π120M30
π120M30
    2PAISEMI(荣湃)
    SOIC8_150MIL
    数字隔离器 10Mbps 3KVrms 3~5.5V SOIC8_150MIL
π120M30 数据手册
2Pai Semi Enhanced ESD, 3.0 kV rms/6.0 kV rms 10Mbps Dual-Channel Digital Isolators π120M/π121M/π122M Data Sheet FEATURES Ultra low power consumption (1Mbps): 0.58mA/Channel High data rate: π12xAxx: 600Mbps π12xExx: 200Mbps π12xMxx: 10Mbps π12xUxx: 150kbps High common-mode transient immunity: 75 kV/µs typical High robustness to radiated and conducted noise Low propagation delay: 8 ns typical for 5 V operation 9 ns typical for 3.3 V operation Isolation voltages: π12xx3x: AC 3000Vrms π12xx6x: AC 6000Vrms High ESD rating: ESDA/JEDEC JS-001-2017 Human body model (HBM) ±8kV, all pins Safety and regulatory approvals (Pending): UL certificate number: E494497 3000Vrms/6000Vrms for 1 minute per UL 1577 CSA Component Acceptance Notice 5A VDE certificate number: 40047929 DIN V VDE V 0884-10 (VDE V 0884-10):2006-12 VIORM = 707V peak/1200V peak CQC certification per GB4943.1-2011 3 V to 5.5 V level translation Wide temperature range: -40°C to 125°C 8/16-lead, RoHS-compliant, (W)SOIC package APPLICATIONS The π1xxxxx isolator data channels are independent and are available in a variety of configurations with a withstand voltage rating of 1.5 kV rms to 6.0 kV rms and the data rate from DC up to 600Mbps (see the Ordering Guide). The devices operate with the supply voltage on either side ranging from 3.0 V to 5.5 V, providing compatibility with lower voltage systems as well as enabling voltage translation functionality across the isolation barrier. The fail-safe state is available in which the outputs transition to a preset state when the input power supply is not applied. FUNCTIONAL BLOCK DIAGRAMS π120X3X VDD1 1 8 VDD2 VIA 2 7 VOA VIB 3 6 VOB GND1 4 5 GND2 π121X3X VDD1 1 8 VDD2 VIA 2 7 VOA OB V 3 6 VIB GND1 4 5 GND2 VDD1 1 VOA 2 VIB GND 1 π122X3X 8 VDD2 7 VIA 3 6 VOB 4 5 GND2 General-purpose multichannel isolation Industrial field bus isolation GENERAL DESCRIPTION The π1xxxxx is a 2PaiSemi digital isolators product family that includes over hundreds of digital isolator products. By using maturated standard semiconductor CMOS technology and 2PaiSEMI iDivider technology, these isolation components provide outstanding performance characteristics and reliability superior to alternatives such as optocoupler devices and other integrated isolators. Intelligent voltage divider technology (iDivider technology) is a new generation digital isolator technology invented by 2PaiSEMI. It uses the principle of capacitor voltage divider to transmit voltage signal directly cross the isolator capacitor without signal modulation and demodulation. π120X6X GND 1 1 16 GND2 NC 2 15 NC VDD1 3 14 VDD2 VIA 4 13 VOA VIB 5 12 VOB NC 6 11 NC GND 1 7 10 NC GND 1 8 9 GND2 GND 1 1 16 GND2 NC 2 15 NC VDD1 3 14 VDD2 VIA 4 13 VOA VOB 5 12 VIB NC 6 11 NC GND 1 7 10 NC GND 1 8 9 GND2 GND1 1 16 GND2 NC 2 15 NC VDD1 3 14 VDD2 VOA 4 13 VIA VIB 5 12 VOB π121X6X π122X6X NC 6 11 NC GND 1 7 10 NC GND1 8 9 GND2 Figure1. π120xxx/π121xxx/π122xxx functional Block Diagram VDD1 VDD2 CIN COUT 0.1uF 0.1uF 1 2 3 4 VIN_A VIN_B GND1 VDD1 VIA VIB GND1 VDD2 VOA VOB GND 2 π120 8 7 6 5 VOUT_A VOUT_B GND2 Figure2. π120xxx Typical Application Circuit Rev.1 Information furnished by 2Pai semi is believed to be accurate and reliable. However, no responsibility is assumed by 2Pai semi for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of 2Pai semi. Trademarks and registered trademarks are the property of their respective owners. Room 308-309, No.22, Boxia Road, Pudong New District, Shanghai, 201203, China 021-50850681 2Pai Semiconductor Co., Limited. All rights reserved. http://www.rpsemi.com/ π120M/π121M/π122M Data Sheet PIN CONFIGURATIONS AND FUNCTIONS π120M3x Pin Function Descriptions Pin No. Name Description 1 VDD1 Supply Voltage for Isolator Side 1. 