BYG20D – BYG20J
Taiwan Semiconductor
1.5A, 200V - 600V High Efficient Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Ideal for automated placement
Fast switching for high efficiency
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
1.5
A
VRRM
200 - 600
V
IFSM
30
A
TJ MAX
150
°C
Package
DO-214AC (SMA)
Configuration
Single die
DC to DC converter
Switching mode converters and inverters
Lighting application
Snubber
Freewheeling application
MECHANICAL DATA
Case: DO-214AC (SMA)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.064g (approximately)
DO-214AC (SMA)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
BYG20D
BYG20G
BYG20J
BYG20D
BYG20G
BYG20J
UNIT
Repetitive peak reverse voltage
VRRM
200
400
600
V
Reverse voltage, total rms value
VR(RMS)
140
280
420
V
Forward current
Peak forward surge current, 8.3ms single half
sine-wave superimposed on rated load
Pulse energy in avalanche mode, non-repetitive
(Inductive load switch off ), L = 120mH
Junction temperature
Storage temperature
IF
1.5
A
IFSM
30
A
ERSM
mJ
TJ
- 55 to +150
°C
TSTG
- 55 to +150
°C
1
Version: F2102
BYG20D – BYG20J
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
25
°C/W
Junction-to-ambient thermal resistance
RӨJA
100
°C/W
Thermal Performance Note: Units mounted on PCB (5mm x 5mm Cu pad test board)
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
IF = 1.0A, TJ = 25°C
(1)
Reverse current @ rated VR
IF = 1.5A, TJ = 25°C
(2)
Reverse recovery time
TJ = 25°C
TJ = 100°C
IF = 0.5A, IR = 1.0A,
Irr = 0.25A
SYMBOL
VF
IR
trr
TYP
MAX
UNIT
1.3
V
1.4
V
1
µA
10
µA
75
ns
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
BYG20x
DO-214AC (SMA)
7,500 / Tape & Reel
Notes:
1. “x” defines voltage from 200V(BYG20D) to 600V(BYG20J)
2
Version: F2102
BYG20D – BYG20J
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
175
150
1.5
CAPACITANCE (pF)
1
0.5
125
100
75
50
25
f=1.0MHz
Vsig=50mVp-p
50
75
100
125
150
0.1
1
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
0.1
0.01
TJ=25°C
0.001
40
50
60
70
80
90
100
10 10
UF1DLW
1
TJ=125°C
TJ=25°C
1
0.1
0.01
Pulse width 300μs
1% duty cycle
Pulse width
0.1
0.001
0.8 0.9 1.0 1.1 1.2 1.3 1.4
0.3
0.4
0.5
0.6
0.7
0.8
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
1.5
0.9
1.6
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
40
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.4 Typical Forward Characteristics
10
10
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
1
10
(A)
AVERAGE FORWARD CURRENT (A)
2
8.3ms single half sine wave
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: F2102
1.2
BYG20D – BYG20J
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: F2102
BYG20D – BYG20J
PACKAGE OUTLINE DIMENSIONS
DO-214AC (SMA)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: F2102
BYG20D – BYG20J
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: F2102
很抱歉,暂时无法提供与“BYG20G R3G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.947341+0.47668
- 10+3.9428110+0.47614
- 25+3.9382725+0.47559
- 国内价格 香港价格
- 1+3.899731+0.47093
- 10+3.1492610+0.38031
- 100+2.14485100+0.25902
- 500+1.60864500+0.19426
- 1000+1.208461000+0.14594
- 2500+0.837502500+0.10114
- 5000+0.786235000+0.09495
- 7500+0.705907500+0.08525
- 22500+0.6836822500+0.08256
