Product data sheet
IMB18-12NNSVC0S
IMB
INDUCTIVE PROXIMITY SENSORS
IMB18-12NNSVC0S | IMB
A
B
C
D
E
F
H
I
J
K
L
M
N
O
P
Q
R
S
T
Ordering information
Type
Part no.
IMB18-12NNSVC0S
1072811
Included in delivery: BEF-MU-M18N (1)
Other models and accessories
www.sick.com/IMB
Illustration may differ
Detailed technical data
Features
Housing
Cylindrical thread design
Housing
Standard
Thread size
M18 x 1
Diameter
Ø 18 mm
Sensing range Sn
12 mm
Safe sensing range Sa
9.72 mm
Installation type
Non-flush
Switching frequency
1,000 Hz
Connection type
Male connector M12, 4-pin 1)
Switching output
NPN
Output function
NO
Electrical wiring
DC 3-wire
Enclosure rating
IP68 2)
IP69K 3)
Special features
Resistant against coolant lubricants, Visual adjustment indicator, Temperature resistance
Special applications
Zones with coolants and lubricants, Mobile machines, Difficult application conditions
1)
2)
3)
With gold plated contact pins.
According to EN 60529.
According to ISO 20653:2013-03.
Mechanics/electronics
Supply voltage
10 V DC ... 30 V DC
Ripple
≤ 10 %
1)
2)
3)
4)
5)
6)
2
At Ia max.
Without load.
Ub and Ta constant.
Of Sr.
When using the non-toothed side of the nut.
Valid if toothed side of nut is used.
INDUCTIVE PROXIMITY SENSORS | SICK
Product data sheet | 2021-11-26 15:21:34
Subject to change without notice
Voltage drop
≤ 2 V 1)
Current consumption
10 mA 2)
Hysteresis
3 % ... 20 %
Reproducibility
≤ 2 % 3) 4)
Temperature drift (of Sr)
± 10 %
EMC
According to EN 60947-5-2
Continuous current Ia
≤ 200 mA
Short-circuit protection
Reverse polarity protection
Power-up pulse protection
Shock and vibration resistance
100 g / 2 ms / 500 cycles; 150 g / 1 Mio cycles; 10 Hz ... 55 Hz / 1 mm; 55 Hz ... 500 Hz /
60 g
Ambient operating temperature
–40 °C ... +100 °C
Housing material
Stainless steel V2A, DIN 1.4305 / AISI 303
Sensing face material
Plastic, LCP
Housing length
65 mm
Thread length
39 mm
Tightening torque, max.
Typ. 60 Nm 5)
Typ. 90 Nm 6)
Items supplied
Mounting nut, V2A stainless steel, with locking teeth (2x)
Protection class
III
UL File No.
E181493
1)
2)
3)
4)
5)
6)
At Ia max.
Without load.
Ub and Ta constant.
Of Sr.
