TSSA5U50HE3G
TSSA5U50HE3G
    TAIWANSEMICONDUCTOR(台半)
    DO214AC
    5A, 50V, TRENCH SCHOTTKY RECTIFI
TSSA5U50HE3G 数据手册
TSSA5U50H – TSSA5U60H Taiwan Semiconductor 5A, 50V - 60V Trench Schottky Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified Patented Trench Schottky technology Low power loss, high efficiency Ideal for automated placement High forward surge capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 5 A VRRM 50 - 60 V IFSM 75 A TJ MAX 150 °C Package DO-214AC (SMA) Configuration Single die APPLICATIONS ● ● ● ● ● Low voltage, high freq. inverter DC/DC converter Freewheeling diodes Reverse battery protection Car lighting ● MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AC (SMA) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.060g (approximately) DO-214AC (SMA) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device TSSA5U50H TSSA5U60H 5U50 5U60 UNIT Repetitive peak reverse voltage VRRM 50 60 V Reverse voltage, total rms value VR(RMS) 35 42 V Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 5 A IFSM 75 A TJ - 55 to +150 °C Storage temperature TSTG - 55 to +150 °C 1 Version: A2102 TSSA5U50H – TSSA5U60H Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL Junction-to-lead thermal resistance TSSA5U50H TSSA5U60H Junction-to-ambient thermal resistance TYP UNIT 25 °C/W 28 °C/W 70 °C/W RӨJL RӨJA ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS TSSA5U50H Forward voltage (1) TSSA5U60H TSSA5U50H TSSA5U60H Reverse current @ rated VR (2) SYMBOL IF = 5A, TJ = 25°C VF IF = 5A, TJ = 125°C TJ = 25°C IR TJ = 125°C TYP MAX UNIT 0.44 0.54 V 0.48 0.56 V 0.39 0.49 V 0.44 0.52 V - 300 µA - 50 mA Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING TSSA5UxH DO-214AC (SMA) 7,500 / Tape & Reel Notes: 1. “x” defines voltage from 50V(TSSA5U50H) to 60V(TSSA5U60H) 2 Version: A2102 TSSA5U50H – TSSA5U60H Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 TSSA5U50H 5 CAPACITANCE (pF) 4 3 TSSA5U60H 2 1 1000 100 With heat sink 5mm x 5mm Cu-pad f=1.0MHz Vsig=50mVp-p 10 0 50 75 100 125 0.1 150 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 100 TSSA5U50H TJ=150°C TJ=125°C 1 TJ=100°C 0.1 0.01 TJ=25°C 0.001 10 20 30 40 50 60 70 80 90 100 10 10 TSSA5U50H 1 1 0.1 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) TJ=100°C 0.1 0.01 TJ=25°C 0.001 10 20 30 40 50 60 70 80 90 TJ=25°C 0.1 0.001 0.0 0.1 0.2 0.3 0.3 0.4 0.5 0.6 Pulse width 300μs 1% duty cycle Pulse width 0.4 0.7 0.5 0.8 0.6 0.9 0.7 1 1.1 1.2 1.1 1.2 Fig.6 Typical Forward Characteristics TSSA5U60H TJ=125°C TJ=100°C FORWARD VOLTAGE (V) 100 1 TJ=125°C TJ=125°C TJ=25°C Fig.5 Typical Reverse Characteristics 10 UF1DLW TJ=150°C 0.01 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) TJ=150°C 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 (A) 25 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 1010 TSSA5U60H 1 10.1 UF1DLW TJ=150°C TJ=125°C TJ=125°C TJ=100°C TJ=25°C (A) AVERAGE FORWARD CURRENT (A) 6 TJ=25°C 0.01 0.1 0.001 0.0 0.1 0.2 0.3 0.3 0.4 0.5 0.6 Pulse width 300μs 1% duty cycle Pulse width 0.4 0.7 0.5 0.8 0.6 0.9 0.7 1 FORWARD VOLTAGE (V) 3 Version: A2102 TSSA5U50H – TSSA5U60H Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.7 Maximum Non-Repetitive Forward Surge Current PEAK FORWARD SURGE CURRENT (A) 80 70 8.3ms single half sine wave 60 50 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 4 Version: A2102 TSSA5U50H – TSSA5U60H Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AC (SMA) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: A2102 TSSA5U50H – TSSA5U60H Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: A2102
TSSA5U50HE3G 价格&库存
很抱歉,暂时无法提供与“TSSA5U50HE3G”相匹配的价格&库存,您可以联系我们找货
