| 2CP5 & 2CP50 SERIES
HVAC/Refrigeration Pressure Sensor
Introduction
The 2CP series is ideal for demanding air conditioning and refrigeration applications where long-term reliability and accuracy is a must. The 2CP series
provides proven reliability at a competitive price.
Sensata Technologies has been a leading global supplier of pressure sensors and switches for over 50 years. The 2CP has many options, consult the
factory to customize a 2CP to meet your application’s needs.
Features
UL recognized
Ceramic capacitive sensor
Durable, compact, low-cost design
Accurate performance over wide temperatures
Overvoltage and short circuit protected
Applications
Discharge and suction pressure monitoring
Subcooling and superheat calculations
Compressor oil pressure monitoring
Condenser fan control
Compressor staging and unloading
Electronic expansion valve control
Remote systems diagnostics and trending
SPECIFICATIONS
Pressure Ranges
Accuracy
Total Error Band
0 to 15 psi, through 0 to 750 psi
±0.8% F.S. (linearity, hysteresis, repeatability and calibration)
Static error band @ 25°C, 5.0VDC
±1.0% (-20°C to +85°C)
±1.5% (-40°C to +125°C)
Operating Temperature
-40°C to +135°C
Storage Temperature
40°C to +150°C
Proof Pressure
5X 15 to 75 psi, 3X 100 to 300 psi, 2X 500+ psi
Burst Pressure
2CP5 - 5x operating pressure
2CP50 - 3x operating pressure
Cycle Life
Random Vibration
Drop (any Axis)
Electrical Connection
10M F.S. cycles
11g (50 to 2000 Hz)
1.5m
Nema 4X, IP65
Page 1
Copyright © 2018 Sensata Technologies, Inc.
www.sensata.com
Supply Voltage
4.5 to 5.5 VDC
Output Voltage
0.5 to 4.5 VDC typical
Supply Current
7 mA (max @ 5.5 VDC no load)
Output Current
2.5 mA (max sinked or source)
Output Load
10K ohms typical
Output Response Time
10mS
Overvoltage Protection
16 VDC
Reverse Voltage
-14 VDC
Short Circuit Protected
Yes
EMC (512MHz to 1 GHz)
50 V/m
EMC (1 MHz to 512 MHz)
100 V/m
ESD (CDF-AEC-Q100-002)
15 kV
STANDARDS
Sample PN
Production PN
Description
2CP5B0520150ANN
2CP5-71-46
Brass, 0 to 150 psia
2CP5B0520200ANN
ANN 2CP5-71-49
Brass, 0 to 200 psia
2CP5B0520300SNN
NN 2CP5-71-50
Brass, 0 to 300 psis
2CP5B0520400SNN
N 2CP5-71-51
Brass, 0 to 400 psis
2CP5B0520500SNN
2CP5-71-47
Brass, 0 to 500 psis
2CP5S0520500SNN
2CP5-71-48
Steel, 0 to 500 psis
SEAL MATERIALS
Material
HNBR
(Hydrogenated Nitrile)
Neoprene
Refridgerant
Maximum Seal Temperature Range
R134a, R404a, R407c,
R410a, R507
-20°C to 135°C
R12, R22, R134a, R404a,
R407c, R410a, R502, R507
-40°C to 120°C
DIMENSIONAL DRAWINGS
Page 2
www.sensata.com
Example : 2CP5-S-05-2-XXXX-A-N-N
ORDERING OPTIONS
2CP5
Pressure Range
S
05
2
XXXX
A
N
N
2CP5 = Up to 500 psi
2CP50 = Above 500 psi
Pressure Connection Material
S = Plated steel
B = Brass (2CP5 only)
Pressure Connection
05 = 1/4” SAE female flare with
deflator, 7/16”-20 UNF-2B
2 = Packard Metri-Pack (Mates with Packard # 12065287)
Connector Harness
N = None required
Y = Packard wire harness, 1 meter standard wire
Seal Material
H = HNBR (Hydrogenated Nitrile)
N = Neoprene
Pressure Reference
A = Absolute
S = Sealed gage
G = Vented gage
Pressure Ranges (see standards below)
From 0-15 psi (0015) to 0-750 psi (0750)
From 0-1 bar (M001) to 0-50 bar (M050)
AGENCY APPROVALS & CERTIFICATIONS
UL recognized file #SA995
RoHS, REACH available
Page 3
Sensata Technologies, Inc. (“Sensata”) data sheets are solely intended to assist designers (“Buyers”) who are developing systems that
incorporate Sensata products (also referred to herein as “components”). Buyer understands and agrees that Buyer remains responsible
for using its independent analysis, evaluation and judgment in designing Buyer’s systems and products. Sensata data sheets have
been created using standard laboratory conditions and engineering practices. Sensata has not conducted any testing other than that
specifically described in the published documentation for a particular data sheet. Sensata may make corrections, enhancements,
improvements and other changes to its data sheets or components without notice.
Buyers are authorized to use Sensata data sheets with the Sensata component(s) identified in each particular data sheet. HOWEVER, NO
OTHER LICENSE, EXPRESS OR IMPLIED, BY ESTOPPEL OR OTHERWISE TO ANY OTHER SENSATA INTELLECTUAL PROPERTY RIGHT, AND
NO LICENSE TO ANY THIRD PARTY TECHNOLOGY OR INTELLECTUAL PROPERTY RIGHT, IS GRANTED HEREIN. SENSATA DATA SHEETS
ARE PROVIDED “AS IS”. SENSATA MAKES NO WARRANTIES OR REPRESENTATIONS WITH REGARD TO THE DATA SHEETS OR USE
OF THE DATA SHEETS, EXPRESS, IMPLIED OR STATUTORY, INCLUDING ACCURACY OR COMPLETENESS. SENSATA DISCLAIMS
ANY WARRANTY OF TITLE AND ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, QUIET
ENJOYMENT, QUIET POSSESSION, AND NON-INFRINGEMENT OF ANY THIRD PARTY INTELLECTUAL PROPERTY RIGHTS WITH REGARD
TO SENSATA DATA SHEETS OR USE THEREOF.
All products are sold subject to Sensata’s terms and conditions of sale supplied at www.sensata.com SENSATA ASSUMES NO LIABILITY
FOR APPLICATIONS ASSISTANCE OR THE DESIGN OF BUYERS’ PRODUCTS. BUYER ACKNOWLEDGES AND AGREES THAT IT IS SOLELY
RESPONSIBLE FOR COMPLIANCE WITH ALL LEGAL, REGULATORY AND SAFETY-RELATED REQUIREMENTS CONCERNING ITS PRODUCTS,
AND ANY USE OF SENSATA COMPONENTS IN ITS APPLICATIONS, NOTWITHSTANDING ANY APPLICATIONS-RELATED INFORMATION
OR SUPPORT THAT MAY BE PROVIDED BY SENSATA.
Mailing Address: Sensata Technologies, Inc., 529 Pleasant Street, Attleboro, MA 02703, USA.
Rev.02/08/18
CONTACT US
Americas
+1 (800) 350 2727
sensors@sensata.com
switches@sensata.com
Europe, Middle East & Africa
+359 (2) 809 1826
pressure-info.eu@sensata.com
Asia Pacific
sales.isasia@list.sensata.com
China +86 (21) 2306 1500
Japan +81 (45) 277 7117
Korea +82 (31) 601 2004
India +91 (80) 67920890
Rest of Asia +886 (2) 27602006
ext 2808
www.sensata.com
