BZX79C2V0 - BZX79C75
Taiwan Semiconductor
500mW, 5% Tolerance Zener Diodes
FEATURES
KEY PARAMETERS
● Wide zener voltage range selection: 2.0V to 75V
● VZ tolerance selection of ± 5%
● Compliant to RoHS directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
VZ
2.0-75
V
Test current IZT
5
mA
PD
500
mW
VF at IF=100mA
1.5
V
TJ Max.
175
°C
APPLICATIONS
Low voltage stabilizers or voltage references
Adapters
Lighting application
On-board DC/DC converter
Package
DO-35
Configuration
Single die
MECHANICAL DATA
Case: DO-35
Terminal: Matte tin plated leads, solderable per J-STD-002
Polarity: Indicated by cathode band
Weight: 109 ± 4 mg (approximately)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Power dissipation
SYMBOL
VALUE
UNIT
PD
500
mW
VF
1.5
V
Junction temperature range
TJ
-65 to +175
°C
Storage temperature range
TSTG
-65 to +175
°C
SYMBOL
TYP
UNIT
RӨJA
300
°C/W
Forward voltage
IF=100mA
THERMAL PERFORMANCE
PARAMETER
Junction to ambient thermal resistance
1
Version:F1804
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
ZENER VOLTAGE
PART
MARKING
NUMBER
CODE
TEST
REGULAR
TEST
LEAKAGE
CURRENT
IMPEDANCE
CURRENT
CURRENT
ZZK @ IZK
IZK
IR @ V R
mA
VZ @ IZT
IZT
V
Min.
mA
Nom.
Max.
ZZT @ IZT
Ω
Ω
Max.
Max.
µA
V
Max.
BZX79C2V0
BZX79C2V0
1.88
2.0
2.12
5
100
600
1.0
150
1.0
BZX79C2V2
BZX79C2V2
2.08
2.2
2.33
5
100
600
1.0
150
1.0
BZX79C2V4
BZX79C2V4
2.28
2.4
2.56
5
100
600
1.0
100
1.0
BZX79C2V7
BZX79C2V7
2.51
2.7
2.89
5
100
600
1.0
75
1.0
BZX79C3V0
BZX79C3V0
2.8
3.0
3.2
5
95
600
1.0
50
1.0
BZX79C3V3
BZX79C3V3
3.1
3.3
3.5
5
95
600
1.0
25
1.0
BZX79C3V6
BZX79C3V6
3.4
3.6
3.8
5
90
600
1.0
15
1.0
BZX79C3V9
BZX79C3V9
3.7
3.9
4.1
5
90
600
1.0
10
1.0
BZX79C4V3
BZX79C4V3
4.0
4.3
4.6
5
90
600
1.0
5
1.0
BZX79C4V7
BZX79C4V7
4.4
4.7
5.0
5
80
500
1.0
3
2.0
BZX79C5V1
BZX79C5V1
4.8
5.1
5.4
5
60
480
1.0
2
2.0
BZX79C5V6
BZX79C5V6
5.2
5.6
6.0
5
40
400
1.0
1
2.0
BZX79C6V2
BZX79C6V2
5.8
6.2
6.6
5
10
150
1.0
3
4.0
BZX79C6V8
BZX79C6V8
6.4
6.8
7.2
5
15
80
1.0
2
4.0
BZX79C7V5
BZX79C7V5
7.0
7.5
7.9
5
15
80
1.0
1
5.0
BZX79C8V2
BZX79C8V2
7.7
8.2
8.7
5
15
80
1.0
0.7
5.0
BZX79C9V1
BZX79C9V1
8.5
9.1
9.6
5
15
100
1.0
0.5
6.0
BZX79C10
BZX79C10
9.4
10
10.6
5
1.0
0.2
7.0
BZX79C11
BZX79C11
10.4
11
11.6
5
1.0
0.1
8.0
BZX79C12
BZX79C12
11.4
12
12.7
5
25
150
1.0
0.1
8.0
BZX79C13
BZX79C13
12.4
13
14.1
5
30
170
1.0
0.1
8
BZX79C15
BZX79C15
13.8
15
15.6
5
30
200
1.0
0.05
10.5
BZX79C16
BZX79C16
15.3
16
17.1
5
40
200
1.0
0.05
11.2
BZX79C18
BZX79C18
16.8
18
19.1
5
45
225
1.0
0.05
12.6
BZX79C20
BZX79C20
18.8
5
55
225
1.0
0.05
14.0
