BD240A
BD240A
    L3HARRIS
    TO-220-3
    PNP TRANSISTOR
BD240A 数据手册
BD240/A/B/C BD240/A/B/C Medium Power Linear and Switching Applications • Complement to BD239/A/B/C respectively TO-220 1 1.Base 2.Collector 3.Emitter PNP Epitaxial Silicon Transistor Absolute Maximum Ratings TC=25°C unless otherwise noted Symbol VCEO VCER Parameter Value Units : BD240 : BD240A : BD240B : BD240C - 45 - 60 - 80 - 100 V V V V Collector-Emitter Voltage : BD240 : BD240A : BD240B : BD240C - 55 - 70 - 90 - 115 V V V V Collector-Base Voltage VEBO Emitter-Base Voltage -5 V IC Collector Current (DC) -2 A ICP *Collector Current (Pulse) -4 A IB Base Current PC Collector Dissipation ( TC=25°C) TJ TSTG - 0.6 A 30 W Junction Temperature 150 °C Storage Temperature - 65 ~ 150 °C Electrical Characteristics TC=25°C unless otherwise noted Symbol VCEO(sus) Parameter * Collector-Emitter Sustaining Voltage : BD240 : BD240A : BD240B : BD240C Test Condition Min. IC = - 30mA, IB = 0 - 45 - 60 - 80 - 100 Typ. Max. Units V V V V ICEO Collector Cut-off Current : BD240/A : BD240B/C VCE = - 30V, IB = 0 VCE = - 60V, IB = 0 - 0.3 - 0.3 mA mA ICES Collector Cut-off Current : BD240 : BD240A : BD240B : BD240C VCE = - 45V, VBE = 0 VCE = - 60V, VBE = 0 VCE = - 80V, VBE = 0 VCE = - 100V, VBE = 0 - 0.2 - 0.2 - 0.2 - 0.2 mA mA mA mA -1 mA IEBO Emitter Cut-off Current VEB = - 5V, IC = 0 hFE * DC Current Gain VCE = - 4V,IC = - 0.2A VCE = - 4V, IC = - 1A 40 15 VCE(sat) * Collector-Emitter Saturation Voltage IC = - 1A , IB = - 0.2A - 0.7 V VBE(on) * Base-Emitter ON Voltage VCE = - 4V, IC = - 1A - 1.3 V * Pulse Test: PW=350µs, duty Cycle≤2.0% Pulsed ©2000 Fairchild Semiconductor International Rev. A, February 2000 BD240/A/B/C Package Demensions TO-220 4.50 ±0.20 2.80 ±0.10 (3.00) +0.10 1.30 –0.05 18.95MAX. (3.70) ø3.60 ±0.10 15.90 ±0.20 1.30 ±0.10 (8.70) (1.46) 9.20 ±0.20 (1.70) 9.90 ±0.20 1.52 ±0.10 0.80 ±0.10 2.54TYP [2.54 ±0.20] 10.08 ±0.30 (1.00) 13.08 ±0.20 ) (45° 1.27 ±0.10 +0.10 0.50 –0.05 2.40 ±0.20 2.54TYP [2.54 ±0.20] 10.00 ±0.20 Dimensions in Millimeters ©2000 Fairchild Semiconductor International Rev. A, February 2000 TRADEMARKS The following are registered and unregistered trademarks Fairchild Semiconductor owns or is authorized to use and is not intended to be an exhaustive list of all such trademarks. ACEx™ Bottomless™ CoolFET™ CROSSVOLT™ E2CMOS™ FACT™ FACT Quiet Series™ FAST® FASTr™ GTO™ HiSeC™ ISOPLANAR™ MICROWIRE™ POP™ PowerTrench® QFET™ QS™ Quiet Series™ SuperSOT™-3 SuperSOT™-6 SuperSOT™-8 SyncFET™ TinyLogic™ UHC™ VCX™ DISCLAIMER FAIRCHILD SEMICONDUCTOR RESERVES THE RIGHT TO MAKE CHANGES WITHOUT FURTHER NOTICE TO ANY PRODUCTS HEREIN TO IMPROVE RELIABILITY, FUNCTION OR DESIGN. FAIRCHILD DOES NOT ASSUME ANY LIABILITY ARISING OUT OF THE APPLICATION OR USE OF ANY PRODUCT OR CIRCUIT DESCRIBED HEREIN; NEITHER DOES IT CONVEY ANY LICENSE UNDER ITS PATENT RIGHTS, NOR THE RIGHTS OF OTHERS. LIFE SUPPORT POLICY FAIRCHILD’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS WITHOUT THE EXPRESS WRITTEN APPROVAL OF FAIRCHILD SEMICONDUCTOR INTERNATIONAL. As used herein: 1. Life support devices or systems are devices or systems which, (a) are intended for surgical implant into the body, or (b) support or sustain life, or (c) whose failure to perform when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. 2. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. PRODUCT STATUS DEFINITIONS Definition of Terms Datasheet Identification Product Status Definition Advance Information Formative or In Design This datasheet contains the design specifications for product development. Specifications may change in any manner without notice. Preliminary First Production This datasheet contains preliminary data, and supplementary data will be published at a later date. Fairchild Semiconductor reserves the right to make changes at any time without notice in order to improve design. No Identification Needed Full Production This datasheet contains final specifications. Fairchild Semiconductor reserves the right to make changes at any time without notice in order to improve design. Obsolete Not In Production This datasheet contains specifications on a product that has been discontinued by Fairchild semiconductor. The datasheet is printed for reference information only. ©2000 Fairchild Semiconductor International Rev. E Product Folder - Fairchild P/N BD240C - PNP Epitaxial Silicon Transistor SEARCH | Parametric | Cross Reference space Fairchild Semiconductor space GO space space space space space >> Find products >> Home find products space space space BD240C Products groups PNP Epitaxial Silicon Transistor Analog and Mixed Signal Contents Discrete Features | Applications | Product Interface status/pricing/packaging Logic space Microcontrollers Non-Volatile Features Memory spaceOptoelectronics Markets and ● Complement to BD239/A/B/C applications respectively New products Product selection and parametric search back to top Cross-reference search Applications Product Folders and Datasheets Application notes Related Links Request samples Dotted line How to order products Dotted line Product Change Notices (PCNs) Dotted line Support Dotted line Distributor and field sales representatives Dotted line Quality and reliability Dotted line Design tools Datasheet Download this datasheet PDF e-mail this datasheet [Email] This page Print version space technical information buy products technical support my Fairchild Medium Power Linear and Switching back to top Product status/pricing/packaging company Product Product status BD240CTU Full Production Pricing* $0.319 Package type Leads Packing method TO-220 3 RAIL * 1,000 piece Budgetary Pricing back to top space Home | Find products | Technical information | Buy products | Support | Company | Contact us | Site index | Privacy policy space © Copyright 2002 Fairchild Semiconductor space file:///H|/imaging/BITTING/cpl/20020725_1/07252002_10/FAIR/07252002/BD240C.html [Jul/26/2002 2:42:16 PM] space Product Folder - Fairchild P/N BD240B - PNP Epitaxial Silicon Transistor SEARCH | Parametric | Cross Reference space Fairchild Semiconductor space GO space space space space space >> Find products >> Home find products space space space BD240B Products groups PNP Epitaxial Silicon Transistor Analog and Mixed Signal Contents Discrete Features | Applications | Product Interface status/pricing/packaging Logic space Microcontrollers Non-Volatile Features Memory spaceOptoelectronics Markets and ● Complement to BD239/A/B/C applications respectively New products Product selection and parametric search back to top Cross-reference search Applications Product Folders and Datasheets Application notes Related Links Request samples Dotted line How to order products Dotted line Product Change Notices (PCNs) Dotted line Support Dotted line Distributor and field sales representatives Dotted line Quality and reliability Dotted line Design tools Datasheet Download this datasheet PDF e-mail this datasheet [Email] This page Print version space technical information buy products technical support my Fairchild Medium Power Linear and Switching back to top Product status/pricing/packaging company Product Product status BD240BTU Full Production BD240B Full Production Pricing* Package type Leads Packing method $0.319 TO-220 3 RAIL $0.32 TO-220 3 BULK * 1,000 piece Budgetary Pricing back to top space Home | Find products | Technical information | Buy products | Support | Company | Contact us | Site index | Privacy policy space © Copyright 2002 Fairchild Semiconductor space file:///H|/imaging/BITTING/cpl/20020725_1/07252002_10/FAIR/07252002/BD240B.html [Jul/26/2002 2:42:18 PM] space Product Folder - Fairchild P/N BD240 - PNP Epitaxial Silicon Transistor SEARCH | Parametric | Cross Reference space Fairchild Semiconductor space GO space space space space space >> Find products >> Home find products space space space BD240 Products groups PNP Epitaxial Silicon Transistor Analog and Mixed Signal Contents Discrete Features | Applications | Product Interface status/pricing/packaging Logic space Microcontrollers Non-Volatile Features Memory spaceOptoelectronics Markets and ● Complement to BD239/A/B/C applications respectively New products Product selection and parametric search back to top Cross-reference search Applications Product Folders and Datasheets Application notes Related Links Request samples Dotted line How to order products Dotted line Product Change Notices (PCNs) Dotted line Support Dotted line Distributor and field sales representatives Dotted line Quality and reliability Dotted line Design tools Datasheet Download this datasheet PDF e-mail this datasheet [Email] This page Print version space technical information buy products technical support my Fairchild Medium Power Linear and Switching back to top Product status/pricing/packaging company Product BD240TU Product status Full Production Pricing* $0.319 Package type Leads Packing method TO-220 3 RAIL * 1,000 piece Budgetary Pricing back to top space Home | Find products | Technical information | Buy products | Support | Company | Contact us | Site index | Privacy policy space © Copyright 2002 Fairchild Semiconductor space file:///H|/imaging/BITTING/cpl/20020725_1/07252002_10/FAIR/07252002/BD240.html [Jul/26/2002 2:42:19 PM] space
BD240A 价格&库存
很抱歉,暂时无法提供与“BD240A”相匹配的价格&库存,您可以联系我们找货
