BZX79B2V4 – BZX79B75
Taiwan Semiconductor
500mW, 2% Zener Diode
FEATURES
KEY PARAMETERS
Wide zener voltage range selection: 2.4V to 75V
VZ Tolerance selection of ±2%
Hermetically sealed glass
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
Low voltage stabilizers or voltage references
Adapters
Lighting application
On-board DC/DC converter
PARAMETER
VALUE
UNIT
VZ
2.4 - 75
V
Test current IZT
2.5 - 5.0
mA
Ptot
500
mW
VF at IF = 100mA
1.5
V
TJ MAX
175
°C
Package
DO-35
Configuration
Single die
MECHANICAL DATA
Case: DO-35
Terminal: Matte tin plated leads, solderable per J-STD-002
Polarity: Indicated by cathode band
Weight: 109 ± 4mg (approximately)
DO-35
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
VALUE
UNIT
Forward voltage @ IF = 100mA
VF
1.5
V
Total power dissipation
Ptot
500
mW
Junction temperature range
TJ
-55 to +175
°C
Storage temperature range
TSTG
-55 to +175
°C
1
Version:E2103
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
ZENER VOLTAGE(1)
PART NUMBER
TEST
CURRENT
REGULAR IMPEDANCE(1)
TEST CURRENT
VZ @ IZ
IZT
ZZT @ IZT
ZZK @ IZK
IZK
V
mA
Ω
Ω
mA
LEAKAGE
CURRENT
VZ @ IZT
V
mA
Min Nom Max
Max
Max
Max.
BZX79B2V4
2.35 2.40 2.45
5
100
600
1.0
100
1.0
BZX79B2V7
2.65 2.70 2.75
5
100
600
1.0
75
1.0
BZX79B3V0
2.94 3.00 3.06
5
95
600
1.0
50
1.0
BZX79B3V3
3.23 3.30 3.37
5
95
600
1.0
25
1.0
BZX79B3V6
3.53 3.60 3.67
5
90
600
1.0
15
1.0
BZX79B3V9
3.82 3.90 3.98
5
90
600
1.0
10
1.0
BZX79B4V3
4.21 4.30 4.39
5
90
600
1.0
5
1.0
BZX79B4V7
4.61 4.70 4.79
5
80
500
1.0
3.0
2.0
BZX79B5V1
5.00 5.10
5.2
5
60
480
1.0
2.0
2.0
BZX79B5V6
5.49 5.60 5.71
5
40
400
1.0
1.0
2.0
BZX79B6V2
6.08 6.20 6.32
5
10
150
1.0
3.0
4.0
BZX79B6V8
6.66 6.80 6.94
5
15
80
1.0
2.0
4.0
BZX79B7V5
7.35 7.50 7.65
5
15
80
1.0
1.0
5.0
BZX79B8V2
8.04 8.20 8.36
5
15
80
1.0
0.7
5.0
BZX79B9V1
8.92 9.10 9.28
5
15
100
1.0
0.5
6.0
BZX79B10
9.80 10.00 10.2
5
1.0
0.2
7.0
BZX79B11
10.78 11.00 11.22
5
1.0
0.1
8.0
BZX79B12
11.76 12.00 12.24
5
25
150
1.0
0.1
8.0
BZX79B13
12.74 13.00 13.26
5
30
170
1.0
0.1
8.0
BZX79B15
14.70 15.00 15.30
5
30
200
1.0
0.05
10.5
BZX79B16
15.68 16.00 16.32
5
40
200
1.0
0.05
11.2
BZX79B18
17.64 18.00 18.36
5
45
225
1.0
0.05
12.6
BZX79B20
19.60 20.00 20.40
5
55
225
1.0
0.05
14.0
BZX79B22
21.56 22.00 22.44
5
55
250
1.0
0.05
15.4
BZX79B24
23.52 24.00 24.48
5
70
250
1.0
0.05
16.8
BZX79B27
26.46 27.00 27.54
2
80
300
0.5
0.05
18.9
BZX79B30
29.40 30.00 30.60
2
80
300
0.5
0.05
21.0
BZX79B33
32.34 33.00 33.66
2
80
325
0.5
0.05
23.1
BZX79B36
35.28 36.00 36.72
2
90
350
0.5
0.05
25.2
BZX79B39
38.22 39.00 39.78
2
130
350
0.5
0.05
27.3
BZX79B43
42.14 43.00 43.86
2
150
375
0.5
0.05
30.1
BZX79B47
46.06 47.00 47.94
2
170
375
0.5
0.05
32.9
BZX79B51
49.98 51.00 52.02
2
180
400
0.5
0.05
35.7
BZX79B56
54.88 56.00 57.12
2
200
425
0.5
0.05
39.2
BZX79B62
60.76 62.00 63.24
2.5
215
430
0.5
0.05
43.4
BZX79B68
66.64 68.00 69.36
2.5
240
447
0.5
0.05
47.6
BZX79B75
73.50 75.00 76.50
2.5
255
470
0.5
0.05
52.5
Notes:
1. ZENER IMPEDANCE (ZZ) derivation ZZT and ZZK are measured by dividing the AC voltage drop across the
device by the AC current applied. The specified limits are for IZ(AC) = 0.1 IZ(DC) with the AC frequency = 60Hz.
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
BZX79Bx R0G
DO-35
10K / 14” Reel
BZX79Bx A0G
DO-35
5K / Box(Ammo)
Notes:
1. “x” defines voltage from 2.4V(BZX79B2V4) to 75V(BZX79B75)
2
Version:E2103
PACKAGE OUTLINE DIMENSION
DO-35
DIM.
Unit(mm)
Unit(inch)
Min
Max
Min
Max
A
0.34
0.60
0.013
0.024
B
2.90
5.08
0.114
0.200
C
25.40
38.10
1.000
1.500
D
1.30
2.28
0.051
0.090
MARKING DIAGRAM
3
Version:E2103
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
4
Version:E2103
很抱歉,暂时无法提供与“BZX79B2V4 A0G”相匹配的价格&库存,您可以联系我们找货
