ACTT12-800CTN
Enhanced and high temperature ACTT power switch
5 September 2018
Product data sheet
1. General description
AC Thyristor Triac power switch in a SOT78 (TO-220AB) plastic package with selfprotective
clamping capabilities against low and high energy transients. This "series CTN" triac will
commutate the full RMS current at the maximum rated junction temperature (Tj(max) = 150 °C)
without the aid of a snubber. It is used in applications where "high junction operating temperature
capability" is required.
2. Features and benefits
Clamping structure ensuring safe high over-voltage withstand capability
High junction operating temperature capability (Tj(max) = 150 °C)
High minimum IGT for guaranteed immunity to gate noise
Full cycle AC conduction
Over-voltage withstand capability to IEC 61000-4-5
Pin compatible with standard triacs
Protective self turn-on capability for high energy transients
Safe clamping capability for low energy over-voltage transients
Less sensitive gate for high noise immunity
Triggering in three quadrants only
Planar passivated for voltage ruggedness and reliability
High commutation capability with maximum false trigger immunity
Very high immunity to false turn-on by dV/dt and IEC 61000-4-4 fast transient
Package is RoHS compliant
Package meets UL94V0 flammability requirement
3. Applications
Electronic themostats (heating and cooling)
High power motor controls e.g washing machine and vacuum cleaners
Rectifier-fed DC inductive loads e.g DC motors and solenoids
Refrigeration and air conditioning compressors
Applications subject to high temperature (Tj(max) = 150 °C)
4. Quick reference data
Table 1. Quick reference data
Symbol
Parameter
VDRM
repetitive peak offstate voltage
IT(RMS)
RMS on-state current
Conditions
full sine wave; Tmb ≤ 121 °C; Fig. 1;
Fig. 2; Fig. 3
Min
Typ
Max
Unit
800
V
12
A
ACTT12-800CTN
WeEn Semiconductors
Symbol
Parameter
ITSM
Min
Typ
Max
Unit
non-repetitive peak on- full sine wave; Tj(init) = 25 °C;
tp = 20 ms; Fig. 4; Fig. 5
state current
120
A
tp = 16.7 ms
132
A
150
°C
Tj = 25 °C; non-repetitive, off-state;
Fig. 6
2
kV
VD = 12 V; IT = 100 mA; LD+ G+;
Tj = 25 °C; Fig. 8
5
35
mA
VD = 12 V; IT = 100 mA; LD+ G-;
Tj = 25 °C; Fig. 8
5
35
mA
VD = 12 V; IT = 100 mA; LD- G-;
Tj = 25 °C; Fig. 8
5
35
mA
Tj
VPP
peak pulse voltage
Conditions
Static characteristics
IGT
gate trigger current
IH
holding current
VD = 12 V; Tj = 25 °C; Fig. 10
30
mA
VT
on-state voltage
IT = 17 A; Tj = 25 °C; Fig. 11
1.5
V
VCL
clamping voltage
ICL = 0.1 mA; tp = 1 ms; Tj = 25 °C
850
V
VDM = 536 V; Tj = 125 °C; (VDM = 67%
of VDRM); exponential waveform; gate
open circuit
4000
V/µs
VDM = 536 V; Tj = 150 °C; exponential
waveform; gate open circuit
2000
V/µs
VD = 400 V; Tj = 150 °C; IT(RMS) = 12 A;
dVcom/dt = 20 V/µs; gate open circuit;
snubberless condition
12
A/ms
dVcom/dt = 10 V/µs; gate open circuit
15
A/ms
dVcom/dt = 1 V/µs; gate open circuit
A/ms
Dynamic characteristics
dVD/dt
dIcom/dt
rate of rise of off-state
voltage
rate of change of
commutating current
ACTT12-800CTN
Product data sheet
All information provided in this document is subject to legal disclaimers.
