AEC Q100 Grade 1 Compliant
FM1106
Nonvolatile 3V Dual State Saver
Features
Nonvolatile State Saver
Logic States Retained in Absence of Power
Outputs Automatically Restored at Power-up
Unlimited Number of State Changes
Max tPD 50ns at 2.7V
Max Frequency 900 kHz
Low Power Operation
Supply voltage of 2.7V to 3.6V
5 A Standby Current (+85C)
Overview
Pin Configuration
The FM1106 is an innovative FRAM-based device
that stores inputs like conventional logic and retains
the stored state in the absence of power. This product
solves three basic problems in an elegant fashion.
First, it provides continuous access to nonvolatile
system settings without performing a memory read
operation or using dedicated processor I/O pins.
Second, it allows the storage of signals that may
change frequently and possibly without notice. Third,
it allows the nonvolatile storage of a system setting
without the system overhead and extra pins of a serial
memory.
Functionally, the inputs are stored and passed to the
output on the rising edge of the clock CLK. This
unique product serves a variety of applications. Here
are a few applications:
Control relays or valves with automatic setting
on power-up without processor intervention
Interface to soft/momentary front-panel switch
and indicator lamp. Capture switch settings and
drive LEDs without processor intervention
Replaces jumpers & control signal routing
Initialize state of I/O card signals
Eliminate the overhead of serial memory for
systems needing only a bit of data
This product conforms to specifications per the terms of the Ramtron
standard warranty. The product has completed Ramtron’s internal
qualification testing and has reached production status.
Rev. 4.0
Oct. 2012
Industry Standard Configuration
Automotive Temperature -40 C to +125 C
o Qualified to AEC Q100 Specification
8-pin “Green”/RoHS SOIC Package
VDD
Q0
D1
1
8
EN
2
7
3
6
CLK
4
5
D0
VSS
Q1
Pin Names
DN
QN
EN
CLK
VDD
VSS
Function
Data In
Data Out
Enable
Clock
Supply Voltage
Ground
Ordering Information
FM1106-GA
FM1106-GATR
Dual State Saver,
8-pin “Green”/RoHS SOIC,
Automotive Grade 1
Dual State Saver,
Automotive Grade 1, Tape&Reel
Ramtron International Corporation
1850 Ramtron Drive, Colorado Springs, CO 80921
(800) 545-FRAM, (719) 481-7000
http://www.ramtron.com
Page 1 of 8
FM1106 - Automotive Temp.
Block Diagram and Truth Table
DN
NV
State
Saver
CLK
EN
QN
EN
H
H
H
L
L
H
X
Q0
INPUTS
CLK
H or L
X
Dn
L
H
X
X
OUTPUT
Qn
L
H
Q0
Hi-Z
Low voltage level
High voltage level
Don’t Care
CLK rising edge
Previous output state before CLK ↑
Pin Descriptions
Pin Name
D 0, D 1
Q 0, Q 1
CLK
EN
VDD
VSS
Rev. 4.0
Oct. 2012
I/O
Input
Output
Input
Input
Supply
Supply
Description
Data inputs
Data outputs
Clock: On a rising edge of CLK, the DN inputs are transferred to the QN outputs. While
CLK is high or low, the QN outputs do not change regardless of the state of the data
inputs. See truth table.
Enable. This active-high input enables the device. When low, inputs are ignored and
updates to the nonvolatile cells are prevented. When high, the device operates
normally.
Power Supply (2.7V to 3.6V)
Ground
Page 2 of 8
Description
Use of Enable Pin
Nonvolatile storage applied to logic is a
revolutionary concept. The FM1106 simplifies the
design of system control functions. This product is
unique because it remembers the stored output
values in the absence of power. Any change in the
latched state is automatically written to a nonvolatile
ferroelectric latch. This function is possible due to
the fast write time and extremely high write
endurance of the underlying ferroelectric memory
technology.
