SICR5650
SICRB5650
SICRD5650
SICRF5650
Technical Data
Data Sheet N1870, Draft 1
SICR5650 / SICRB5650 / SICRD5650 / SICRF5650
650V SIC POWER SCHOTTKY RECTIFIER
Description
Features
SICR5650/ SICRB5650/ SICRD5650/ SICRF5650 are all
single SiC Schottky rectifiers packaged in TO-220AC,
D2PAK, DPAK and ITO-220ACcase. The device is a high
voltage Schottky rectifier that has very low total
conduction losses and very stable switching
characteristics over temperature extremes. The
SICR5650/ SICRB5650/ SICRD5650/ SICRF5650 are ideal
for energy sensitive, high frequency applications in
challenging environments.
Applications
Alternative energy inverters
Power Factor Correction (PFC)
Free-Wheeling diodes
Switching supply output rectification
Reverse polarity protection
175°C TJ operation
Ultra-low switching loss
Switching speeds independent of operating
temperature
Low total conduction losses
High forward surge current capability
High package isolation voltage
Guard ring for enhanced ruggedness and long term
reliability
Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional electrical and life testing can be performed
upon request
SICR5650
SICRB5650
SICRD5650
SICRF5650
TO-220AC
D2PAK
DPAK
ITO-220AC
Maximum Ratings:
Characteristics
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
Symbol
Condition
VRRM
VRWM
VR
Max.
Units
650
V
Average Rectified Forward Current
IF (AV)
5
A
Peak One Cycle Non-Repetitive Surge
Current
50% duty cycle @Tc=105°C,
rectangular wave form
IFSM
8.3ms, Half Sine pulse
60
A
China - Germany - Korea - Singapore - United States
http://www.smc-diodes.com - sales@ smc-diodes.com
SICR5650
SICRB5650
SICRD5650
SICRF5650
Technical Data
Electrical Characteristics:
Characteristics
Symbol
Forward Voltage Drop*
Reverse Current at DC condition*
Reverse Current *
Units
@ 5A, Pulse, TJ = 25 C
1.5
1.7
V
@ 5A, Pulse, TJ = 150 C
@VR = rated VR
TJ = 25 C
@VR = rated VR
TJ = 125 C
@VR = 5V, TC = 25 C
fSIG = 1MHz
Measured lead to lead 5 mm from
package body
Clip mounting, the epoxy body away
from the heatsink edge by more than
0.110" along the lead direction.
Clip mounting, the epoxy body is inside
the heatsink.
Screw mounting, the epoxy body is
inside the heatsink.
1.98
2.5
V
5
60
A
70
250
A
TBD
pF
TBD
nH
10,000
V/s
4500
3500
1500
IR1
LS
Voltage Rate of Change
RSM Isolation Voltage
(t = 1.0 second, R. H. < =30%,
TA = 25 C)
Max.
VF2
CT
Series Inductance
Typ.
VF1
IR2
Junction Capacitance
Condition
dv/dt
VISO
* Pulse width < 300 µs, duty cycle < 2%
V
Thermal-Mechanical Specifications:
Characteristics
Symbol
Junction Temperature
Storage Temperature
Maximum Thermal Resistance Junction
to Case
TJ
Tstg
RJC
Ordering Information
SICR5650
2.4
SICRB5650 SICRD5650
-55 to +175
-55 to +175
2.4
2.4
SICRF5650
Units
C
C
4.2
C/W
Tube Specification(TO-220AC/ITO-220AC)
Device
Package
Weight
Shipping
SICR5650
TO-220AC
1.8g
50pcs / tube
SICRB5650
D²PAK
1.85g
800pcs / reel
SICRD5650
DPAK
0.39g
2500pcs / reel
SICRF5650
ITO-220AC
1.8g
50pcs / tube
For information on tape and reel specifications, including part
orientation and tape sizes, please refer to our tape and reel
packaging specification.
SICR5650
SICRB5650
SICRD5650
SICRF5650
Technical Data
Marking Diagram
Where XXXXX is YYWWL
SICR
B/D/F
5
650
SSG
YY
WW
L
= Device Type
= Package type
= Forward Current (5A)
= Reverse Voltage (650V)
= SSG
= Year
= Week
= Lot Number
Cautions:Molding resin
Epoxy resin UL:94V-0
Carrier Tape & Reel Specification DPAK
SYMBOL
A
Millimeters
Min.
Max.
6.80
7.00
B
10.40
10.60
C
2.60
2.80
d
Φ1.45
Φ1.65
E
1.65
1.85
F
7.40
7.60
P0
3.90
4.10
P
7.90
8.10
P1
1.90
2.10
W
15.90
16.30
Carrier Tape & Reel Specification D2PAK
SYMBOL
Millimeters
Min.
