SFEM016GB1EA1TO-I-GE-111-STD 数据手册
Product Fact Sheet
Industrial
eMMC Memory
EM-26 Series
JEDEC eMMC 5.0 compliant,
BGA 153 ball, Enhanced Mode (pSLC)
Industrial Temperature Grade
Date:
Revision:
December 02, 2019
1.02
Embedded MMC 5.0
EM-26 Industrial eMMC Memory 2GB to 32GB
Main Features
Fully compliant with JEDEC eMMC 5.0 Standard (JESD84-B50)
153-ball BGA, 0.5mm pitch
11.5 x 13mm, RoHS compliant
Single partition
High performance eMMC 5.0 specification
o Eleven-wire bus (clock, Data Strobe, 1 bit command, 8 bit data bus) and a hardware reset
o Three different data bus width modes: 1-bit (default), 4-bit, and 8-bit
o Clock frequencies 0-200MHz, High Speed Mode HS400
o Up to 270MB/s sequential read and up to 160MB/s sequential write
Power Supply: (Low-power CMOS technology)
o VCCQ 1.7V…1.95V or 2.7V…3.6V eMMC supply
o VCC 2.7V…3.6V NAND Flash supply
Optimized FW algorithms
o Power-fail data loss protection
o Wear Leveling technology
Equal wear leveling of static and dynamic data. The wear leveling assures that dynamic data as
well as static data is balanced evenly across the memory. With that the maximum write
endurance of the device is guaranteed
o Read Disturb Management
The read commands per region are monitored and the content is conditionally refreshed when
critical levels have occurred
o Auto Read Refresh
The interruptible background process maintains the user data for Read Disturb effects or Retention
degradation due to high temperature effects
o Diagnostic features with Device Health Report according to eMMC Spec 5.0, and new Firmware
FW2 with detailed Lifetime Monitor data.
o Field Firmware update according to eMMC Spec 5.0
o Discard and Sanitize, Trim
o Boot Operation Mode and Alternative Boot Operation Mode
o Replay Protected Memory Block (RPMB)
High reliability
o Designed with sophisticated firmware architecture for industrial and embedded markets.
o Enhanced Mode (pSLC) with higher write performance and endurance than MLC configured
products (EM-20).
o Ideal for application like POS/POI, PLC, IoT, gaming, medical and use as general boot medium for
embedded applications.
o The product is optimized for long life cycle that requires superior data retention as well as power
fail safety.
o Industrial Temperature range, -40° up to 85°C
Controlled BOM & PCN process
Swissbit AG
Industriestrasse 4
CH-9552 Bronschhofen
Switzerland
Revision: 1.02
www.swissbit.com
industrial@swissbit.com
EM-26_Fact_Sheet_Rev102
Page 2 of 3
Order Information for EM-26
Density
Part Number
2GB
SFEM4096B1EA1TO-I-GE-111-E02
4GB
SFEM008GB1EA1TO-I-GE-111-E04
8GB
SFEM016GB1EA1TO-I-GE-111-E08
16GB
SFEM032GB1EA1TO-I-LF-111-E16
32GB
SFEM064GB1EA1TO-I-HG-111-E32
2GB
SFEM2048B1EA1TO-I-GE-12P-STD
4GB
SFEM4096B1EA1TO-I-GE-12P-STD
8GB
SFEM008GB1EA1TO-I-GE-12P-STD
16GB
SFEM016GB1EA1TO-I-LF-12P-STD
32GB
SFEM032GB1EA1TO-I-HG-12P-STD
Temp. Range
Firmware
Flash Technology
-40°C to 85°C
FW1: default
pSLC NAND Flash
-40°C to 85°C
FW2: detailed
Lifetime Monitor
data
pSLC NAND Flash
System Performance
System Performance
Typ. Sustained
Max. Enhanced Mode
Sequential Read
178
up to 270
Sequential Write
60
up to 160
Write
Typ. ICCQ current
@ VCCQ 1.8V
110
Typ. ICC current
@ VCC 3.3V
83
Read
178
37
Idle
0.2
Burst Data transfer Rate HS400 (max clock 200MHz)
Current Consumption, 32GB device, HS400
Unit
400
MB/s
Unit
mA
Physical Dimensions
Physical Dimensions
Value
Length
13±0.1
Width
11.5±0.1
Thickness
1.0 max.
Unit
mm
Recommended Temperature Conditions
Parameter
Min.
Typ.
Max.
Unit
Industrial Operating Temperature
-40
25
85*
°C
Storage Temperature
-40
25
85*
°C
* High temperature storage without operation reduces the data retention, in operation the data will be refreshed, if data error issues
were detected.
For more information on eMMC interface, please visit JEDEC homepage (www.jedec.org)
Why Swissbit?
Swissbit strives to create innovative technologies for future market opportunities utilizing a highly skilled inhouse product research and development team. Swissbit maintains a marketing edge by continuing to
manufacture world-class high quality memory products and providing customers with both high value and
low cost of ownership achieved through efficient processes and procedures.
Swissbit AG
Industriestrasse 4
Switzerland
Revision: 1.02
www.swissbit.com
Page 3 of 3
SFEM016GB1EA1TO-I-GE-111-STD 价格&库存
很抱歉,暂时无法提供与“SFEM016GB1EA1TO-I-GE-111-STD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 152+279.59840152+33.63300
- 304+266.66803304+32.07760
- 456+253.73765456+30.52220
- 608+227.87690608+27.41140
