C4D10120E
VRRM = 1200 V
Silicon Carbide Schottky Diode
IF (TC=135˚C) = 16 A
Z-Rec Rectifier
Q c
Features
1.2kV Schottky Rectifier
Zero Reverse Recovery Current
High-Frequency Operation
Temperature-Independent Switching Behavior
Extremely Fast Switching
Positive Temperature Coefficient on VF
TO-252-2
Replace Bipolar with Unipolar Rectifiers
Essentially No Switching Losses
Higher Efficiency
Reduction of Heat Sink Requirements
Parallel Devices Without Thermal Runaway
Solar Inverters
Switch Mode Power Supplies (SMPS)
Boost diodes in PFC or DC/DC stages
Free Wheeling Diodes in Inverter stages
AC/DC converters
PIN 1
CASE
PIN 2
Applications
52 nC
Package
Benefits
Part Number
Package
Marking
C4D10120E
TO-252-2
C4D10120
Maximum Ratings (TC=25°C unless otherwise specified)
Symbol Parameter
Unit
Test Conditions
Note
VRRM
Repetitive Peak Reverse Voltage
1200
V
VRSM
Surge Peak Reverse Voltage
1300
V
VDC
DC Blocking Voltage
1200
V
33
16
10
A
TC=25˚C
TC=135˚C
TC=156˚C
47
31.5
A
TC=25˚C, tP=10 ms, Half Sine pulse
TC=110˚C, tP=10 ms, Half Sine pulse
71
59
A
Fig. 8
750
620
A
TC=25˚C, tP=10 ms, Pulse
TC=110˚C, tP=10 ms, Pulse
Fig. 8
166.5
72
W
TC=25˚C
TC=110˚C
Fig. 4
VR=0-960V
IF
Continuous Forward Current
IFRM
Repetitive Peak Forward Surge Current
IFSM
Non-Repetitive Peak Forward Surge Current
IF,Max
Non-Repetitive Peak Forward Current
Ptot
Power Dissipation
dV/dt
Diode dV/dt ruggedness
200
V/ns
∫i2dt
i2t value
25
17.5
A2s
-55 to
+175
˚C
TJ , Tstg
1
Value
Operating Junction and Storage Temperature
C4D10120E Rev. G, 01-2017
TC=25˚C, tP=10 ms
TC=110˚C, tP=10 ms
Fig. 3
Electrical Characteristics
Symbol
Parameter
Typ.
Max.
Unit
Test Conditions
Note
VF
Forward Voltage
1.5
2.2
1.8
3
V
IF = 10 A TJ=25°C
IF = 10 A TJ=175°C
Fig. 1
IR
Reverse Current
30
55
250
350
μA
VR = 1200 V TJ=25°C
VR = 1200 V TJ=175°C
Fig. 2
QC
Total Capacitive Charge
52
nC
VR = 800 V, IF = 10A
di/dt = 200 A/μs
TJ = 25°C
Fig. 5
C
Total Capacitance
754
45
38
pF
VR = 0 V, TJ = 25°C, f = 1 MHz
VR = 400 V, TJ = 25˚C, f = 1 MHz
VR = 800 V, TJ = 25˚C, f = 1 MHz
Fig. 6
EC
Capacitance Stored Energy
14.5
μJ
VR = 800 V
Fig. 7
Note: This is a majority carrier diode, so there is no reverse recovery charge.
Thermal Characteristics
Symbol
RθJC
Parameter
Thermal Resistance from Junction to Case
Typ.
