NBB2-8GH20-E2-V3
NBB2-8GH20-E2-V3
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M8
    INDUCTIVE SEN 2MM PNP
NBB2-8GH20-E2-V3 数据手册
Inductive sensor NBB2-8GH20-E2-V3 < < < < Increased operating distance Short version Materials used compliant with FDA Housing with stainless steel (V4A; 1.4435) Dimensions M8 x 1 30 20 6 4 13 LED Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 216679_eng.pdf M8 x 1 Technical Data General specifications Switching function Normally open (NO) Output type PNP Rated operating distance sn 2 mm Installation flush Output polarity DC Assured operating distance sa 0 ... 1.62 mm Reduction factor rAl 0.25 Reduction factor rCu 0.2 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NBB2-8GH20-E2-V3 Technical Data Reduction factor r304 0.63 Reduction factor rBrass 0.31 Nominal ratings Operating voltage UB 10 ... 30 V Switching frequency f 0 ... 1500 Hz Hysteresis H typ. 5 % Reverse polarity protection reverse polarity protected Short-circuit protection pulsing Voltage drop Ud ≤3V Operating current IL 0 ... 100 mA Off-state current Ir 0 ... 0.5 mA typ. 10 µA at 25 °C No-load supply current I0 ≤ 15 mA Switching state indicator Multihole-LED, yellow Functional safety related parameters MTTFd 2750 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type M8 x 1 connector, 3-pin Housing material Stainless steel 1.4435 / AISI 316L Sensing face LCP, (conforms with FDA) Degree of protection IP67 Mass 10 g Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 216679_eng.pdf Connection 1 L+ 4 3 L- Connection Assignment 4 1 3 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NBB2-8GH20-E2-V3 Wire colors in accordance with EN 60947-5-2 1 3 4 BN BU BK (brown) (blue) (black) Accessories Mounting flange, 8 mm V3-WMV4A-5M-PUR Female cordset single-ended, M8, stainless steel V4A, 3-pin, PUR cable V3-WM-2M-PUR Female cordset single-ended, M8, 3-pin, PUR cable Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 216679_eng.pdf BF 8 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NBB2-8GH20-E2-V3 价格&库存
很抱歉,暂时无法提供与“NBB2-8GH20-E2-V3”相匹配的价格&库存,您可以联系我们找货