Max.
A
10.70
10.90
B
16.03
16.23
C
5.11
5.31
d
1.45
1.65
E
1.65
1.85
F
11.40
11.60
P0
3.90
4.10
P
15.90
16.10
P1
1.90
2.10
W
23.90
24.30
SICR5650
SICRB5650
SICRD5650
SICRF5650
Technical Data
Mechanical Dimensions TO-220AC
Symbol
A
A1
A2
b
b1
c
D
D1
E
E1
e1
H1
L
L1
ΦP
Q
Θ1
Θ2
Θ3
Dimensions in millimeters
Min.
4.47
1.17
2.52
0.71
1.17
0.31
14.64
8.50
10.01
9.98
4.98
6.04
13.00
3.56
3.74
2.54
Typical
4.70
1.27
2.69
0.81
1.27
0.38
14.94
8.07
10.16
10.18
5.08
6.24
13.86
3.80
3.84
2.74
5°
4°
4°
Max.
4.85
1.37
2.89
0.96
1.37
0.61
15.24
8.90
10.31
10.38
5.18
6.44
14.08
3.96
4.04
2.94
Mechanical Dimensions DPAK
SYMBOL
A
A1
b
c
D
D1
D2
E
e
L
L1
L2
L3
L4
Φ
Θ
h
V
Millimeters
Inches
Min.
Max.
2.20
2.40
0.00
0.127
0.66
0.86
0.46
0.60
6.50
6.70
5.13
5.46
4.83 REF.
6.00
6.20
2.186
2.386
9.70
10.40
2.90 REF.
1.40
1.70
1.60 REF.
0.60
1.00
1.10
1.30
0°
8°
0.00
0.30
5.35 REF.
Min.
Max.
0.087
0.094
0.000
0.005
0.026
0.034
0.018
0.024
0.256
0.264
0.202
0.215
0.190 REF.
0.236
0.244
0.086
0.094
0.381
0.409
0.144 REF.
0.055
0.067
0.063 REF.
0.024
0.039
0.043
0.051
0°
8°
0.000
0.012
0.211 REF.
SICR5650
SICRB5650
SICRD5650
SICRF5650
Technical Data
Mechanical Dimensions D2PAK
Symbol
A
A1
A2
b
b1
c
c1
D
D1
E
E1
E2
e
H
L
L1
L2
L3
e
e1
e2
e3
Min.
4.55
0.71
0.36
1.17
8.55
6.40
10.01
7.6
9.98
14.6
2.00
1.17
Typical
4.70
0.10
2.69
0.81
1.27
0.38
1.27
8.70
Max.
4.85
0.25
2.89
0.96
10.16
10.31
10.08
2.54
15.1
2.30
1.27
10.18
0.25BSC
5°
4°
4°
0.61
1.37
8.85
15.6
2.70
1.40
2.20
8°
Mechanical Dimensions ITO-220AC
SYMBOL
A
A1
A2
A3
b
b1
c
D
E
e
H1
L
L1
L2
L3
ΦP1(上口)
ΦP2(下口)
Q
Θ1
Θ2
Θ3
Θ4
Θ5
MIN.
4.30
1.10
2.50
2.50
0.50
1.10
0.50
14.80
9.96
6.50
12.70
1.60
0.80
0.60
3.30
2.99
2.50
Millimeters
TYP.
4.50
1.30
3.00
2.70
0.60
1.20
0.60
15.00
10.16
5.10
6.70
13.20
1.80
1.00
0.80
3.50
3.19
2.70
5°
4°
10°
5°
5°
MAX.
4.70
1.50
3.20
2.90
0.85
1.35
0.85
15.20
10.36
6.90
13.70
2.00
1.20
1.00
3.70
3.39
2.90
SICR5650
SICRB5650
SICRD5650
SICRF5650
Technical Data
DISCLAIMER:
1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product
characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales
department for the latest version of the datasheet(s).
2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment,
medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by
means of users’ fail-safe precautions or other arrangement .
3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or
any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd
assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information,
products or circuits described in the datasheets.
4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any
secondary damage resulting from use at a value exceeding the absolute maximum rating.
5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics
(Nanjing) Co., Ltd.
6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC
- Sangdest Microelectronics (Nanjing) Co., Ltd.
7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will
hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third
party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and
regulations..
很抱歉,暂时无法提供与“SICRD5650TR”相匹配的价格&库存,您可以联系我们找货
