C3D08065I
VRRM
Silicon Carbide Schottky Diode
Z-Rec®
IF (TC=130˚C)
Rectifier
Q c
Features
650 V
8A
21 nC
Package
650-Volt Schottky Rectifier
Ceramic Package Provides 2.5kV Isolation
Zero Reverse Recovery Current
High-Frequency Operation
Temperature-Independent Switching Behavior
Positive Temperature Coefficient on VF
TO-220 Isolated
Benefits
Electrically Isolated Package
Essentially No Switching Losses
Higher Efficiency
Reduction of Heat Sink Requirements
Parallel Devices Without Thermal Runaway
PIN 1
CASE
PIN 2
Applications
HVAC
Switch Mode Power Supplies (SMPS)
Boost diodes in PFC or DC/DC stages
Free Wheeling Diodes in Inverter Stages
AC/DC converters
Maximum
Package
Marking
C3D08065I
Isolated TO-220-2
C3D08065I
Ratings (TC = 25˚C unless otherwise specified)
Symbol Parameter
Value
Unit
VRRM
Repetitive Peak Reverse Voltage
650
V
VRSM
Surge Peak Reverse Voltage
650
V
VDC
DC Blocking Voltage
650
V
Continuous Forward Current
16.5
8
7.5
A
IF
Test Conditions
TC=25˚C
TC=130˚C
TC=135˚C
Note
Fig. 3
IFRM
Repetitive Peak Forward Surge Current
29
19
A
TC=25˚C, tP=10 ms, Half Sine Wave
TC=110˚C, tP=10 ms, Half Sine Wave
IFSM
Non-Repetitive Peak Forward Surge Current
69
55
A
Fig. 8
IF,Max
650
530
A
TC=25˚C, tP = 10 µs, Pulse
TC=110˚C, tP = 10 µs, Pulse
Fig. 8
Power Dissipation
53.6
23.2
W
TC=25˚C
TC=110˚C
Fig. 4
dV/dt
Diode dV/dt ruggedness
200
V/ns
VR=0-650V
∫i2dt
i2t value
23.8
15
A2s
-55 to
+175
˚C
1
8.8
Nm
lbf-in
Ptot
TJ , Tstg
Operating Junction and Storage Temperature
TO-220 Mounting Torque
1
Part Number
C3D08065I Rev. C, 01-2018
TC=25˚C, tP=10 ms
TC=110˚C, tP=10 ms
M3 Screw
6-32 Screw
Electrical Characteristics
Symbol
Parameter
Typ.
Max.
Unit
VF
Forward Voltage
1.5
2.1
1.8
2.4
V
IR
Reverse Current
10
12
51
204
QC
Total Capacitive Charge
C
EC
Test Conditions
Note
IF = 8 A TJ=25°C
IF = 8 A TJ=175°C
Fig. 1
μA
VR = 650 V TJ=25°C
VR = 650 V TJ=175°C
Fig. 2
nC
VR = 400 V, IF = 8A
di/dt = 500 A/μs
TJ = 25°C
Fig. 5
Total Capacitance
395
37
32
pF
VR = 0 V, TJ = 25°C, f = 1 MHz
VR = 200 V, TJ = 25˚C, f = 1 MHz
VR = 400 V, TJ = 25˚C, f = 1 MHz
Fig. 6
Capacitance Stored Energy
3.0
μJ
VR = 400 V
Fig. 7
Note:This is a majority carrier diode, so there is no reverse recovery charge.
Thermal Characteristics
Symbol
RθJC
Parameter
Package Thermal Resistance from Junction to Case
Typ.