5 September 2018
WeEn Semiconductors Co., Ltd. 2018. All rights reserved
2 / 14
ACTT12-800CTN
WeEn Semiconductors
5. Pinning information
Table 2. Pinning information
Pin
Symbol Description
1
CM
common
2
LD
load
3
G
gate
mb
LD
mounting base; load
Simplified outline
Graphic symbol
LD
mb
G
CM
003aaf296
1 2 3
TO-220AB (SOT78)
6. Ordering information
Table 3. Ordering information
Type number
ACTT12-800CTN
ACTT12-800CTN
Product data sheet
Package
Name
Description
Version
TO-220AB
plastic single-ended package; heatsink mounted; 1 mounting
hole; 3-lead TO-220AB
SOT78
5 September 2018
3 / 14
ACTT12-800CTN
WeEn Semiconductors
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VDRM
repetitive peak off-state
voltage
IT(RMS)
ITSM
non-repetitive peak onstate current
2
Conditions
2
Min
Max
Unit
800
V
Fig. 2; Fig. 3
12
A
full sine wave; Tj(init) = 25 °C; tp = 20 ms;
Fig. 4; Fig. 5
120
A
full sine wave; Tj(init) = 25 °C; tp = 16.7 ms
132
A
I t
I t for fusing
tp = 10 ms; sine-wave pulse
72
A²s
dIT/dt
rate of rise of on-state
current
IG = 70 mA
100
A/µs
IGM
peak gate current
t = 20 μs
2
A
PGM
peak gate power
5
W
PG(AV)
average gate power
0.5
W
Tstg
storage temperature
-40
150
°C
Tj
150
°C
VPP
peak pulse voltage
2
kV
over any 20 ms period
Tj = 25 °C; non-repetitive, off-state; Fig. 6
aaa-019086
14
IT(RMS)
(A)
12
aaa-019087
16
121 °C
IT(RMS)
(A)
10
14
8
6
12
4
2
100
Tmb (°C)
10
10-2
150
Fig. 1. RMS on-state current as a function of mounting
base temperature; maximum values
ACTT12-800CTN
Product data sheet
10-1
1
10
surge duration (s)
f = 50 Hz; Tmb = 121 °C
Fig. 2. RMS on-state current as a function of surge
duration; maximum values
5 September 2018
4 / 14
ACTT12-800CTN
WeEn Semiconductors
aaa-019088
16
Ptot
(W)
12
8
conduction
angle, α
(degrees)
form
factor
a
30
60
90
120
180
2.816
1.967
1.570
1.329
1.110
α = 180 °C
α
Tmb(max)
(°C)
120 °C
126
90 °C
60 °C
α
30 °C
134
4
142
8
12
150
16
IT(RMS) (A)
α = conduction angle
a = form factor = IT(RMS) / IT(AV)
Fig. 3. Total power dissipation as a function of RMS on-state current; maximum values
aaa-019089
140
ITSM
IT
ITSM
(A)
t
120
1/f
Tj(init) = 25 °C max
80
40
102
10
number of cycles (n)
103
f = 50 Hz
Fig. 4. Non-repetitive peak on-state current as a function of the number of sinusoidal current cycles; maximum
values
ACTT12-800CTN
Product data sheet
5 September 2018
5 / 14
ACTT12-800CTN
WeEn Semiconductors
aaa-019090
104
ITSM
IT
ITSM
(A)
t
tp
103
(1)
102
10
10-5
10-4
10-3
10-2
tp (s)
10-1
tp ≤ 20 ms
(1) dIT/dt limit
Fig. 5. Non-repetitive peak on-state current as a function of pulse width; maximum values
IEC 61000-4-5 Standards
Surge Generator
RGen
2
Filtering Unit
R
13
AC Mains
L
2 H
Load Model
RG
DUT
220
003aal147
