LPC47N217-JV
LPC47N217-JV
    ROCHESTER(罗切斯特)
    LQFP64
    SUPER I/O CONTROLLER
LPC47N217-JV 数据手册
LPC47N217 64-Pin Super I/O with LPC Interface Data Brief Product Features ƒ 3.3 Volt Operation (5V tolerant) ƒ Multi-Mode Parallel Port with ChiProtect − Standard Mode IBM PC/XT, PC/AT, and PS/2 Compatible Bidirectional Parallel Port − Enhanced Parallel Port (EPP) Compatible - EPP 1.7 and EPP 1.9 (IEEE 1284 Compliant) − IEEE 1284 Compliant Enhanced Capabilities Port (ECP) − ChiProtect Circuitry for Protection Against Damage Due to Printer Power-On − 192 Base I/O Address, 15 IRQ and 3 DMA Options ƒ Programmable Wakeup Event Interface (IO_PME# Pin) ƒ SMI Support (IO_SMI# Pin) ƒ GPIOs (14) ƒ Two IRQ Input Pins ƒ XNOR Chain ƒ PC99a, PC2001 ƒ ACPI 2.0 Compliant ƒ LPC Bus Host Interface ƒ 64-pin STQFP Lead-free RoHS Compliant Package − − − − − ƒ Intelligent Auto Power Management ƒ Serial Ports − One Full Function Serial Port − High Speed 16C550A Compatible UART with Send/Receive 16-Byte FIFO − Supports 230k and 460k Baud − Programmable Baud Rate Generator − Modem Control Circuitry − − Multiplexed Command, Address and Data Bus 8-Bit I/O Transfers 8-Bit DMA Transfers 16-Bit Address Qualification Serial IRQ Interface Compatible with Serialized IRQ Support for PCI Systems PCI CLKRUN# Support Power Management Event (IO_PME#) Interface Pin ƒ Infrared Communications Controller − IrDA v1.2 (4Mbps), HPSIR, ASKIR, Consumer IR Support − 1 IR Port − 96 Base I/O Address, 15 IRQ Options and 3 DMA Options ORDERING INFORMATION Order Number: LPC47N217-JV for 64 pin STQFP lead-free RoHS compliant package SMSC LPC47N217 Page 1 PRODUCT PREVIEW Revision 0.2 (03-29-07) 80 ARKAY DRIVE, HAUPPAUGE, NY 11788 (631) 435-6000, FAX (631) 273-3123 Copyright © 2007 SMSC or its subsidiaries. All rights reserved. Circuit diagrams and other information relating to SMSC products are included as a means of illustrating typical applications. Consequently, complete information sufficient for construction purposes is not necessarily given. Although the information has been checked and is believed to be accurate, no responsibility is assumed for inaccuracies. SMSC reserves the right to make changes to specifications and product descriptions at any time without notice. Contact your local SMSC sales office to obtain the latest specifications before placing your product order. The provision of this information does not convey to the purchaser of the described semiconductor devices any licenses under any patent rights or other intellectual property rights of SMSC or others. All sales are expressly conditional on your agreement to the terms and conditions of the most recently dated version of SMSC's standard Terms of Sale Agreement dated before the date of your order (the "Terms of Sale Agreement"). The product may contain design defects or errors known as anomalies which may cause the product's functions to deviate from published specifications. Anomaly sheets are available upon request. SMSC products are not designed, intended, authorized or warranted for use in any life support or other application where product failure could cause or contribute to personal injury or severe property damage. Any and all such uses without prior written approval of an Officer of SMSC and further testing and/or modification will be fully at the risk of the customer. Copies of this document or other SMSC literature, as well as the Terms of Sale Agreement, may be obtained by visiting SMSC’s website at http://www.smsc.com. SMSC is a registered trademark of Standard Microsystems Corporation (“SMSC”). Product names and company names are the trademarks of their respective holders. SMSC DISCLAIMS AND EXCLUDES ANY AND ALL WARRANTIES, INCLUDING WITHOUT LIMITATION ANY AND ALL IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, TITLE, AND AGAINST INFRINGEMENT AND THE LIKE, AND ANY AND ALL WARRANTIES ARISING FROM ANY COURSE OF DEALING OR USAGE OF TRADE. IN NO EVENT SHALL SMSC BE LIABLE FOR ANY DIRECT, INCIDENTAL, INDIRECT, SPECIAL, PUNITIVE, OR