C2D05120A
C2D05120A
    WOLFSPEED
    TO220-2
    DIODE SCHOTTKY 1.2KV 5A TO220-2
C2D05120A 数据手册
C2D05120A VRRM = Silicon Carbide Schottky Diode Zero R ecovery® • • • • • • • IF (TC=135˚C) = 8.5 A Rectifier Features 1200 V Qc = 28 nC Package 1.2kV Schottky Rectifier Zero Reverse Recovery Current Zero Forward Recovery Voltage High-Frequency Operation Temperature-Independent Switching Behavior Extremely Fast Switching Positive Temperature Coefficient on VF TO-220-2 Benefits • • • • • Replace Bipolar with Unipolar Rectifiers Essentially No Switching Losses Higher Efficiency Reduction of Heat Sink Requirements Parallel Devices Without Thermal Runaway Applications • • • • Switch Mode Power Supplies Power Factor Correction Motor Drives High Voltage Multipliers Part Number Package Marking C2D05120A TO-220-2 C2D05120 Maximum Ratings (TC=25°C unless otherwise specified) Symbol Parameter Unit Test Conditions VRRM Repetitive Peak Reverse Voltage 1200 V VRSM Surge Peak Reverse Voltage 1200 V VR DC Peak Reverse Voltage 1200 V IF Continuous Forward Current 17.5 8.5 5 A TC=25˚C TC=135˚C TC=157˚C 30 A TC=25˚C, tP=10 ms, Half Sine Wave IFRM Repetitive Peak Forward Surge Current IFSM Non-Repetitive Peak Forward Surge Current 100 A TC=25˚C, tP=10 µs, Pulse Ptot Power Dissipation 136 59 W TC=25˚C TC=110˚C -55 to +175 ˚C 1 8.8 Nm lbf-in TJ , Tstg Operating Junction and Storage Temperature TO-220 Mounting Torque 1 Value C2D05120 Rev. E M3 Screw 6-32 Screw Note Electrical Characteristics Symbol Parameter Typ. Max. Unit Test Conditions VF Forward Voltage 1.6 2.6 1.8 3.0 V IR Reverse Current 50 100 200 1000 µA VR = 1200 V TJ=25°C VR = 1200 V TJ=175°C QC Total Capacitive Charge 28 nC VR = 1200 V, IF = 5 A di/dt = 500 A/µs TJ = 25°C C Total Capacitance 455 45 33 pF VR = 0 V, TJ = 25°C, f = 1 MHz VR = 200 V, TJ = 25˚C, f = 1 MHz VR = 400 V, TJ = 25˚C, f = 1 MHz Note IF = 5 A TJ=25°C IF = 5 A TJ=175°C Note: 1. This is a majority carrier diode, so there is no reverse recovery charge. Thermal Characteristics Symbol Parameter Typ. Unit RθJC Thermal Resistance from Junction to Case 1.1 °C/W 20 200 18 180 16 160 14 140 IR Reverse Current (μA) IF Forward Current (A) Typical Performance 12 10 8 6 100 80 60 4 40 2 20 0 0 1.0 2.0 3.0 4.0 5.0 VF Forward Voltage (V) Figure 1. Forward Characteristics 2 120 C2D05120 Rev. E 0 0 500 1000 1500 VR Reverse Voltage (V) Figure 2. Reverse Characteristics Typical Performance Current Derating 150 Typical Performance 140 10% 20% 30% 50% 70% DC 40 40.0 130 120 30 30.0 Tot IF(PEAK) Peak Forward Current (A) IF Forward Current (A) 50 50.0 Duty* Duty* Duty* Duty* Duty* Power (W) P Dissipation (W) 60 60.0 20 20.0 110 100 90 80 70 60 50 40 30 10 10.0 20 10 0 0.00 25 50 75 100 125 150 175 25 50 75 100 125 150 175 25 50 TC Case Temperature (°C) Tc Case Temperature (°°C) * Frequency > 1KHz Figure 3. Current Derating 75 100 125 Tc Case T Temperature ˚C (°C) C Figure 4. Power Derating 400 350 300 C Capacitance (pF) Page 1 250 200 150 100 50 0 1 10 100 1000 VR Reverse Voltage (V) Figure 5. Capacitance vs. Reverse Voltage 3 C2D05120 Rev. E 150 175 Figure 6. Transient Thermal Impedance 4 C2D05120 Rev. E Package Dimensions POS Package TO-220-2 C P F J Min Max A .381 .410 9.677 10.414 B .235 .255 5.969 6.477 DP OS Q E A F B B D X S E Y 1 2 G Z T U V L M J E F L G MH T Q US W N GC HD N J L P M Q N SP H Millimeters Max C A Inches Min .120 2.540 M illim eters .337 5.664 M in M ax .615 14.986 10.033 10.414 .153 3.632 5.969 6.477 .102 2.591 1.105 .112 1.147 .337.500 .337 .550 8.560 .590 .610 14.986 R 0.197 .149 .153 3.785 .025 1.147 .036 1.127 28.626 2.845 28.067 8.560 12.700 15.494 3.886 .635 29.134 1.143 13.970 .055 13.462 .205 R 0.2544.953 .028 .165 .045 .048 .195 .170 3° .711 .185 1.143 .054 4.953 6° 4.318 .055 .205 .180 .048 3° .054 3° 3° 5° 1.219 6° 6°3° 8.560 15.621 3.886 29.134 13.970 R 0.197 .530.045 .550 R 0.010 .195 .036 3.048 .914 4.191 1.397 1.219 5.207 3° 4.572 1.371 3° 5° 3° .914 1.397 5.207 4.699 1.372 6° 6° 6° U WV 3° 5° .094 3° 5° .100.014 .110 3° .110 3° .025 2.54 5° 2.388 5° .356 2.794 XW .014 3° 5.5° .356 3° .533 5.5° Y X Y 3°.385 5° .395 .410 .130 .130 .150 3° .410 10.033 .150 3.302 5° 9.779 10.414 3.302 3.810 10.414 V z T .100 Inc hes .223 M in M ax .590 .395 .410 .235.143 .255 Z .021 2.794 .635 3.810 NOTE: 1. Dimension L, M, W apply for Solder Dip Finish Recommended Solder Pad Layout TO-220-2 Part Number Package Marking C2D05120A TO-220-2 C2D05120 Note: Recommended soldering profiles can be found in the applications note here: http://www.cree.com/power_app_notes/soldering 5 C2D05120 Rev. E Notes • RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree representative or from the Product Documentation sections of www.cree.com. • REACh Compliance REACh substances of high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future,please contact a Cree representative to insure you get the most up-to-date REACh SVHC Declaration. REACh banned substance information (REACh Article 67) is also available upon request. • This product has not been designed or tested for use in, and is not intended for use in, applications implanted into the human body nor in applications in which failure of the product could lead to death, personal injury or property damage, including but not limited to equipment used in the operation of nuclear facilities, life-support machines, cardiac defibrillators or similar emergency medical equipment, aircraft navigation or communication or control systems, air traffic control systems, or weapons systems. Copyright © 2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo, and Zero Recovery are registered trademarks of Cree, Inc. 6 C2D05120 Rev. E Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5451 www.cree.com/power
C2D05120A 价格&库存
很抱歉,暂时无法提供与“C2D05120A”相匹配的价格&库存,您可以联系我们找货