2 VIA Logic Input A. 3 VIB Logic Input B. 4 GND1 Ground 1. This pin is the ground reference for Isolator Side 1. 5 GND2 Ground 2. This pin is the ground reference for Isolator Side 2. 6 VOB Logic Output B. 7 VOA Logic Output A. 8 VDD2 Supply Voltage for Isolator Side 2. Figure3. π120M3x Pin Configuration π121M3x Pin Function Descriptions Pin No. Name Description 1 VDD1 Supply Voltage for Isolator Side 1. VIA 2 2 VIA Logic Input A. VOB 3 3 VOB Logic Output B. GND1 4 4 GND1 Ground 1. This pin is the ground reference for Isolator Side 1. 5 GND2 Ground 2. This pin is the ground reference for Isolator Side 2. 6 VIB Logic Input B. 7 VOA Logic Output A. 8 VDD2 Supply Voltage for Isolator Side 2. VDD1 1 π121x4 8 VDD2 7 VOA TOP VIEW (Not to scale) 6 VIB 5 GND2 Figure4. π121M3x Pin Configuration π122M3x Pin Function Descriptions Pin No. Name Description 1 VDD1 Supply Voltage for Isolator Side 1. VOA 2 2 VOA Logic Output A. VIB 3 3 VIB Logic Input B. 4 GND1 Ground 1. This pin is the ground reference for Isolator Side 1. 5 GND2 Ground 2. This pin is the ground reference for Isolator Side 2. 6 VOB Logic Output B. 7 VIA Logic Input A. 8 VDD2 Supply Voltage for Isolator Side 2. VDD1 1 GND1 4 π120M6x Pin Function Descriptions π122x4 7 VIA TOP VIEW (Not to scale) 6 VOB 5 GND2 Figure5. π122M3x Pin Configuration 16 GND2 GND1 1 Pin No. Name Description 1 GND1 Ground 1. This pin is the ground reference for Isolator Side 1. 2 NC No connect. 3 VDD1 Supply Voltage for Isolator Side 1. 4 VIA Logic Input A. VIB 5 5 VIB Logic Input B. NC 6 6 NC No Connect. 7 GND1 Ground 1. This pin is the ground reference for Isolator Side 1. 8 GND1 Ground 1. This pin is the ground reference for Isolator Side 1. 9 GND2 Ground 2. This pin is the ground reference for Isolator Side 2. Rev. 1 | Page 2 of 15 8 VDD2 π120x6 NC 2 VDD1 3 14 VDD2 VIA 4 13 VOA TOP VIEW (Not to scale) 15 NC 12 VOB 11 NC GND1 7 10 NC GND1 8 9 GND2 Figure6. π120M6x Pin Configuration π120M/π121M/π122M Data Sheet 10 NC No Connect. 11 NC No Connect. 12 VOB Logic Output B. 13 VOA Logic Output A. 14 VDD2 Supply Voltage for Isolator Side 2. 15 NC No Connect. 16 GND2 Ground 2. This pin is the ground reference for Isolator Side 2. π121M6x Pin Function Descriptions Pin No. Name Description 1 GND1 Ground 1. This pin is the ground reference for Isolator Side 1. 2 NC No Connect. 3 VDD1 Supply Voltage for Isolator Side 1. 4 VIA Logic Input A. 5 VOB Logic Output B. 6 NC No Connect. 7 GND1 Ground 1. This pin is the ground reference for Isolator Side 1. 8 GND1 Ground 1. This pin is the ground reference for Isolator Side 1. 9 GND2 Ground 2. This pin is the ground reference for Isolator Side 2. 10 NC No Connect. 11 NC No Connect. 12 VIB Logic Input B. 13 VOA Logic Output A. 14 VDD2 Supply Voltage for Isolator Side 2. 15 NC No Connect. 16 GND2 Ground 2. This pin is the ground reference for Isolator Side 2. GND1 1 NC 2 16 GND2 π121x6 15 NC VDD1 3 14 VDD2 VIA 4 13 VOA VOB 5 NC 6 TOP VIEW (Not to scale) 12 VIB 11 NC GND1 7 10 NC GND1 8 9 GND2 Figure7. π121M6x Pin Configuration Figure8. π121x6 Pin Configuration π122M6x Pin Function Descriptions Pin No. Name Description 1 GND1 Ground 1. This pin is the ground reference for Isolator Side 1. 2 NC No Connect. 3 VDD1 Supply Voltage for Isolator Side 1. 4 VOA Logic Output A. 5 VIB Logic Input B. 6 NC No Connect. 7 GND1 Ground 1. This pin is the ground reference for Isolator Side 1. 8 GND1 Ground 1. This pin is the ground reference for Isolator Side 1. GND1 7 10 NC GND1 8 9 GND2 GND1 1 NC 2 9 GND2 Ground 2. This pin is the ground reference for Isolator Side 2. 10 NC No Connect. 11 NC No Connect. 12 VOB Logic Output B. 13 VIA Logic Input A. 14 VDD2 Supply Voltage for Isolator Side 2. 15 NC No Connect. 