EI3010TBOSS
EI3010TBOSS
    CARLOGAVAZZI
    Cylinder,Threaded-M30
    SENSOR PROX INDUCTIVE 10MM CYL
EI3010TBOSS 数据手册
Proximity Sensors Inductive Stainless Steel Housing Types EI, AC, M12, M18, M30 • Stainless steel housing, cylindrical • Diameter: M12, M18, M30 • Sensing distance: 2 to 15 mm • Power supply: 20 to 250 VAC • Output: SCR, make or break switching • Protection: Overvoltage • LED-indication for output ON • Long or short housing • 2 m cable or plug M12 (double keyed) Product Description Ordering Key AC proximity switches constructed in stainless steel (1.4301) housings. Sizes available are M12, M18 and M30. Length of housing is selectable with 30 mm thread or 50 Type Housing diameter (mm) Rated operating dist. (mm) Output type Housing material Body style Plug mm thread. Bright LED ring utilizing a yellow LED clearly gives indication of output status. Protection rating IP 67 ensures environmental compatibility. EI 1202 TBOSL-6 Type Selection AC Types, Cable and M12 Plug Housing diameter Body style Connection Rated operating dist. (Sn) Ordering no. SCR Make switching Ordering no. SCR Break switching M12 M12 M12 M12 Long Long Long Long Cable Plug Cable Plug 2 mm 1) 2 mm 1) 4 mm 2) 4 mm 2) EI 1202 TBOSL EI 1202 TBOSL-6 EI 1204 TBOSL EI 1204 TBOSL-6 EI 1202 TBCSL EI 1202 TBCSL-6 EI 1204 TBCSL EI 1204 TBCSL-6 M18 M18 M18 M18 M18 M18 M18 M18 Short Short Long Long Short Short Long Long Cable Plug Cable Plug Cable Plug Cable Plug 5 mm 1) 5 mm 1) 5 mm 1) 5 mm 1) 8 mm 2) 8 mm 2) 8 mm 2) 8 mm 2) EI 1805 TBOSS EI 1805 TBOSS-6 EI 1805 TBOSL EI 1805 TBOSL-6 EI 1808 TBOSS EI 1808 TBOSS-6 EI 1808 TBOSL EI 1808 TBOSL-6 EI 1805 TBCSS EI 1805 TBCSS-6 EI 1805 TBCSL EI 1805 TBCSL-6 EI 1808 TBCSS EI 1808 TBCSS-6 EI 1808 TBCSL EI 1808 TBCSL-6 M30 M30 M30 M30 M30 M30 M30 M30 Short Short Long Long Short Short Long Long Cable Plug Cable Plug Cable Plug Cable Plug 10 mm 1) 10 mm 1) 10 mm 1) 10 mm 1) 15 mm 2) 15 mm 2) 15 mm 2) 15 mm 2) EI 3010 TBOSS EI 3010 TBOSS-6 EI 3010 TBOSL EI 3010 TBOSL-6 EI 3015 TBOSS EI 3015 TBOSS-6 EI 3015 TBOSL EI 3015 TBOSL-6 EI 3010 TBCSS EI 3010 TBCSS-6 EI 3010 TBCSL EI 3010 TBCSL-6 EI 3015 TBCSS EI 3015 TBCSS-6 EI 3015 TBCSL EI 3015 TBCSL-6 Short = 30 mm thread Long = 50 mm thread Make switching = Normally Open (NO) Break switching = Normally Closed (NC) 1) 2) For flush mounting in metal For non-flush mounting in metal Specifications are subject to change without notice (20.08.01) 1 EI, AC, M12, M18, M30 Specifications Rated operational volt. (Ue) (UB) Rated operational current (Ie) Continuous Short-time Minimum load current OFF-state current (Ir) Voltage drop (Ud) Protection Transient