FM24C16B-G1
FM24C16B-G1
    ROCHESTER(罗切斯特)
    SOIC8
    IC FRAM 16KBIT I2C 1MHZ 8SOIC
FM24C16B-G1 数据手册
FM24C16U/17U – 16K-Bit Standard 2-Wire Bus Interface Serial EEPROM General Description Features The FM24C16U/17U devices are 16,384 bits of CMOS nonvolatile electrically erasable memory. These devices conform to all specifications in the Standard IIC 2-wire protocol. They are designed to minimize device pin count and simplify PC board layout requirements. ■ Extended operating voltage 2.7V – 5.5V ■ 400 KHz clock frequency (F) at 2.7V - 5.5V ■ 200µA active current typical 10µA standby current typical 1µA standby current typical (L) 0.1µA standby current typical (LZ) The upper half (upper 8Kbit) of the memory of the FM24C17U can be write protected by connecting the WP pin to VCC. This section of memory then becomes unalterable unless WP is switched to VSS. ■ IIC compatible interface – Provides bi-directional data transfer protocol ■ Sixteen byte page write mode – Minimizes total write time per byte This communications protocol uses CLOCK (SCL) and DATA I/O (SDA) lines to synchronously clock data between the master (for example a microprocessor) and the slave EEPROM device(s). The Standard IIC protocol allows for a maximum of 16K of EEPROM memory which is supported by the Fairchild family in 2K, 4K, 8K, and 16K devices, allowing the user to configure the memory as the application requires with any combination of EEPROMs. In order to implement higher EEPROM memory densities on the IIC bus, the Extended IIC protocol must be used. (Refer to the FM24C32 or FM24C65 datasheets for more information.) ■ Self timed write cycle Typical write cycle time of 6ms ■ Hardware Write Protect for upper half (FM24C17U only) ■ Endurance: 1,000,000 data changes ■ Data retention greater than 40 years ■ Packages available: 8-pin DIP, 8-pin SO, and 8-pin TSSOP ■ Available in three temperature ranges - Commercial: 0° to +70°C - Extended (E): -40° to +85C - Automotive (V): -40° to +125°C Fairchild EEPROMs are designed and tested for applications requiring high endurance, high reliability and low power consumption. Block Diagram VCC VSS WP SDA H.V. GENERATION TIMING &CONTROL START STOP LOGIC CONTROL LOGIC SCL SLAVE ADDRESS REGISTER XDEC E2PROM ARRAY WORD ADDRESS COUNTER R/W YDEC CK DATA REGISTER DIN © 2002 Fairchild Semiconductor International FM24C16U/17U Rev. A.3 1 DOUT www.fairchildsemi.com FM24C16U/17U – 16K-Bit Standard 2-Wire Bus Interface Serial EEPROM September 2002 Dual-in-Line Package (N) and SO Package (M8) NC 1 NC 2 8 VCC 7 NC TSSOP Package (MT8) NC 1 VCC 2 24C16 8 SCL 7 SDA 24C16 NC 3 6 SCL NC 3 6 VSS VSS 4 5 SDA NC 4 5 NC See Package Number N08E, M08A and MTC08 Pin Names VSS Ground SDA Serial Data I/O SCL Serial Clock Input NC No Connection VCC Power Supply Dual-in-Line Package (N) and SO Package (M8) NC 1 NC 2 TSSOP Package (MT8) 8 VCC WP 1 7 WP VCC 2 24C17 8 SCL 7 SDA 24C17 NC 3 6 SCL NC 3 6 VSS VSS 4 5 SDA NC 4 5 NC See Package Number N08E, M08A and MTC08 Pin Names NC No Connection VSS Ground SDA Serial Data I/O SCL Serial Clock input WP Write Protect VCC Power Supply NOTE: Pins designated as "NC" are typically unbonded pins. However some of them are bonded for special testing purposes. Hence if a signal is applied to these pins, care should be taken that the voltage applied on these pins does not exceed the VCC applied to the device. This will ensure proper operation. 2 FM24C16U/17U Rev. A.3 www.fairchildsemi.com FM24C16U/17U – 16K-Bit Standard 2-Wire Bus Interface Serial EEPROM Connection Diagrams FM 24 C XX U F T LZ E XXX Letter Description N M8 MT8 8-pin DIP 8-pin SOIC 8-pin TSSOP Temp. Range None V E 0 to 70°C -40 to +125°C -40 to +85°C Voltage Operating Range Blank L LZ 4.5V to 5.5V 2.7V to 5.5V 2.7V to 5.5V and
FM24C16B-G1 价格&库存
很抱歉,暂时无法提供与“FM24C16B-G1”相匹配的价格&库存,您可以联系我们找货