CONSEQUENTIAL DAMAGES; OR FOR LOST DATA, PROFITS, SAVINGS OR REVENUES OF ANY KIND; REGARDLESS OF THE FORM OF ACTION, WHETHER BASED ON CONTRACT; TORT; NEGLIGENCE OF SMSC OR OTHERS; STRICT LIABILITY; BREACH OF WARRANTY; OR OTHERWISE; WHETHER OR NOT ANY REMEDY OF BUYER IS HELD TO HAVE FAILED OF ITS ESSENTIAL PURPOSE, AND WHETHER OR NOT SMSC HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. Revision 0.2 (03-29-07) Page 2 PRODUCT PREVIEW SMSC LPC47N217 General Description The SMSC LPC47N217 is a 3.3V PC 99, PC2001, and ACPI 2.0 compliant Super I/O Controller. The LPC47N217 implements the LPC interface, a pin reduced ISA interface which provides the same or better performance as the ISA/X-bus with a substantial savings in pins used. The part also includes 14 GPIO pins. The LPC47N217 incorporates a 16C550A compatible UART and one Multi-Mode parallel port with ChiProtect™ circuitry plus EPP and ECP support. This device also offers a full 16-bit internally decoded address bus, a Serial IRQ interface with PCI CLKRUN# support, relocatable configuration ports, and three DMA channel options. The on-chip UART is compatible with the 16C550A. There is a dedicated Serial Infrared interface UART, which complies with IrDA v1.2 (Fast IR), HPSIR, and ASKIR formats (used by Sharp and other PDAs), as well as Consumer IR. The parallel port is compatible with IBM PC/AT architectures, as well as IEEE 1284 EPP and ECP. The parallel port ChiProtect™ circuitry prevents damage caused by an attached powered printer when the LPC47N217 is not powered. The LPC47N217 features Software Configurable Logic (SCL) for ease of use. SCL allows programmable system configuration of key functions such as the parallel port and UART. The LPC47N217 supports the ISA Plug-and-Play Standard register set (Version 1.0a) and provides the recommended functionality to support Windows operating systems, PC99, and PC2001. The I/O Address, DMA Channel, and Hardware IRQ of each device in the LPC47N217 may be reprogrammed through the internal configuration registers. There are multiple I/O address location options, a Serialized IRQ interface, and three DMA channels. SMSC LPC47N217 Page 3 PRODUCT PREVIEW Revision 0.2 (03-29-07) Block Diagram PD[0:7], IO_SMI#* IO_PME# MULTI-MODE PARALLEL PORT SMI PME WDT CONTROL, ADDRESS, DATA LAD0 LAD1 LAD2 LAD3 LFRAME# LDRQ# PCI_RESET# SERIAL IRQ IRQIN1*, IRQIN2* ACPI BLOCK CONFIGURATION REGISTERS nSLCTIN, nALF nINIT, nSTROBE GP10, GP11, GP12*, GP13*, GP14*, GP23*, GP4[0:7] GENERAL PURPOSE I/O SER_IRQ PCI_CLK BUSY, SLCT, PE, nERROR, nACK TXD1, nRTS1, nDTR1 16C550 COMPATIBLE SERIAL PORT 1 LPC BUS INTERFACE nCTS1, RXD1, nDSR1, nDCD1, nRI1 LPCPD# CLKRUN# IRTX2, IRMODE* INFRARED INTERFACE IRRX2, IRRX3* CLOCK GEN V TR Vcc Vss CLOCKI * Denotes Multifunction Pins Figure 1 - LPC47N217 Block Diagram Revision 0.2 (03-29-07) Page 4 PRODUCT PREVIEW SMSC LPC47N217 Package Outline Figure 2 - 64 Pin STQFP Package Outline, 7x7x1.4 Body, 2 MM Footprint Table 1 - 64 Pin STQFP Package Parameters A A1 A2 D D1 E E1 H L L1 e θ W ccc MIN ~ 0.05 1.35 8.80 6.80 8.80 6.80 0.09 0.45 ~ o 0 0.13 ~ NOMINAL ~ ~ 1.40 9.00 7.00 9.00 7.00 ~ 0.60 1.00 REF. 0.40 Basic ~ 0.18 ~ MAX 1.60 0.15 1.45 9.20 7.20 9.20 7.20 0.20 0.75 ~ REMARKS Overall Package Height Standoff Body Thickness X Span X body Size Y Span Y body Size Lead Frame Thickness Lead Foot Length Lead Length Lead Pitch Lead Foot Angle Lead Width Coplanarity 7o 0.23 0.08 Notes: 1. Controlling Unit: millimeter. 2. Tolerance on the true position of the leads is ± 0.035 mm maximum. 3. Package body dimensions D1 and E1 do not include the mold protrusion. Maximum mold protrusion is 0.25 mm per side. D1 and E1 dimensions determined at datum plane H. 4. Dimension for foot length L measured at the gauge plane 0.25 mm above the seating plane. 5. Details of pin 1 identifier are optional but must be located within the zone indicated. SMSC LPC47N217 Page 5 PRODUCT PREVIEW Revision 0.2 (03-29-07)
LPC47N217-JV 价格&库存
很抱歉,暂时无法提供与“LPC47N217-JV”相匹配的价格&库存,您可以联系我们找货
