MTZJ2V0SA - MTZJ56S
Taiwan Semiconductor
500mW, 2V-56V Zener Diodes
FEATURES
KEY PARAMETERS
● Wide zener voltage range selection: 2.0V to 56V
● Hermetically sealed glasss
● Compliant to RoHS directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
PARAMETER
VALUE
UNIT
VZ
2.0 - 56
V
Test current IZT
5
mA
PD
500
mW
TJ MAX
175
°C
APPLICATIONS
Low voltage stabilizers or voltage references
Adapters
Lighting application
On-board DC/DC converter
Package
DO-34
Configuration
Single die
MECHANICAL DATA
Case: DO-34
Terminal: Matte tin plated leads, solderable per J-STD-002
Polarity: Indicated by cathode band
Weight: 92 mg (approximately)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Power dissipation
Junction temperature range
Storage temperature
SYMBOL
PD
TJ
TSTG
1
VALUE
500
-55 to +175
-55 to +175
UNIT
mW
°C
°C
Version: C1804
MTZJ2V0SA - MTZJ56S
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
ZENER VOLTAGE
MARKING
PART NUMBER
MTZJ2V0S
MTZJ2V2S
MTZJ2V4S
MTZJ2V7S
MTZJ3V0S
MTZJ3V3S
MTZJ3V6S
MTZJ3V9S
MTZJ4V3S
MTZJ4V7S
MTZJ5V1S
MTZJ5V6S
MTZJ6V2S
MTZJ6V8S
MTZJ7V5S
MTZJ8V2S
MTZJ9V1S
MTZJ10S
MTZJ11S
MTZJ12S
MTZJ13S
MTZJ15S
MTZJ16S
A
B
A
B
A
B
A
B
A
B
A
B
A
B
A
B
A
B
C
A
B
C
A
B
C
A
B
C
A
B
C
A
B
C
A
B
C
A
B
C
A
B
C
A
B
C
D
A
B
C
A
B
C
A
B
C
A
B
C
A
B
C
CODE
2V0A
2V0B
2V2A
2V2B
2V4A
2V4B
2V7A
2V7B
3V0A
3V0B
3V3A
3V3B
3V6A
3V6B
3V9A
3V9B
4V3A
4V3B
4V3C
4V7A
4V7B
4V7C
5V1A
5V1B
5V1C
5V6A
5V6B
5V6C
6V2A
6V2B
6V2C
6V8A
6V8B
6V8C
7V5A
7V5B
7V5C
8V2A
8V2B
8V2C
9V1A
9V1B
9V1C
10A
10B
10C
10D
11A
11B
11C
12A
12B
12C
13A
13B
13C
15A
15B
15C
16A
16B
16C
Min.
1.88
2.02
2.12
2.22
2.33
2.43
2.54
2.69
2.85
3.01
3.16
3.32
3.45
3.60
3.74
3.89
4.04
4.17
4.30
4.44
4.55
4.68
4.81
4.94
5.09
5.28
5.45
5.61
5.78
5.96
6.12
6.29
6.49
6.66
6.85
7.07
7.29
7.53
7.78
8.03
8.29
8.57
8.83
9.12
9.41
9.70
9.97
10.18
10.50
10.82
11.13
11.44
11.74
12.11
12.55
12.99
13.44
13.89
14.35
14.80
15.25
15.69
TEST
REGULAR
TEST
CURRENT
IMPEDANCE
CURRENT
LEAKAGE
CURRENT
IZK
IR @ V R
VZ @ IZT
IZT
V
mA
Nom.
1.99
2.11
2.21
2.32
2.43
2.53
2.65
2.80
2.96
3.12
3.27
3.43
3.58
3.72
3.88
4.03
4.17
4.30
4.44
4.56
4.68
4.81
4.94
5.07
5.23
5.42
5.59
5.76
5.94
6.12
6.28
6.46
6.66
6.84
7.04
7.26
7.48
7.73
7.99
8.24
8.51
8.79
9.07
9.36
9.66
9.95
10.21
10.45
10.78
11.10
11.42
11.74
12.05
12.43
12.88
13.33
13.79
14.26
14.72
15.19
15.65
16.10
Max.
2.10
2.20
2.30
2.41
2.52
2.63
2.75
2.91
3.07
3.22
3.38
3.53
3.695
3.845
4.01
4.16
4.29
4.43
4.57
4.68
4.80
4.93
5.07
5.20
5.37
5.55
5.73
5.91
6.09
6.27
6.44
6.63
6.83
7.01
7.22
7.45
7.67
7.92
8.19
8.45
8.73
9.01
9.30
9.59
9.90
10.20
10.44
10.71
11.05
11.38
11.71
12.03
12.35
12.75
13.21
13.66
14.13
14.62
15.09
15.57
16.04
16.51
ZZT @ IZT
ZZK @ IZK
Ω
Ω
Max.
Max.
mA
μA
V
Max.
