RS2255
CMOS 4-Channel Analog Multiplexer/Demultiplexer
FEATURES
-3dB Bandwidth: 180MHz
Single Supply Operation +2.5V to +5.5V
Low ON Resistance, 24Ω(TYP) With
5V Supply
High Off-Isolation: -83dB (RL = 50Ω,
f = 1MHz)
Break-Before-Make Switching
Binary Address Decoding on Chip
Operating Temperature Range:
-40°C to +125°C
PACKAGES: MSOP-10
DESCRIPTION
The RS2255 is a CMOS analog IC configured as 4channel multiplexers. This CMOS device can operate
from 2.5 V to 5.5 V.
The RS2255 device are digitally-controlled analog
switches. It has low on-resistance (24 Ω TYP) and
very low off-leakage current (1nA TYP).
The RS2255 is available in Green MSOP-10
packages. It operates over an ambient temperature
range of -40°C to +125°C.
Functional Diagrams of RS2255
APPLICATIONS
Sensors
Analog and Digital Multiplexing and
Demultiplexing
A/D and D/A Conversion
Signal Gating
Battery-Operated Equipment
Factory Automation
Appliances
Communications Circuits
ENA BLE
B
X0
A
BA
00
X1
01
X
10
X2
11
X3
RS2255
REV C.3
1
www.run-ic.com
RS2255
PIN CONFIGURATIONS
RS2255(TOP VIEW)
X2
1
10 Vcc
X3
2
9
X
X1
3
8
X0
ENABLE
4
7
A
GND 5
6
B
MSOP-10
PIN DESCRIPTION
NAME
X2
X3
X1
PIN
1
2
3
ENABLE
4
GND
B
A
X0
X
VCC
5
6
7
8
9
10
FUNCTION
Analog Switch Normally Open Inputs 2.
Analog Switch Normally Open Inputs 3.
Analog Switch Normally Open Inputs 1.
Inhibit. Drive ENABLE low or connect to GND for normal operation.
Drive ENABLE high or connect to VCC to turn all switches off.
Ground.
Digital Address “B” Input.
Digital Address “A” Input.
Analog Switch Normally Open Inputs 0.
Analog Switch Common.
Positive Analog and Digital Supply Voltage.
FUNCTION TABLE
ENABLE
INPUT
1
INPUT STATES
B
X
1
A
X
X=Don’t care
NOTE: Input and output pins are identical and interchangeable. Either may be considered an input or
output; signals pass equally well in either direction.
ON CHANNEL(S)
NONE
X0
X1
X2
X3
2
www.run-ic.com
RS2255
SPECIFICATIONS
Absolute Maximum Ratings
Over operating free-air temperature range (unless otherwise noted) (1)
SYMBOL
PARAMETER
MIN
MAX
VCC
Supply Voltage
-0.3
6
VIN
Input Voltage (All inputs)
-0.3
VCC+0.3
IIN
Switch Input Current
Any one input
-20
+20
IPEAK
Peak Switch Current
Pulsed at 1ms Duration,
很抱歉,暂时无法提供与“RS2255XN”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.36640
- 100+1.05730
- 1000+0.87920
- 2000+0.79970
- 4000+0.73360
- 国内价格
- 5+1.89670
- 50+1.46010
- 150+1.27300
- 500+1.03950
