Product data sheet
WTF12-3P2441
W12-3
SMALL PHOTOELECTRIC SENSORS
WTF12-3P2441 | W12-3
A
B
C
D
E
F
H
I
J
K
L
M
N
O
P
Q
R
S
T
Ordering information
Type
Part no.
WTF12-3P2441
1041400
Included in delivery: BEF-KH-W12 (2)
Other models and accessories
www.sick.com/W12-3
Illustration may differ
Detailed technical data
Features
Device type
Photoelectric sensors
Sensor/ detection principle
Photoelectric proximity sensor, Foreground suppression
Dimensions (W x H x D)
15.6 mm x 48.5 mm x 42 mm
Housing design (light emission)
Rectangular
Sensing range max.
30 mm ... 500 mm 1)
Sensing range
30 mm ... 500 mm
Type of light
Visible red light
Light source
LED 2)
Light spot size (distance)
Ø 7 mm (300 mm)
Wave length
640 nm
Adjustment
Potentiometer, 5 turns
1)
2)
Object with 90 % reflectance (referred to standard white, DIN 5033).
Average service life: 100,000 h at TU = +25 °C.
Mechanics/electronics
Supply voltage
1)
2)
3)
4)
5)
6)
7)
8)
2
10 V DC ... 30 V DC 1)
Limit values when operated in short-circuit protected network: max. 8 A.
May not exceed or fall below Uv tolerances.
Without load.
Signal transit time with resistive load.
With light/dark ratio 1:1.
A = VS connections reverse-polarity protected.
C = interference suppression.
D = outputs overcurrent and short-circuit protected.
PHOTOELECTRIC SENSORS | SICK
Product data sheet | 2021-11-16 18:52:29
Subject to change without notice
Ripple
Uv - 2,5 V / ca. 0 V
Output current Imax.
≤ 100 mA
Response time
≤ 330 µs 4)
Switching frequency
1,500 Hz 5)
Connection type
Male connector M12, 4-pin
Circuit protection
A 6)
C 7)
D 8)
Protection class
III
Weight
120 g
Housing material
Metal
Optics material
Plastic, PMMA
Enclosure rating
IP66
IP67
IP69K
Items supplied
2 x clamps BEF-KH-W12, incl. screws
Ambient operating temperature
–40 °C ... +60 °C
Ambient temperature, storage
–40 °C ... +75 °C
UL File No.
NRKH.E181493 & NRKH7.E181493
1)
2)
3)
4)
5)
6)
7)
8)
Without load.
Safety-related parameters
MTTFD
810 years
DCavg
0 %
Classifications
ECl@ss 5.0
27270904
ECl@ss 5.1.4
27270904
ECl@ss 6.0
27270904
ECl@ss 6.2
27270904
ECl@ss 7.0
27270904
ECl@ss 8.0
27270904
ECl@ss 8.1
27270904
2021-11-16 18:52:29 | Product data sheet
Subject
3
A
B
C
D
E
F
ECl@ss 9.0
27270904
ECl@ss 10.0
27270904
ECl@ss 11.0
27270904
ETIM 5.0
EC002719
ETIM 6.0
EC002719
ETIM 7.0
EC002719
ETIM 8.0
EC002719
UNSPSC 16.0901
39121528
Connection diagram
Cd-083
BN
1
WH 2
BU 3
H
I
J
K
L
M
N
O
P
Q
R
S
T
BK 4
+ (L+)
Q
- (M)
Q
Characteristic curve
WTF12-3, 500 mm
–2
3
–4
90%/90%
–6
1
–8
6%/90%
–10
–12
2
–14
18%/90%
–16
–18
–20
mm
100
200
300
400
500
(inch)
(3.94)
(7.87)
(11.81)
(15.75)
(19.69)
Distance in mm (inch)
① Sensing range on black, 6% remission
② Sensing range on gray, 18 % remission
③ Sensing range on white, 90% remission
4
Sensing range diagram
WTF12-3, 500 mm
1
2
3
50
300
50
500
50
200
400
600
800
(7.87)
(15.75)
(23.62)
(31.50)
Sensing range
Adjustments
WTB12-3, WTF12-3, potentiometer
5 4
8
④ LED indicator green: Supply voltage active
⑤ LED indicator yellow: Status of received light beam
⑧ Sensing range adjustment: potentiometer
Subject
5
Dimensional drawing (Dimensions in mm (inch))
24 (0.94)
10 (0.39)
7.3 (0.29)
6.1
(0.24)
7
9
23.1
5.1
15
3
32 (1.26)
1
(0.51)
(0.91)
H
I
J
K
L
M
N
O
P
Q
R
S
T
3.5
12.9
2
39.9 (1.57)
48.5 (1.91)
ø 4.2
(0.91)
7
(0.2)
42 (1.65)
29.9 (1.18)
15.6 (0.61)
(0.14)
6
(0.59)
A
B
C
D
E
F
8
4
5
19.4
(0.76)
① Standard direction of the material being detected
② Optical axis, receiver
③ Optical axis, sender
⑥ M4 threaded mounting hole, 4 mm deep
⑦ Mounting hole, Ø 4.2 mm
⑨ Connection
Recommended accessories
www.sick.com/W12-3
Brief description
Type
Part no.
YF2A14050VB3XLEAX
2096235
STE-1204-G
6009932
Plug connectors and cables
Head A: female connector, M12, 4-pin, straight, A-coded
Head B: Flying leads
Cable: Sensor/actuator cable, PVC, unshielded, 5 m
Head A: male connector, M12, 4-pin, straight
Head B: Cable: unshielded
6
Online data sheet
SICK at a glance
SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely
and efficiently, protecting individuals from accidents and preventing damage to the environment.
We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in
Europe, Asia and North America, system solutions are tested and optimized in accordance with customer
specifications. All this makes us a reliable supplier and development partner.
Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity.
For us, that is “Sensor Intelligence.”
Worldwide presence:
Contacts and other locations – www.sick.com
SICK AG | Waldkirch | Germany | www.sick.com
很抱歉,暂时无法提供与“WTF12-3P2441”相匹配的价格&库存,您可以联系我们找货
