SK82C – SK810C
Taiwan Semiconductor
8A, 20V - 100V Schottky Barrier Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Low power loss, high efficiency
Ideal for automated placement
Guard ring for overvoltage protection
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
8
A
VRRM
20 - 100
V
IFSM
150
A
TJ MAX
125, 150
°C
Package
DO-214AB (SMC)
Configuration
Single die
Switching mode power supply (SMPS)
Adapters
Lighting application
Converter
MECHANICAL DATA
Case: DO-214AB (SMC)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.210g (approximately)
DO-214AB (SMC)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Repetitive peak reverse voltage
VRRM
SK
82C
SK
82C
Reverse voltage, total rms value
VR(RMS)
14
PARAMETER
SYMBOL
Marking code on the device
Forward current
Surge peak forward current, 8.3ms
single half sine-wave superimposed
on rated load
Critical rate of rise of off-state
voltage
Junction temperature
Storage temperature
SK
83C
SK
83C
30
SK
84C
SK
84C
40
SK
85C
SK
85C
50
SK
86C
SK
86C
60
SK
810C
SK
810C
100
21
28
35
42
70
UNIT
V
V
IF
8
A
IFSM
150
A
dV/dt
10,000
V/µs
TJ
- 55 to +125
TSTG
- 55 to +150
- 55 to +150
1
°C
°C
Version: L2102
SK82C – SK810C
THERMAL PERFORMANCE
PARAMETER
Junction-to-ambient thermal resistance
SYMBOL
TYP
UNIT
RӨJA
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
SK82C
SK83C
SK84C
SK85C
SK86C
SK810C
(1)
Reverse current @ rated VR
(2)
(2)
IF = 8A, TJ = 25°C
TJ = 25°C
SK82C
SK83C
SK84C
SK85C
SK86C
SK810C
SYMBOL
VF
IR
TJ = 100°C
TYP
MAX
UNIT
0.55
V
0.75
V
0.90
V
0.5
mA
15
mA
10
mA
IR
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
SK8xC
DO-214AB (SMC)
3,000 / Tape & Reel
Notes:
1. “x” defines voltage from 20V(SK82C) to 100V(SK810C)
2
Version: L2102
SK82C – SK810C
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
SK85C - SK810C
8
CAPACITANCE (pF)
6
SK82C - SK84C
4
1000
SK82C - SK84C
100
SK85C - SK86C
2
25
50
75
100
125
150
0.1
1
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=75°C
0.1
TJ=25°C
0.01
0.001
0.0001
10
40
50
60
70
80
90 100
100 10
10
1
SK82C
- SK84C
UF1DLW
TJ=125°C
TJ=25°C
0.1
SK85C - SK86C
1
SK810C
0.01
0.1
0.001
0.1
Pulse width 300μs
1% duty cyclePulse width
0.3
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
0.3
0.4
0.5
0.5
0.7
0.9
0.6
0.7
0.8
1.1
0.9
1.3
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
180
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
SK82C - SK84C
SK85C - SK810C
10
1
100
Fig.4 Typical Forward Characteristics
1000
TJ=125°C
10
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
100
SK810C
f=1.0MHz
Vsig=50mVp-p
(A)
AVERAGE FORWARD CURRENT (A)
10
8.3ms single half sine wave
150
120
90
60
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: L2102
1.2
SK82C – SK810C
Fig.6 Typical Transient Thermal Characteristics
TRANSIENT THERMAL IMPEDANCE (°C/W)
100
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
4
Version: L2102
SK82C – SK810C
PACKAGE OUTLINE DIMENSIONS
DO-214AB (SMC)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: L2102
SK82C – SK810C
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: L2102
很抱歉,暂时无法提供与“SK810C V6G”相匹配的价格&库存,您可以联系我们找货
