ST1060STR
ST1060STR
    SMCDIODESOLUTIONS(桑德斯)
    TO277
    TRENCH SCHOTTKY RECTIFIERS 60V T
ST1060STR 数据手册
ST1060S Technical Data Data Sheet N1709 Rev. A ST1060S SCHOTTKY RECTIFIER Features 150C TJ operation Center tap configuration Ultra low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability “-A” is an AEC-Q101 qualified device This is a Pb − Free Device All SMC parts are traceable to the wafer lot           TO-277B Circuit Diagram Additional testing can be offered upon request Applications     Switching power supply Converters Free-Wheeling diodes Reverse battery protection Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Symbol VRRM VRWM VR Condition - Max. Units 60 V Average Rectified Forward Current IF (AV) 10 A Peak One Cycle Non-Repetitive Surge Current 50% duty cycle @Tc=80°C, rectangular wave form IFSM 8.3ms, Half Sine pulse, Tc= 25 C 275 A Electrical Characteristics: Characteristics Forward Voltage Drop* Reverse Current* Symbol VF1 IR1 IR2 Junction Capacitance CT Condition @ 10A, Pulse, TJ = 25 C @VR = rated VR TJ = 25 C @VR = rated VR TJ = 125 C @VR = 5V, TC = 25 C fSIG = 1MHz Typ. - Max. 0.60 Units V - 0.36 mA 20 - mA 850 - pF * Pulse width < 300 µs, duty cycle < 2%  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  ST1060S Technical Data Data Sheet N1709 Rev. A Thermal-Mechanical Specifications: Characteristics Junction Temperature Storage Temperature Typical Thermal Resistance Junction to Ambient (Note 2) Typical Thermal Resistance Junction to Case (Note1) Approximate Weight Symbol TJ Tstg Condition - Specification -55 to +150 -55 to +150 Units C C RJA DC operation 110 C/W RJC DC operation 10 C/W 0.08 g wt - Notes: 1. Mounted on an FR4 PCB, single-sided copper, with 100cm2 copper pad area. 2. Mounted on an FR4 PCB, single-sided copper, mini pad. Mechanical Dimensions TO-277B SYMBOL Millimeters Inches Min. Max. Min. Max. A 0.95 1.25 0.037 0.049 A1 0.20 0.30 0.008 0.012 b 0.85 0.95 0.033 0.037 b1 1.70 1.90 0.067 0.075 D 3.88 4.08 0.153 0.161 D1 2.90 3.20 0.114 0.126 e 1.74 1.94 0.069 0.076 E 6.30 6.70 0.248 0.264 E1 5.28 5.48 0.208 0.216 E2 3.40 3.70 0.134 0.146 L 0.70 1.00 0.028 0.039 L1 0.41 0.71 0.016 0.028 W 1.10 1.40 0.043 0.055 Carrier Tape Specification TO-277B SYMBOL A B C d d1 E F P P0 T W Millimeters Min. Max. 4.28 6.80 1.30 1.40 1.65 5.40 7.90 3.90 0.24 4.48 7.10 1.50 1.60 1.50 1.85 5.60 8.10 4.10 0.44 11.70 12.30  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  ST1060S Technical Data Data Sheet N1709 Rev. A Ordering Information Device ST1060S ST1060STR Package TO-277B(Pb-Free) TO-277B(Pb-Free) Marking Diagram Shipping 5000pcs/ reel 5000pcs/ reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. Where XXXXX is YYWWL ST 10 60 S YY WW L = Device Type = Forward Current (10A) = Reverse Voltage (60V) = Package type = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC Diode Solutions. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
ST1060STR 价格&库存
很抱歉,暂时无法提供与“ST1060STR”相匹配的价格&库存,您可以联系我们找货