BZX79C22
BZX79C22
20.8
22
23.3
5
55
250
1.0
0.05
15.4
BZX79C24
BZX79C24
22.8
24
25.6
5
70
250
1.0
0.05
16.8
BZX79C27
BZX79C27
25.1
27
28.9
2
80
300
0.5
0.05
18.9
BZX79C30
BZX79C30
28.0
30
32.0
2
80
300
0.5
0.05
21.0
BZX79C33
BZX79C33
31.0
33
35.0
2
80
325
0.5
0.05
23.1
BZX79C36
BZX79C36
34.0
36
38.0
2
90
350
0.5
0.05
25.2
BZX79C39
BZX79C39
37.0
39
41.0
2
130
350
0.5
0.05
27.3
BZX79C43
BZX79C43
40.0
43
46.0
2
150
375
0.5
0.05
30.1
BZX79C47
BZX79C47
44.0
47
50.0
2
170
375
0.5
0.05
32.9
BZX79C51
BZX79C51
48.0
51
54.0
2
180
400
0.5
0.05
35.7
BZX79C56
BZX79C56
52.0
56
60.0
2
200
425
0.5
0.05
39.2
BZX79C62
BZX79C62
58.0
62
66.0
2.5
215
1000
0.5
0.05
43.4
BZX79C68
BZX79C68
64.0
68
72.0
2.5
240
1000
0.5
0.05
47.6
BZX79C75
BZX79C75
70.0
75
80.0
2.5
255
1000
0.5
0.05
52.5
2
Version:F1804
Notes:
1. The zener voltage (VZ) is tested under pulse condition of 30ms.
2. The device numbers listed have a standard tolerance on the nomial zener voltage of ±5%.
3. For detailed information on price, availability and delivery of nominal zener voltages between the voltages
shown and tighter voltage tolerances, contact your nearest Taiwan Semiconductor representative.
4. The Zener impedance is derived from the 60-cycle ac voltage, which results when an ac current
having an RMS value equal to 10% of the DC Zener current(IZT or IZK) is superimposed to IZT or IZK.
ORDERING INFORMATION
PART NO.
(Note 1)
PACKAGE
PACKING
BZX79Cxxx R0
DO-35
10K / 14" Reel
BZX79Cxxx R0G
DO-35
10K / 14" Reel
BZX79Cxxx A0
DO-35
5K / Box (Ammo)
BZX79Cxxx A0G
DO-35
5K / Box (Ammo)
Note:
1. "xxx" defines part no. from BZX79C2V0 to BZX79C75
3
Version:F1804
CHARACTERISTICS CURVES
Fig.1 Power Dissipation VS.
Fig. 2 Total Capacitance
Ambient Temperature
1000
500
Total Capacitance (pF)
PD-Power dissipation (mW)
600
400
300
200
VR=2V
100
VR=5V
10
100
VR=20V
VR=30V
1
80
120
160
200
60
VZ - Reverse Voltage (V)
Temperature (oC)
Fig. 3 Differential Impedance VS. Zener Voltage
80
Fig.4 Forward Current VS. Forward Voltage
1000
1000
IZ=1mA
TA=25oC
IZ=2mA
100
Forward Current (mA)
Differential Zener Impedance(Ohm)
f=1MHz
TA=25oC
VR=0V
IZ=5mA
10
IZ=10mA
100
10
1
1
0.1
10
0.0
100
0.2
0.4
0.6
0.8
1.0
1.2
VF - Forward Voltage (mV)
4
Version:F1804
PACKAGE OUTLINE DIMENSION
DO-35
DIM.
5
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
0.34
0.60
0.013
0.024
B
2.90
5.08
0.114
0.200
C
25.40
38.10
1.000
1.500
D
1.30
2.28
0.051
0.090
Version:F1804
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version:F1804
很抱歉,暂时无法提供与“BZX79C3V3 A0G”相匹配的价格&库存,您可以联系我们找货