Unit
Note
0.9
°C/W
Fig.9
Typical Performance
TJ=-55°C
T = 25°C
TJ= 75°C
J
T =125°C
TJ =175°C
J
18
16
4
14
12
IF (A)
IR (mA)
3
10
8
TJ=-55°C
T = 25°C
TJ= 75°C
J
T =125°C
TJ =175°C
J
2
6
4
1
2
1
1.5
2
2.5
3
VF (V)
Figure 1. Forward Characteristics
2
3.5
4
1000
VR (V)
1500
Figure 2. Reverse Characteristics
2000
Typical Performance
180.0
120
70
160.0
10%
20%
30%
50%
70%
DC
100
60
140.0
120.0
PTot (W)
IF(peak) (A)
50
80
Duty
Duty
Duty
Duty
Duty
100.0
40
60
30
80.0
60.0
40
20.0
25
50
50
75
75
100
100
125
125
150
150
0.0
175
175
25
50
75
TC ˚C
100
125
150
175
TC ˚C
Figure 3. Current Derating
Figure 4. Power Derating
70
800
60
700
600
50
C (pF)
Qc (nC)
500
40
30
400
300
10
100
400
600
800
0.1
VR (V)
Figure 5. Recovery Charge vs. Reverse Voltage
3
1
10
100
VR (V)
Figure 6. Capacitance vs. Reverse Voltage
1000
Typical Performance
25
25.0
1000
1000
EC Capacitive
Energy (uJ)
C
(A)
IFSMIFSM
(A)
E (mJ)
15
15.0
10
10.0
100
100
TJ_initial = 25°C
T
= 110°C
J_initial
5.05
0.00
0 200 400 600 800 1000
400
600
800
1000
10
10
1E-05 1E-04 1E-03 1E-02
1.E-05
1.E-04
1.E-03
1.E-02
tp(s)
tp (s)
VR Reverse Voltage (V)
VR (V)
Figure 7. Typical Capacitance Stored Energy
Figure 8. Non-repetitive peak forward surge current
versus pulse duration (sinusoidal waveform)
1
Thermal Resistance (˚C/W)
0.5
0.3
0.1
100E-3
0.05
0.02
SinglePulse
0.01
10E-3
1E-3
1E-6
10E-6
100E-6
1E-3
10E-3
T (Sec)
Figure 9. Transient Thermal Impedance
4
100E-3
1
Package Dimensions
SYMBOL
Package TO-252-2
A
A1
b
b2
b3
c
c2
D
D1
E
E1
e
H
L
L2
L3
L4
qθ
MILLIMETERS
MIN
MAX
2.159
2.413
0.64
0.89
0.653
1.143
5.004
5.6
0.457
0.61
0.457
0.864
5.867
6.248
5.21
6.35
7.341
4.32
4.58 BSC
9.65
10.414
1.106
1.78
0.51 BSC
0.889
1.27
0.64
1.01
0°
8°
Tjb June 2015
MX+DI+PSI
Recommended Solder Pad Layout
Part Number
Package
Marking
C4D10120E
TO-252-2
C4D10120
TO-252-2
Note: Recommended soldering profiles can be found in the applications note here:
http://www.wolfspeed.com/power_app_notes/soldering
5
Diode Model
Diode Model CSD04060
Vf TfT==
VTV+T+If*R
If*RT T
V
-3
V
VTT==0.965
+ (Tj *J*-1.3*10
) -3)
0.98+(T
-1.71*10
-3
RTT==0.096
+ (Tj * 1.06*10
) -4
0.040+(T
J* 5.32*10 )
Note: Tj = Diode Junction Temperature In Degrees Celsius,
valid from 25°C to 175°C
VT
RT
Notes
• RoHS Compliance
The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred
to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance
with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RRoHS Declarations for this product
can be obtained from your Wolfspeed representative or from the Product Ecology section of our website at http://
www.wolfspeed.com/power/tools-and-support/product-ecology.
• REACh Compliance
REACh substances of high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable
future,please contact a Cree representative to insure you get the most up-to-date REACh SVHC Declaration.
REACh banned substance information (REACh Article 67) is also available upon request.
This product has not been designed or tested for use in, and is not intended for use in, applications implanted into
the human body nor in applications in which failure of the product could lead to death, personal injury or property
damage, including but not limited to equipment used in the operation of nuclear facilities, life-support machines,
cardiac defibrillators or similar emergency medical equipment, aircraft navigation or communication or control
systems, or air traffic control systems.
Related Links
Cree SiC Schottky diode portfolio: http://www.wolfspeed.com/Power/Products#SiCSchottkyDiodes
Schottky diode Spice models: http://www.wolfspeed.com/power/tools-and-support/DIODE-model-request2
SiC MOSFET and diode reference designs: http://go.pardot.com/l/101562/2015-07-31/349i
Copyright © 2017 Cree, Inc. All rights reserved.
The information in this document is subject to change without notice.
Cree, the Cree logo, and Zero Recovery are registered trademarks of Cree, Inc.
6
Cree, Inc.
4600 Silicon Drive
Durham, NC 27703
USA Tel: +1.919.313.5300
Fax: +1.919.313.5451
www.cree.com/power