Unit
Note
2.8
°C/W
Fig. 8
Typical Performance
18
TJ = -55 °C
25
14
Reverse Leakage Current, IRR (mA)
TJ = 25 °C
TJ = 75 °C
12
10
IR (mA)
TJ = 125 °C
TJ = 175 °C
F
FowardICurrent,
(A) IF (A)
16
8
6
4
2
TJ = 175 °C
TJ = 125 °C
15
TJ = 75 °C
10
TJ = 25 °C
TJ = -55 °C
5
0.5
1.0
1.5
2.0
2.5
3.0
FowardVVoltage,
(V) VF (V)
F
Figure 1. Forward Characteristics
2
3.5
4.0
100 200 300 400 500 600 700 800 900 1000
ReverseVVoltage,
(V) VR (V)
R
Figure 2. Reverse Characteristics
Typical Performance
60
60
10% Duty
20% Duty
30% Duty
50% Duty
70% Duty
DC
50
40
PTot (W)
IF(peak) (A)
40
50
30
30
10
50
75
100
125
150
25
50
75
TC ˚C
450
175
Conditions:
TJ = 25 °C
Ftest = 1 MHz
Vtest = 25 mV
400
350
Capacitance
C (pF)(pF)
CapacitiveQCharge,
(nC) QC (nC)
C
150
Figure 4. Power Derating
Conditions:
TJ = 25 °C
25
125
TC ˚C
Figure 3. Current Derating
30
100
15
10
300
250
200
150
100
5
50
200
300
400
500
600
700
ReverseVVoltage,
(V) VR (V)
R
Figure 5. Total Capacitance Charge vs. Reverse Voltage
3
10
100
(V) VR (V)
ReverseVVoltage,
R
Figure 6. Capacitance vs. Reverse Voltage
1000
Typical Performance
1,000
8
6
IFSM
I (A)
(A)
5
FSM
4
C
Capacitance StoredE Energy,
µJ)
(mJ) EC (µ
7
3
100
TJ = 25 °C
TJ = 110 °C
2
1
200
300
400
500
600
10
10E-6
700
100E-6
ReverseVVoltage,
(V) VR (V)
1E-3
tp (s)
Time,
tp (s)
R
Figure 8. Non-repetitive peak forward surge current
versus pulse duration (sinusoidal waveform)
Figure 7. Capacitance Stored Energy
Thermal Resistance (˚C/W)
0.5
1
0.3
0.1
0.05
100E-3
0.02
SinglePulse
0.01
10E-3
1E-3
1E-6
10E-6
100E-6
1E-3
10E-3
T (Sec)
100E-3
Figure 9. Transient Thermal Impedance
4
10E-3
1
10
Package Dimensions
Package TO-220-2
Recommended Solder Pad Layout
TO-220-2
Part Number
Package
Marking
C3D08065I
Isolated TO-220-2
C3D08065I
Note: Recommended soldering profiles can be found in the applications note here:
http://www.wolfspeed.com/power_app_notes/soldering
5
Diode Model
Diode Model CSD04060
Vf T = VT + If*RT
VT= 0.965 + (Tj * -1.3*10-3)
RT= 0.096 + (Tj * 1.06*10-3)
VfT = VT + If * RT
VT = 0.95 + (TJ * -1.2*10-3)
RT = 0.054 + (TJ * 5.5*10-4)
VT
RT
Note: Tj = Diode Junction Temperature In Degrees Celsius,
valid from 25°C to 175°C
Notes
• RoHS Compliance
The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred
to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance
with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can
be obtained from your Wolfspeed representative or from the Product Ecology section of our website at http://
www.wolfspeed.com/power/tools-and-support/product-ecology.
• REACh Compliance
REACh substances of high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable
future,please contact a Cree representative to insure you get the most up-to-date REACh SVHC Declaration.
REACh banned substance information (REACh Article 67) is also available upon request.
This product has not been designed or tested for use in, and is not intended for use in, applications implanted into
the human body nor in applications in which failure of the product could lead to death, personal injury or property
damage, including but not limited to equipment used in the operation of nuclear facilities, life-support machines,
cardiac defibrillators or similar emergency medical equipment, aircraft navigation or communication or control
systems, or air traffic control systems.
Related Links
Cree SiC Schottky diode portfolio: http://www.wolfspeed.com/Power/Products#SiCSchottkyDiodes
Schottky diode Spice models: http://www.wolfspeed.com/power/tools-and-support/DIODE-model-request2
SiC MOSFET and diode reference designs: http://go.pardot.com/l/101562/2015-07-31/349i
Copyright © 2018 Cree, Inc. All rights reserved.
The information in this document is subject to change without notice.
Cree, the Cree logo, and Zero Recovery are registered trademarks of Cree, Inc.
6
Cree, Inc.
4600 Silicon Drive
Durham, NC 27703
USA Tel: +1.919.313.5300
Fax: +1.919.313.5451
www.cree.com/power