Fig. 6. Test circuit for inductive and resistive loads with conditions equivalent to IEC 61000-4-5
ACTT12-800CTN
Product data sheet
5 September 2018
6 / 14
ACTT12-800CTN
WeEn Semiconductors
8. Thermal characteristics
Table 5. Thermal characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-mb)
thermal resistance
from junction to
mounting base
full cycle; Fig. 7
2
K/W
Rth(j-a)
thermal resistance
from junction to
ambient free air
in free air
60
K/W
aaa-014073
10
Zth(j-mb)
(K/W)
1
10-1
10-2
10-5
P
tp
10-4
10-3
10-2
10-1
1
tp (s)
t
10
Fig. 7. Transient thermal impedance from junction to mounting base as a function of pulse width
ACTT12-800CTN
Product data sheet
5 September 2018
7 / 14
ACTT12-800CTN
WeEn Semiconductors
9. Characteristics
Table 6. Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Tj = 25 °C; Fig. 8
5
35
mA
Tj = 25 °C; Fig. 8
5
35
mA
Tj = 25 °C; Fig. 8
5
35
mA
VD = 12 V; IG = 100 mA; LD+ G+;
Tj = 25 °C; Fig. 9
40
mA
VD = 12 V; IG = 100 mA; LD+ G-;
Tj = 25 °C; Fig. 9
60
mA
VD = 12 V; IG = 100 mA; LD- G-;
Tj = 25 °C; Fig. 9
40
mA
IGT
IL
latching current
IH
holding current
30
mA
VT
on-state voltage
1.5
V
VGT
gate trigger voltage
VD = 12 V; IT = 100 mA; Tj = 25 °C;
Fig. 12
0.8
1
V
VD = 400 V; IT = 100 mA; Tj = 150 °C;
Fig. 12
0.2
0.45
V
VD = 800 V; Tj = 25 °C
10
µA
VD = 800 V; Tj = 150 °C
2
mA
850
V
open circuit
4000
V/µs
2000
V/µs
12
A/ms
15
A/ms
A/ms
ID
VCL
off-state current
clamping voltage
dVD/dt
dIcom/dt
voltage
rate of change of
commutating current
ACTT12-800CTN
Product data sheet
5 September 2018
8 / 14
ACTT12-800CTN
WeEn Semiconductors
aaa-019091
3
IGT
IGT(25°C)
aaa-012385
3
IL
IL(25°C)
(3)
2
2
(2)
(1)
1
1
100
Tj (°C)
150
(1) LD+ G+
(2) LD+ G(3) LD- G-
100
Tj (°C)
150
Fig. 9. Normalized latching current as a function of
Fig. 8. Normalized gate trigger current as a function of
aaa-014112
3
aaa-019092
25
IT
(A)
IH
IH(25°C)
15
10
1
(1) (2)
5
100
Tj (°C)
1
2
VT (V)
3
Vo = 0.892 V; Rs = 0.033 Ω
(1) Tj = 150 °C; typical values
(2) Tj = 150 °C; maximum values
(3) Tj = 25 °C; maximum values
Fig. 10. Normalized holding current as a function of
Fig. 11. On-state current as a function of on-state
voltage
ACTT12-800CTN
Product data sheet
5 September 2018
9 / 14
ACTT12-800CTN
WeEn Semiconductors
aaa-014113
1.6
VGT
VGT(25°C)
1.2
0.8
0.4
-50
100
Tj (°C)
150
Fig. 12. Normalized gate trigger voltage as a function of junction temperature
ACTT12-800CTN
Product data sheet
5 September 2018
10 / 14
ACTT12-800CTN
WeEn Semiconductors
10. Package outline
Plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220AB
SOT78
E
A
A1
p
q
mounting
base
D1
D
L1(1)
L2(1)
Q
L
b1(2)
(3×)
b2(2)
(2×)
1
2
3
b(3×)
e
c
e
10 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
b
b1(2)
b2(2)
c
D
D1
E
e
L
L1(1)
L2(1)
max.
