CD74HCU04E
CD74HCU04E
    L3HARRIS
    DIP-14
    IC INVERTER 6CH 6-INP 14DIP
CD74HCU04E 数据手册
[ /Title (CD74 HCU04 ) /Subject (High Speed CMOS Logic Hex Inverter CD74HCU04 Data sheet acquired from Harris Semiconductor SCHS127D High-Speed CMOS Logic Hex Inverter February 1998 - Revised May 2004 Features Description • Typical Propagation Delay: 6ns at VCC = 5V, CL = 15pF, TA = 25oC, Fastest Part in QMOS Line The CD74HCU04 unbuffered hex inverter utilizes silicon-gate CMOS technology to achieve operation speeds similar to LSTTL gates, with the low power consumption of standard CMOS integrated circuits. These devices especially are useful in crystal oscillator and analog applications. • Wide Operating Temperature Range . . . -55oC to 125oC • Balanced Propagation Delay and Transition Times • Significant Power Reduction Compared to LSTTL Logic ICs Ordering Information • HCU Types - 2-V to 6-V Operation - High Noise Immunity: NIL = 20%, NIH = 30% of VCC at VCC = 5V PART NUMBER • CMOS Input Compatibility, Il ≤ 1µA at VOL, VOH TEMP. RANGE (oC) PACKAGE CD74HCU04E -55 to 125 14 Ld PDIP CD74HCU04M -55 to 125 14 Ld SOIC CD74HCU04MT -55 to 125 14 Ld SOIC CD74HCU04M96 -55 to 125 14 Ld SOIC CD74HCU04PWR -55 to 125 14 Ld TSSOP NOTE: When ordering, use the entire part number. The suffixes 96 and R denote tape and reel. The suffix T denotes a smallquantity reel of 250. Pinout CD74HCU04 (PDIP, SOIC, TSSOP) TOP VIEW 1A 1 14 VCC 1Y 2 13 6A 2A 3 12 6Y 2Y 4 11 5A 3A 5 10 5Y 3Y 6 9 4A GND 7 8 4Y CAUTION: These devices are sensitive to electrostatic discharge. Users should follow proper IC Handling Procedures. Copyright © 2004, Texas Instruments Incorporated 1 CD74HCU04 Functional Diagram 1A 1Y 2A 2Y 3A 3Y GND 1 14 2 13 3 12 4 11 5 10 6 9 7 8 VCC 6A 6Y 5A 5Y 4A 4Y Logic Symbol nA nY Schematic Diagram VCC (3, 5, 9, 11, 13) 1 2 (4, 6, 8, 10, 12) 2 CD74HCU04 Absolute Maximum Ratings Thermal Information DC Supply Voltage, VCC Voltages Referenced to Ground . . . . . . . . . . . . . . . . -0.5V to +7V DC Input Diode Current, IIK For VI < -0.5V or VI > VCC + 0.5V . . . . . . . . . . . . . . . . . . . . . .±20mA DC Output Diode Current, IOK For VO < -0.5V or VO > VCC + 0.5V . . . . . . . . . . . . . . . . . . . .±20mA DC Drain Current, per Output, IO For VO > -0.5V or VO < VCC + 0.5V . . . . . . . . . . . . . . . . . . . .±25mA DC VCC or Ground Current, ICC . . . . . . . . . . . . . . . . . . . . . . . . .±50mA Thermal Resistance (Typical, Note 1) θJA (oC/W) E (PDIP) Package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 80 M (SOIC) Package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 86 PW (TSSOP) Package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 113 Maximum Junction Temperature (Hermetic Package or Die) . . . 175oC Maximum Junction Temperature (Plastic Package) . . . . . . . . 150oC Maximum Storage Temperature Range . . . . . . . . . .-65oC to 150oC Maximum Lead Temperature (Soldering 10s) . . . . . . . . . . . . . 300oC (SOIC - Lead Tips Only) Operating Conditions Temperature Range TA . . . . . . . . . . . . . . . . . . . . . . . -55oC to 125oC Supply Voltage Range, VCC . . . . . . . . . . . . . . . . . . . . . . . . .2V to 6V DC Input or Output Voltage, VI, VO . . . . . . . . . . . . . . . . . 