SM312DSC W/10
SM312DSC W/10
    BANNER
    SM312DSC W/10 SHIELDED CABLE
SM312DSC W/10 数据手册
MINI-BEAM dc-Voltage Series Self-contained photoelectric sensors Models Sensing Mode Range Opposed Emitter Opposed Receiver OPPOSED Opposed Emitter - Long Range Opposed Receiver - Long Range OPPOSED LED Model SM31E 3 m (10 ft) Infrared 880 nm 30 m (100 ft) SM31R SM31EL SM31RL Opposed Emitter - Clear Plastic Detection 0 to 300 mm (0 to 12 in) Actual range varies, Opposed Receiver - Clear Plastic Detec- depending on the light transmission properties of the plastic material being sensed. tion SM31EPD SM31RPD Visible Red 650 nm Non-Polarized Retroreflective 5 m (15 ft) SM312LV Polarized Retroreflective 55 mm to 2 m (2 in to 7 ft) SM312LVAG Extended-Range Polarized Retroreflective 10 mm to 3 m (0.4 in to 10 ft) SM312LP 380 mm (15 in) SM312D 300 mm (12 in) SM312DBZ RETRO P POLAR RETRO Diffuse DIFFUSE Divergent Diffuse CONVERGENT 130 mm (5 in) Infrared 880 nm 16 mm (0.65 in) Focus SM312C 43 mm (1.7 in) Focus SM312C2 16 mm (0.65 in) Focus 43 mm (1.7 in) Focus CONVERGENT Convergent SM312CV Visible Red 650 nm 16 mm (0.65 in) Focus 49 mm (1.9 in) Focus CONVERGENT 49 mm (1.9 in) Focus Glass Fiber Optic GLASS FIBER Range varies, depending on sensing mode and fiber optics used. Plastic Fiber Optic PLASTIC FIBER SM312CV2B SM312CVG Visible Green 525 nm SM312CV2G Infrared 880 nm SM312F Visible Red 650 nm SM312FV Visible Blue 475 nm SM312FVB Visible Green 525 nm SM312FVG Visible Red 650 nm SM312FP Visible Blue 475 nm SM312FPB Visible Green 525 nm SM312FPG Special High-Power Option Plastic Fiber Optic Visible Red 650 nm Standard 2 m (6.5') cable models are listed. • 9 m (30') cable: add suffix “W/30” (e.g., SM31EW/30). • 4-pin Euro QD models: add suffix “QD” (e.g., SM31EQD). • 150 mm (6") QD Pigtail: add suffix “QDP” (e.g., SM31EQDP). For a 0.3 ms response: add suffix “MHS” (eg., SM31EMHS). P/N 69943 rev. C SM312CV2 SM312CVB Visible Blue 475 nm 16 mm (0.65 in) Focus CONVERGENT SM312W 6/19/2012 SM312FPH MINI-BEAM dc-Voltage Series Dimensions Models with suffix E, EL, EPD, R, RL, RPD, LV, LVAG, LP, D, C, C2, CV, CV2, CVG, CV2G, CVB, and CV2B 3.2 mm (0.13”) Models with suffix DBZ and W 12.2 mm (0.48”) 3 mm dia Clearance (2) 30.7 mm (1.21”) Bezel 24.1 mm (0.95”) 3 mm dia Clearance (2) 18.0 mm (0.71”) M18 × 1 × 15 mm Thread (Mounting nut supplied) 2 m (6.5’) Cable Mounting peg (6.3 mm dia × 2.5 mm) 39.1 mm (1.54”) 19.1 mm (0.75”) 13.2 mm (0.52”) 27.4 mm (1.08”) 53.3 mm (2.10”) Models with suffix F, FV, FVB, and FVG Models with suffix FP, FPB, FPG, and FPH 3.2 mm (0.13”) M18 x 1 x 19 mm Thread (Mounting Nut Supplied) 30.7 mm (1.21”) 12.2 mm (0.48”) 24.1 mm (0.95”) 3 mm dia clearance (2) Fiber Optic Fitting Fiber Optic Fitting 2 m (6.5’) Cable Mounting Peg (6.3 mm dia × 2.5 mm) 57.5 mm (2.27") 22.3 mm (0.88”) 19.1 mm (0.75”) 31.2 mm (1.23") 42.1 mm (1.66”) QD Models 16.2 mm (0.64”) Sensor Features Gain (Sensitivity) Adjustment Screw 12 mm Thread Quick-disconnect Alignment Indicator Device (AID)* 20.0 mm (0.79”) Light/Dark Operate Select Switch Clockwise: Light Operate (outputs conduct when sensing light is received). Counterclockwise: Dark Operate (outputs conduct when sensing light is not received). *U.S. Patent no. 4356393 2 www.bannerengineering.com - tel: 763-544-3164 P/N 69943 rev. C MINI-BEAM dc-Voltage Series Wiring Diagrams Emitters with Attached Cable All Other Models with Attached Cable bn bn 10-30V dc bu wh – Load All Other Models with Quick Disconnect (4-pin Euro-Style) bn + 10-30V dc – bu Load bk Emitters with Quick Disconnect (4-pin Euro-Style) bn + 10-30V dc – bu + + 10-30V dc – bu wh wh bk bk Load Load The output type for all models is Bipolar NPN/PNP; load 150 mA max., each output. Sensor Mounting and Alignment MINI-BEAM sensors perform most reliably if they are properly aligned and securely mounted. For maximum mechanical stability, mount MINI-BEAM sensors through 18 mm diameter holes by their threaded barrel (where available), or use a mounting bracket. A complete selection of mounting brackets is available. Visit www.bannerengineering.com or contact the factory for information on mounting options. Begin with line-of-sight positioning of the MINI-BEAM sensor to its emitter (opposed-mode