16 GND2 Ground 2. This pin is the ground reference for Isolator Side 2. 16 GND2 π122x6 15 NC VDD1 3 14 VDD2 VOA 4 13 VIA VIB 5 NC 6 TOP VIEW (Not to scale) 12 VOB 11 NC Figure8. π122M6x Pin Configuration Figure9. π122x6 Pin Configuration Rev. 1 | Page 3 of 15 π120M/π121M/π122M Data Sheet ABSOLUTE MAXIMUM RATINGS TA = 25°C, unless otherwise noted. Table 1. Absolute Maximum Ratings4 Parameter Rating Supply Voltages (VDD1-GND1, VDD2-GND2) Input Voltages −0.5 V to +7.0 V (VIA, VIB)1 Output Voltages −0.5 V to VDDx + 0.5 V (VOA, VOB)1 −0.5 V to VDDx + 0.5 V Average Output Current per Pin2 Side 1 Output Current (IO1) −10 mA to +10 mA Average Output Current per Pin2 Side 2 Output Current (IO2) −10 mA to +10 mA Common-Mode Transients Immunity 3 −150 kV/µs to +150 kV/µs Storage Temperature (TST) Range −65°C to +150°C Ambient Operating Temperature (TA) Range −40°C to +125°C Notes: 1 VDDx is the side voltage power supply VDD, where x = 1 or 2. 2 See Figure9 for the maximum rated current values for various temperatures. 3 See Figure19 for Common-mode transient immunity (CMTI) measurement. 4 Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. RECOMMENDED OPERATING CONDITIONS Table 2. Recommended Operating Conditions Parameter Supply Voltage High Level Input Signal Voltage Symbol Min VDDx 1 3 VIH 0.7*VDDx Low Level Input Signal Voltage VIL 0 High Level Output Current IOH -6 Low Level Output Current IOL Maximum Data Rate Typ 1 Max Unit 5.5 V VDDx 1 0.3*VDDx V 1 V mA 6 mA 0 10 Mbps Junction Temperature TJ -40 150 °C Ambient Operating Temperature TA -40 125 °C Notes: 1 VDDx is the side voltage power supply VDD, where x = 1 or 2. Truth Tables Table 3. π120xxx/π121xxx/π122xxx Truth Table Default Low Default High VOx Output1 VOx Output1 Test Conditions /Comments Powered2 Low Low Normal operation Powered2 High High Normal operation Open Powered2 Powered2 Low High Default output Don’t Care4 Unpowered3 Powered2 Low High Default output5 Don’t Care4 Powered2 Unpowered3 High Impedance High Impedance VIx Input1 VDDI State1 VDDO State1 Low Powered2 High Powered2 Notes: 1 VIx/VOx are the input/output signals of a given channel (A or B). VDDI/VDDO are the supply voltages on the input/output signal sides of this given channel. Rev. 1 | Page 4 of 15 π120M/π121M/π122M Data Sheet 2 Powered means VDDx≥ 2.9 V means VDDx < 2.3V 4 Input signal (VIx) must be in a low state to avoid powering the given VDDI1 through its ESD protection circuitry. 5 If the VDDI goes into unpowered status, the channel outputs the default logic signal after around 1us. If the VDDI goes into powered status, the channel outputs the input status logic signal after around 1us. 3 Unpowered SPECIFICATIONS ELECTRICAL CHARACTERISTICS Table 4. Switching Specifications VDD1 - VGND1 = VDD2 - VGND2 = 3.3VDC±10% or 5VDC±10%, TA=25°C, unless otherwise noted. Parameter Minimum Pulse Width Symbol Pulse Width Distortion4 Part to Part Propagation Delay Skew4 Channel to Channel Propagation Delay Skew4 Typ PW Maximum Data Rate Propagation Delay Time1,4 Min Max 100 10 tpHL, tpLH PWD Test Conditions/Comments ns Within pulse width distortion (PWD) limit Mbps Within PWD limit 5.5 8 12.5 ns The different time between 50% input signal to 50% output signal 50% @ 5VDC supply 6.5 9 13.5 ns @ 3.3VDC supply 0 0.3 0.8 ns The max different time between tpHL and tpLH@ 5VDC supply. And The value is | tpHL - tpLH | 0 0.3 0.8 ns @ 3.3VDC supply 1 ns The max different propagation delay time between any two devices at the same temperature, load and voltage @ 5VDC supply 1 ns 0 1 ns 0 0.8 ns tPSK tCSK Unit @ 3.3VDC supply The max amount propagation delay time differs between any two output channels in the single device @ 5VDC supply. @ 3.3VDC supply Output Signal Rise/Fall Time4 tr/tf 1.5 Dynamic Input Supply Current