NJU7043
High Output Current, Rail-to-Rail Input/Output
Dual CMOS Operational Amplifier
■GENERAL DESCRIPTION
■PACKAGE OUTLINE
The NJU7043 is a Rail-to-Rail Input/Output dual CMOS operational
amplifier with a low operating voltage from 1.8V to 5.5V and high
output current of 40mA which is higher than our conventional CMOS
operational amplifiers.
It also offers a rail-to-rail input/output between both rails, low
operating current of 300μA per amplifier, low input bias current of 1pA
and ground sensing, which is suitable for various applications. The
NJU7043 is available in 8-lead package of DIP8, 8-lead small surface
mount packages of DMP8, SOP8 JEDEC 150mil, SSOP8, MSOP8
(TVSP8) and PCSP20−CC.
■FEATURES
● Operating Voltage
● Rail-to-Rail Input/Output
● High Output Current
● Input Offset Voltage
● Wide Input Common Mode
Voltage Range
● Operating Current
● High Input Impedance
● Low Input Bias Current
● Ground Sensing
● Package
■PIN CONFIGURATION
○NJU7043D,M,E,V,RB1
( Top View )
NJU7043M
( DMP8 )
NJU7043E
(SOP8)
NJU7043V
( SSOP8 )
NJU7043RB1
(MSOP8(TVSP8))
NJU7043SCC
(PCSP20−CC)
40mA typ. (at Vo=0V)
VIO=10mV max.
VSS to VDD
IDD=300μA typ. (per Amplifier)
1T typ.
IIB=1pA typ.
DIP8,DMP8,SOP8 JEDEC 150mil , SSOP8
MSOP8 (TVSP8)MEET JEDEC MO-187-DA / THIN TYPE,
PCSP20−CC
PIN FUNCTION
1. OUTPUT A
2. −INPUT A
1
8
3. +INPUT A
7
4. VSS(V )
A
2
VDD=1.8 to 5.5V
NJU7043D
( DIP8 )
B
3
6
4
5
5. +INPUT B
6. −INPUT B
7. OUTPUT B
8. VDD(V+)
○NJU7043SCC
18
17
16
16
17
18
19
PIN FUNCTION
1. OUTPUT A
11. NC
1
15
15
1
2. NC
12. +INPUT B
2
14
14
2
3. –INPUT A
13. –INPUT B
3
13
13
3
4. +INPUT A
14. NC
4
12
12
4
5. NC
15. OUTPUT B
6. NC
16. NC
A
B
11
5
6
7
8
9
(Top View)
10
PAD
11
5
10
9
8
7
6
(Bottom View)
(Note 1) The NC pin and the PAD should connect with a VSS terminal.
17. NC
7. NC
8. VSS (V )
18. VDD(V+)
9. NC
19. NC
10. NC
(Note 2) The NC pin is electrically not connected to the die in a package.
(Note 3) The PAD is electrically not connected to the backside of the die. The PAD cannot be used as VSS pin.
Ver.2014-05-20
20. NC
-1-
NJU7043
■ABSOLUTE MAXIMUM RATINGS
(Ta=25°C)
PARAMETER
Supply Voltage
SYMBOL
VDD
RATING
7
UNIT
V
Common Mode Input Voltage Range
VICM
0 to 7 (Note4)
V
Differential Input Voltage Range
VID
Power Dissipation
PD
Operating Temperature Range
Storage Temperature Range
Topr
Tstg
±7
500 (DIP8)
300 (DMP8)
300 (SOP8)
250 (SSOP8)
320 (MSOP8 (TVSP8))
400 (PCSP20−CC)(note 6)
-40 ~ +85
-55 ~ +125
V
mW
°C
°C
(Note 4) When supply voltage is less than 7V, the absolute maximum input voltage is equal to the voltage.
(Note 5) Decoupling capacitor should be connected between VDD and VSS due to the stabilized operation for the circuit.
(Note 6) On the PCB " EIA/JEDEC (76.2x114.3x1.6mm, two layers, FR-4) ".
(Note 7) Do not exceed "Power dissipation: PD" in which power dissipation in IC is shown by the absolute maximum rating.
Refer to following Figure 1 for a permissible loss when ambient temperature (Ta) is Ta≥25°C.