p
q
Q
mm
4.7
4.1
1.40
1.25
0.9
0.6
1.6
1.0
1.3
1.0
0.7
0.4
16.0
15.2
6.6
5.9
10.3
9.7
2.54
15.0
12.8
3.30
2.79
3.0
3.8
3.5
3.0
2.7
2.6
2.2
Notes
1. Lead shoulder designs may vary.
2. Dimension includes excess dambar.
OUTLINE
VERSION
SOT78
REFERENCES
IEC
JEDEC
JEITA
3-lead TO-220AB
SC-46
EUROPEAN
PROJECTION
ISSUE DATE
08-04-23
08-06-13
Fig. 13. Package outline TO-220AB (SOT78)
ACTT12-800CTN
Product data sheet
5 September 2018
11 / 14
ACTT12-800CTN
WeEn Semiconductors
Right to make changes — WeEn Semiconductors reserves the right to
make changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
11. Legal information
Data sheet status
Document
status [1][2]
Product
status [3]
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Definition
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. WeEn Semiconductors does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences
of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local WeEn
Semiconductors sales office. In case of any inconsistency or conflict with the
short data sheet, the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
WeEn Semiconductors and its customer, unless WeEn Semiconductors and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the WeEn Semiconductors product
is deemed to offer functions and qualities beyond those described in the
Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, WeEn Semiconductors does not
give any representations or warranties, expressed or implied, as to the
accuracy or completeness of such information and shall have no liability for
the consequences of use of such information. WeEn Semiconductors takes
no responsibility for the content in this document if provided by an information
source outside of WeEn Semiconductors.
In no event shall WeEn Semiconductors be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, WeEn Semiconductors’ aggregate and cumulative liability
towards customer for the products described herein shall be limited in
accordance with the Terms and conditions of commercial sale of WeEn
Semiconductors.
Product data sheet
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. WeEn Semiconductors makes
no representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.ween-semi.com.
ACTT12-800CTN
Suitability for use — WeEn Semiconductors products are not designed,
authorized or warranted to be suitable for use in life support, life-critical
or safety-critical systems or equipment, nor in applications where failure
or malfunction of an WeEn Semiconductors product can reasonably
be expected to result in personal injury, death or severe property or
environmental damage. WeEn Semiconductors and its suppliers accept no
liability for inclusion and/or use of WeEn Semiconductors products in such
equipment or applications and therefore such inclusion and/or use is at the
customer’s own risk.
Customers are responsible for the design and operation of their applications
and products using WeEn Semiconductors products, and WeEn
Semiconductors accepts no liability for any assistance with applications or
customer product design. It is customer’s sole responsibility to determine
whether the WeEn Semiconductors product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products.
WeEn Semiconductors does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default
in the customer’s applications or products, or the application or use by
customer’s third party customer(s). Customer is responsible for doing all
necessary testing for the customer’s applications and products using WeEn
Semiconductors products in order to avoid a default of the applications
and the products or of the application or use by customer’s third party
customer(s). WeEn does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific WeEn Semiconductors product is automotive
qualified, the product is not suitable for automotive use. It is neither qualified
nor tested in accordance with automotive testing or application requirements.
WeEn Semiconductors accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without WeEn Semiconductors’ warranty
of the product for such automotive applications, use and specifications, and
(b) whenever customer uses the product for automotive applications beyond
WeEn Semiconductors’ specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies WeEn Semiconductors for
any liability, damages or failed product claims resulting from customer
design and use of the product for automotive applications beyond WeEn
Semiconductors’ standard warranty and WeEn Semiconductors’ product
specifications.
5 September 2018
12 / 14
ACTT12-800CTN
WeEn Semiconductors
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
ACTT12-800CTN
Product data sheet
5 September 2018
13 / 14
ACTT12-800CTN
WeEn Semiconductors
12. Contents
1. General description......................................................1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................3
6. Ordering information....................................................3
7. Limiting values............................................................. 4
8. Thermal characteristics............................................... 7
9. Characteristics..............................................................8
10. Package outline........................................................ 11
11. Legal information..................................................... 12
For more information, please visit: http://www.ween-semi.com
For sales office addresses, please send an email to: salesaddresses@ween-semi.com
Date of release: 5 September 2018
ACTT12-800CTN
Product data sheet
5 September 2018
14 / 14
