 1.37k 100pF AC Electrical Specifications Over the recommended operating conditions, unless otherwise specified. X28C010-12 SYMBOL PARAMETER MIN MAX X28C010-15 MIN MAX X28C010-20, X28HT010W MIN MAX X28C010-25 MIN MAX UNIT READ CYCLE LIMITS tRC Read cycle time 120 150 200 250 ns tCE Chip enable access time 120 150 200 250 ns tAA Address access time 120 150 200 250 ns tOE Output enable access time 50 50 50 50 ns tLZ (Note 4) CE LOW to active output 0 0 0 0 ns tOLZ (Note 4) OE LOW to active output 0 0 0 0 ns tHZ (Note 4) CE HIGH to high Z output 50 50 50 50 ns tOHZ (Note 4) OE HIGH to high Z output 50 50 50 50 ns tOH Output hold from address change 11 0 0 0 0 ns FN8105.1 February 12, 2007 X28C010, X28HT010 Read Cycle tRC Address tCE CE tOE OE VIH WE tOLZ tOHZ tLZ Data I/O HIGH Z tOH tHZ Data Valid Data Valid tAA NOTE: 4. tLZ min.,tHZ, tOLZ min., and tOHZ are periodically sampled and not 100% tested. tHZ max. and tOHZ max. are measured, with CL = 5pF, from the point when CE or OE return HIGH (whichever occurs first) to the time when the outputs are no longer driven. Write Cycle Limits SYMBOL tWC (Note 5) PARAMETER MIN Write cycle time MAX UNIT 10 ms tAS Address setup time 0 ns tAH Address hold time 50 ns tCS Write setup time 0 ns tCH Write hold time 0 ns tCW CE pulse width 100 ns tOES OE HIGH setup time 10 ns tOEH OE HIGH hold time 10 ns tWP WE pulse width 100 ns WE HIGH recovery 100 ns tWPH tDV Data valid tDS Data setup 50 ns tDH Data hold 0 ns tDW Delay to next write 10 µs tBLC Byte load cycle 0.2 1 12 100 µs µs FN8105.1 February 12, 2007 X28C010, X28HT010 WE Controlled Write Cycle tWC Address tAS tAH tCS tCH CE OE tOES tOEH tWP WE tWPH tDV Data In Data Valid tDH tDS Data Out HIGH Z NOTE: 5. tWC is the minimum cycle time to be allowed from the system perspective unless polling techniques are used. It is the maximum time the device requires to complete internal write operation. CE Controlled Write Cycle tWC Address tAS tAH tCW CE tWPH tOES OE tOEH tCS tCH WE tDV Data Valid Data In tDS tDH HIGH Z Data Out 13 FN8105.1 February 12, 2007 X28C010, X28HT010 Page Write Cycle OE (Note 5) CE tBLC tWP WE tWPH Address* (Note 7) Last Byte I/O Byte 0 Byte 1 Byte 2 Byte n Byte n+1 Byte n+2 tWC *For each successive write within the page write operation, A8-A16 should be the same or writes to an unknown address could occur. NOTES: 6. Between successive byte writes within a page write operation, OE can be strobed LOW: e.g. this can be done with CE and WE HIGH to fetch data from another memory device within the system for the next write; or with WE HIGH and CE LOW effectively performing a polling operation. 7. The timings shown above are unique to page write operations. Individual byte load operations within the page write must conform to either the CE or WE controlled write cycle timing. DATA Polling Timing Diagram (Note 8) Address An An An CE WE tOEH tOES OE tDW DIN = X I/O7 DOUT = X DOUT = X tWC 14 FN8105.1 February 12, 2007 X28C010, X28HT010 Toggle Bit Timing Diagram CE WE tOES tOEH OE tDW I/O6 HIGH Z * * tWC * I/O6 beginning and ending state will vary. NOTE: 8. Polling operations are by definition read cycles and are therefore subject to read cycle timings. 15 FN8105.1 February 12, 2007 X28C010, X28HT010 Ceramic Dual-In-Line Frit Seal Packages (CERDIP) F32.6 MIL-STD-1835 GDIP1-T32 (D-16, CONFIGURATION A) 32 LEAD CERAMIC DUAL-IN-LINE FRIT SEAL PACKAGE LEAD FINISH c1 -D- -A- BASE METAL (c) E M -Bbbb S C A-B S Q -C- SEATING PLANE S1 b2 b ccc M C A-B S eA/2 - 0.232 - 5.92 - 0.026 0.36 0.66 2 b1 0.014 0.023 0.36 0.58 3 b2 0.045 0.065 1.14 1.65 - b3 0.023 0.045 0.58 1.14 4 c 0.008 0.018 0.20 0.46 2 c1 0.008 0.015 0.20 0.38 3 D - 1.690 - 42.95 5 E 0.500 0.610 15.49 5 c aaa M C A - B S D S D S NOTES 0.014 eA e MAX b  A A MIN A A L MILLIMETERS MAX M (b) D BASE PLANE MIN b1 SECTION A-A D S INCHES SYMBOL NOTES: 1. Index area: A notch or a pin one identification mark shall be located adjacent to pin one and shall be located within the shaded area shown. The manufacturer’s identification shall not be used as a pin one identification mark. e 12.70 0.100 BSC 2.54 BSC - eA 0.600 BSC 15.24 BSC - eA/2 0.300 BSC 7.62 BSC - L 0.125 0.200 3.18 5.08 - Q 0.015 0.060 0.38 1.52 6 S1 0.005 - 0.13 - 7 105° 90° 105° - 2. The maximum limits of lead dimensions b and c or M shall be measured at the centroid of the finished lead surfaces, when solder dip or tin plate lead finish is applied.  