T30 Sensors AC-Voltage Series
Quick Start Guide
Self-Contained, AC-Operated Sensors
For complete technical information about this product, including installation instructions, application requirements and guidelines,
EU Declaration of Conformity, technical specifications, and accessories, see www.bannerengineering.com and search 121523.
WARNING: Not To Be Used for Personnel Protection
Never use this device as a sensing device for personnel protection. Doing so
could lead to serious injury or death. This device does not include the selfchecking redundant circuitry necessary to allow its use in personnel safety
applications. A sensor failure or malfunction can cause either an energized or
de-energized sensor output condition.
Models
Model1
Sensing Mode
Output
T303E
OPPOSED
P
Range
LED
60 m (200 ft)
Infrared, 950 nm
6 m (20 ft)
Visible red, 680 nm
T30AW3R
LO
T30RW3R
DO
T30AW3LP
LO
T30RW3LP
DO
POLAR RETRO
FIXED-FIELD
T30AW3FF200
LO
T30RW3FF200
DO
T30AW3FF400
LO
T30RW3FF400
DO
T30AW3FF600
LO
T30RW3FF600
DO
200 mm (8 in) cutoff
400 mm (16 in) cutoff
Infrared, 880 nm
600 mm (24 in) cutoff
Wiring Diagrams
Cabled Emitters
Quick Disconnect Emitters (4-pin Micro-Style)
rd/bk
20-250 V ac
rd/wh
bn
20-250V ac
bu
rd
No Connection
gn
All Other Cabled Models
All Other Quick Disconnect Models (4-pin Micro-Style)
bn
rd/bk
20-250V ac
bu
bk
rd/wh
rd
Load
gn
20-250 V ac
Load
No Connection
1 Standard 2 m (6.5 ft) cable models are listed.
9 m (30 ft) cable: add suffix “W/30” (for example, T303E W/30).
4-pin Micro-style integral QD: add suffix “Q1” (for example, T303EQ1). A model with a QD connector requires a mating cable.
Original Document
116162 Rev. C
2 October 2018
116162
Specifications
Output Protection Circuitry
Protected against false pulse on power-up
Supply Voltage and Current
20 V ac to 250 V ac (50 Hz to 60 Hz)
Average current: 20 mA
Peak current:
200 mA at 20 V ac
500 mA at 120 V ac
750 mA at 250 V ac
Output Response
Time Opposed mode: 16 ms ON, 8 ms OFF
Other models: 16 ms ON and OFF
Note: 100 ms delay on power-up; outputs do not
conduct during this time.
Supply Protection Circuitry
Protected against transient voltages
Output Configuration
SPST solid-state ac switch; three-wire hookup; light operate or dark
operate, depending on model
Light Operate: Output conducts when sensor sees its own (or the emitter’s)
modulated light
Dark Operate: Output conducts when the sensor sees dark
Output Rating
300 mA maximum (continuous)
Fixed-Field models: derate 5 mA/°C above +50° C (+122° F)
Inrush capability: 1 amp for 20 ms, non-repetitive
OFF-state leakage current: < 100 mA
ON-state saturation voltage: 3 V at 300 mA ac; 2 V at 15 mA ac
Required Overcurrent Protection
WARNING: Electrical connections must be
made by qualified personnel in accordance with
local and national electrical codes and
regulations.
Overcurrent protection is required to be provided by end product
application per the supplied table.
Overcurrent protection may be provided with external fusing or via Current
Limiting, Class 2 Power Supply.
Supply wiring leads < 24 AWG shall not be spliced.
For additional product support, go to www.bannerengineering.com.
Supply Wiring (AWG)
Required Overcurrent Protection (Amps)
22
3.0
24
2.0
26
1.0
28
0.8
30
0.5
Repeatability
Opposed mode: 2 ms
Other models: 4 ms
Repeatability and response are independent of signal strength
Indicators
Two LEDs (Green and Amber)
Green ON steady: power to sensor is ON
Amber ON steady: sensor sees light
Amber flashing: excess gain marginal (1 to 1.5 times) in light condition
Construction
PBT polyester housing; polycarbonate (opposed-mode) or acrylic lens
Environmental Rating
Leakproof design rated NEMA 6P, DIN IP69K
Connections
2 m (6.5 ft) integral PVC cable, or Integral 4-pin Micro-style quick disconnect
Operating Conditions
Temperature: –40 °C to +70 °C (–40 °F to +158 °F)
Humidity: 90% at +50 °C maximum relative humidity (non-condensing)
Vibration and Mechanical Shock
All models meet MIL-STD-202F, Method 201A (Vibration: 10 Hz to 60 Hz
maximum, 0.06 inch (1.52 mm) double amplitude, 10G acceleration)
requirements. Method 213B conditions H&I. (Shock: 75G with unit
operating; 100G for non-operation)
Certifications
Banner Engineering Corp. Limited Warranty
Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or
replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not
cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product.
THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF
MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE.
This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO
BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES
RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT,
STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE.
Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously
manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the
product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will
void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at
any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to:
For patent information, see www.bannerengineering.com/patents.
© Banner Engineering Corp. All rights reserved