0V to VCC CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating, and operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. NOTE: 1. The package thermal impedance is calculated in accordance with JESD 51-7. DC Electrical Specifications TEST CONDITIONS PARAMETER High Level Input Voltage Low Level Input Voltage High Level Output Voltage CMOS Loads SYMBOL VI (V) VIH - VIL Quiescent Device Current MAX MIN MAX MIN MAX UNITS 2 1.7 - 1.7 - 1.7 - V 4.5 3.6 - 3.6 - 3.6 - V 6 4.8 - 4.8 - 4.8 - V - 0.3 - 0.3 - 0.3 V 0.8 - 0.8 - 0.8 V 6 - 1.1 - 1.1 - 1.1 V -0.02 2 1.8 - 1.8 - 1.8 - V -0.02 4.5 4 - 4 - 4 - V -0.02 6 5.5 - 5.5 - 5.5 - V -4 4.5 3.98 - 3.84 - 3.7 - V -5.2 6 5.48 - 5.34 - 5.2 - V 0.02 2 - 0.2 - 0.2 - 0.2 V 0.02 4.5 - 0.5 - 0.5 - 0.5 V 0.02 6 - 0.5 - 0.5 - 0.5 V 4 4.5 - 0.26 - 0.33 - 0.4 V VCC or GND 5.2 6 - 0.26 - 0.33 - 0.4 V II VCC or GND - 6 - ±0.1 - ±1 - ±1 µA ICC VCC or GND 0 6 - 2 - 20 - 40 µA VIH or VIL VCC or GND VOL VIH or VIL - MIN - Low Level Output Voltage TTL Loads Input Leakage Current - -55oC TO 125oC 2 High Level Output Voltage TTL Loads Low Level Output Voltage CMOS Loads IO (mA) VCC (V) -40oC TO +85oC 4.5 VOH - 25oC 3 CD74HCU04 Switching Specifications Input tr, tf = 6ns PARAMETER Propagation Delay, Input to Output Y (Figure 1) Transition Times (Figure 1) Input Capacitance Power Dissipation Capacitance (Notes 2, 3) 25oC -40oC TO 85oC -55oC TO 125oC SYMBOL TEST CONDITIONS tPLH, tPHL CL = 50pF 2 - - 70 - 90 - 105 ns CL = 50pF 4.5 - - 14 - 18 - 21 ns CL = 15pF 5 - 5 - - - - - ns CL = 50pF 6 - - 12 - 15 - 18 ns CL = 50pF 2 - - 75 - 95 18 110 ns 4.5 - - 15 - 19 - 22 ns 6 - - 13 - 16 - 19 ns tTLH, tTHL CI - CPD - VCC (V) MIN TYP MAX MIN MAX MIN MAX UNITS See Figure 3 5 - 14 - - pF - - - NOTES: 2. CPD is used to determine the dynamic power consumption, per inverter. 3. PD = VCC2 fi (CPD + CL) where fi = input frequency, CL = output load capacitance, VCC = supply voltage. Test Circuits and Waveforms tr = 6ns tf = 6ns VCC 90% 50% 10% INPUT GND tTHL tTLH 90% 50% 10% INVERTING OUTPUT tPLH tPHL FIGURE 1. HC AND HCU TRANSITION TIMES AND PROPAGATION DELAY TIMES, COMBINATION LOGIC ICC, VCC TO GND CURRENT (mA) Typical Performance Curves AMBIENT TEMPERATURE TA = 25o C 25.0 22.5 VCC = 6V 20.0 17.5 15.0 VCC = 4.5V 12.5 10.0 7.5 5.0 VCC = 2V 2.5 0 1 2 3 4 5 VI, INPUT VOLTAGE (V) 6 FIGURE 2. TYPICAL INVERTER SUPPLY CURRENT AS FUNCTION OF INPUT VOLTAGE 4 pF CD74HCU04 CI, INPUT CAPACITANCE (pF) Typical Performance Curves 70 65 60 55 50 45 40 35 30 25 20 15 10 5 0 (Continued) AMBIENT TEMPERATURE, TA = 25oC VDD = 2V, VI 0-2V INPUT PIN 5 CONDITIONS VDD = 3V, VI 0-3V VDD = 4V, VI 0-4V VDD = 5V, VI 0-5V VDD = 6V, VI 0-6V 1 2 3 VIN, INPUT VOLTAGE (V) 4 FIGURE 3. INPUT CAPACITANCE AS A FUNCTION OF INPUT VOLTAGE 5 5 6 PACKAGE OPTION ADDENDUM www.ti.com 6-Feb-2020 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan Lead/Ball Finish MSL Peak Temp (2) (6) (3) Op Temp (°C) Device Marking (4/5) CD74HCU04E ACTIVE PDIP N 14 25 Green (RoHS & no Sb/Br) NIPDAU N / A for Pkg Type -55 to 125 CD74HCU04E CD74HCU04EE4 ACTIVE PDIP N 14 25 Green (RoHS & no Sb/Br) NIPDAU N / A for Pkg Type -55 to 125 CD74HCU04E CD74HCU04M ACTIVE SOIC D 14 50 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 HCU04M CD74HCU04M96 ACTIVE SOIC D 14 2500 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 HCU04M CD74HCU04M96E4 ACTIVE SOIC D 14 2500 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 HCU04M CD74HCU04M96G4 ACTIVE SOIC D 14 2500 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 HCU04M CD74HCU04PWR ACTIVE TSSOP PW 14 2000 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 HJU04 (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may reference these types of products as "Pb-Free". RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption. Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
CD74HCU04E 价格&库存
很抱歉,暂时无法提供与“CD74HCU04E”相匹配的价格&库存,您可以联系我们找货