The FM1106 has an enable pin that is intended to be
used in conjunction with a system reset. An activelow reset may be tied directly to the EN pin. At
power-up, /RESET will be held low for some time
during which the data input and CLK pins will be
ignored. Once the system comes out of reset and EN
goes high, the outputs QN drive to the state that were
previously latched and the device operates normally.
When the EN pin is low, the outputs QN are tristated.
The enable pin may be tied to VDD since the device
integrates a power management circuit that monitors
the VDD level during power cycles.
Rev. 4.0
Oct. 2012
Page 3 of 8
Electrical Specifications
Absolute Maximum Ratings
Symbol
Description
VDD
Power Supply Voltage with respect to VSS
VIN
Voltage on any signal pin with respect to VSS
TSTG
TLEAD
VESD
Ratings
-1.0V to +5.0V
-1.0V to +5.0V
and VIN < VDD+1.0V
-55C to + 125C
300 C
Storage temperature
Lead temperature (Soldering, 10 seconds)
Electrostatic Discharge Voltage
- Human Body Model (JEDEC Std JESD22-A114-B)
- Charged Device Model (JEDEC Std JESD22-C101-A)
- Machine Model (JEDEC Std JESD22-A115-A)
Package Moisture Sensitivity Level
4kV
1kV
200V
MSL-1
Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating
only, and the functional operation of the device at these or any other conditions above those listed in the operational section of this
specification is not implied. Exposure to absolute maximum ratings conditions for extended periods may affect device reliability.
DC Operating Conditions (TA = -40 C to +125 C, VDD = 2.7V to 3.6V unless otherwise specified)
Symbol Parameter
Min
Typ
Max
Units
Notes
VDD
2.7
3.6
V
ISB
Standby Current
1
A
5
@ +85C
A
8
@ +125C
CPD
Power Dissipation Capacitance
165
pF
2
ILI
Input Leakage Current
3
1
A
ILO
Output Leakage Current
3
1
A
VIL
Input Low Voltage
-0.3
0.3 VDD
V
VIH
Input High Voltage
0.7 VDD
VDD + 0.3
V
VOH
Output High Voltage
@ IOH = -1 mA
VDD – 0.5
V
VOL
Output Low Voltage
@ IOL = 1 mA (VDD=2.7V)
0.4
V
@ IOL = 10 mA (VDD=2.7V)
0.8
V
VHYS
Input Hysteresis (CLK, EN)
200
mV
4
Notes
1. CLK = VSS, all other inputs at VDD or VSS.
2. To calculate device power dissipation, P D = CPD*VDD2*fi + CL*VDD2*fo, where fi is the input clk freq, fo is the output freq,
3.
4.
and CL is the output load capacitance. Active current IDD may be calculated as IDD = CPD*VDD*fi, assuming outputs are
floating.
VIN or VOUT = VSS to VDD.
This parameter is characterized but not tested.
Capacitance (TA = 25 C , f=1.0 MHz, VDD = 3.3V)
Symbol Parameter
CI
Input Capacitance
Notes
1.
Min
Max
8
Units
pF
Notes
1
Rev. 4.0
Oct. 2012
Page 4 of 8
AC Parameters (TA = -40 C to +125 C, VDD = 2.7V to 3.6V, CL = 30 pF unless otherwise specified)
Symbol Parameter
Min
Max
fMAX
Maximum Clock Frequency
900
tLOW
CLK Low Period
0.3
tHIGH
CLK High Period
0.3
tPD
Propagation delay CLK to QN
50
tHZ
EN Low to QN Hi-Z
25
tR
Input Rise Time
100
tF
Input Fall Time
100
tDS
Data (DN) Setup Time to CLK
5
tDH
Data (DN) Hold Time after CLK
10
tEHD
EN Hold Time (EN High after CLK )
50
tEH
EN High Time
5
tEL
EN Low Time
2
Notes
1. This parameter is characterized but not tested.
Units
kHz
s
s
ns
ns
ns
ns
ns
ns
ns
s
s
Power Cycling and Data Retention (TA = -40 C to +125 C, VDD = 2.7V to 3.6V, unless otherwise specified)
Symbol
Parameter
Min
Max
Units
Nonvolatile Data Retention Time
45
years
tVDR
VDD Rise Time
25
s/V
tVDF
VDD Fall Time
50
s/V
tRES
EN High to QN Restore Time
0.5
s
tPDS
EN Low to Power Down Time
1
s
tEHFC
EN High to First Clock (CLK ) after Power Up
4
s
Notes
1.