90° aaa - 0.015 - 0.38 - 3. Dimensions b1 and c1 apply to lead base metal only. Dimension M applies to lead plating and finish thickness. bbb - 0.030 - 0.76 - ccc - 0.010 - 0.25 - M - 0.0015 - 0.038 2, 3 4. Corner leads (1, N, N/2, and N/2+1) may be configured with a partial lead paddle. For this configuration dimension b3 replaces dimension b2. 5. This dimension allows for off-center lid, meniscus, and glass overrun. N 32 32 8 Rev. 0 8/06 6. Dimension Q shall be measured from the seating plane to the base plane. 7. Measure dimension S1 at all four corners. 8. N is the maximum number of terminal positions. 9. Dimensioning and tolerancing per ANSI Y14.5M - 1982. 10. Controlling dimension: INCH. 16 FN8105.1 February 12, 2007 X28C010, X28HT010 Packaging Information 32-Lead Ceramic Flat Pack Type F 1.228 (31.19) 1.000 (25.40) Pin 1 Index 1 0.019 (0.48) 0.015 (0.38) 32 0.050 (1.27) BSC 0.830 (21.08) Max. 0.045 (1.14) Max. 0.005 (0.13) Min. 0.440 0.430 (10.93) 0.007 (0.18) 0.004 (0.10) 0.120 (3.05) 0.090 (2.29) 0.370 (9.40) 0.270 (6.86) 0.347 (8.82) 0.330 (8.38) 0.026 (0.66) Min. 0.030 (0.76) Min. NOTE: ALL DIMENSIONS IN INCHES (IN PARENTHESES IN MILLIMETERS) 17 FN8105.1 February 12, 2007 X28C010, X28HT010 Packaging Information 32-Pad Stretched Ceramic Leadless Chip Carrier Package Type N 0.300 BSC 0.035 x 45° Ref. Detail A 0.085 ± 0.010 Pin 1 Detail A 0.005/0.015 0.025 ± 0.003 0.006/0.022 0.400 BSC 0.050 ± 0.005 0.050 BSC 0.020 (1.02) x 45° Ref. Typ. (3) Plcs. 0.450 ± 0.008 0.060/0.120 0.458 Max. 0.700 ± 0.010 0.708 Max. Pin #1 Index Corner NOTES: 1. ALL DIMENSIONS IN INCHES (IN PARENTHESES IN MILLIMETERS) 2. TOLERANCE: ±1% NLT±0.005 (0.127) 18 FN8105.1 February 12, 2007 X28C010, X28HT010 Packaging Information 32-Lead Ceramic Small Outline Gull Wing Package Type R 0.060 Nom. See Detail “A” For Lead Information 0.020 Min. 0.165 Typ. 0.340 ±0.007 0.015 R Typ. 0.015 R Typ. 0.035 Typ. 0.035 Min. Detail “A” 0.050" Typical 0.019 0.015 0.830 Max. 0.750 ±0.005 0.050 0.050" Typical 0.560" Typical FOOTPRINT 0.030" Typical 32 Places 0.440 Max. 0.560 Nom. NOTES: 1. ALL DIMENSIONS IN INCHES 2. FORMED LEAD SHALL BE PLANAR WITH RESPECT TO ONE ANOTHER WITHIN 0.004 INCHES 19 FN8105.1 February 12, 2007 X28C010, X28HT010 Packaging Information 36 Lead Ceramic Pin Grid Array Package Package Code G36.760x760A 15 17 19 21 22 A 13 14 12 11 16 18 20 23 24 25 26 0.008 (0.20) 0.050 (1.27) A 10 9 27 28 8 7 29 30 6 Typ. 0.180 (.010) (4.57 ± .25) 4 Corners 5 2 36 34 32 4 3 1 35 33 31 NOTE: Leads 5, 14, 23, & 32 Typ. 0.100 (2.54) All Leads Typ. 0.180 (.010) (4.57 ± .25) 4 Corners 0.120 (3.05) 0.100 (2.54) 0.072 (1.83) 0.062 (1.57) Pin 1 Index 0.770 (19.56) 0.750 (19.05) SQ 0.020 (0.51) 0.016 (0.41) A A 0.185 (4.70) 0.175 (4.45) NOTE: ALL DIMENSIONS IN INCHES (IN PARENTHESES IN MILLIMETERS) All Intersil U.S. products are manufactured, assembled and tested utilizing ISO9001 quality systems. Intersil Corporation’s quality certifications can be viewed at www.intersil.com/design/quality Intersil products are sold by description only. Intersil Corporation reserves the right to make changes in circuit design, software and/or specifications at any time without notice. Accordingly, the reader is cautioned to verify that data sheets are current before placing orders. Information furnished by Intersil is believed to be accurate and reliable. However, no responsibility is assumed by Intersil or its subsidiaries for its use; nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent or patent rights of Intersil or its subsidiaries. For information regarding Intersil Corporation and its products, see www.intersil.com 20 FN8105.1 February 12, 2007
X28C010FI-15 价格&库存
很抱歉,暂时无法提供与“X28C010FI-15”相匹配的价格&库存,您可以联系我们找货