per Channel IDDI (D) 9 µA /Mbps 10% to 90% signal terminated 50,See figure15. Inputs switching, 50% duty cycle square wave, CL = 0 pF @ 5VDC Supply Dynamic Output Supply Current per Channel IDDO (D) 38 µA /Mbps Inputs switching, 50% duty cycle square wave, CL = 0 pF @ 5VDC Supply Dynamic Input Supply Current per Channel IDDI (D) 5 µA /Mbps Inputs switching, 50% duty cycle square wave, CL = 0 pF @ 3.3VDC Supply Dynamic Output Supply Current per Channel IDDO (D) 23 µA /Mbps Inputs switching, 50% duty cycle square wave, CL = 0 pF @ 3.3VDC Supply Common-Mode Transient Immunity3 CMTI 75 kV/µs VIN = VDDx2 or 0V, VCM = 1000 V. 120 ps p-p See the Jitter Measurement section 20 ps rms See the Jitter Measurement section ±8 kV All pins Jitter ESD(HBM - Human body model) ESD ns Notes: 1 tpLH = low-to-high propagation delay time, tpHL = high-to-low propagation delay time. See figure 16. 2 VDDx is the side voltage power supply VDD, where x = 1 or 2. 3 See Figure19 for Common-mode transient immunity (CMTI) measurement. 4 Output Signal Terminated 50 Rev. 1 | Page 5 of 15 π120M/π121M/π122M Data Sheet Table 5. DC Specifications VDD1 - VGND1 = VDD2 - VGND2 = 3.3VDC±10% or 5VDC±10%, TA=25°C, unless otherwise noted. Parameter Symbol Rising Input Signal Voltage Threshold Falling Input Signal Voltage Threshold High Level Output Voltage Low Level Output Voltage Input Current per Signal Channel VDDx1 Undervoltage Rising Threshold VDDx1 Undervoltage Falling Threshold VDDx1 Hysteresis Min VIT+ Typ Max 0.6*VDDx 1 0.7*VDDx Unit 1 Test Conditions/Comments V VIT- 0.3* VDDX1 0.4* VDDX1 V VOH 1 VDDx − 0.1 VDDx V −20 µA output current VDDx − 0.2 VDDx − 0.1 V −2 mA output current VOL 0 0.1 V 20 µA output current 0.1 0.2 V 2 mA output current 0 V ≤ Signal voltage ≤ VDDX1 IIN −10 0.5 10 µA VDDxUV+ 2.45 2.65 2.9 V VDDxUV− 2.3 2.5 2.75 V VDDxUVH 0.15 V Notes: 1 VDDx is the side voltage power supply VDD, where x = 1 or 2. Table 6. Quiescent Supply Current VDD1 - VGND1 = VDD2 - VGND2 = 3.3VDC±10% or 5VDC±10%, TA=25°C, CL = 0 pF, unless otherwise noted. Parameter Symbol π120Mxx Quiescent Supply Current @ 5VDC Supply @ 3.3VDC Supply π121Mxx Quiescent Supply Current @ 5VDC Supply @ 3.3VDC Supply π122Mxx Quiescent Supply Current @ 5VDC Supply @ 3.3VDC Supply Min Typ Max Unit Test Conditions IDD1 (Q) 64 80 104 µA 0V Input signal IDD2 (Q) 781 976 1269 µA 0V Input signal IDD1 (Q) 158 197 256 µA 5V Input signal IDD2 (Q) 738 923 1200 µA 5V Input signal IDD1 (Q) 63 79 103 µA 0V Input signal IDD2 (Q) 772 965 1255 µA 0V Input signal IDD1 (Q) 116 145 189 µA 3.3V Input signal IDD2 (Q) 709 886 1152 µA 3.3V Input signal IDD1 (Q) 419 524 681 µA 0V Input signal IDD2 (Q) 419 524 681 µA 0V Input signal IDD1 (Q) 436 545 709 µA 5V Input signal IDD2 (Q) 436 545 709 µA 5V Input signal IDD1 (Q) 414 518 673 µA 0V Input signal IDD2 (Q) 414 518 673 µA 0V Input signal IDD1 (Q) 408 510 663 µA 3.3V Input signal IDD2 (Q) 408 510 663 µA 3.3V Input signal IDD1 (Q) 419 524 681 µA 0V Input signal IDD2 (Q) 419 524 681 µA 0V Input signal IDD1 (Q) IDD2 (Q) 436 436 545 545 709 709 µA µA 5V Input signal 5V Input signal IDD1 (Q) 414 518 673 µA 0V Input signal IDD2 (Q) 414 518 673 µA 0V Input signal Rev. 1 | Page 6 of 15 π120M/π121M/π122M Data Sheet IDD1 (Q) 408 510 663 µA 3.3V Input signal IDD2 (Q) 408 510 663 µA 3.3V Input signal Table 7. Total Supply Current vs. Data Throughput (CL = 0 pF) VDD1 - VGND1 = VDD2 - VGND2 = 3.3VDC±10% or 5VDC±10%, TA=25°C, CL = 0 pF, unless otherwise noted. Parameter 150 Kbps Symbol π120Mxx Supply Current @ 5VDC @ 3.3VDC π121Mxx Supply Current @ 5VDC @ 3.3VDC π122Mxx Supply Current @ 5VDC @ 3.3VDC Min Typ Max IDD1 0.14 IDD2 1 Mbps Min Typ Max 0.21 0.15 0.95 1.43 IDD1 0.11 IDD2 10 Mbps Min Typ Max Unit 0.22 0.24 0.36 mA 1.02 1.52 1.76 2.63 mA 0.17 0.12 0.17 0.18 0.27 mA 