BC817-16/-25/-40
Taiwan Semiconductor
300mW, NPN Small Signal Transistor
FEATURES
KEY PARAMETERS
Low power loss, high efficiency
Ideal for automated placement
High surge current capability
Compliant to RoHS directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
APPLICATIONS
Switching mode power supply (SMPS)
Adapters
Lighting application
On-board DC/DC converter
PARAMETER
VALUE
UNIT
VCBO
50
V
VCEO
45
V
VEBO
5
V
IC
500
mA
hFE
250-600
Package
SOT-23
Configuration
Single Dice
MECHANICAL DATA
Case: SOT-23
Molding compound meets UL 94 V-0 flammability rating
Moisture sensitivity level: level 1, per J-STD-020
Packing code with suffix "G" means green compound
(halogen-free)
● Terminal: Matte tin plated leads, solderable per J-STD-002
● Meet JESD 201 class 1A whisker test
● Weight: 8mg (approximately)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
Power dissipation
BC817- BC817- BC81716
6A
25
6B
40
6C
UNIT
PD
300
mW
Collector-base voltage, emitter open
IC = 10 μA, IE = 0
VCBO
50
V
Collector-emitter voltage, base open
IC = 10 mA, IB = 0
VCEO
45
V
Emitter-base voltage, collector open
IE = 1 μA, IC = 0
VEBO
5
V
Collector current, dc
IC
500
mA
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
1
Version:J1702
BC817-16/-25/-40
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
Collector cutoff current, emitter
open
Emitter cutoff current, collector
open
SYMBOL
MIN
TYP
MAX
UNIT
VCB = 45 V, IE = 0
ICBO
0.1
µA
VEB = 4 V, IC = 0
IEBO
0.1
µA
100
250
160
400
250
600
BC817-16
VCE = 1 V,
DC current gain
IC = 100 mA
Collector-emitter saturation
voltage
Base-emitter saturation
voltage
BC817-25
hFE
BC817-40
IC = 500 mA, IB = 50 mA
VCE(sat)
0.7
V
VBE(sat)
1.2
V
fT
100
MHz
VCE = 5 V , IC = 10 mA,
Transition frequency
f= 100MHz
ORDERING INFORMATION
PART NO.
PACKING
PACKING CODE
CODE
SUFFIX(*)
RF
G
BC817-XX
(Note 1)
PACKAGE
PACKING
SOT-23
3K / 7" Reel
Notes:
1. "xx" is Device Code is"16" and "25" and "40"
*: optional available
EXAMPLE
EXAMPLE P/N
PART NO.
PACKING CODE
BC817-16 RFG
BC817-16
RF
PACKING CODE
SUFFIX
G
2
DESCRIPTION
Green compound
Version:J1702
BC817-16/-25/-40
CHARACTERISTICS CURVES
Fig.1 Typical Pulsed Current Gain VS.
Fig. 2 Collector-Emitter Saturation Voltage VS.
Collector Current
Collector Current
10.00
IC , Collector Current (mA)
IC , Collector Current (A)
10
1
0.1
0.01
1.00
0.10
VCE = 5 V
0.01
0.001
200
300
400
0.0
500
hFE
0.1
0.3
0.4
0.5
0.6
VCE(sat) , Collector Emitter Voltage (V)
Fig.3 Base-Emitter Saturation Voltage
Fig.4 Base-Emitter On Voltage
VS. Collector Current
1000
1
-IC, Collector Current (mA)
0.2
100
10
1
0.1
0.01
0.001
0.0
0.2
0.4
0.6
0.8
1.0
1.2
1.4
0.0
0.2
0.4
0.6
0.8
1.0
1.2
1.4
VBE(sat) , Base-Emitter on Voltage (V)
VBE , Base-Emitter Voltage (V)
3
Version:J1702
BC817-16/-25/-40
Fig.5 Collector-Base Capacitance VS.
Collector-Base Voltage
Collector-Base Capacitance (pF)
40
30
8
12
16
28
VCB , Collector-Base Voltage (V)
4
Version:J1702
BC817-16/-25/-40
PACKAGE OUTLINE DIMENSION
SOT-23
DIM.
Unit(mm)
Unit(inch)
Min
Max
Min
Max
A
2.70
3.10
0.106
0.122
B
1.10
1.50
0.043
0.059
C
0.30
0.51
0.012
0.020
D
1.78
2.04
0.070
0.080
E
2.10
2.64
0.083
0.104
F
0.89
1.30
0.035
0.051
G
0.55 REF
0.022 REF
H
0.10 REF
0.004 REF
SUGGEST PAD LAYOUT
Unit(mm)
Unit(inch)
TYP
TYP
Z
2.8
0.11
X
0.7
0.03
Y
0.9
0.04
C
1.9
0.07
E
1.0
0.04
DIM.
5
Version:J1702
BC817-16/-25/-40
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version:J1702
很抱歉,暂时无法提供与“BC817-40 RFG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 250+0.44676
- 750+0.43739
- 1500+0.42385
