TIP32 Series(TIP32/32A/32B/32C)
Medium Power Linear Switching Applications
• Complement to TIP31/31A/31B/31C
TO-220
1
1.Base
2.Collector
3.Emitter
PNP Epitaxial Silicon Transistor
Absolute Maximum Ratings TC=25°C unless otherwise noted
Symbol
VCBO
Collector-Base Voltage
Parameter
: TIP32
: TIP32A
: TIP32B
: TIP32C
Value
- 40
- 60
- 80
- 100
Units
V
V
V
V
- 40
- 60
- 80
-100
V
V
V
V
V
VCEO
Collector-Emitter Voltage : TIP32
: TIP32A
: TIP32B
: TIP32C
VEBO
Emitter-Base Voltage
-5
IC
Collector Current (DC)
-3
A
ICP
Collector Current (Pulse)
-5
A
IB
Base Current
-3
A
PC
Collector Dissipation (TC=25°C)
40
W
PC
Collector Dissipation (Ta=25°C)
2
W
TJ
Junction Temperature
150
°C
TSTG
Storage Temperature
- 65 ~ 150
°C
Electrical Characteristics TC=25°C unless otherwise noted
Symbol
VCEO(sus)
ICEO
ICES
Parameter
* Collector-Emitter Sustaining Voltage
: TIP32
: TIP32A
: TIP32B
: TIP32C
Collector Cut-off Current
: TIP32/32A
: TIP32B/32C
Test Condition
IC = - 30mA, IB = 0
Min.
Max.
-40
-60
-80
-100
Units
V
V
V
V
VCE = - 30V, IB = 0
VCE = - 60V, IB = 0
- 0.3
- 0.3
mA
mA
VCE = - 40V, VEB = 0
VCE = - 60V, VEB = 0
VCE = - 80V, VEB = 0
VCE = - 100V, VCE = 0
- 200
- 200
- 200
- 200
µA
µA
µA
µA
-1
mA
: TIP32
: TIP32A
: TIP32B
: TIP32C
IEBO
Emitter Cut-off Current
VEB = - 5V, IC = 0
hFE
* DC Current Gain
VCE = - 4V, IC = - 1A
VCE = - 4V, IC = - 3A
VCE(sat)
* Collector-Emitter Saturation Voltage
IC = - 3A, IB = - 375mA
- 1.2
V
VBE(sat)
* Base-Emitter Saturation Voltage
- 1.8
V
fT
Current Gain Bandwidth Product
VCE = - 10V, IC = - 500mA
25
10
3.0
50
MHz
* Pulse Test: PW≤300µs, Duty Cycle≤2%
©2000 Fairchild Semiconductor International
Rev. A, February 2000
hFE, DC CURRENT GAIN
VCE = -4V
100
10
1
-1
-10
-100
-1000
VBE(sat), VCE(sat)[mV], SATURATION VOLTAGE
1000
-10000
IC /IB = 10
-1000
V BE(sat)
-100
V CE(sat)
-10
-10000
-1
-10
-1000
-10000
IC[mA], COLLECTOR CURRENT
Figure 1. DC current Gain
Figure 2. Base-Emitter Saturation Voltage
50
-10
IC(MAX) (PULSE)
IC(MAX) (DC)
s
1m
-1
TIP32 V CEO MAX.
TIP32A V CEO MAX.
TIP32B V CEO MAX.
TIP32C V CEO MAX.
PC[W], POWER DISSIPATION
45
100µ s
s
5m
IC[A], COLLECTOR CURRENT
-100
40
35
30
25
10
5
-10
-100
VCE [V], COLLECTOR-EMITTER VOLTAGE
Figure 3. Safe Operating Area
50
75
100
125
150
175
200
o
TC[ C], CASE TEMPERATURE
Figure 4. Power Derating
Typical Characteristics
Package Demensions
TO-220
4.50 ±0.20
2.80 ±0.10
(3.00)
+0.10
1.30 –0.05
18.95MAX.