2.
3.
Notes
1
1
1
Notes
1
1
2
3
Slope measured at any point on VDD waveform.
After power up, when EN goes high the nonvolatile latches are read and the values restored to the outputs QN.
After power up, this is the minimum time required before a state change operation may occur. EN and VDD may be
coincident at power up, and in this case tEHFC time is referenced to VDD (min) and CLK .
Data Retention (VDD = 3.0V to 3.6V)
Parameter
Min
Max
Units
Notes
Data Retention
45
Years
@ TA = 85C
9000
Hours
@ TA = 125C
Note : The device is guaranteed to retain data after both conditions have been applied : (1) 45 yrs at a temperature
of 85C and (2) 9000 hrs at 125C.
Typical Grade 1 Storage Profile
Typical Grade 1 Operating Profile
25000
1600
1400
20000
1000
Hours
Hours
1200
800
600
400
15000
10000
5000
200
75
80
85
90
95 100 105 110 115 120 125
Temperature (°C)
Rev. 4.0
Oct. 2012
5 10 15 20 25 30 35 40 45 50 55 60 65 70 75 80
Temperature (°C)
Page 5 of 8
AC Test Conditions
Input Pulse Levels
Input Rise and Fall Times
Input and Output Timing Levels
Output Load Capacitance
0.1 VDD to 0.9 VDD
10 ns
0.5 VDD
30pF
FM1106 Signal Timing
tEL
EN
1/fMAX
tEHD
tHIGH
tLOW
tEH
CLK
tDS
tHZ
tDH
D0
DN
D1
tPD
tPD
previous
QN
tRES
Q0
Q1
Q1
t=0
Power Cycle Timing
D8
DLAST
Q7
Q8
QLAST
QLAST
tPDS
EN
VDD
D0
QN
D7
D1
DN
CLK
VDD (MIN)
Q0
Q1
tRES
tEHFC
VDD (MIN)
Rev. 4.0
Oct. 2012
Page 6 of 8
Mechanical Drawing
8-pin SOIC (JEDEC Standard MS-012 variation AA)
Recommended PCB Footprint
7.70
3.90 ±0.10
3.70
6.00 ±0.20
2.00
Pin 1
0.65
1.27
4.90 ±0.10
1.27
0.33
0.51
0.25
0.50
1.35
1.75
0.10
0.25
0.10 mm
0- 8
0.19
0.25
45
0.40
1.27
Refer to JEDEC MS-012 for complete dimensions and notes.
All dimensions in millimeters.
SOIC Package Marking Scheme
XXXXXXX-PT
LLLLLLL
RICYYWW
Legend:
XXXX= part number, P= package type, T= temp (A=automotive grade, blank=ind.)
LLLLLLL= lot code
RIC=Ramtron Int’l Corp, YY=year, WW=work week
Example: FM1106, “Green” SOIC package, Automotive, Year 2008, Work Week 19
FM1106-GA
A80007G
RIC0819
Rev. 4.0
Oct. 2012
Page 7 of 8
Revision History
Revision
1.0
1.1
3.0
4.0
Rev. 4.0
Oct. 2012
Date
11/26/2008
2/3/2009
4/15/2009
4th Oct 2012
Summary
Created automotive temperature spec.
Added tape and reel ordering information.
Changed to Production status. Changed 125C retention time.
Added obsolete text
Page 8 of 8
