D44H11
D44H11
    L3HARRIS
    TO-220-3
    POWER BIPOLAR TRANSISTOR, NPN
D44H11 数据手册
D44H8 / NZT44H8 / D44H11 NPN Power Amplifier Features • This device is designed for power amplifier, regulator and switching circuits where speed is important. • Sourced from process 4Q. C E C B C B TO-220 E D44H8 / D44H11 Absolute Maximum Ratings* SOT-223 NZT44H8 TA=25°C unless otherwise noted Value Symbol VCEO IC TJ, TSTG Parameter Units D44H8 NZT44H8 D44H11 Collector-Emitter Voltage 60 80 V Collector Current 8.0 10.0 A - Continuous Operating and Storage Junction Temperature Range °C -55 to +150 *These ratings are limiting values above which the serviceability of any semiconductor device may be impaired. NOTES: 1) These ratings are based on a maximum junction temperature of 150°C. 2) These are steady state limits. The factory should be consulted on applications involving pulsed or low duty cycle operations. Thermal Characteristics TA=25°C unless otherwise noted Max. Symbol Parameter D44H8 D44H11 PD Total Device Dissipation Derate above 25°C 60 480 RθJC Thermal Resistance, Junction to Case 2.1 RθJA Thermal Resistance, Junction to Ambient 62.5 *NZT44H8 1.5 12 © 2010 Fairchild Semiconductor Corporation W mW/°C °C/W 83.3 *Device mounted on FR-4 PCB 36mm X 18mm X 1.5mm; mounting pad for the collector lead min. D44H8 / NZT44H8 / D44H11 Rev. B2 Units °C/W 6cm2. www.fairchildsemi.com 1 D44H8 / NZT44H8 / D44H11 — NPN Power Amplifier February 2010 Symbol TA=25°C unless otherwise noted Parameter Test Condition Min. Max. Units Off Characteristics V(BR)CEO Collector-Emitter Breakdown D44H8 / NZT44H8 IC = 100mA, IB = 0 Voltage D44H11 ICBO Collector-Cutoff Current IEBO Emitter-Cutoff Current 60 80 D44H8 / NZT44H8 VCB = 60V, IE = 0 VCB = 80V, IE = 0 D44H11 VEB = 5V, IC = 0 V 10 μA 100 μA On Characteristics 60 40 DC Current Gain VCE = 1V, IC = 2A VCE = 1V, IC = 4A VCE(sat) Collector-Emitter Saturation Voltage IC = 8A, IB = 0.4A 1.0 V VBE(sat) Base-Emitter Saturation Voltage IC = 8A, IB = 0.8A 1.5 V VBE(on) Base-Emitter On Voltage VCE = 2V, IC = 10mA 0.65 V hFE 0.52 Small Signal Characteristics fT Current Gain-Bandwidth Product IC = 500mA, VCE = 10V © 2010 Fairchild Semiconductor Corporation D44H8 / NZT44H8 / D44H11 Rev. B2 50 MHz www.fairchildsemi.com 2 D44H8 / NZT44H8 / D44H11 — NPN Power Amplifier Electrical Characteristics D44H8 / NZT44H8 / D44H11 — NPN Power Amplifier © 2010 Fairchild Semiconductor Corporation D44H8 / NZT44H8 / D44H11 Rev. B2 www.fairchildsemi.com 3 D44H8 / NZT44H8 / D44H11 — NPN Power Amplifier © 2010 Fairchild Semiconductor Corporation D44H8 / NZT44H8 / D44H11 Rev. B2 www.fairchildsemi.com 4 D44H8 / NZT44H8 / D44H11 — NPN Power Amplifier © 2010 Fairchild Semiconductor Corporation D44H8 / NZT44H8 / D44H11 Rev. B2 www.fairchildsemi.com 5 D44H8 / NZT44H8 / D44H11 — NPN Power Amplifier Physical Dimensions TO-220 Dimensions in Millimeters © 2010 Fairchild Semiconductor Corporation D44H8 / NZT44H8 / D44H11 Rev. B2 www.fairchildsemi.com 6 D44H8 / NZT44H8 / D44H11 — NPN Power Amplifier Physical Dimensions (Continued) SOT-223 Dimensions in Millimeters © 2010 Fairchild Semiconductor Corporation D44H8 / NZT44H8 / D44H11 Rev. B2 www.fairchildsemi.com 7 TRADEMARKS The following includes registered and unregistered trademarks and service marks, owned by Fairchild Semiconductor and/or its global subsidiaries, and is not intended to be an exhaustive list of all such trademarks. FRFET® SM Global Power Resource Green FPS¥ Green FPS¥ e-Series¥ Gmax¥ GTO¥ IntelliMAX¥ ISOPLANAR¥ MegaBuck¥ MICROCOUPLER¥ MicroFET¥ MicroPak¥ MicroPak2¥ MillerDrive¥ MotionMax¥ Motion-SPM¥ OptoHiT™ OPTOLOGIC® OPTOPLANAR® AccuPower¥ Auto-SPM¥ Build it Now¥ CorePLUS¥ CorePOWER¥ CROSSVOLT¥ CTL¥ Current Transfer Logic¥ DEUXPEED® Dual Cool™ EcoSPARK® EfficientMax¥ ® Fairchild® Fairchild Semiconductor® FACT Quiet Series¥ ® FACT FAST® FastvCore¥ FETBench¥ FlashWriter®* FPS¥ F-PFS¥ ® PDP SPM™ Power-SPM¥ PowerTrench® PowerXS™ Programmable Active Droop¥ QFET® QS¥ Quiet Series¥ RapidConfigure¥ ¥ Saving our world, 1mW/W/kW at a time™ SignalWise¥ SmartMax¥ SMART START¥ SPM® STEALTH¥ SuperFET¥ SuperSOT¥-3 SuperSOT¥-6 SuperSOT¥-8 SupreMOS¥ SyncFET¥ Sync-Lock™ ® * The Power Franchise® TinyBoost¥ TinyBuck¥ TinyCalc¥ TinyLogic® TINYOPTO¥ TinyPower¥ TinyPWM¥ TinyWire¥ TriFault Detect¥ TRUECURRENT¥* PSerDes¥ ® UHC Ultra FRFET¥ UniFET¥ VCX¥ VisualMax¥ XS™ * Trademarks of System General Corporation, used under license by Fairchild Semiconductor. DISCLAIMER FAIRCHILD SEMICONDUCTOR RESERVES THE RIGHT TO MAKE CHANGES WITHOUT FURTHER NOTICE TO ANY PRODUCTS HEREIN TO IMPROVE RELIABILITY, FUNCTION, OR DESIGN. FAIRCHILD DOES NOT ASSUME ANY LIABILITY ARISING OUT OF THE APPLICATION OR USE OF ANY PRODUCT OR CIRCUIT DESCRIBED HEREIN; NEITHER DOES IT CONVEY ANY LICENSE UNDER ITS PATENT RIGHTS, NOR THE RIGHTS OF OTHERS. THESE SPECIFICATIONS DO NOT EXPAND THE TERMS OF FAIRCHILD’S WORLDWIDE TERMS AND CONDITIONS, SPECIFICALLY THE WARRANTY THEREIN, WHICH COVERS THESE PRODUCTS. LIFE SUPPORT POLICY FAIRCHILD’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS WITHOUT THE EXPRESS WRITTEN APPROVAL OF FAIRCHILD SEMICONDUCTOR CORPORATION. As used herein: 1. Life support devices or systems are devices or systems which, (a) are intended for surgical implant into the body or (b) support or sustain life, and (c) whose failure to perform when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in a significant injury of the user. 2. A critical component in any component of a life support, device, or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. ANTI-COUNTERFEITING POLICY Fairchild Semiconductor Corporation's Anti-Counterfeiting Policy. Fairchild's Anti-Counterfeiting Policy is also stated on our external website, www.fairchildsemi.com, under Sales Support. Counterfeiting of semiconductor parts is a growing problem in the industry. All manufacturers of semiconductor products are experiencing counterfeiting of their parts. Customers who inadvertently purchase counterfeit parts experience many problems such as loss of brand reputation, substandard performance, failed applications, and increased cost of production and manufacturing delays. Fairchild is taking strong measures to protect ourselves and our customers from the proliferation of counterfeit parts. Fairchild strongly encourages customers to purchase Fairchild parts either directly from Fairchild or from Authorized Fairchild Distributors who are listed by country on our web page cited above. Products customers buy either from Fairchild directly or from Authorized Fairchild Distributors are genuine parts, have full traceability, meet Fairchild's quality standards for handling and storage and provide access to Fairchild's full range of up-to-date technical and product information. Fairchild and our Authorized Distributors will stand behind all warranties and will appropriately address any warranty issues that may arise. Fairchild will not provide any warranty coverage or other assistance for parts bought from Unauthorized Sources. Fairchild is committed to combat this global problem and encourage our customers to do their part in stopping this practice by buying direct or from authorized distributors. PRODUCT STATUS DEFINITIONS Definition of Terms Datasheet Identification Product Status Advance Information Formative / In Design Preliminary First Production No Identification Needed Full Production Obsolete Not In Production Definition Datasheet contains the design specifications for product development. Specifications may change in any manner without notice. Datasheet contains preliminary data; supplementary data will be published at a later date. Fairchild Semiconductor reserves the right to make changes at any time without notice to improve design. Datasheet contains final specifications. Fairchild Semiconductor reserves the right to make changes at any time without notice to improve the design. Datasheet contains specifications on a product that is discontinued by Fairchild Semiconductor. The datasheet is for reference information only. Rev. I47 © Fairchild Semiconductor Corporation www.fairchildsemi.com
D44H11 价格&库存
很抱歉,暂时无法提供与“D44H11”相匹配的价格&库存,您可以联系我们找货
