1N4728G ~ 1N4758G
Taiwan Semiconductor
Small Signal Product
1W DO-41 Zener Volatge Regulators
FEATURES
- Zener voltage range 3.3 to 56Volts
- DO-41 package (JEDEC)
- Through-hole device type mounting
- Hermetically sealed glass
- Compression bonded construction
- All external surfaces are corrosion resistant and
terminals are readily solderable
DO-41
- Solder hot dip tin(Sn) lead finish
- Pb free and RoHS compliant
MECHANICAL DATA
- Lead: Pure tin plated, lead free, solderable per
Cathode
MIL-STD-202, method 208 guaranteed
Anode
- Polarity: Color band denotes cathode
- High temperature soldering guaranteed: ' 260oC/10 s
- Weight: 0.270~0.290 grams
- Marking code: 1N47XXG for ± 5% Vz
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25℃ unless otherwise noted)
PARAMETER
SYMBOL
VALUE
Power Dissipation
Thermal Resistance Junction to Lead
PD
Rjl
1
53.5
Thermal Resistance Junction to Ambient
Rja
100
OperatingTemperature Range
TOPR
- 65 to + 200
o
C
Storage Temperature Range
TSTG
- 65 to + 200
o
C
UNIT
W
o
C/W
o
C/W
Note: These ratings are limiting values above which the serviceability of the diode may be impaired
Version: F1606
1N4728G ~ 1N4758G
ELECTRICAL CHARACTERISTICS (Ratings at TA=25oC ambient temperature unless otherwise specified)
VF Forward Voltage = 1.2 V Maximum @ IF = 200 mA for all types
ZZK @ IZK
IR @ VR
(Ω)
Max.
(μA)
Max.
1
400
100
1
10
1
400
100
1
64
9
1
400
50
1
4.3
58
9
1
400
10
1
1N4732G
4.7
53
8
1
500
10
1
1N4733G
5.1
49
7
1
550
10
1
10
2
Device
Type
VZ @ IZT
(V)
Typ.
IZT
(mA)
ZZT @ OZK
(Ω)
Max.
IZK
(mA)
1N4728G
3.3
76
10
1N4729G
3.6
69
1N4730G
3.9
1N4731G
VR
(V)
1N4734G
5.6
45
5
1
600
1N4735G
6.2
41
2
1
700
10
3
1N4736G
6.8
37
3.5
1
700
10
4
1N4737G
7.5
34
4
0.5
700
10
5
1N4738G
8.2
31
4.5
0.5
700
10
6
1N4739G
9.1
28
5
0.5
700
10
7
1N4740G
10
25
7
0.25
700
10
7.6
1N4741G
11
23
8
0.25
700
5
8.4
1N4742G
12
21
9
0.25
700
5
9.1
1N4743G
13
19
10
0.25
700
5
9.9
5
11.4
1N4744G
15
17
14
0.25
700
1N4745G
16
15.5
16
0.25
700
5
12.2
1N4746G
18
14
700
5
13.7
1N4747G
22
0.25
750
5
15.2
1N4748G
22
11.5
23
0.25
750
5
16.7
1N4749G
24
10.5
25
0.25
750
5
18.2
1N4750G
27
9.5
35
0.25
750
5
20.6
1N4751G
30
8.5
40
0.25
1000
5
22.8
1N4752G
33
7.5
45
0.25
1000
5
25.1
1N4753G
36
7
50
0.25
1000
5
27.4
5
29.7
1N4754G
39
6.5
60
0.25
1000
1N4755G
43
6
70
0.25
1500
5
32.7
1N4756G
47
5.5
80
0.25
1500
5
35.8
1N4757G
51
5
95
0.25
1500
5
38.8
1N4758G
56
4.5
110
0.25
2000
5
42.6
Notes : 1. TOLERANCE AND TYPE NUMBER DESIGNATION (VZ)
The type numbers listed have a standard tolerance on the nmial zener voltage of ±5%.
2. SPECIAL AVAILABLE INCLUDE
Nomial zener voltages shown and tighter voltage, for detailed information on price, availability and delivery,
contact your nearest Taiwan Semiconductor representative.
3. ZENER VOLTAGE (VZ) MEASUREMENT
The zener voltage (VZ) is tested under pulse condition. The measured VZ is guaranteed to be within
specification with device junction in thermal equilibrium.
4. ZENER IMPEDANCE (ZZ) DERIVATION
The zener impedance is derived from the 60-cycle ac voltage, which results when an ac current having an
RMS value equal to 10% of the dc zener current(IZT or IZK) is superimposed to IZT or IZK.
Version: F1606
1N4728G ~ 1N4758G
ORDERING INFORMATION
GREEN COMPOUND
PART NO.
PACKING CODE
1N47xxG
(Note1,2)
R0
CODE
G
A0
G
PACKAGE
PACKING
DO-41
5K / 14" Reel
DO-41
3K / BOX (Ammo)
Note 1: "xx" is Device Code from "28" through "58"
Note 2: Whole series with green compound.
EXAMPLE
PREFERRED
PART NO.
1N4728G R0G
PART NO.
1N4728G
PACKING
PACKING CODE
CODE
SUFFIX
R0
G
DESCRIPTION
Green compound
Version: F1606
1N4728G ~ 1N4758G
PACKAGE OUTLINE DIMENSIONS
DO-41
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
0.50
0.90
0.020
0.035
B
3.50
5.20
0.138
0.205
C
22.00
0.866
D
1.80
2.80
0.071
0.110
MARKING DIAGRAM
XX
XX
XXX
1N
47
XXG
Version: F1606
1N4728G ~ 1N4758G
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no
responsibility or liability for any errors inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property
rights is granted by this document. Except as provided in TSC's terms and conditions of sale for such products, TSC assumes no liability
whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties
relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or seling these
products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such
improper use or sale.
Version: F1606
很抱歉,暂时无法提供与“1N4728G A0G”相匹配的价格&库存,您可以联系我们找货