Figure1. Power Dissipation vs. Temperature
Power Dissipation PD [mW]
600
500
DIP8
PCSP20-CC
400
MSOP8
300
200
SOP8/DMP8
100
SSOP8
50
75
100
Ambient Temperature Ta [ºC]
■RECOMMENDED OPERATION CONDITION
PARAMETER
Supply Voltage
-2-
SYMBOL
VDD
125
(Ta=25°C)
RATING
1.8 ~ 5.5
UNIT
V
Ver.2014-05-20
NJU7043
■ELECTRICAL CHARACTERISTICS
● DC CHARACTERISTICS
(VDD=3.0V, Ta=25°C)
PARAMETER
SYMBOL
RATING
MIN
TYP
MAX
UNIT
Operating Current
IDD
No Signal, Dual Circuits
600
1,000
µA
VIO
10
mV
Input Bias Current
IB
1
pA
Input Offset Current
IIO
1
pA
Voltage Gain
AV
RL=10kΩ
70
90
dB
Common Mode Rejection Ratio
CMR
0≤ VCM ≤1.5V,
1.5 ≤VCM ≤3.0V (note7 )
42
60
dB
Supply Voltage Rejection Ratio
SVR
2.0V ≤ VDD ≤ 5.0V , VCM = VDD / 2
61
80
dB
H Level Output Voltage 1
VOH1
RL=10kΩ
2.95
V
L Level Output Voltage 1
VOL1
RL=10kΩ
0.05
V
H Level Output Voltage 2
VOH2
RL=600Ω
2.90
V
L Level Output Voltage 2
VOL2
RL=600Ω
0.10
V
V
Input Common Mode
VICM
CMR≥45dB
Voltage Range
(Note 8) CMR is represented by either CMR+ or CMR- which has lower value.
CMR+ is measured with 1.5V≤VCM≤3V and CMR- is measured with 0V≤VCM≤1.5V.
● AC CHARACTERISTICS
(VDD=3.0V, Ta=25°C)
PARAMETER
SYMBOL
RATING
MIN
TYP
MAX
UNIT
Unity Gain Bandwidth
GB
RL=10kΩ
0.8
MHz
Total Harmonic Distortion
THD
f=1kHz , Vin=1Vpp , Av=0dB
0.05
Equivalent Input Noise Voltage
en
f=1kHz
40
nV/
√Hz
PARAMETER
SYMBOL
RATING
MIN
TYP
MAX
UNIT
Slew Rate
SR
RL=10 kΩ
0.7
V/µs
● TRANSIENT CHARACTERISTICS
Ver.2014-05-20
(VDD=3.0V, Ta=25°C)
-3-
NJU7043
■TYPICAL CHARACTERISTICS
Supply Current vs. Supply Voltge
Supply Current vs. Supply Voltage
(Ambient Temperature)
Gv = 0dB
Gv = 0dB, Ta=25ºC
900
900
800
800
Supply Current [μA]
1000
Supply Current [μA]
1000
700
600
500
400
300
700
600
Ta=25ºC
500
400
Ta=-40ºC
300
200
200
100
100
2
3
4
Supply Voltage V [V]
5
6
Supply Voltage vs. Ambient Temperature
1
2
3
4
5
6
Input Offset Voltage vs. Ambient Temperature
V+/V-=±1.5V Gv = 0dB
V /V =±1.5V
1000
3
900
2.5
Input Offset Voltage [mV]
Supply Current [μA]
Ta=85ºC
800
700
600
500
400
2
1.5
1
0.5
300
200
-25
50
75
100
Ambient Temperature [ºC]
125
-50
Output Voltage vs. Supply Voltage
-25
50
75
100
125
Output Voltage vs. Load Resistance (Supply Voltage)
Gv = OPEN RL=600Ω Ta=25ºC
Gv = OPEN Ta=25ºC
3
2.5
2
1.5
Output Voltage [V]
Output Voltage [V]
2
1
V /V =±2.5V
0.5
V /V =±1.5V
V+/V-=±0.9V
-0.5
-1
-1
-1.5
-2
-2
-2.5
-3
±1
±2
+ Supply Voltage V /V [V]
±3
10
100
1000
Load Resistance [Ω]
10000
Ver.2014-05-20
NJU7043
Gain/Phase vs. Frequency
THD vs. Output Voltage
V+/V-=±1.5V, Gv=40dB, RF=100k, Rg=1k, CL=0
V+/V-=±1.5V, Gv=0dB, RL=10k, Ta=25ºC
80
200
Phase
150
100
Gain
f=20kHz
