Product data sheet
IMB08-02BPSVU2K
IMB
INDUCTIVE PROXIMITY SENSORS
IMB08-02BPSVU2K | IMB
A
B
C
D
E
F
Ordering information
Type
Part no.
IMB08-02BPSVU2K
1072697
Included in delivery: BEF-MU-M08N (1)
Other models and accessories
www.sick.com/IMB
Illustration may differ
Detailed technical data
H
I
J
K
L
M
N
O
P
Q
R
S
T
Features
Housing
Cylindrical thread design
Housing
Short-body
Thread size
M8 x 1
Diameter
Ø 8 mm
Sensing range Sn
2 mm
Safe sensing range Sa
1.62 mm
Installation type
Flush
Switching frequency
4,000 Hz
Connection type
Cable, 3-wire, 2 m
Switching output
PNP
Output function
NO
Electrical wiring
DC 3-wire
Enclosure rating
IP68 1)
IP69K 2)
Special features
Resistant against coolant lubricants, Visual adjustment indicator, IO-Link, Temperature resistance
Special applications
Zones with coolants and lubricants, Mobile machines, Difficult application conditions
1)
2)
2
According to EN 60529.
According to ISO 20653:2013-03.
INDUCTIVE PROXIMITY SENSORS | SICK
Product data sheet | 2021-11-26 15:21:34
Subject to change without notice
Mechanics/electronics
Supply voltage
10 V DC ... 30 V DC
Ripple
≤ 10 %
Voltage drop
≤ 2 V 1)
Current consumption
10 mA 2)
Hysteresis
3 % ... 20 %
Reproducibility
≤ 2 % 3) 4)
Temperature drift (of Sr)
± 10 %
EMC
According to EN 60947-5-2
Continuous current Ia
≤ 200 mA
Cable material
PUR
Short-circuit protection
Reverse polarity protection
Power-up pulse protection
Shock and vibration resistance
100 g / 11 ms / 1000 cycles; 150 g / 1 Mio cycles; 10 Hz ... 55 Hz, 1 mm / 55 Hz ... 500 Hz /
15 g
Ambient operating temperature
–40 °C ... +100 °C
Housing material
Stainless steel V2A, DIN 1.4305 / AISI 303
Sensing face material
Plastic, LCP
Housing length
32 mm
Thread length
28 mm
Tightening torque, max.
Typ. 7 Nm 5)
Typ. 14 Nm 6)
Items supplied
Mounting nut, V2A stainless steel, with locking teeth (2x)
Protection class
III
UL File No.
E181493
1)
2)
3)
4)
5)
6)
At Ia max.
Without load.
Ub and Ta constant.
Of Sr.
When using the non-toothed side of the nut.
Valid if toothed side of nut is used.
Safety-related parameters
MTTFD
1,971 years
DCavg
0 %
Communication interface
IO-Link V1.0
Communication Interface detail
COM2 (38,4 kBaud)
Process data length
1 Byte
Process data structure
Bit 0 = Sr reached
Bit 1 = Sa reached
2021-11-26 15:21:34 | Product data sheet
Subject
3
A
B
C
D
E
F
Reduction factors
Note
The values are reference values which may vary
St37 steel (Fe)
1
Stainless steel (V2A, 304)
Approx. 0.74
Aluminum (Al)
Approx. 0.43
Copper (Cu)
Approx. 0.33
Brass (Br)
Approx. 0.46
Installation note
Remark
Associated graphic see "Installation"
B
6.5 mm
C
8 mm
D
6 mm
F
16 mm
Classifications
H
I
J
K
L
M
N
O
P
Q
R
S
T
ECl@ss 5.0
27270101
ECl@ss 5.1.4
27270101
ECl@ss 6.0
27270101
ECl@ss 6.2
27270101
ECl@ss 7.0
27270101
ECl@ss 8.0
27270101
ECl@ss 8.1
27270101
ECl@ss 9.0
27270101
ECl@ss 10.0
27270101
ECl@ss 11.0
27270101
ETIM 5.0
EC002714
ETIM 6.0
EC002714
ETIM 7.0
EC002714
ETIM 8.0
EC002714
UNSPSC 16.0901
39122230
Installation note
Flush installation
F
B
C
D
4
Connection diagram
Cd-452
BN
+ (L+)
BK
BU
NO/C
- (M)
Characteristic curve
Response diagram
Distance in mm (inch)
8
(0.31)
4
(0.16)
(0.16)
8
(0.31)
1
1.5
2
(0.02)
(0.04)
(0.06)
(0.08)
Sn in mm (inch)
Adjustments
Installation aid
Q
LED
Distance
of target
Sr
Sa=0.81 Sn
Dimensional drawing (Dimensions in mm (inch))
IMB08 Short-body housing, cable, flush
32 (1.26)
28 (1.1)
Subject
(0.12)
Ø 3.0
M8x1
1.7 (0.07)
5
A
B
C
D
E
F
H
I
J
K
L
M
N
O
P
Q
R
S
T
Recommended accessories
www.sick.com/IMB
Brief description
Type
Part no.
Mounting plate for M8 sensors, steel, zinc coated, without mounting hardware
BEF-WG-M08
5321722
Mounting bracket for M8 sensors, steel, zinc coated, without mounting hardware
BEF-WN-M08
5321721
Head A: female connector, M12, 4-pin, straight
Head B: Cable: unshielded
DOS-1204-GN
6028357
Head A: female connector, M12, 4-pin, angled
DOS-1204-WN
6028358
Head A: male connector, M12, 4-pin, straight
STE-1204-GN
6028359
For 2 cable connections
STE-1204-TN
6028360
Mounting brackets and plates
Plug connectors and cables
Recommended services
Additional services
www.sick.com/IMB
Type
Part no.
Function Block Factory
On request
• Description: The Function Block Factory supports common programmable logic controllers
(PLCs) from various manufacturers, such as Siemens, Beckhoff, Rockwell Automation and
B&R. More information on the FBF can be found here.
6
Online data sheet
SICK at a glance
SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely
and efficiently, protecting individuals from accidents and preventing damage to the environment.
We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in
Europe, Asia and North America, system solutions are tested and optimized in accordance with customer
specifications. All this makes us a reliable supplier and development partner.
Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity.
For us, that is “Sensor Intelligence.”
Worldwide presence:
Contacts and other locations – www.sick.com
SICK AG | Waldkirch | Germany | www.sick.com
很抱歉,暂时无法提供与“IMB08-02BPSVU2K”相匹配的价格&库存,您可以联系我们找货