voltage Power ON delay Frequency of operating cycles (f) Indication for output ON Assured operating dist. (Sa) Repeat accuracy (R) Hysteresis (H) (Differential travel) Effective operating dist. (Sr) 24 to 240 VAC, 20 to 265 VAC, 50 to 60 Hz 10 - 500 mA ≤ 2.5 A, max. 20 ms 10 mA ≤ 2 mA ≤ 8 VAC at max. load Transients Level 3, 2.5 kV, acc. to IEC 60255-5 (500 Ω, 0.5 J) (prepared) ≤ 100 ms 25 Hz LED, yellow 0 ≤ Sa ≤ 0.81 Sn ≤ 5% 3 to 20% of sensing distance 0.9 x Sn ≤ Sr ≤ 1.1 x Sn 0.9 x Sr ≤ Su ≤ 1.1 x Sr Usable operating dist. (S) Ambient temperature Operating Storage Degree of protection Housing material Body Front Back Connection Cable -25° to +70°C (-13° to +158°F) -30° to +80°C (-22° to +176°F) IP 67 (Nema 1, 3, 4, 6, 13) Stainless steel (1.4301) Grey thermoplastic polyester Black thermoplastic polyester 2 m, 2 x 0.50 mm2, grey PVC, oil proof M12 x 1 (double keyed) CONH6A-xx EI 12 80 g EI 18 130 g EI 30 200 g EI 12 7.5 Nm (x) 17.5 Nm (y) EI 18 27.5 Nm EI 30 100.0 Nm UL, CSA Yes Plug Cables for plug (-6) Weight (cable excluded) Tightening torque Approvals CE-marking Dimensions Type EI 1202 TB..L EI 1202 TB..L-6 EI 1204 TB..L EI 1204 TB..L-6 EI 1805 TB..S EI 1805 TB..S-6 EI 1805 TB..L EI 1805 TB..L-6 EI 1808 TB..S EI 1808 TB..S-6 EI 1808 TB..L EI 1808 TB..L-6 A B mm C mm 66 74.5 70 78.5 57 55 77 75 65 63 85 83 0 0 4 4 0 0 0 0 8 8 8 8 M 12 x 1 x 50 M 12 x 1 x 50 M 12 x 1 x 50 M 12 x 1 x 50 M 18 x 1 x 30 M 18 x 1 x 30 M 18 x 1 x 50 M 18 x 1 x 50 M 18 x 1 x 30 M 18 x 1 x 30 M 18 x 1 x 50 M 18 x 1 x 50 Type EI 3010 TB..S EI 3010 TB..S-6 EI 3010 TB..L EI 3010 TB..L-6 EI 3015 TB..S EI 3015 TB..S-6 EI 3015 TB..L EI 3015 TB..L-6 A B mm C mm 59 55.5 79 75.5 87.5 67.5 91 71 0 0 0 0 12 12 12 12 M 30 x 1.5 x 30 M 30 x 1.5 x 30 M 30 x 1.5 x 50 M 30 x 1.5 x 50 M 30 x 1.5 x 30 M 30 x 1.5 x 30 M 30 x 1.5 x 50 M 30 x 1.5 x 50 A A 3 1 2 M12x1 B Cable type 2 C LED B C LED Plug type Specifications are subject to change without notice (20.08.01) EI, AC, M12, M18, M30 Installation Hints To avoid interference from inductive voltage/ current peaks, separate the prox. switch power cables from any other power cables, e.g. motor, contactor or solenoid cables Relief of cable strain Protection of the sensing face Switch mounted on mobile carrier A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Incorrect Correct The cable should not be pulled Wiring Diagrams Power Supplies Power supplies VAC: 2 BN 2 BN 3 BU 3 BU TBCS > SS 110 TBOS Specifications are subject to change without notice (20.08.01) 3
EI3010TBOSS 价格&库存
很抱歉,暂时无法提供与“EI3010TBOSS”相匹配的价格&库存,您可以联系我们找货
EI3010TBOSS
    • 1+1277.37500
    EI3010TBOSS
      • 1+946.43530