sensing) or to its target (all other sensing modes). When using a retroreflective sensor, the target is the retroreflector (“retro target”). For diffuse or convergent sensing modes, the target is the object to be detected. Apply power to the sensor (and to the emitter, if using the opposed mode). Advance the 15-turn Gain control to maximum (clockwise end of rotation) using a small flat-blade screwdriver. The Gain control is clutched at both ends to avoid damage and will “free-wheel” when either endpoint is reached. If the MINI-BEAM sensor is receiving its light signal, the red LED Alignment indicator will be ON and flashing at a rate proportional to the signal strength (faster = more signal). Move the sensor (or retro target, if applicable) up-down-right-left (including angular rotation) to find the center of the movement zone within which the LED indicator remains ON. Reducing the Gain setting reduces the size of the movement zone for more precise alignment. Repeat the alignment motions after each Gain reduction. When optimum alignment is achieved, mount sensor(s) (and the retro target, if applicable) solidly in that position. Increase the Gain to maximum. Test the sensor by placing the object to be detected in the sensing position, then removing it. The Alignment indicator LED should come ON when the sensing beam is established (Light condition) or be ON when the beam is broken (Dark condition). If the Alignment indicator LED stays ON for both sensing conditions, consider the following tips for each sensing mode. Opposed Mode Alignment “Flooding” occurs when a portion of the sensing beam passes around the object to be sensed. “Burn-through” occurs when a portion of the emitter’s light energy passes through a thin or translucent object, and is sensed by the receiver. To correct either problem, do one or more of the following to reduce the light energy: Emitter • Reduce the Gain adjustment on the receiver. • Add an aperture to one or both lenses. (MINI-BEAM apertures, available from Banner, fit neatly inside the lens assembly.) • Intentionally misalign the emitter and receiver. t jec Ob Note: Receiver P/N 69943 rev. C • Light condition: sensor output is ON when there is no object in beam • Dark condition: sensor output is ON when there is an object in beam www.bannerengineering.com - tel: 763-544-3164 3 MINI-BEAM dc-Voltage Series Diffuse Mode Alignment If the Alignment LED does not go OFF when the object is removed from the beam, the sensor is probably detecting light reflected from some background object. To remedy this problem: t jec Ob • Reduce the reflectivity of the background by painting the surface(s) flat-black, scuffing any shiny surface, or drilling a large hole, directly opposite the diffuse sensor. • Move the sensor closer to the object to be detected and reduce the Gain adjustment. Rule of thumb for diffuse sensing: The distance to the nearest background object should be at least three times the sensing distance. Note: • Light condition: sensor output is ON when there is no object in beam • Dark condition: sensor output is ON when there is an object in beam Retroreflective Mode Alignment A highly reflective object may reflect enough light back to a retroreflective sensor to allow that object to slip through the beam, without being detected. This problem is called “proxing,” and the following methods may be used to correct it: tro Re t ge r a T • Position the sensor and retro target so the beam will not strike a shiny surface perpendicular to the sensor lens. • Reduce the Gain adjustment. • Add a polarizing filter (for model SM312LV). Note: • Light condition: sensor output is ON when there is no object in beam • Dark condition: sensor output is ON when there is an object in beam Convergent Mode Alignment The sensing energy of a convergent mode sensor is concentrated at the specified focus point. Convergent mode sensors are less sensitive to background reflections, compared with diffuse mode sensors. However, if background reflections are a problem: w Lo vity ti flec ound e R gr ck a B jec Ob t • Skew the sensor position at a 10° to 25° angle to eliminate direct reflections from shiny background surfaces. • Reduce the reflectivity of the background by painting the surface(s) flat-black, scuffing any shiny surface, or drilling a large hole, directly opposite the sensor. • Reduce the Gain adjustment. Note: • Light condition: sensor output is ON when there is no object in beam • Dark condition: sensor output is ON when there is an object in beam 4 www.bannerengineering.com - tel: 763-544-3164 P/N 69943 rev. C MINI-BEAM dc-Voltage Series Glass Fiber Installation Retaining Clip O-ring 1. Install the O-ring (supplied with the fiber) on each fiber end, as shown in the drawing. 