BZX79B27 A0G
BZX79B27 A0G
    TAIWANSEMICONDUCTOR(台半)
    DO-35(DO-204AH)
    DIODE ZENER 27V 500MW DO35
BZX79B27 A0G 数据手册
BZX79B2V4 – BZX79B75 Taiwan Semiconductor 500mW, 2% Zener Diode FEATURES ● ● ● ● ● KEY PARAMETERS Wide zener voltage range selection: 2.4V to 75V VZ Tolerance selection of ±2% Hermetically sealed glass RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● Low voltage stabilizers or voltage references Adapters Lighting application On-board DC/DC converter PARAMETER VALUE UNIT VZ 2.4 - 75 V Test current IZT 2.5 - 5.0 mA Ptot 500 mW VF at IF = 100mA 1.5 V TJ MAX 175 °C Package DO-35 Configuration Single die MECHANICAL DATA ● ● ● ● Case: DO-35 Terminal: Matte tin plated leads, solderable per J-STD-002 Polarity: Indicated by cathode band Weight: 109 ± 4mg (approximately) DO-35 ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL VALUE UNIT Forward voltage @ IF = 100mA VF 1.5 V Total power dissipation Ptot 500 mW Junction temperature range TJ -55 to +175 °C Storage temperature range TSTG -55 to +175 °C 1 Version:E2103 BZX79B2V4 – BZX79B75 Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) ZENER VOLTAGE(1) PART NUMBER TEST CURRENT REGULAR IMPEDANCE(1) TEST CURRENT VZ @ IZ IZT ZZT @ IZT ZZK @ IZK IZK V mA Ω Ω mA LEAKAGE CURRENT VZ @ IZT V mA Min Nom Max Max Max Max. BZX79B2V4 2.35 2.40 2.45 5 100 600 1.0 100 1.0 BZX79B2V7 2.65 2.70 2.75 5 100 600 1.0 75 1.0 BZX79B3V0 2.94 3.00 3.06 5 95 600 1.0 50 1.0 BZX79B3V3 3.23 3.30 3.37 5 95 600 1.0 25 1.0 BZX79B3V6 3.53 3.60 3.67 5 90 600 1.0 15 1.0 BZX79B3V9 3.82 3.90 3.98 5 90 600 1.0 10 1.0 BZX79B4V3 4.21 4.30 4.39 5 90 600 1.0 5 1.0 BZX79B4V7 4.61 4.70 4.79 5 80 500 1.0 3.0 2.0 BZX79B5V1 5.00 5.10 5.2 5 60 480 1.0 2.0 2.0 BZX79B5V6 5.49 5.60 5.71 5 40 400 1.0 1.0 2.0 BZX79B6V2 6.08 6.20 6.32 5 10 150 1.0 3.0 4.0 BZX79B6V8 6.66 6.80 6.94 5 15 80 1.0 2.0 4.0 BZX79B7V5 7.35 7.50 7.65 5 15 80 1.0 1.0 5.0 BZX79B8V2 8.04 8.20 8.36 5 15 80 1.0 0.7 5.0 BZX79B9V1 8.92 9.10 9.28 5 15 100 1.0 0.5 6.0 BZX79B10 9.80 10.00 10.2 5 20 150 1.0 0.2 7.0 BZX79B11 10.78 11.00 11.22 5 20 150 1.0 0.1 8.0 BZX79B12 11.76 12.00 12.24 5 25 150 1.0 0.1 8.0 BZX79B13 12.74 13.00 13.26 5 30 170 1.0 0.1 8.0 BZX79B15 14.70 15.00 15.30 5 30 200 1.0 0.05 10.5 BZX79B16 15.68 16.00 16.32 5 40 200 1.0 0.05 11.2 BZX79B18 17.64 18.00 18.36 5 45 225 1.0 0.05 12.6 BZX79B20 19.60 20.00 20.40 5 55 225 1.0 0.05 14.0 BZX79B22 21.56 22.00 22.44 5 55 250 1.0 0.05 15.4 BZX79B24 23.52 24.00 24.48 5 70 250 1.0 0.05 16.8 BZX79B27 26.46 27.00 27.54 2 80 300 0.5 0.05 18.9 BZX79B30 29.40 30.00 30.60 2 80 300 0.5 0.05 21.0 BZX79B33 32.34 33.00 33.66 2 80 325 0.5 0.05 23.1 BZX79B36 35.28 36.00 36.72 2 90 350 0.5 0.05 25.2 BZX79B39 38.22 39.00 39.78 2 130 350 0.5 0.05 27.3 BZX79B43 42.14 43.00 43.86 2 150 375 0.5 0.05 30.1 BZX79B47 46.06 47.00 47.94 2 170 375 0.5 0.05 32.9 BZX79B51 49.98 51.00 52.02 2 180 400 0.5 0.05 35.7 BZX79B56 54.88 56.00 57.12 2 200 425 0.5 0.05 39.2 BZX79B62 60.76 62.00 63.24 2.5 215 430 0.5 0.05 43.4 BZX79B68 66.64 68.00 69.36 2.5 240 447 0.5 0.05 47.6 BZX79B75 73.50 75.00 76.50 2.5 255 470 0.5 0.05 52.5 Notes: 1. ZENER IMPEDANCE (ZZ) derivation ZZT and ZZK are measured by dividing the AC voltage drop across the device by the AC current applied. The specified limits are for IZ(AC) = 0.1 IZ(DC) with the AC frequency = 60Hz. ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING BZX79Bx R0G DO-35 10K / 14” Reel BZX79Bx A0G DO-35 5K / Box(Ammo) Notes: 1. “x” defines voltage from 2.4V(BZX79B2V4) to 75V(BZX79B75) 2 Version:E2103 BZX79B2V4 – BZX79B75 Taiwan Semiconductor PACKAGE OUTLINE DIMENSION DO-35 DIM. Unit(mm) Unit(inch) Min Max Min Max A 0.34 0.60 0.013 0.024 B 2.90 5.08 0.114 0.200 C 25.40 38.10 1.000 1.500 D 1.30 2.28 0.051 0.090 MARKING DIAGRAM 3 Version:E2103 BZX79B2V4 – BZX79B75 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 4 Version:E2103
BZX79B27 A0G 价格&库存
很抱歉,暂时无法提供与“BZX79B27 A0G”相匹配的价格&库存,您可以联系我们找货