0.93 1.40 0.97 1.46 1.43 2.14 mA IDD1 0.54 0.81 0.58 0.86 0.97 1.46 mA IDD2 0.54 0.81 0.58 0.86 0.97 1.46 mA IDD1 0.52 0.78 0.54 0.81 0.77 1.16 mA IDD2 0.52 0.78 0.54 0.81 0.77 1.16 mA IDD1 0.54 0.81 0.58 0.86 0.97 1.60 mA IDD2 0.54 0.81 0.58 0.86 0.97 1.60 mA IDD1 0.52 0.78 0.54 0.81 0.77 1.20 mA IDD2 0.52 0.78 0.54 0.81 0.77 1.20 mA INSULATION AND SAFETY RELATED SPECIFICATIONS Table 8. Insulation Specifications Parameter Rated Dielectric Insulation Voltage Minimum External Air Gap (Clearance) Minimum External Tracking (Creepage) Minimum Internal Gap (Internal Clearance) Tracking Resistance (Comparative Tracking Index) Symbol Value Unit Test Conditions/Comments π12xM3x π12xM6x 3000 6000 L (CLR) 4 8 mm min L (CRP) 4 8 mm min 11 21 µm min Insulation distance through insulation >400 >400 V DIN IEC 112/VDE 0303 Part 1 II II CTI Material Group V rms 1-minute duration Measured from input terminals to output terminals, shortest distance through air Measured from input terminals to output terminals, shortest distance path along body Material Group (DIN VDE 0110, 1/89, Table 1) PACKAGE CHARACTERISTICS Table 9. Package Characteristics Parameter Symbol Typical Value π12xM3x π12xM6x Unit Test Conditions/Comments Resistance (Input to Output)1 RI-O 10 11 10 11 Ω Capacitance (Input to Output)1 CI-O 0.6 0.6 pF @1MHz CI 3 3 pF @1MHz θJA 100 45 °C/W Thermocouple located at center of package underside Input Capacitance2 IC Junction to Ambient Thermal Resistance Notes: 1The device is considered a 2-terminal device; SOIC-8 Pin 1 - Pin 4(WSOIC-16 Pin 1-Pin8) are shorted together as the one terminal, and SOIC-8 Pin 5 - Pin 8(WSOIC-16 Pin 9- Pin16) are shorted together as the other terminal. 2Testing from the input signal pin to ground. Rev. 1 | Page 7 of 15 π120M/π121M/π122M Data Sheet REGULATORY INFORMATION See Table 10 and the Insulation Lifetime section for details regarding recommended maximum working voltages for specific cross isolation waveforms and insulation levels. Table10. Regulatory π12xM3x Regulatory UL π12xM6x Recognized under UL 1577 Component Recognition Recognized under UL 1577 Program1 Component Recognition Program1 Single Protection, 3000 V rms Isolation Voltage CSA Single Protection, 6000V rms Isolation Voltage File (E494497) File (pending) Approved under CSA Component Acceptance Notice 5A Approved under CSA Component Acceptance Notice 5A CSA 60950-1-07+A1+A2 and CSA 60950-1-07+A1+A2 and IEC 60950-1, second edition, +A1+A2: IEC 60950-1, second edition, +A1+A2: Basic insulation at 500 V rms (707 V peak) Basic insulation at 845 V rms (1200 V peak) Reinforced insulation at 250 V rms Reinforced insulation at 422 V rms (353 V peak) (600 V peak) File (pending) VDE CQC DIN V VDE V 0884-10 (VDE V File (pending) 0884-10):2006-122 DIN V VDE V 0884-10 (VDE V 0884-10):2006-122 Basic insulation, VIORM = 707 V peak, VIOSM = 4615 V peak Basic insulation, VIORM = 1200 V peak, VIOSM = 7000 V peak File (40047929) File (pending) Certified under Certified under CQC11-471543-2012 CQC11-471543-2012 GB4943.1-2011 Basic insulation at 500 V rms (707 V peak) working voltage GB4943.1-2011 Basic insulation at 845 V rms (1200 V peak) working voltage Reinforced insulation at Reinforced insulation at 250 V rms (353 V peak) 422 V rms (600 V peak) File (pending) File (pending) Notes: 1 In accordance with UL 1577, each π120M3x/π121M3x/π122M3x is proof tested by applying an insulation test voltage ≥ 3600 V rms for 1 sec; each π120M6x/π121M6x/π122M6x is proof tested by applying an isulation test voltage ≥ 7200 V rms for 1 sec 2 In accordance with DIN V VDE V 0884-10, each π120M3x/π121M3x/π122M3x is proof tested by applying an insulation test voltage ≥ 1326 V peak for 1 sec (partial discharge detection limit = 5 pC); each π120M6x/π121M6x/π122M6x is proof