(3.70)
ø3.60 ±0.10
15.90 ±0.20
1.30 ±0.10
(8.70)
(1.46)
9.20 ±0.20
(1.70)
9.90 ±0.20
1.52 ±0.10
0.80 ±0.10
2.54TYP
[2.54 ±0.20]
10.08 ±0.30
(1.00)
13.08 ±0.20
(45°
1.27 ±0.10
+0.10
0.50 –0.05
2.40 ±0.20
2.54TYP
[2.54 ±0.20]
10.00 ±0.20
Dimensions in Millimeters
TRADEMARKS
The following are registered and unregistered trademarks Fairchild Semiconductor owns or is authorized to use and is
not intended to be an exhaustive list of all such trademarks.
ACEx™
Bottomless™
CoolFET™
CROSSVOLT™
E2CMOS™
FACT™
FACT Quiet Series™
FAST®
FASTr™
GTO™
HiSeC™
ISOPLANAR™
MICROWIRE™
POP™
PowerTrench®
QFET™
QS™
Quiet Series™
SuperSOT™-3
SuperSOT™-6
SuperSOT™-8
SyncFET™
TinyLogic™
UHC™
VCX™
DISCLAIMER
FAIRCHILD SEMICONDUCTOR RESERVES THE RIGHT TO MAKE CHANGES WITHOUT FURTHER NOTICE TO ANY
PRODUCTS HEREIN TO IMPROVE RELIABILITY, FUNCTION OR DESIGN. FAIRCHILD DOES NOT ASSUME ANY
LIABILITY ARISING OUT OF THE APPLICATION OR USE OF ANY PRODUCT OR CIRCUIT DESCRIBED HEREIN;
NEITHER DOES IT CONVEY ANY LICENSE UNDER ITS PATENT RIGHTS, NOR THE RIGHTS OF OTHERS.
LIFE SUPPORT POLICY
FAIRCHILD’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT
DEVICES OR SYSTEMS WITHOUT THE EXPRESS WRITTEN APPROVAL OF FAIRCHILD SEMICONDUCTOR
INTERNATIONAL.
As used herein:
1. Life support devices or systems are devices or systems
which, (a) are intended for surgical implant into the body,
or (b) support or sustain life, or (c) whose failure to perform
when properly used in accordance with instructions for use
provided in the labeling, can be reasonably expected to
result in significant injury to the user.
2. A critical component is any component of a life support
device or system whose failure to perform can be
reasonably expected to cause the failure of the life support
device or system, or to affect its safety or effectiveness.
PRODUCT STATUS DEFINITIONS
Definition of Terms
Datasheet Identification
Product Status
Definition
Advance Information
Formative or In
Design
This datasheet contains the design specifications for
product development. Specifications may change in
any manner without notice.
Preliminary
First Production
This datasheet contains preliminary data, and
supplementary data will be published at a later date.
Fairchild Semiconductor reserves the right to make
changes at any time without notice in order to improve
design.
No Identification Needed
Full Production
This datasheet contains final specifications. Fairchild
Semiconductor reserves the right to make changes at
any time without notice in order to improve design.
Obsolete
Not In Production
This datasheet contains specifications on a product
that has been discontinued by Fairchild semiconductor.
The datasheet is printed for reference information only.