Safety-related parameters
MTTFD
1,971 years
DCavg
0 %
Reduction factors
Note
The values are reference values which may vary
St37 steel (Fe)
1
Stainless steel (V2A, 304)
Approx. 0.7
Aluminum (Al)
Approx. 0.43
Copper (Cu)
Approx. 0.37
Brass (Br)
Approx. 0.43
Installation note
Remark
Associated graphic see "Installation"
A
18 mm
B
45 mm
2021-11-26 15:21:34 | Product data sheet
Subject
3
A
B
C
D
E
F
H
I
J
K
L
M
N
O
P
Q
R
S
T
C
18 mm
D
36 mm
E
12 mm
F
96 mm
Classifications
ECl@ss 5.0
27270101
ECl@ss 5.1.4
27270101
ECl@ss 6.0
27270101
ECl@ss 6.2
27270101
ECl@ss 7.0
27270101
ECl@ss 8.0
27270101
ECl@ss 8.1
27270101
ECl@ss 9.0
27270101
ECl@ss 10.0
27270101
ECl@ss 11.0
27270101
ETIM 5.0
EC002714
ETIM 6.0
EC002714
ETIM 7.0
EC002714
ETIM 8.0
EC002714
UNSPSC 16.0901
39122230
Installation note
Non-flush installation
F
B
C
A
A
D
E
4
Connection diagram
Cd-007
1
BN
BK 4
2
3
BU
+ (L+)
NO
not connected
- (M)
Characteristic curve
Response diagram
Distance in mm (inch)
10
(0.39)
(0.39)
(0.08)
4
6
8
10
12
(0.16) (0.24) (0.31) (0.39) (0.47)
Sn in mm (inch)
Adjustments
Installation aid
Q
LED
Distance
of target
Sr
Sa=0.81 Sn
Subject
5
Dimensional drawing (Dimensions in mm (inch))
IMB18 Standard, connector M12, non-flush
65 (2.56)
8 (0.31)
39 (1.54)
8.9 (0.35)
M18x1
A
B
C
D
E
F
Recommended accessories
H
I
J
K
L
M
N
O
P
Q
R
S
T
www.sick.com/IMB
Brief description
Type
Part no.
BEF-KHS-N06N
2051622
Mounting plate for M18 sensors, stainless steel, without mounting hardware
BEF-WG-M18N
5320948
Mounting bracket for M18 sensors, stainless steel, without mounting hardware
BEF-WN-M18N
5320947
Head A: female connector, M12, 4-pin, straight
Head B: Flying leads
Cable: Sensor/actuator cable, PP, unshielded, 2 m
This product is generally resistant to chemical cleaning agents (see ECOLAB) and other
chemical compounds such as H2O2 and CH2O2. Before permanent installation is carried out, the material's resistance to the cleaning agent being used must be checked.,
Resistant against lactic acid & hydrogen peroxide (H2O2)
DOL-1204-G02MRN
6058291
Cable: Sensor/actuator cable, PP, unshielded, 5 m
DOL-1204-G05MRN
6058476
Head A: female connector, M12, 4-pin, angled
Resistant against lactic acid & hydrogen peroxide (H2O2), only suitable for PNP sensors
DOL-1204-L02MRN
6058482
Universal bar clamp systems
Plate N06N for universal clamp bracket, M18, Stainless steel 1.4571 (sheet), Stainless
steel 1.4408 (clamp), Universal clamp (5322627), mounting hardware
Mounting brackets and plates
Plug connectors and cables
6
Brief description
Type
Part no.
DOL-1204-L05MRN
6058483
DOL-1204-W02MRN
6058474
DOL-1204-W05MRN
6058477
Head A: female connector, M12, 4-pin, straight, A-coded
Cable: Sensor/actuator cable, PUR, halogen-free, unshielded, 2 m
YF2A14020UB3XLEAX
2095607
Cable: Sensor/actuator cable, PUR, halogen-free, unshielded, 5 m
YF2A14050UB3XLEAX
2095608
Head A: female connector, M12, 4-pin, angled, A-coded
YG2A14050UB3XLEAX
2095767
Head B: male connector, M12, 4-pin, straight
DSL-1204-B02MRN
6058502
DSL-1204-B05MRN
6058503
DSL-1204-G02MRN
6058499
DSL-1204-G05MRN
6058500
Subject
7
A
B
C
D
E
F
H
I
J
K
L
M
N
O
P
Q
R
S
T
Brief description
Head B: male connector, M12, 4-pin, straight, A-coded
8
Type
Part no.
YF2A14050UB3M2A14
2096001
Online data sheet
SICK at a glance
SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely
and efficiently, protecting individuals from accidents and preventing damage to the environment.
We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in
Europe, Asia and North America, system solutions are tested and optimized in accordance with customer
specifications. All this makes us a reliable supplier and development partner.
Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity.
For us, that is “Sensor Intelligence.”
Worldwide presence:
Contacts and other locations – www.sick.com
SICK AG | Waldkirch | Germany | www.sick.com
