ER1830PPAS-1
ER1830PPAS-1
    CARLOGAVAZZI
    SENSOR RETROREFLECTIVE 3M PNP
ER1830PPAS-1 数据手册
Photoelectrics Retro-reflective Type ER1830.PAS, DC, Metal-housing • • • • • • • • Range: 3 m Modulated infrared light Supply voltage: 10 to 40 VDC Output: 200 mA NPN or PNP Make and break switching function, LED indication Protection: Reverse polarity, short circuit, transients High immunity to ambient light Cable and plug versions Product Description Ordering Key Retro-reflective photoelectric switch with extended range up to 3 m. Easily adjustable sensitivity with 270° potentiometer. LED output indica- Type Housing diameter Range Output type Housing material Connection type tion. Short M18 metal housing for heavy duty applications. IP 67. Easy mounting. DC and AC types, fully protected. ER 18 30 NPA S-1 Type Selection Housing diameter Rated operating dist. (Sn) Ordering no. NPN/cable Make & break swit. Ordering no. NPN/plug Make & break swit. Ordering no. PNP/cable Make & break swit. Ordering no. PNP/plug Make & break swit. M18 3m ER 1830 NPAS ER 1830 NPAS-1 ER 1830 PPAS ER 1830 PPAS-1 Specifications Rated operating dist. (Sn) Sensitivity Adjustable Temperature drift Hysteresis (H) (Differential travel) Rated operational volt. (UB) Ripple (Urpp) Output current Continuous (Ie) Short-time (I) No load supply current (IO) Min. operational current (Im) OFF-state current (Ir) Voltage drop (Ud) Protection Transient voltage Power ON delay (tv) Light source Light type Up to 3 m Ref. reflector type ER4 ∅ 84 mm 270° single turn pot. meter 0.4%/K 3 to 20% 10 to 40 VDC (ripple included) Max. 10% Max. 200 mA 200 mA, max. load capacity 100 nF Max. 20 mA @ 200 mA 0.5 mA Max. 100 μA Max. 2.5 V Reverse polarity, short circuit overload, transients 1 kV/0.5 J Typ. 100 ms GaAlAs LED, 880 nm Infrared, modulated Specifications are subject to change without notice (08.02.06) Optical angle Light spot size Ambient light Operating frequency (f) Response time OFF-ON (tON) ON-OFF (tOFF) Indication function Output ON Environment Overvoltage category Pollution degree Degree of protection Temperature Operating Storage Vibration Shock Dielectric voltage Housing material Body Front Cable end Nuts ± 2.2° 150 mm at 2 m Max. 10,000 lux Max. 120 Hz, light/dark ratio 1:2 ≤ 3.2 ms ≤ 5 ms Dark and light (complementary switch) LED, yellow III (IEC 60664/60664A; 60947-1) 3 (IEC 60664/60664A; 60947-1) IP 67 (IEC 60529; 60947-1) -20° to +60°C (-4° to 140°F) -30° to + 70°C (-22° to 158°F) 10 to 150 Hz, 0.5 mm/7.5 g (IEC 60068-2-6) 2 x 1 m & 100 x 0.5 m (IEC 60068-2-32) 600 VAC (IEC 60364-4-41) Nickel plated brass Luran®, black Polyester, black Nickel plated brass 1 ER1830.PAS, DC Specifications (cont.) Connection Cable Dimensions Grey, 2 m, 4 x 0.35 mm2, oilproof PVC M12 x 1 CON.1A-...series Plug Cables for plug (-1) Weight Cable version Plug version Approvals CE-marking 140 g 55 g UL, CSA Yes Operation Diagram Power supply Object present, light beam interrupted Output ON: Break switching (NC), WH (2) Make switching (NO), BK (4) Tv Tv Detection Diagram Wiring Diagrams Sensor 1 BN + X 4 BK Y ER4 Reflector (feet) 1.6 3.3 4.9 6.6 8.2 9.8 11.5 13 60.0 0.8 30.0 0.4 2 WH (mm) PNP 0 0.0 NPN -30.0 -0.4 -60.0 -0.8 0.0 0.5 1.0 Installation Hints To avoid interference from inductive voltage/ current peaks, separate the prox. switch power cables from any other power cables, e.g. motor, contactor or solenoid cables Relief of cable strain 1.5 2.0 2.5 Distance (m) 3.0 Protection of the sensing face Switch mounted on mobile carrier A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided 3.5 Incorrect Correct The cable should not be pulled Delivery Contents Accessories • Photoelectric switch: ER1830 • 2 nuts • Packaging: plastic bag • • • • Reflectors: ER series Connector type CON.1A../CON.14NF.. series MB18A APA18-RAR For further information refer to "Accessories" 2 Specifications are subject to change without notice (08.02.06) 4.0 (inch) 3 BU
ER1830PPAS-1 价格&库存
很抱歉,暂时无法提供与“ER1830PPAS-1”相匹配的价格&库存,您可以联系我们找货
ER1830PPAS-1
    • 1+1148.51074
    库存:1
