NJU7141F-TE1
NJU7141F-TE1
    NJR(新日本无线)
    SOT23-5
    LOW-VOLTAGE OPERATION TINY SINGL
NJU7141F-TE1 数据手册
NJU7141 LOW-VOLTAGE OPERATION TINY SINGLE CMOS COMPARATOR ■ GENERAL DESCRIPTION The NJU7141 is a low voltage single-power-supply operation single CMOS comparator with open drain output. The NJU7141 operated from 1 to 5.5V supply and interface with most of TTL and CMOS type standard logic ICs. The NJU7141 is in SOT−23−5 package, and it is suitable for battery use items and other portable system. ■ PACKAGE OUTLINE ■ FEATURES ● Single-Power-Supply ● Input Offset Voltage ● Low Operating Current ● Low Input Bias Current ● Open Drain Output ● Output Signal Falling Time ● C-MOS Technology ● Package Outline ■ PIN CONFIGURATION NJU7141F ( VDD=1 to 5.5V ) ( VIO=10mV max.@ 3.0V ) ( IDD=5µA typ. ) ( IIB=1pA typ. ) ( 30ns typ. ) SOT−23−5 ■ EQUIVALENT CIRCUIT Ver.2012-10-31 -1- NJU7141 ■ ABSOLUTE MAXIMUM RATINGS ( Ta=25˚C ) PARAMETER Supply Voltage Differential Input Voltage Common Mode Input Voltage Power Dissipation Operating Temperature Range Storage Temperature Range SYMBOL VIN VID VIC PD Topr Tstg RATINGS 7 ± 7 ( note1 ) -0.3~7 200 -40~+85 -55~+125 UNIT V V V mW ˚C ˚C ( note1 ) If the supply voltage ( VDD ) is less than 7V, the input voltage must not over the VDD level though 7V is limit specified. ( note2 ) Decoupling capacitor should be connected between VDD and VSS due to the stabilized operation for the circuit. ■ ELECTRICAL CHARACTERISTICS ( Ta=25˚C,VDD=3.0V,RL=∞ ) PARAMETER Operating Voltage Input Offset Voltage Input Offset Current Input Bias Current Input Common Mode Voltage Range Output Leakage Current Low Level Output Voltage Common Mode Rejection Ratio Supply Voltage Rejection Ratio Operating Current SYMBOL VDD VIO IIO IIB VICM IOFF VOL CMR SVR IDD TEST CONDITION VIN=1/2VDD VOH=VDD IOL=-2mA VIC=1/2VDD VDD=3~5V No Load,VO=0V MIN. 1.0 0~2.5 55 60 - TYP. 1 1 5 MAX. 5.5 10 1 0.3 12 UNIT V mV pA pA V µA V dB dB µA ■ SWITCHING CHARACTERISTICS ( Ta=25˚C,VDD=3.0V,f=10kHz,CL=15pF ) PARAMETER Propagation Delay High to Low Propagation Delay Low to High Output Signal Falling Time -2- SYMBOL tPHL tPLH tTHL CONDITIONS Over Drive=100mV VIC=0V TTL Level Step Over Drive=100mV VIC=0V TTL Level Step Over Drive=100mV MIN. - TYP. 0.35 0.10 0.90 0.60 MAX. - UNIT - 30 - ns µs µs Ver.2012-10-31 NJU7141 ■ SWITCHING CHARACTERISTICS MEASUREMENT CIRCUIT ■ TIMING WAVEFORM [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. Ver.2012-10-31 -3-
NJU7141F-TE1 价格&库存
很抱歉,暂时无法提供与“NJU7141F-TE1”相匹配的价格&库存,您可以联系我们找货