2. While pressing the fiber ends firmly into the ports on the sensor front, slide the U-shaped retaining clip (supplied with the sensor) into the slot in the sensor’s barrel, until it snaps into place. Plastic Fiber Installation Gripper Unlock Lock Sensor Face Adapters for 0.25- and 0.5-mm fibers Trimmed fiber control ends Plastic fiber receiver port Plastic fiber emitter port 1. With supplied fiber cutter, make a clean cut at control ends of fibers. 2. Unlock the fiber gripper as shown below. Apply appropriate fiber adaptors prior to fiber insertion, if needed. 3. Gently insert the prepared fiber ends into the ports, as far as they will go. 4. Slide the fiber gripper back to lock, as shown below. P/N 69943 rev. C www.bannerengineering.com - tel: 763-544-3164 5 MINI-BEAM dc-Voltage Series Specifications Supply Voltage and Current 10 to 30V dc (10% maximum ripple) at less than 25 mA (exclusive of load) Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Configuration Bipolar: One current sourcing (PNP) and one current sinking (NPN) open collector transistor Output Rating 150 mA maximum each output at 25° C, derated to 100 mA at 70° C (derate ≈ 1 mA per ° C) OFF State Leakage Current: less than 1 microamp Output Saturation Voltage (PNP Output): less than 1 volt at 10 mA, less than 2 volts at 150 mA Output Saturation Voltage (NPN Output): less than 200 millivolts at 10 mA, less than 1 volt at 150 mA Output Protection Circuitry Protected against false pulse on power-up and continuous overload or short-circuit of outputs Output Response Time Sensors will respond to either a “light” or “dark” signal of 1 millisecond or longer duration, 500 Hz maximum. Modification for 0.3 millisecond response is available (MHS-suffix models; these models also feature reduced sensitivity range and reduced repeatability.) NOTE: Outputs are non-conducting during 100 millisecond delay on power-up. Repeatability Opposed: 0.14 milliseconds Non-Polarized and Polarized Retro, Diffuse, Convergent, Glass Fiber Optic, and Plastic Fiber Optic: 0.3 milliseconds Adjustments Light/Dark Operate Select switch 15-turn slotted brass screw Gain (sensitivity) adjustment potentiometer (clutched at both ends of travel) Located on the rear panel, protected by a gasketed, clear acrylic cover. Indicators Patented alignment Indicator Device system (AID™, US patent #4356393) lights a rear-panel-mounted LED indicator when the sensor sees light. Its pulse rate is proportional to the light signal strength (the stronger the signal, the faster the pulse rate). Construction Reinforced thermoplastic polyester housing, totally encapsulated, o-ring sealing, acrylic lenses, stainless steel screws Environmental Rating Meets NEMA standards 1, 2, 3, 3S, 4, 4X, 6, 12, and 13; IEC IP67. Connections PVC-jacketed 4-conductor 2 m (6.5') or 9 m (30') cables, or 4-pin Eurostyle QD fitting; QD cables available separately Operating Conditions Temperature: –20° to +70°C (–4° to +158°F) Maximum relative humidity: 90% at 50°C (non-condensing) Application Note The NPN (current sinking) output of dc MINI-BEAM sensors is directly compatible as an input to Banner logic modules, including all non-amplified MAXI-AMP and MICRO-AMP modules. MINI-BEAMs are TTL compatible. Certifications Response time and repeatability specifications are independent of signal strength. WARNING: Not To Be Used for Personnel Protection Never use this product as a sensing device for personnel protection. Doing so could lead to serious injury or death. This product does NOT include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Banner Engineering Corp Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp.
SM312DSC W/10 价格&库存
很抱歉,暂时无法提供与“SM312DSC W/10”相匹配的价格&库存,您可以联系我们找货