5
100
1000
0.5
120
0.5
5
100
1000
0.5
120
0.7
5
100
1000
0.5
120
1.0
5
110
1000
0.5
100
1.0
5
120
1000
0.5
50
1.0
5
120
1000
0.5
5
100
1000
1.0
10
1.0
5
100
1000
1.0
5
1.0
5
100
1000
1.0
5
1.0
5
80
900
0.5
5
1.0
5
80
1200
0.5
5
1.5
5
60
900
0.5
5
2.5
5
60
500
0.5
5
3.0
5
0.5
2
3.5
5
0.5
0.5
4.0
5
0.5
0.5
5.0
5
25
120
0.5
0.5
6.0
5
30
120
0.5
0.2
7
5
30
120
0.5
0.2
8
5
30
110
0.5
0.2
9
5
35
110
0.5
0.2
10
5
40
110
0.5
0.2
11
5
40
150
0.5
0.2
12
2
Version: C1804
MTZJ2V0SA - MTZJ56S
MTZJ18S
MTZJ20S
MTZJ22S
MTZJ24S
MTZJ27S
MTZJ30S
MTZJ33S
MTZJ36S
MTZJ39S
MTZJ43S
MTZJ47S
MTZJ51S
MTZJ56S
A
B
C
A
B
C
D
A
B
C
D
A
B
C
D
A
B
C
D
A
B
C
D
A
B
C
D
A
B
C
D
A
B
C
D
E
F
G
CODE
18A
18B
18C
20A
20B
20C
20D
22A
22B
22C
22D
24A
24B
24C
24D
27A
27B
27C
27D
30A
30B
30C
30D
33A
33B
33C
33D
36A
36B
36C
36D
39A
39B
39C
39D
39E
39F
39G
43S
47S
51S
56S
Min.
16.22
16.82
17.42
18.02
18.63
19.23
19.72
20.15
20.64
21.08
21.52
22.05
22.61
23.12
23.63
24.26
24.97
25.63
26.29
26.99
27.70
28.36
29.02
29.68
30.32
30.90
31.49
32.14
32.79
33.40
34.01
34.68
35.36
36.00
36.63
37.36
38.14
38.94
40.00
44.00
48.00
53.00
REGULAR
TEST
IMPEDANCE
CURRENT
VZ @ IZT
IZT
ZZT @ IZT
ZZK @ IZK
IZK
IR @ V R
V
mA
Ω
Ω
mA
Max.
Max.
5
45
150
0.5
0.2
13
5
55
200
0.5
0.2
15
5
30
200
0.5
0.2
17
5
35
200
0.5
0.2
19
5
45
250
0.5
0.2
21
5
55
250
0.5
0.2
23
5
65
250
0.5
0.2
25
5
75
250
0.5
0.2
27
5
85
250
0.5
0.2
30
5
90
90
110
110
250
250
250
250
0.5
0.5
0.5
0.5
0.2
0.2
0.2
0.2
33
36
39
43
CURRENT
MARKING
PART NUMBER
TEST
LEAKAGE
CURRENT
ZENER VOLTAGE
Nom.
16.64
17.26
17.88
18.49
19.11
19.73
20.22
20.68
21.18
21.63
22.08
22.62
23.19
23.72
24.24
24.89
25.62
26.29
26.97
27.69
28.42
29.09
29.77
30.45
31.10
31.70
32.30
32.97
33.64
34.27
34.89
35.58
36.28
36.93
37.58
38.33
39.13
39.87
42.50
46.50
51.00
56.50
Max.
17.06
17.70
18.33
18.96
19.59
20.22
20.72
21.2
21.71
22.17
22.63
23.18
23.77
24.31
24.85
25.52
26.26
26.95
27.64
28.39
29.13
29.82
30.51
31.22
31.88
32.50
33.11
33.79
34.49
35.13
35.77
36.47
37.19
37.85
38.52
39.29
40.11
40.80
45.00
49.00
54.00
60.00
μA
V
Max.
Notes:
1. The zener voltage subdivision (VZ) is measured 30ms after diode is powered up
2. The operating resistance (ZZT or ZZK) is measured by superimposing a minute alternation current in the
regulated current (IZ)
3. When ordering, please specify tolerance A, B, C, D, E, F, G
3
Version: C1804
MTZJ2V0SA - MTZJ56S
ORDERING INFORMATION
ORDERING CODE
(Note 1, 2)
PACKAGE
PACKING
MTZJxxxSx R0
DO-34
10K / 14" Reel
MTZJxxxSx R0G
DO-34
10K / 14" Reel
MTZJxxxSx A0
DO-34
5K / Box (Ammo)
MTZJxxxSx A0G
DO-34
5K / Box (Ammo)
Note:
1. "xxx" defines voltage from 2.0V (MTZJ2V0SA) to 56V (MTZJ56S)
2. “G” means green compound (Halogen free)
4
Version: C1804
MTZJ2V0SA - MTZJ56S
CHARACTERISTICS CURVES
Fig. 1 VZ - IZ Characteristics
10
8.2
7.5
6.8
1
22
24
30
27
36
33
39
Zener Current, IZ (mA)
6.2
16
15
13
12
11
10
9.1
5.6
0.1
5.1
4.7
4.3
0.01
3.9
3.6
0.001
4
6
8
10
12
14
16
18
24
Zener Voltage, VZ (V)
28
30
32
34
36
38
40
Fig. 3 rz - VZ Characteristics
Fig. 2 PD - TA Characteristics
0.10
Temp. Coefficient : rz (%/ oC)
600
Power Dissipation : PD (mW)
26
500
400
300
200
Iz = 5 mA
0.08
Iz = 10 mA
0.06
0.04
0.02
0.00
-0.02
Iz = 10 mA
-0.04
100
Iz = 5 mA
-0.06
50
75
100
125
150
175
-0.08
200
Ambient Temperature : TA (oC)
10
40
50
Zener Voltage (V)
5
Version: C1804
MTZJ2V0SA - MTZJ56S
PACKAGE OUTLINE DIMENSION
DO-34
DIM
A
B
C
D
Unit (mm)
Min
Max
0.30
0.55
2.16
3.04
25.40
38.10
1.27
2.00
Unit (inch)
Min
Max
0.012
0.022
0.085
0.120
1.000
1.500
0.050
0.079
MARKING DIAGRAM
xxx = Marking code
6
Version: C1804
MTZJ2V0SA - MTZJ56S
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: C1804
很抱歉,暂时无法提供与“MTZJ27SB R0G”相匹配的价格&库存,您可以联系我们找货
