Proximity Sensors Inductive
Thermoplastic Polyester Housing
Types EI, DC, M12, M18, M30
• Euronorm thermoplastic polyester housing,
cylindrical
• Diameter: M12, M18, M30
• Flush and non-flush types
• Long and short body versions
• Sensing distance: 2 to 15 mm
• Power supply: 10 to 40 VDC
• Output: Transistor NPN/PNP, Normally open or Normaly
closed
• Protection: Short-circuit, reverse polarity and overload
• LED-indication for output ON
• 2 m cable or M12 plug
Product Description
Ordering Key
Proximity switch in M12, M18
and M30 polyester housings.
Made in accordance with
Type
Housing diameter (mm)
Rated operating dist. (mm)
Output type
Housing material
Body style
Plug
euronorms EN 50 008 and
EN 50 036.
EI 1808 PPCPL-1
Type Selection DC Types, Cable and M12 Plug
Housing
diameter
Body
style
Connection
Rated
operating
dist. (Sn)
Ordering no.
Transistor NPN
Normaly open
Ordering no.
Transistor PNP
Normaly open
M12
M12
M12
Long
Short
Long
Cable
Cable
Cable
2 mm 1)
4 mm 2)
4 mm 2)
EI 1202 NPOPL
EI 1202 PPOPL
EI 1204 PPOPS
EI 1204 PPOPL
1)
M18
M18
M18
M18
M18
M18
Short
Long
Short
Short
Long
Long
Cable
Cable
Cable
Plug
Cable
Plug
5 mm
5 mm 1)
8 mm 2)
8 mm 2)
8 mm 2)
8 mm 2)
M30
M30
M30
Long
Short
Long
Cable
Cable
Cable
10 mm 1)
15 mm 2)
15 mm 2)
1)
For flush mounting in metal
2)
EI 1204 NPOPL
EI 1805 NPOPL
EI 1808 NPOPS
EI 1808 NPOPL
EI 3010 NPOPL
EI 3015 NPOPS
Ordering no.
Transistor PNP
Normaly closed
EI 1805 PPOPS
EI 1805 PPOPL
EI 1808 PPOPS
EI 1808 PPOPS-1
EI 1808 PPOPL
EI 1808 PPCPL
EI 1808 PPOPL-1 EI 1808 PPCPL-1
EI 3010 PPOPL
EI 3010 PPCPL
EI 3015 PPOPL
For non-flush mounting in metal
Specifications
Rated operational volt. (Ue)
(UB)
Ripple
Rated operational current (Ie)
Continuous
No-load supply current (Io)
Voltage drop (Ud)
Protection
Transient voltage
Power ON delay
12 to 36 VDC
10 to 40 VDC (ripple incl.)
≤ 10%
≤ 200 mA
Output ON: < 6.5 mA
Output OFF: < 2.7 mA
≤ 2 VDC at max. load
Reverse polarity, short-circuit,
transients
≤ 700 V/0.5 J
< 10 ms
Specifications are subject to change without notice (10.01.14)
Frequency of operating cycles (f)
EI 1202
EI 1204
EI 1805
EI 1808
EI 3010
EI 3015
Indication for output ON
Assured operating dist. (Sa)
Repeat accuracy (R)
Hysteresis (H) (Differential travel)
Effective operating dist. (Sr)
Usable operating dist. (S)
800 Hz
500 Hz
500 Hz
400 Hz
300 Hz
100 Hz
LED, yellow
0 ≤ Sa ≤ 0.81 Sn
≤ 5%
1 to 15% of sensing distance
0.9 x Sn ≤ Sr ≤ 1.1 x Sn
0.9 x Sr ≤ Su ≤ 1.1 x Sr
1
Specifications (cont.)
Weight (cable excluded)
Ambient temperature
Operating
Storage
Degree of protection
Housing material
Body
Back
Connection
Cable
EI12
EI 1805
EI 1808
EI 3010
EI 3015
-25° to +70°C (-13° to +158°F)
-30° to +80°C (-22° to +176°F)
IP 67 (Nema 1, 3, 4, 6, 13)
Grey thermoplastic polyester
Black polyester
Tightening torque
EI 12 1.8 Nm
EI 18 2.6 Nm
EI 30 7.5 Nm
UL, CSA
Yes
Approved acc. to EN 50 080,
EN 50 081
2
2 m, 3 x 0.3 mm , grey PVC,
oil proof
M 12 x 1
CONH1A serie
Plug
Cables for plug (-1)
10 g
18 g
20 g
50 g
70 g
Approvals
CE-marking
EMC
Dimensions
Type
A
B (Ø mm)
C (mm)
D (mm)
E (mm)
F (mm)
SW (mm)
EI 1202 XPXPL
EI 1204 XPXPS
EI 1204 XPXPL
M 12 x 1 x 50
M 12 x 1 x 30
M 12 x 1 x 50
10.7
10.7
10.7
50
34
54
11
11
11
5.0
5.0
5.0
8
8
8
17
17
17
EI 1805 XPXPS
EI 1805 XPXPL
EI 1808 XPXPS
EI 1808 XPXPL
EI 1808 XPXPL-1
M 18 x 1 x 30
M 18 x 1 x 50
M 18 x 1 x 30
M 18 x 1 x 50
M 18 x 1 x 50
16.7
16.7
16.7
16.7
16.7
30
50
38
58
58
11.6
11.6
11.6
11.6
13.1
15.4
15.4
15.4
15.4
11.9
8
8
8
8
8
24
24
24
24
24
M 30 x 1.5 x 50
M 30 x 1.5 x 30
M 30 x 1.5 x 50
28
28
28
50
42
62
13.6
13.6
13.6
15.4
15.4
15.4
10
10
10
36
36
36
EI 3010 XPXPL
EI 3015 XPXPS
EI 3015 XPXPL
D
E
D
C
E
B
B
C
M 12 x 1
F
F
SW
A
SW
LED
Cable
A
LED
Plug
Wiring Diagrams
1 BN
1 BN
1 BN
1 BN
4 BK
BK
2 WH
2 BK
WH
4 BK
3 BU
NPN - Normally open
2
3 BU
NPN - Normally closed
3 BU
3 BU
PNP - Normally open
PNP - Normally closed
Installation Hints
To avoid interference from inductive voltage/
current peaks, separate the prox. switch
power cables from any other power cables,
e.g. motor, contactor or solenoid cables
Relief of cable strain
Protection of the sensing face
Switch mounted on mobile carrier
Incorrect
Correct
The cable should not be pulled
A proximity switch should not serve as
mechanical stop
Any repetitive flexing of the
cable should be avoided
Power Supplies
Power supplies VAC:
> SS 110.
Power supplies VDC:
> SS 130/140.
Power supplies with amplifier relays: > SV 190.
3
很抱歉,暂时无法提供与“EI1204NPOPL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+510.07509
- 5+468.95411
