MX2A Active Thermocouple Vacuum Gauge
Part Number: 2-8910-1XX
Operating Specifications 1
Operating Range
Communications
Analog Output
Programmable Set Points
Set Point 1
Set Point 2
Supply Voltage
Maximum Power
Calibration Medium
Overpressure
Digital Output Resolution
Analog Output Resolution
Operating Temperature
Storage Temperature
Bakeout Temperature
Brass (P/N: 2-8910-110)
Stainless (P/N: All Others)
Response Time
Accuracy
0.1 mTorr to 1 mTorr
1 mTorr to 10 mTorr
10 mTorr to 1 Torr
1 Torr to 100 Torr
100 Torr to 1000 Torr
Analog Output
Display Readable Distance
Description
10-4 Torr
1x
to 1000 Torr
RS-485
7 selectable 0 V DC to 10 V DC
2
Open collector
Relay
+22 V DC to +26 V DC
8W
Dry air or nitrogen
150 psi
2 significant digits with exponent
16 bits
0 °C to 50 °C
-20 °C to 60 °C
100 °C (electronics removed)
200 °C (electronics removed)
≤2s
0.1 mTorr resolution
±1 mTorr
±10% of reading
±30% of reading (vertical mount)
±10% of reading (vertical mount)
±10 mV
3 m (10 ft)
The MX2A Active Gauge utilizes an easily replaceable (no screws) Televac 2A thermocouple
vacuum sensor. It has a variety of features including a wide range of measurement from 1 x
10-4 Torr up to 1000 Torr, RS-485 communications, two programmable set points, and a
selectable analog output. The bright OLED display makes it easy to read from a distance.
Options can be set from four capacitive touch controls located on the
top of the unit or through RS-485 communications. The extensive selection of fittings, simplicity of use, ease of sensor replacement, and
competitive cost make this unit an excellent choice for a variety of vacuum applications.
Applications
Heat treatment and vacuum furnaces
Thin film deposition and coating processes
Cryogenics
Pharmaceutical product processes
Visit the Televac website at www.frederickscompany.com for a full
list of applications.
Analog Output Behavior
Physical Characteristics
Housing
Electrical Connections
Weight with Sensor (typical)
Weight without Sensor
Dimensions
Aluminum
D-Sub 15-pin male
345 g (0.76 lbs)
186 g (0.41 lbs)
See dimensional drawings
Sample RS-485 Commands (assume address 0) 2
*0R1
*0R2
*0W10001
*0W10002
*0W10003
*0W2XXXXXXXX
*0S1
Read units
Read SP1L and SP1H
Set units to Pascal
Set units to Torr
Set units to Millibar
Set SP1 low and high values
Read vacuum
Benefits
Simple sensor replacement - no screws to remove
Competitively priced
Compact design with an easy to read color OLED display
Excellent resolution and accuracy of measurements
Superior unit to unit performance
Excellent customer support
1
See the Televac website at www.frederickscompany.com for a list of definitions for terms. All test data was acquired at 23 °C.
Ratings and Compliance
• Certified to CAN/CSA C22.2 No. 61010-1-12
• CE certified to EN 61010-1, EN 61236-1, EN 55011
• RoHS
• IP40
• EAC certified
2
See the MX2A Instruction Manual for RS-485 command descriptions and
setup instructions.
sales@frederickscompany.com
+1 215 947 2500
mx2a_ds rev K
page 1/2
Pin
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
Dimensional Drawings
Description
Analog Out (Ground)
RS-485 A (-)
SP2 NC
SP2 NO
SP1 Open Drain
Floating
Floating
Supply Voltage (+)
Analog Out (0 to 10) V
RS-485 B (+)
SP2 Com
SP1 Source
Floating
Floating
Supply Voltage (-)
Materials Exposed to Vacuum
MX2A PN: 2-8910-110, -116, -125
Nickel
Glass
Gold
Tophet
Cupron
Solder
MX2A P/N: All Others
Nickel
Glass
Gold
Tophet
Cupron
Stainless Steel
Set Points
The MX2A has two set points. Set point 1 is an N-Channel 60 V MOSFET
open collector. It has a maximum current rating of 1 A. The data sheet
can be found at www.vishay.com/docs/69958/si2308bd.pdf. Set point
2 is a relay with a maximum switching voltage of 220 V DC (250 V AC)
and a maximum switching current of 2A. The data sheet can be found
at www.te.com/catalog/pn/en/1393788-3.
Related Products and Replacement Sensors
2A Nickel Plated Brass Sensor
1/8” NPT
NW16 (DN16 ISO-KF)
NW25 (DN25 ISO-KF)
Part Number
2-2100-10
2-2100-016
2-2100-025
2A Stainless Steel Sensor
1/8” NPT
1/2” Straight
NW16 (DN16 ISO-KF)
NW25 (DN25 ISO-KF)
NW40 (DN40 ISO-KF)
1.33” CF (DN16 ISO-CF-F)
2.75” CF (DN40 ISO-CF-F)
Part Number
2-2126-01
2-2126-11
2-2126-30
2-2126-31
2-2126-32
2-2126-50
2-2126-52
Ordering Information
MX2A
1/8” NPT Stainless Steel
1/8” NPT Nickel Plated Brass
1/2” Straight Stainless Steel
NW16 (DN16 ISO-KF) Nickel Plated Brass
NW16 (DN16 ISO-KF) Stainless Steel
NW25 (DN25 ISO-KF) Nickel Plated Brass
NW25 (DN25 ISO-KF) Stainless Steel
NW40 (DN40 ISO-KF) Stainless Steel
1.33” CF (DN16 ISO-CF-F) Stainless Steel
2.75” CF (DN40 ISO-CF-F) Stainless Steel
VCR and VCO available upon request
Part Number
2-8910-101
2-8910-110
2-8910-111
2-8910-116
2-8910-130
2-8910-125
2-8910-131
2-8910-132
2-8910-150
2-8910-152
D-Sub 6 Conductor Cable (flying leads)
20 ft (6 m)
50 ft (15 m)
100 ft (30 m)
Part Number
2-9857-020
2-9857-050
2-9857-100
D-Sub 15 Conductor Cable (flying leads)
20 ft (6 m)
50 ft (15 m)
100 ft (30 m)
Part Number
2-9858-020
2-9858-050
2-9858-100
Wall Power Supply
100-240 V AC/47-63 Hz, plug types A, C, G, I
Part Number
2-7900-097
Contact Us
Televac - The Fredericks Company
2400 Philmont Avenue
Huntingdon Valley, PA 19006
MP7ER Active Gauge - This gauge measures high vacuum from 1x10-8
Torr up to 1x10-2 Torr. Combining it with the MX2A provides a full
range (ATM to UHV) active gauge measurement solution.
Visit the Televac website at www.frederickscompany.com for a full list
of products.
tel: +1 215 947 2500
email: sales@frederickscompany.com
web: www.frederickscompany.com
Disclaimer: Specifications subject to change without notice. The Fredericks Company assumes no responsibility for inaccuracies in product specifications or any liability arising from product use.
© 2020 The Fredericks Company
+1 215 947 2500
mx2a_ds rev K
page 2/2
很抱歉,暂时无法提供与“2-8910-130”相匹配的价格&库存,您可以联系我们找货
