EP1820NPAS
EP1820NPAS
    CARLOGAVAZZI
    SENSOR REFLECTIVE 2M NPN
EP1820NPAS 数据手册
Photoelectrics Retro-reflective, Polarized Type EP 1820, DC, PBTP-housing • Range: 2.0 m • Modulated red light, polarized • Supply voltage: 10 to 40 VDC • Output: 200 mA NPN or PNP • Make and break switching functions, LED, indication • Protection: Reverse polarity, short-circuit, transients • Improved immunity to reflecting surfaces • Heavy duty M18 metal housing, IP67 • Cable and plug versions Product Description The EP1830 is a family of general purpose polarized retro-reflective sensors in a short M18 metal housing for heavy duty applications. They are useful for simple applications, where a basic sensor Ordering Key provides adequate sensing performance. The sensors are easy to adjust with a 270° single turn potentiometer. The output is a 4-wire complementary NO or NC thyristor (SCR) output. Type Housing diameter Range Output type Housing material Connection type EP 18 20 NPA S-1 Type Selection Housing diameter Rated operating dist. (Sn) Connection Ordering no. NPN Make & break switching Ordering no. PNP Make & break switching M18 M18 2.0 m 2.0 m Cable Plug EP 1820 NPAS EP 1820 NPAS-1 EP 1820 PPAS EP 1820 PPAS-1 Light source Light type Optical angle Light spot size Ambient light Operating frequency (f) GaAlAs LED, 660 nm Red polarized, modulated ± 2° 150 mm at 2 m Max 5'000 lux Max. 100 Hz, light-dark ratio 1.2 Specifications Rated operating dist. (Sn) Sensitivity Temperature drift Hysteresis (H) (Differential travel) Rated operational volt. (UB) Ripple (Urpp) Output current Continuous (Ie) Short-time (I) No load supply current (IO) Min. operational current (Im) OFF-state current (Ir) Voltage drop (Ud) Protection Transient voltage Power ON delay (tv) Up to 2.0 m Ref. reflector type ER4, Ø 84 mm 270° single turn pot.meter 0.4%/°C 3 to 20 % 10 to 40 VDC (ripple included) Max. 10% ≤ 200 mA 200 mA max. load capacity 100nF Max. 20 mA 0,5 mA Max. 100 µA Max. 2.5 VDC @ 200 mA Reverse polarity, short-circuit, transients 1 kV / 0.5 J Typ. 70 ms Response time OFF-ON (tON) ON-OFF (tOFF) Indication Function Output ON Environment Overvoltage category Pollution degree Degree of protection Temperature Operating Storage Vibration Shock Specifications are subject to change without notice (08.02.06) ≤ 3.2 ms ≤ 5 ms Dark and light (complementary) switch. LED, yellow III (IEC 60664/60664A; 60947-1) 3 (IEC 60664/60664A; 60947-1) IP 67 (IEC 60529; 60947-1) -20° to +60°C (-4° to 140°F) -30° to + 70°C (-22° to 158°F) 10 to 150 Hz, 0.5 mm/7.5 g (IEC 60068-2-6) 2 x 1 m & 100 x 0.5 m (IEC 60068-2-32) 1 EP 1820, DC Dimensions Specifications (cont.) Dielectric voltage Housing material Body Front Cable end Nuts Connection Cable 500 V (IEC 60364-4-41) Plug Cable for plug (M1) Weight Cable version Plug version CE-marking ø 5.2 Nickel plated brass PMMA, red Polyester, black Nickel plated brass Grey, 2 m, 4 x 0.35 mm2, oilproof PVC M12 x 1 CON.1A... series SENSIT 175 g 90 g Yes SENSIT Operation Diagram Power supply Object present, light beam interrupted Output ON: Break switching (NC), WH (2) Make switching (NO), BK (4) Tv Tv Wiring Diagrams Detection Diagram Sensor 1 BN + 1 BN + X 4 BK 2 WH Y ER4 Reflector (feet) 1.6 3.3 4.9 6.6 8.2 10 20.0 0.8 10.0 0.4 2 WH PNP - 0 0.0 NPN -0.4 -10.0 -20.0 0.0 0.5 Installation Hints To avoid interference from inductive voltage/ current peaks, separate the prox. switch power cables from any other power cables, e.g. motor, contactor or solenoid cables Relief of cable strain (inch) 3 BU 3 BU (mm) 4 BK 1.0 1.5 Distance (m) 2.0 2.5 Protection of the sensing face Switch mounted on mobile carrier A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided -0.8 3.0 Incorrect Correct The cable should not be pulled Delivery Contents Accessories • Photoelectric switch ER1820. • 2 nuts • Packaging: Plastic bag • • • • Reflectors: ER series Connector type CON.1A../CON.14NF.. series MB18A APA18-RAR For further information refer to “Accessories”. 2 Specifications are subject to change without notice (08.02.06)
EP1820NPAS 价格&库存
很抱歉,暂时无法提供与“EP1820NPAS”相匹配的价格&库存,您可以联系我们找货
