CC-10 Wide Range Active Vacuum Gauge
Part Number: 2-7980-0XX
Operating Specifications 1
Operating Range
Communications
Analog Output
Programmable Set Points
Supply Voltage
Maximum Power
Calibration Medium
Overpressure
Digital Output Resolution
Analog Output Resolution
Operating Temperature
Storage Temperature
Bakeout Temperature
Response Time
Accuracy
10-9 Torr to 10-1 Torr
10-1 Torr to 200 Torr
200 Torr to 1000 Torr
Analog Output
Display Readable Distance
Description
10-9 Torr
1x
to 1000 Torr
RS-485
0 V to 10 V linear/logarithmic
3 relays
+22 V DC to +26 V DC
8W
Dry air or nitrogen
150 psi
2 significant digits with exponent
16 bits
0 °C to 50 °C
-40 °C to 85 °C
120 °C (electronics removed)
≤ 500 ms
The CC-10 Active Gauge utilizes dual sensor
technology to replace multiple conventional
vacuum gauges, permitting seamless measurement of twelve decades of pressure. It has
a variety of features including a wide range of
measurement from 1 x 10-9 Torr up to 1000
Torr, RS-485 communications, three programmable set points, and a selectable
analog output. The bright LED display makes
it easy to read from a distance.
Options can be set from either four touch controls located on the front
of the unit or through RS-485 communications. The simplicity of use
and wide measurement range make this unit an excellent choice for a
variety of vacuum applications.
±0.2 of decade
±15% of reading
±5% of reading
±10 mV
4 m (13 ft)
Analog Output Behavior
Physical Characteristics
Enclosure Material
Electrical Connections
Weight with Sensor
Weight without Sensor
Dimensions
Metallized plastic
D-Sub 15-pin male
698 g (1.54 lbs) (NW25 Flange)
355 g (0.78 lbs)
3.7” x 2.75” x 6.3” (NW25 Flange)
RS-485 Commands (assume address 0) 2
0R1
0R2
0R5
0W1XXXX
0W2XXXXXXXX
0C1
0S1
0S2
Read units
Read SP1L and SP1H
Read analog output set parameter
Set pressure unit
Set SP1L and SP1H
Crystal gauge atm adjustment
Read pressure data
Read error status
Benefits
Wide measurement range
Compact design
Easy to read LED display
Analog and RS-485 communications standard
Excellent resolution and repeatability
Superior unit to unit performance
Excellent customer support
Ratings and Compliance
See the Televac website at www.televac.com for a list of definitions for terms
used in the operating specifications. All test data was acquired at 23 °C.
1
email: sales@frederickscompany.com
tel: +1 215 947 2500
CE certified to EN 61010-1, EN 61236-1
RoHS compliant
IP40
2 See the CC-10 Instruction Manual for all RS-485 command descriptions and
setup instructions.
web: frederickscompany.com
form: cc10_ds rev D
page: 1/2
Pin
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
Dimensional Drawings
Description
Analog Out (Ground)
RS-485 A (-)
SP3 Out
SP2 Out
SP1 Out
Zero adjust input (signal in)
EXT Vcc (signal in)
Supply voltage (+)
Analog Out (0 to 10) V
RS-485 B (+)
SP2, SP3 COM
SP1 COM
HV inhibit signal (signal in)
Atm adjust input (signal in)
Supply Voltage (-)
Materials Exposed to Vacuum
Molybdenum
Glass
Copper
Stainless Steel
Gold
Chromium
Solder
Fluorocarbon Elastomer
Quartz
Ordering Information
Set Points
The CC-10 has three set points. All three are optically coupled solid
state relays that are rated for 0.12 A at 50 V DC. Each set point has
hysteresis characteristics and consists of two set values: upper threshold and lower threshold. LEDs on the front panel display the status of
each set point. The high and low threshold values of each of the three
set points can be set independently.
Related Products
MM200 Vacuum Sensor Controller - The MM200 controls any Televac
vacuum sensor including cold cathode, convection, diaphragm, hot ion,
and thermocouple sensors. It also has optional features including up to
8 relay set points and RS-232/RS-485 communications. The large,
bright LED display makes it easy to read from a distance. The MM200
is a modular unit, allowing customers to choose a vacuum sensing solution specific to their needs.
Visit the Televac website at www.televac.com for a full list of products
and product applications.
CC-10 Part Number
Vacuum Fittings
NW25 (DN25 ISO-KF)
NW40 (DN40 ISO-KF)
2.75” CF (DN40 ISO-CF-M)
CC-10 Cable
10 ft
20 ft
35 ft
50 ft
(90 to 240) V AC / 24 V DC CE Power Supply
with International Plug Adapters
Replacement Anode Assembly
Replacement O-Ring for Anode Assembly
Remote Display Module
2-7980-0XX
XX
31
32
52
2-9858-0XX
10
50
2-7900-097
2-7900-101
2-7900-099
6-4210-260
2-7900-098
Contact Us
Televac
The Fredericks Company
2400 Philmont Avenue
Huntingdon Valley, PA 19006
email: sales@televac.com
web: www.televac.com
Disclaimer: Specifications subject to change without notice. The Fredericks Company assumes no responsibility for inaccuracies in product specifications or any liability arising from product use.
© 2015 The Fredericks Company
form: cc10_ds rev D
page: 2/2
很抱歉,暂时无法提供与“2-7980-052”相匹配的价格&库存,您可以联系我们找货
