0601-25241-1-013
    SUCO(苏克)
    Cylinder,Threaded
    PRESSURE TRANSDUCER, 0-10V OUTPU
0601-25241-1-013 数据手册
Pressure transmitters, Performance series Technical details Type: 0 6 01 0 6 02 Output signal: 0 – 10 V (3-wire) 4 – 20 mA (2-wire) Supply voltage UV+ : 11 - 32 VDC with reverse voltage protection 9.6 - 32 VDC with reverse voltage protection Permissible loadapparent ohmic resistance: ≥ 4.7 kΩ ≤ (Uv+– 10 V) / 20 mA Idle power consumption: approx. 5 mA < 4 mA Type: 0601 / 0602 Standard pressure ranges p : nom 1) Overpressure protection p : u Burst pressure : 1) Mechanical life expectancy: 0 - 2 bar 0 - 4 bar (0 – 29 psi) (0 – 58 psi) 0 - 16 bar 0 - 40 bar (0 – 145 psi) (0 – 230 psi) (0 – 580 psi) (0 – 1,450 psi) 10 bar 20 bar 40 bar 100 bar (58 psi) (145 psi) (290 psi) (580 psi) (1,450 psi) (2,175 psi) (5,439 psi) 8 bar 20 bar 35 bar 60 bar 140 bar 300 bar 500 bar (115 psi) (290 psi) (500 psi) (870 psi) (2,000 psi) (4,350 psi) (7,250 psi) ≤ ±1 % full scale (FS) at room temperature, ±0.5 % BFSL ±0.3 % of full scale (FS) per year Repeatability : 2) ±0.1 % FS error2): ≤ ±0.04 % of full scale (FS) / °C Compensated temperature range: 32 °F …+158 °F Temperature range ambient: -22 °F … +212 °F (-30 °C … +100 °C) Temperature range media: (0 °C … +70 °C) with NBR (BunaN) seal: -22 °F … +212 °F (-30 °C … +100 °C) with EPDM seal: -22 °F … +257 °F (-30 °C … +125 °C) with FKM (Viton®) seal: -4 °F … +257 °F (-20 °C … +125 °C) with TPE seal: -22 °F … + 230 °F Housing: Stainless steel AISI 303 (1.4305) Measuring cell: Ceramic Seal material: NBR (BunaN), EPDM, FKM (Viton®) or TPE (-30 °C … +110 °C) 3) Insulation resistance: > 100 MΩ (35 VDC) Response time 10 – 90 %: ≤ 2 ms Vibration resistance: 20 g; at 4 … 2000 Hz sine wave; DIN EN 60068-2-6 Shock resistance: half sine wave 500 m/s²; 11 ms; DIN EN 60068-2-27 Protection class IP65: DIN EN 175301-803-A, IP67: M12x1, AMP Superseal 1.5®, cable connector IP67 and IP6K9K: Bayonet ISO 15170-A1-4.1, Deutsch DT04-3P Electromagnetic compatibility: EMC 2014/30/EU, EN 61000-6-2:2005, EN 61000-6-3:2007 Max. length of connection cable: 30 m Protection against reverse polarity, short-circuit and overvoltage: Built-in Cable output thread size: Weight: 375 bar 5,000,000 pulsations at rise rates to 14,500 psi/s (1,000 bar/s) at p nom Accuracy: Wetted parts material (0 – 3,625 psi) 4 bar Permitted pressure change rate: Temperature 0 - 250 bar 150 bar ≤ 14,500 psi/s (≤ 1,000 bar/s) Long term stability: 0 - 100 bar 0 - 10 bar For DIN EN 175301: PG9 (outside diameter of cable 6 to 9 mm) approx. 2.82 oz / 80 g (DIN EN 175301 approx. 3.88 oz /110 g) 1) Static pressure, dynamic pressure 30 to 50% lower. Values refer to the hydraulic or pneumatic part of the pressure transducer 2) Within the compensated temperature range FKM sealings are only suitable for pressure ranges up to 0-16 bar. 3) T 145 0601 / 0602 T.1 Order matrix for pressure transducers hex 24 Performance Type 0 – 10 V, 3-wire 0601 4 – 20 mA, 2-wire 0602 Burst pressure Max. overpressure 1) Pressure Pressure Seal range connection material Electrical connection Pressure range 4 bar 8 bar 0 – 2 bar (58 psi) (115 psi) (approx. 29 psi) 10 bar 20 bar 0 – 4 bar (145 psi) (290 psi) (approx. 58 psi) 20 bar 35 bar 0 – 10 bar (290 psi) (500 psi) (approx. 145 psi) 40 bar 60 bar 0 – 16 bar (580 psi) (870 psi) (approx. 230 psi) 100 bar 140 bar (1,450 psi) (2,000 psi) (approx. 580 psi) 150 bar 300 bar 0 – 100 bar (2,175 psi) (4,350 psi) (approx. 1,450 psi) 375 bar 500 bar 0 – 250 bar (5,439 psi) (7,250 psi) (approx. 3,625 psi) 0 – 40 bar 200 400 101 161 401 102 252 Pressure connection 1/4 BSPP – (DIN 3852), form E, male thread 41 NPT 1/4 09 Seal material – Application areas NBR (BunaN) Hydraulic/machine oil, heating oil, air, nitrogen, water, etc 1 EPDM Brake fluid, water, acetylene, hydrogen, oxygen etc. 2 FKM (Viton®) 2) TPE 3 Hydraulic/machine oil, water, air, nitrogen, acetylene, etc. T 7 Electrical connection DIN EN 175301-803-A (DIN 43650-A) ; socket device included 013 M 12x1 - DIN EN 61076-2-101-A 002 Bayonet ISO 15170-A1-4.1 (DIN 72585-A1-4.1) 015 AMP Superseal 1.5® 007 Deutsch DT04-3P 014 Order number: 1) 2) 06XX XXX XX X XXX Static pressure, dynamic pressure 30 to 50% lower. Values refer to the hydraulic or pneumatic part of the pressure transducer. FKM sealings are only suitable for pressure ranges up to 0-16 bar. RoHSIII 2020-209 compliant 147 T.6 Mating plugs Accessories For requirements at short notice and for realising custom solutions Deutsch DT06-3S (for DT04-3P) 3 x 0,5 mm² PUR cable (2 m), IP67 Suitable for connection code 010 Deutsch DT04-3P Article number: 1-1-36-653-160 TE AMP Superseal 1.5®, 3-pin 3 x 0,5 mm² Radox cable (2 m), IP65 Suitable for connection code 007 AMP Superseal 1.5® Article number: 1-1-32-653-158 M12 DIN EN 61076-2-LF, 4-pin 4 x 0,34 mm² PUR cable (2 m), IP65 Suitable for connection code 002 M12 DIN EN 61076-2-101 A Article number: 1-1-00-653-162 Terminals for wire diameter 0.75 mm² (AWG 18) Suitable for connection code 002 Article number: 1-6-00-652-016 ~ 54 Socket device M 12x1 DIN EN 61076-2-101 A straight, 4-pin Hex thread ring (tightening torque: 0,6 Nm) M 12x1 DIN EN 61076-2-101-LF Ø 20 Coupler socket device M 12x1 DIN EN 61076-2-101 A angled, 4-pin Terminals for wire diameter 0.75 mm² (AWG 18) Suitable for connection code 002 Article number: 1-6-00-652-017 ~ 35 Ø 20 M 12x1 DIN EN 61076-2-101-LF ~ 40 165
0601-25241-1-013 价格&库存
很抱歉,暂时无法提供与“0601-25241-1-013”相匹配的价格&库存,您可以联系我们找货