tested by ≥ 2250V peak for 1 sec. The * marking branded on the component designates DIN V VDE V 0884-10 approval. DIN V VDE V 0884-10 (VDE V 0884-10) INSULATION CHARACTERISTICS These isolators are suitable for reinforced electrical isolation only within the safety limit data. Protective circuits ensure the maintenance of the safety data. The * marking on packages denotes DIN V VDE V 0884-10 approval. Table 11. VDE Insulation Characteristics Description Test Conditions/Comments Symbol Characteristic π12xM3x π12xM6x For Rated Mains Voltage ≤ 150 V rms I to IV I to IV For Rated Mains Voltage ≤ 300 V rms I to III I to III Installation Classification per DIN VDE 0110 For Rated Mains Voltage ≤ 400 V rms Climatic Classification Pollution Degree per DIN VDE 0110, Table 1 Rev. 1 | Page 8 of 15 I to III I to III 40/105/21 40/105/21 2 2 Unit π120M/π121M/π122M Data Sheet Maximum Working Insulation Voltage Input to Output Test Voltage, Method B1 VIORM 707 1200 V peak VIORM × 1.875 = Vpd (m), 100% production test, tini = tm = 1 sec, partial discharge < 5 pC Vpd (m) 1326 2250 V peak VIORM × 1.5 = Vpd (m), tini = 60 sec, tm = 10 sec, partial discharge < 5 pC Vpd (m) 1061 1800 V peak 849 1440 V peak VIOTM 4200 8500 V peak 4615 7000 V peak Input to Output Test Voltage, Method A After Environmental Tests Subgroup 1 After Input and/or Safety Test Subgroup 2 and Subgroup 3 Highest Allowable Overvoltage VIORM × 1.2 = Vpd (m), tini = 60 sec, tm = 10 sec, partial discharge < 5 pC Surge Isolation Voltage Basic Basic insulation, 1.2 µs rise time, 50 µs, 50% fall time VIOSM Surge Isolation Voltage Reinforced Reinforced insulation, 1.2 µs rise time, 50 µs, 50% fall time VIOSM Safety Limiting Values Maximum value allowed in the event of a failure (see Figure 9) Maximum Junction Temperature TS Total Power Dissipation at 25°C Insulation Resistance at TS VIO = 800 V π12xM3x V peak 150 150 °C PS 1.56 2.78 W RS >109 >109 Ω π12xM6x 3 12.0 2.9 Propagation Delay Time(nS) Power Supply Undervoltage Threshold Figure9. Thermal Derating Curve, Dependence of Safety Limiting Values with Ambient Temperature per VDE 2.8 2.7 2.6 2.5 VDDxUV+(V) VDDxUV−(V) 2.4 2.3 2.2 10.0 8.0 6.0 tpHL(ns)@3.3V tpLH(ns)@3.3V tpHL(ns)@5.0V tpLH(ns)@5.0V 4.0 2.0 0.0 0 50 100 150 0 Free-Air Temperature ( °C) Figure10. UVLO vs. Free-Air Temperature 50 100 Free-Air Temperature ( °C) Figure11. Propagation Delay Time vs. Free-Air Temperature Rev. 1 | Page 9 of 15 150 π120M/π121M/π122M π120Mxx Quiescent Supply Current (mA) 0.5 0.45 0.4 0.35 0.3 0.25 0.2 0.15 0.1 0.05 0 @3.3V Supply with 0V Input @3.3V Supply with 3.3V Input @5V Supply with 0V Input @5V Supply with 5V Input 0 50 100 Free-Air Temperature ( °C) 150 Figure12. π121Mxx/π122Mxx Quiescent Supply Current vs. Free-Air Temperature π120Mxx Quiescent Supply Current (mA) π122Mxx Quiescent Supply Current (mA) Data Sheet 0.8 0.7 0.6 IDD1@ 0V Input IDD2@ 0V Input IDD1@ 3.3V Input IDD2@ 3.3V Input 0.5 0.4 0.3 0.2 0.1 0 0 50 100 150 Free-Air Temperature ( °C) Figure13. π120Mxx Quiescent Supply Current with 3.3V Supply vs. Free-Air Temperature 0.8 0.7 0.6 Figure12. Propagation delay time waveform measurement 0.5 Figure11. Transition time waveform measurement IDD1@ 0V Input IDD2@ 0V Input IDD1@ 5V Input IDD2@ 5V Input 0.4 0.3 0.2 0.1 0 0 50 100 150 Free-Air Temperature ( °C) Figure14. π120Mxx Quiescent Supply Current with 5V Supply vs. Free-Air Temperature VDDX Figure12. Propagation delay time waveform measurement Figure15. Transition time waveform measurement Figure16. Propagation delay time waveform measurement Rev. 1 | Page 10 of 15 π120M/π121M/π122M Data Sheet APPLICATIONS INFORMATION the user may also include resistors (50–300 Ω) in series with the inputs and outputs if the system is excessively noisy. OVERVIEW The π1xxxxx are 2PaiSemi