ICB12S23F04PO
ICB12S23F04PO
    CARLOGAVAZZI
    Cylinder,Threaded-M12
    SENSOR PROX INDUCTIVE 4MM CYLIND
ICB12S23F04PO 数据手册
 ICB, M12 - Extra short body version Proximity inductive sensors with extended range and nickel-plated brass housing Benefits • • • • • • • • • • • • Sensing distance: 4 to 8 mm Flush or non-flush types Extra short body versions Rated operational voltage (Ub): 10 - 36 VDC Output: DC 200 mA, NPN or PNP Normally open or Normally closed LED indication for output ON Protection: reverse polarity, short circuit, transients Cable or M12 plug versions According to IEC 60947-5-2 Laser engraved on front cap, permanently legible Extended temperature range of -25°C to +70°C Description A family of inductive proximity switches in industrial standard nickel-plated brass housings. They are characterized by extremely high performance in a very small design, to satisfy the most demanding applications, also where the space available for the sensor is limited and extended sensing range is requested. Output is open collector NPN or PNP transistors. 04/07/2019 ICB12S23_3-wire_DS_EN Carlo Gavazzi Automation S.p.A. 1 ICB, M12 - Extra short body version  References Order code ICB12S23 Enter the code option instead of Code ICB 12 S 23 Option F N 04 08 M1 A2 N P O C Description Proximity inductive sensors, nickel-plated brass housing Housing size Housing length Thread length Detection principle: flush mounting Detection principle: non-flush mounting Sensing distance: 4mm Sensing distance: 8mm M12 plug 2 m PVC cable Output type: NPN Output type: PNP Output configuration: normally open Output configuration: normally closed Selection guide Connection Cable Cable Plug Plug 1) 2) Rated operating distance Sn 4 mm 1) 8 mm 2) 4 mm 1) 8 mm 2) Ordering no. NPN, Normally open ICB12S23F04A2NO ICB12S23N08A2NO ICB12S23F04M1NO ICB12S23N08M1NO Ordering no. PNP, Normally open ICB12S23F04A2PO ICB12S23N08A2PO ICB12S23F04M1PO ICB12S23N08M1PO Ordering no. NPN, Normally closed ICB12S23F04A2NC ICB12S23N08A2NC ICB12S23F04M1NC ICB12S23N08M1NC Ordering no. PNP, Normally closed ICB12S23F04A2PC ICB12S23N08A2PC ICB12S23F04M1PC ICB12S23N08M1PC For flush mounting in metal For non-flush mounting in metal 04/07/2019 ICB12S23_3-wire_DS_EN Carlo Gavazzi Automation S.p.A. 2 ICB, M12 - Extra short body version  Structure A B C A B C D A B C D Element A B Component Sensing face 2 nuts C LED D M12 x 1, 4 pin, male connector 04/07/2019 ICB12S23_3-wire_DS_EN Function Flush or non-flush For sensor mounting Yellow LED: Output flashing: short circuit or overload indication For plug versions only Carlo Gavazzi Automation S.p.A. 3 ICB, M12 - Extra short body version  Sensing Detection Assured operating sensing distance (Sa) Effective operating distance (Sr) Usable operating distance (Su) Differential travel (H) (Hysteresis) 0 ≤ Sa ≤ 0.81 x Sn 0.9 x Sn ≤ Sr ≤ 1.1 x Sn 0.9 x Sr ≤ Su ≤ 1.1 x Sr 1 to 20% of sensing dist. Correction factors The specific operating distance Sn refers to defined measuring conditions. The following data have to be considered as general guidelines. Fe360: steel CrNi: chrome-nickel CuZn: brass Al: aluminium Cu: copper Sr: effective operating distance Fig. 1 The rated operating distance is reduced by the use of metals and alloys other than Fe360. The most important reduction factors for inductive proximity sensors are shown in the figure. Accuracy Repeat accuracy (R) 04/07/2019 ICB12S23_3-wire_DS_EN ≤ 10% Carlo Gavazzi Automation S.p.A. 4 ICB, M12 - Extra short body