Rev. E
Product Folder - Fairchild P/N TIP32B - PNP Epitaxial Silicon Transistor
SEARCH | Parametric | Cross Reference
space
space
GO
space
space
space
space
space >> Find products >>
Home
find products
space
space
space
TIP32B
Products groups
Analog and Mixed
Signal
Contents
Discrete
Features | Applications | Product
Interface
status/pricing/packaging
Logic
space
Microcontrollers
Non-Volatile
Features
Memory
spaceOptoelectronics
Markets and
● Complement to TIP31/31A/31B/31C
applications
New products
Product selection and
back to top
parametric search
Cross-reference
Applications
search
technical information
Product Folders and
Datasheets
Application
notes
Related Links
Request samples
Dotted line
How to order products
Dotted line
Product Change Notices
(PCNs)
Dotted line
Support
Dotted line
Distributor and field sales
representatives
Dotted line
Quality and reliability
Dotted line
Design tools
Datasheet
Download this
datasheet
PDF
e-mail this datasheet
[Email]
This pagePrint version
space
buy products
technical support
my Fairchild
back to top
Product status/pricing/packaging
company
Product
Product status
TIP32BTU
Full Production
Pricing*
$0.319
Package type
Leads
Packing method
TO-220
3
RAIL
* 1,000 piece Budgetary Pricing
back to top
space
Home | Find products | Technical information | Buy products |
Support | Company | Contact us | Site index | Privacy policy
space
© Copyright 2002 Fairchild Semiconductor
space
file:///C|/PDF/TIP32B.html [29-Jul-02 9:38:22 AM]
space
Product Folder - Fairchild P/N TIP32C - PNP Epitaxial Silicon Transistor
space
space
GO
space
space
space
space
Home
find products
space
space
space
TIP32C
Products groups
Analog and Mixed
Signal
Contents
Discrete
Interface
Logic
space
Microcontrollers
Non-Volatile
Features
Memory
Markets and
applications
New products
back to top
parametric search
Cross-reference
Applications
search
Product Folders and
Datasheets
Application
notes
Related Links
Datasheet
Download this
datasheet
PDF
[Email]
space
Request samples
Dotted line
Dotted line
(PCNs)
Dotted line
Support
Dotted line
representatives
Dotted line
Dotted line
Design tools
buy products
technical support
my Fairchild
back to top
company
Product
Product status
Pricing*
Package type
Leads
Packing method
TIP32C
Full Production
$0.319
TO-220
3
BULK
TIP32CTSTU
Full Production
$0.319
TO-220
3
RAIL
back to top
space
space
space
file:///C|/PDF/TIP32C.html [29-Jul-02 9:38:23 AM]
space
Product Folder - Fairchild P/N TIP32A - PNP Epitaxial Silicon Transistor
space
space
GO
space
space
space
space
Home
find products
space
space
space
TIP32A
Products groups
Analog and Mixed
Signal
Contents
Discrete
Interface
Logic
space
Microcontrollers
Non-Volatile
Features
Memory
Markets and
applications
New products
back to top
parametric search
Cross-reference
Applications
search
Product Folders and
Datasheets
Application
notes
Related Links
Request samples
Dotted line
Dotted line
(PCNs)
Dotted line
Support
Dotted line
representatives
Dotted line
Dotted line
Design tools
Datasheet
Download this
datasheet
PDF
[Email]
space
buy products
technical support
my Fairchild
back to top
company
Product
Product status
TIP32ATU
Full Production
TIP32A
Full Production
Pricing*
Package type
Leads
Packing method
$0.319
TO-220
3
RAIL
$0.32
TO-220
3
BULK
back to top
space
space
space
file:///C|/PDF/TIP32A.html [29-Jul-02 9:38:24 AM]
space
Product Folder - Fairchild P/N TIP32 - PNP Epitaxial Silicon Transistor
space
space
GO
space
space
space
space
Home
find products
space
space
space
TIP32
Products groups
Analog and Mixed
Signal
Contents
Discrete
Interface
Logic
space
Microcontrollers
Non-Volatile
Features
Memory
Markets and
applications
New products
back to top
parametric search
Cross-reference
Applications
search
Product Folders and
Datasheets
Application
notes
Related Links
Request samples
Dotted line
Dotted line
(PCNs)
Dotted line
Support
Dotted line
representatives
Dotted line
Dotted line
Design tools
Datasheet
Download this
datasheet
PDF
[Email]
space
buy products
technical support
my Fairchild
back to top
company
Product
Product status
Pricing*
Package type
Leads
Packing method
TIP32
Full Production
$0.319
TO-220
3
BULK
TIP32TU
Full Production
$0.319
TO-220
3
RAIL
back to top
space
space
space
file:///C|/PDF/TIP32.html [29-Jul-02 9:38:25 AM]
space
很抱歉,暂时无法提供与“TIP32B”相匹配的价格&库存,您可以联系我们找货