digital isolators product family based on 2PaiSEMI unique iDivider technology. Intelligent voltage Divider technology (iDivider technology) is a new generation digital isolator technology invented by 2PaiSEMI. It uses the principle of capacitor voltage divider to transmit signal directly cross the isolator capacitor without signal modulation and demodulation. Compare to the traditional Opto-couple technology, icoupler technology, OOK technology, iDivider is a more essential and concise isolation signal transmit technology which leads to greatly simplification on circuit design and therefore significantly improves device performance, such as lower power consumption, faster speed, enhanced antiinterference ability, lower noise. By using maturated standard semiconductor CMOS technology and the innovative iDivider design, these isolation components provide outstanding performance characteristics and reliability superior to alternatives such as optocoupler devices and other integrated isolators. The π1xxxxx isolator data channels are independent and are available in a variety of configurations with a withstand voltage rating of 1.5 kV rms to 6.0 kV rms and the data rate from DC up to 600Mbps (see the Ordering Guide). The π120Mxx/π121Mxx/π122Mxx are the outstanding 10 Mbps dual-channel digital isolators with the enhanced ESD capability. the devices transmit data across an isolation barrier by layers of silicon dioxide isolation. The devices operate with the supply voltage on either side ranging from 3.0 V to 5.5 V, offering voltage translation of 3.3 V and 5 V logic. The π120Mxx/π121Mxx/π122Mxx have very low propagation delay and high speed. The input/output design techniques allow logic and supply voltages over a wide range from 3.0 V to 5.5 V, offering voltage translation of 3.3 V and 5 V logic. The architecture is designed for high common-mode transient immunity and high immunity to electrical noise and magnetic interference. See the Ordering Guide for the model numbers that have the failsafe output state of low or high. PCB LAYOUT The low-ESR ceramic bypass capacitors must be connected between VDD1 and GND1 and between VDD2 and GND2. The bypass capacitors are placed on the PCB as close to the isolator device as possible. The recommended bypass capacitor value is between 0.1 μF and 10 μF. To enhance the robustness of a design, VDD1 VIA/VOA VIB/VOB Avoid reducing the isolation capability, Keep the space underneath the isolator device free from metal such as planes, pads, traces and vias. To minimize the impedance of the signal return loop, keep the solid ground plane directly underneath the high-speed signal path, the closer the better. The return path will couple between the nearest ground plane to the signal path. Keep suitable trace width for controlled impedance transmission lines interconnect. To reduce the rise time degradation, keep the length of input/output signal traces as short as possible, and route low inductance loop for the signal path and It’s return path. JITTER MEASUREMENT The eye diagram shown in the figure18 provides the jitter measurement result for the π120Mxx/π121Mxx/π122Mxx. The Keysight 81160A pulse function arbitrary generator works as the data source for the π120Mxx/π121Mxx/π122Mxx, which generates 10Mbps pseudo random bit sequence (PRBS). The Keysight DSOS104A digital storage oscilloscope captures the π120Mxx/π121Mxx/π122Mxx output waveform and recoveries the eye diagram with the SDA jitter tools and eye diagram analysis tools. The result shows a typical measurement 120ps p-p jitter. Figure18. π120Mxx/π121Mxx/π122Mxx Eye Diagram CMTI MEASUREMENT To measure the Common-Mode Transient Immunity (CMTI) of π1xxxxx isolator under specified common-mode pulse magnitude (VCM) and specified slew rate of the