version  Features Power Supply Rated operational voltage (Ub) Ripple (Urpp) No load supply current (Io) Power ON delay (tv) 10 to 36 VDC (ripple incl.) ≤ 10% ≤ 16 mA ≤ 40 ms Outputs Output current (Ie) OFF-state current (Ir) Voltage drop (Ud) Protection Voltage transient ≤ 200 mA ≤ 50 μA Max. 2.5 VDC @ 200 mA Reverse polarity, short-circuit, transients 1 kV/0.5 J Response times Max. operating frequency (f) ≤ 2000 Hz Indication Indication for output ON NO version NC version Indication for short circuit/ overload Activated LED, yellow Target present Target not present LED blinking (f = 2 Hz) Environmental Ambient temperature Operating Storage Shock and vibration Degree of protection 04/07/2019 ICB12S23_3-wire_DS_EN -25° to +70°C (-13° to +158°F) -25° to +80°C (-13° to +176°F) IEC 60947-5-2/7.4 IP67 Carlo Gavazzi Automation S.p.A. 5 ICB, M12 - Extra short body version  Compatibility and conformity Power frequency magnetic fields EMC protection - According to IEC 60947-5-2 IEC 61000-4-2 8 kV air discharge, 4 kV contact discharge IEC 61000-4-3 3 V/m IEC 61000-4-4 2 kV IEC 61000-4-6 3V IEC 61000-4-8 30 A/m MTTFd 3090 years @ 50°C (122°F) Electrostatic discharge (ESD) Radiated radio frequency Burst immunity Conducted radio frequency Approvals CCC is not required for products rated ≤ 36 V Mechanical data Weight (cable/nuts included) Mounting Material Tightening torque Max. 68 g Flush or non flush mountable Body: nickel-plated brass Front: grey thermoplastic polyester 10 Nm Electrical connection Cable Plug 04/07/2019 ICB12S23_3-wire_DS_EN Ø 4.1 x 2 m, 3 x 0.25 mm2, grey PVC, oil proof M12 x 1 Carlo Gavazzi Automation S.p.A. 6 ICB, M12 - Extra short body version  Connection Diagrams 1 BN + + 1 BN 2 BK 4 BK 3 BU 3 BU - Fig. 2 NPN - Normally open 1 BN - Fig. 3 NPN - Normally closed + 1 BN + 4 BK 2 BK 3 BU 3 BU - Fig. 4 PNP - Normally open BN: brown 04/07/2019 ICB12S23_3-wire_DS_EN - Fig. 5 PNP - Normally closed Colour code BK: black BU: blue Carlo Gavazzi Automation S.p.A. 7 ICB, M12 - Extra short body version  Dimensions LED M12X1 M12X1 LED 4 23 25 23 29 Fig. 6 Short body, flush version, cable Fig. 7 Short body, non-flush version, cable LED (4 x 90°) M12X1 M12X1 LED (4 x 90°) 10 23 4 23 10 40 44 Fig. 8 Short body, flush version, plug Fig. 9 Short body, non-flush version, plug 4 1 04/07/2019 ICB12S23_3-wire_DS_EN 3 2 4 1 3 2 Carlo Gavazzi Automation S.p.A. 8 ICB, M12 - Extra short body version  Installation d ≥ 3 x Sn d ≥ 2 x Sn d ** Fig. 10 Flush sensor, when installed in damping material ≥ 3 x Sn d ≥3xd d ** Fig. 12 Non-flush sensor, when installed in damping material Fig. 11 Flush sensors, when installed together in damping material d d 2xd d d Fig. 13 Non-flush sensors, when installed together in damping material ** Free zone or non-damping material Sn: nominal sensing distance d: sensor diameter: 12 mm 04/07/2019 ICB12S23_3-wire_DS_EN Carlo Gavazzi Automation S.p.A. 9 ICB, M12 - Extra short body version  Sensors installed opposite each other ≥ 6 x Sn Fig. 14 For sensors installed opposite each other, a minimum space of 6 x Sn (the nominal sensing distance) must be observed Delivery contents • Inductive proximity switch • 2 nuts • Packaging: plastic bag COPYRIGHT ©2019 Content subject to change. Download the PDF: www.productselection.net 04/07/2019 ICB12S23_3-wire_DS_EN Carlo Gavazzi Automation S.p.A. 10
ICB12S23F04PO 价格&库存
很抱歉,暂时无法提供与“ICB12S23F04PO”相匹配的价格&库存,您可以联系我们找货
ICB12S23F04PO
    • 1+840.19249
    库存:3
    ICB12S23F04PO
      • 1+615.06929
      库存:3