0.1
THD [%]
40
1
Phase [deg]
Voltage Gain [dB]
60
10
f=1kHz
0.01
f=20Hz
-20
0.001
-50
-40
100
0M
0M
1k
10k
0M
100k
0M
Frequency [Hz]
1M
-100
10M
0.0001
0.01
10
Equivalent Input Noise Voltage vs. Frequency
Noise Voltage vs. Source Resistance
V+/V-=±1.5V, Gv=40dB, Rs=600, RG=100, RF=10k, Ta=25ºC
V+/V-=±1.5V, Gv=40dB, RG=100, RF=1k, Ta=25ºC
300
100
250
Noise Voltage [μV]
[nV/Hz]
0.1
1
Output Voltage [Vrms]
200
150
100
10
DIN-AUDIO
JIS A
1
50
10
100
1000
1k
Frequency [Hz]
10000
10k
0k
10
100
0k
1k
10k
Source Resistance [Ω]
Pulse Response
Pulse Response
100k
2
6
V /V =±1.5V, VIN=1Vp-p, f=10kHz
Gv=0dB, Rs=50, RL=10k, CL=0F, Ta=25ºC
V /V =±1.5V, VIN=3Vp-p, f=10kHz
1.8
0.6
1.4
0.2
4
-1
2
-2
Output
1
-3
-1
-5
-2
Ver.2014-05-20
40
80
120
Time [μs]
160
-6
200
1
-0.2
Input
0.6
-0.6
0.2
-1
-0.2
-1.4
Output
-0.6
Input Voltage [V]
1
Output Voltage [V]
5
Input Voltage [V]
Output Voltage [V]
Input
40
60
Time [μs]
80
-1.8
100
-5-
NJU7043
Pulse Response (Rise)
Pulse Response (Fall)
0.6
1.8
1.4
0.2
1.4
-0.2
1
Input
0.6
-0.6
0.2
-1
-0.2
Output Voltage [V]
1.8
Input Voltage [V]
Output Voltage [V]
0.6
Input
0.2
1
-0.2
0.6
-0.6
Output
0.2
-1.4
-0.2
-1.8
-0.6
-1
Input Voltage [V]
-1.4
Output
-0.6
4
6
Time [μs]
8
10
8
10
V.F.Peak vs. Frequency (Load Capacitance)
V+/V-=±1.5V, VIN=-20dBm, Gv=0dB, RL=600, Ta=25ºC
15
CL=680pF
CL=330pF
CL=220pF
5
CL=100pF
CL=0pF
-5
10
Voltage Gain [dB]
CL=470pF
-10
CL=470pF
5
CL=330pF
CL=220pF
CL=100pF
CL=0pF
-5
-10
-15
10k
100k
1000k
1M
Frequency [Hz]
-15
10k
10000k
10M
Phase Margin vs. Load Capacitance
100k
1000k
1M
Frequency [Hz]
10000k
10M
V /V =±1.5V, VIN=-30dBm, Gv=40dB,
RL=10k, Rs=50, Rg=1k, RF=100k, Ta=25ºC
RL=600, Rs=50, Rg=1k, RF=100k, Ta=25ºC
70
70
60
60
50
50
Phase Margin [deg]
Phase Margin [deg]
4
6
Time [μs]
V+/V-=±1.5V, VIN=-20dBm, Gv=0dB, RL=10k, Ta=25ºC
10
40
30
40
30
100
Load Capacitance [pF]
-6-
2
15
Voltage Gain [dB]
-1.8
10
100
1000
Ver.2014-05-20
NJU7043
Gain Bandwidth Product vs. Load Capacitance
1.4
1.4
1.2
1.2
Gain Bandwidth Product [MHz]
1
0.8
0.6
0.4
0.2
0.8
0.6
0.4
0.2
100
1000
10
Overshoot vs. Load Capacitance
100
1000
Gv=0dB, RL=10k, Rs=50, Ta=25ºC
Gv=0dB, RL=600, Rs=50, Ta=25ºC
25
Overshoot [%]
Overshoot [%]
15
Positive
10
5
Positive
15
10
Negative
Negative
5
100
1000
10
100
1000
[CAUTION]
The specifications on this data book are only given for
information, without any guarantee as regards either mistakes
or omissions. The application circuits in this data book are
described only to show representative usages of the product
and not intended for the guarantee or permission of any right
including the industrial rights.
Ver.2014-05-20
-7-