common-mode pulse (dVCM/dt) and other specified test or ambient conditions, The VDD2 VOA/VIA VOB/VIB GND1 GND2 Figure17.Recommended Printed Circuit Board Layout PAI12X系列 Figure19. Common-mode transient immunity (CMTI) measurement Rev. 1 | Page 11 of 15 π120M/π121M/π122M Data Sheet common-mode pulse generator (G1) will be capable of providing fast rising and falling pulses of specified magnitude and duration of the common-mode pulse (VCM) and the maximum commonmode slew rates (dVCM/dt) can be applied to π1xxxxx isolator coupler under measurement. The common-mode pulse is applied between one side ground GND1 and the other side ground GND2 of π1xxxxx isolator and shall be capable of providing positive transients as well as negative transients. OUTLINE DIMENSIONS Figure20. 8-Lead Standard Small Outline Package [8-Lead SOIC_N] Figure21. 16-Lead Wide Body Outline Package [16-Lead SOIC_W] Rev. 1 | Page 12 of 15 π120M/π121M/π122M Data Sheet REEL INFORMATION 8-Lead SOIC_N Figure16. Propagation delay time waveform measurement 16-Lead SOIC_W Rev. 1 | Page 13 of 15 π120M/π121M/π122M Data Sheet ORDERING GUIDE π120M31 Pai120M31 −40°C to +125°C No. of Inp uts, VDD1 Side 2 0 3 High 8-Lead SOIC_N S-8-N 4000 per reel π120M30 Pai120M30 −40°C to +125°C 2 0 3 Low 8-Lead SOIC_N S-8-N 4000 per reel π121M31 Pai121M31 −40°C to +125°C 1 1 3 High 8-Lead SOIC_N S-8-N 4000 per reel π121M30 Pai121M30 −40°C to +125°C 1 1 3 Low 8-Lead SOIC_N S-8-N 4000 per reel π122M31 Pai122M31 −40°C to +125°C 1 1 3 High 8-Lead SOIC_N S-8-N 4000 per reel π122M30 Pai122M30 −40°C to +125°C 1 1 3 Low 8-Lead SOIC_N S-8-N 4000 per reel π120M61 Pai120M61 −40°C to +125°C 2 0 6 High 16-Lead SOIC_W S-16-W 1500 per reel π120M60 Pai120M60 −40°C to +125°C 2 0 6 Low 16-Lead SOIC_W S-16-W 1500 per reel π121M61 Pai121M61 −40°C to +125°C 1 1 6 High 16-Lead SOIC_W S-16-W 1500 per reel π121M60 Pai121M60 −40°C to +125°C 1 1 6 Low 16-Lead SOIC_W S-16-W 1500 per reel π122M61 Pai122M61 −40°C to +125°C 1 1 6 High 16-Lead SOIC_W S-16-W 1500 per reel π122M60 Pai122M60 −40°C to +125°C 1 1 6 Low 16-Lead SOIC_W S-16-W 1500 per reel Model Name Temperature Range No. of Inputs, VDD2 Side Withstand Voltage Rating (kV rms) FailSafe Output State Package Description Package Option PART NUMBER NAMED RULE π(1)(2)(0)(A)(3)(0)(S) SeriesNumber: 1,2,3... Total Channel Am ount: N=N Channels N=1,2,3,4,5,6... Reverse Channel Amount: N=N Channels N=0,1,2,3... Data Rate:A=600Mbps E=200Mbps M=10Mbps U=150Kbps Isolation Voltag es: N=1 1.5KVrms AC N=3 3KVrms AC N=6 6KVrms AC Fail-Safe Output Stat e: 0=Logic Low 1=Logic High Optional: S=SSOP Package Q=AEC-Q100 Qualified Notes: Pai12xxxx is equals to π12xxxx in the customer BOM Rev. 1 | Page 14 of 15 Quantity π120M/π121M/π122M Data Sheet REVISION HISTORY Revision Updated Date Page Change Record 1 Jason 2018/09/17 All 2 Jason 2018/11/28 P11 3 Devin 2019/09/08 P1,P11,P13,P14 Initial version Changed the recommended bypass capacitor value from between 0.1 μF and 1 μF to between 0.1 μF and 10 μF. P1: Changed the address from ‘Room 19307, Building 8, No.498, GuoShouJing Road’ to ‘Room 308-309, No.22, Boxia Road’; Add iDivider technology description in General Description. Changed propagation delay for 5V from 7.5ns to 8ns. Changed CMTI from 50KV/us to 75KV/us. Changed ESD(HBM) from 7KV to 8KV. P11: Add iDivider technology description in overview. P13: Updated 16-Lead SOIC_W reel drawing. P14: Add character ‘S’ and ‘Q’ in part number named rule; Changed the SOIC_W quantity from ‘1000 per reel’ to ‘1500 per reel’. Rev. 1 | Page 15 of 15
π120M30 价格&库存
很抱歉,暂时无法提供与“π120M30”相匹配的价格&库存,您可以联系我们找货
Π120M30
  • 1+9.35482
  • 5+8.38460
  • 16+7.15087
  • 43+6.76757
  • 100+6.69570
库存:3607
π120M30
  • 1+3.33500
  • 30+3.22000
  • 100+2.99000
  • 500+2.76000
  • 1000+2.64500
库存:1399
