ES3DV M6G
ES3DV M6G
    TAIWANSEMICONDUCTOR(台半)
    DO214AB
    DIODE GEN PURP 200V 3A DO214AB
ES3DV M6G 数据手册
ES3DV Taiwan Semiconductor 3A, 200V Ultra Fast Surface Mount Rectifier FEATURES ● ● ● ● ● ● KEY PARAMETERS Glass passivated chip junction Ideal for automated placement Ultra Fast recovery time for high efficiency Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● High frequency rectification ● Freewheeling application ● Switching mode converters and inverters in computer, telecommunication PARAMETER VALUE UNIT IF 3 A VRRM 200 V IFSM 100 A TJ MAX 150 °C Package DO-214AB (SMC) Configuration Single die MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AB (SMC) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.210g (approximately) DO-214AB (SMC) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device ES3DV UNIT ES3DV Repetitive peak reverse voltage VRRM 200 V Reverse voltage, total rms value VR(RMS) 140 V Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 3 A IFSM 100 A TJ - 55 to +150 °C Storage temperature TSTG - 55 to +150 °C 1 Version: D2102 ES3DV Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 17 °C/W Junction-to-ambient thermal resistance RӨJA 50 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR IF = 3A, TJ = 25°C (2) Junction capacitance Reverse recovery time TJ = 25°C SYMBOL TYP MAX UNIT VF - 0.9 V - 10 µA - 500 µA CJ 45 - pF trr - 20 ns IR TJ = 125°C 1MHz, VR = 4.0V IF = 0.5A, IR = 1.0A, Irr = 0.25A Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE PACKAGE PACKING ES3DV DO-214AB (SMC) 3,000 / Tape & Reel 2 Version: D2102 ES3DV Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 90 75 3 CAPACITANCE (pF) 2 1 60 45 30 15 0 f=1.0MHz Vsig=50mVp-p 0 25 50 75 100 125 150 0.1 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 1 TJ=25°C 0.1 20 30 40 50 60 70 80 90 100 10 10 UF1DLW 1 TJ=125°C TJ=125°C 1 0.1 TJ=25°C TJ=25°C 0.01 0.1 0.001 0.4 0.3 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% duty cycle Pulse width 0.6 0.4 0.5 0.8 0.6 0.7 1.0 0.8 0.9 1.2 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 120 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.4 Typical Forward Characteristics 100 10 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 (A) AVERAGE FORWARD CURRENT (A) 4 8.3ms single half sine wave 100 80 60 40 20 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: D2102 1.2 ES3DV Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AB (SMC) SUGGESTED PAD LAYOUT MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: D2102 ES3DV Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: D2102
ES3DV M6G 价格&库存
很抱歉,暂时无法提供与“ES3DV M6G”相匹配的价格&库存,您可以联系我们找货
