BZX79C62 A0G
BZX79C62 A0G
    TAIWANSEMICONDUCTOR(台半)
    DO-35(DO-204AH)
    DIODE ZENER 62V 500MW DO35
BZX79C62 A0G 数据手册
BZX79C2V0 - BZX79C75 Taiwan Semiconductor 500mW, 5% Tolerance Zener Diodes FEATURES KEY PARAMETERS ● Wide zener voltage range selection: 2.0V to 75V ● VZ tolerance selection of ± 5% ● Compliant to RoHS directive 2011/65/EU and in accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT VZ 2.0-75 V Test current IZT 5 mA PD 500 mW VF at IF=100mA 1.5 V TJ Max. 175 °C APPLICATIONS ● ● ● ● Low voltage stabilizers or voltage references Adapters Lighting application On-board DC/DC converter Package DO-35 Configuration Single die MECHANICAL DATA ● ● ● ● Case: DO-35 Terminal: Matte tin plated leads, solderable per J-STD-002 Polarity: Indicated by cathode band Weight: 109 ± 4 mg (approximately) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Power dissipation SYMBOL VALUE UNIT PD 500 mW VF 1.5 V Junction temperature range TJ -65 to +175 °C Storage temperature range TSTG -65 to +175 °C SYMBOL TYP UNIT RӨJA 300 °C/W Forward voltage IF=100mA THERMAL PERFORMANCE PARAMETER Junction to ambient thermal resistance 1 Version:F1804 BZX79C2V0 - BZX79C75 Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) ZENER VOLTAGE PART MARKING NUMBER CODE TEST REGULAR TEST LEAKAGE CURRENT IMPEDANCE CURRENT CURRENT ZZK @ IZK IZK IR @ V R mA VZ @ IZT IZT V Min. mA Nom. Max. ZZT @ IZT Ω Ω Max. Max. µA V Max. BZX79C2V0 BZX79C2V0 1.88 2.0 2.12 5 100 600 1.0 150 1.0 BZX79C2V2 BZX79C2V2 2.08 2.2 2.33 5 100 600 1.0 150 1.0 BZX79C2V4 BZX79C2V4 2.28 2.4 2.56 5 100 600 1.0 100 1.0 BZX79C2V7 BZX79C2V7 2.51 2.7 2.89 5 100 600 1.0 75 1.0 BZX79C3V0 BZX79C3V0 2.8 3.0 3.2 5 95 600 1.0 50 1.0 BZX79C3V3 BZX79C3V3 3.1 3.3 3.5 5 95 600 1.0 25 1.0 BZX79C3V6 BZX79C3V6 3.4 3.6 3.8 5 90 600 1.0 15 1.0 BZX79C3V9 BZX79C3V9 3.7 3.9 4.1 5 90 600 1.0 10 1.0 BZX79C4V3 BZX79C4V3 4.0 4.3 4.6 5 90 600 1.0 5 1.0 BZX79C4V7 BZX79C4V7 4.4 4.7 5.0 5 80 500 1.0 3 2.0 BZX79C5V1 BZX79C5V1 4.8 5.1 5.4 5 60 480 1.0 2 2.0 BZX79C5V6 BZX79C5V6 5.2 5.6 6.0 5 40 400 1.0 1 2.0 BZX79C6V2 BZX79C6V2 5.8 6.2 6.6 5 10 150 1.0 3 4.0 BZX79C6V8 BZX79C6V8 6.4 6.8 7.2 5 15 80 1.0 2 4.0 BZX79C7V5 BZX79C7V5 7.0 7.5 7.9 5 15 80 1.0 1 5.0 BZX79C8V2 BZX79C8V2 7.7 8.2 8.7 5 15 80 1.0 0.7 5.0 BZX79C9V1 BZX79C9V1 8.5 9.1 9.6 5 15 100 1.0 0.5 6.0 BZX79C10 BZX79C10 9.4 10 10.6 5 20 150 1.0 0.2 7.0 BZX79C11 BZX79C11 10.4 11 11.6 5 20 150 1.0 0.1 8.0 BZX79C12 BZX79C12 11.4 12 12.7 5 25 150 1.0 0.1 8.0 BZX79C13 BZX79C13 12.4 13 14.1 5 30 170 1.0 0.1 8 BZX79C15 BZX79C15 13.8 15 15.6 5 30 200 1.0 0.05 10.5 BZX79C16 BZX79C16 15.3 16 17.1 5 40 200 1.0 0.05 11.2 BZX79C18 BZX79C18 16.8 18 19.1 5 45 225 1.0 0.05 12.6 BZX79C20 BZX79C20 18.8 20 21.2 5 55 225 1.0 0.05 14.0 BZX79C22 BZX79C22 20.8 22 23.3 5 55 250 1.0 0.05 15.4 BZX79C24 BZX79C24 22.8 24 25.6 5 70 250 1.0 0.05 16.8 BZX79C27 BZX79C27 25.1 27 28.9 2 80 300 0.5 0.05 18.9 BZX79C30 BZX79C30 28.0 30 32.0 2 80 300 0.5 0.05 21.0 BZX79C33 BZX79C33 31.0 33 35.0 2 80 325 0.5 0.05 23.1 BZX79C36 BZX79C36 34.0 36 38.0 2 90 350 0.5 0.05 25.2 BZX79C39 BZX79C39 37.0 39 41.0 2 130 350 0.5 0.05 27.3 BZX79C43 BZX79C43 40.0 43 46.0 2 150 375 0.5 0.05 30.1 BZX79C47 BZX79C47 44.0 47 50.0 2 170 375 0.5 0.05 32.9 BZX79C51 BZX79C51 48.0 51 54.0 2 180 400 0.5 0.05 35.7 BZX79C56 BZX79C56 52.0 56 60.0 2 200 425 0.5 0.05 39.2 BZX79C62 BZX79C62 58.0 62 66.0 2.5 215 1000 0.5 0.05 43.4 BZX79C68 BZX79C68 64.0 68 72.0 2.5 240 1000 0.5 0.05 47.6 BZX79C75 BZX79C75 70.0 75 80.0 2.5 255 1000 0.5 0.05 52.5 2 Version:F1804 BZX79C2V0 - BZX79C75 Taiwan Semiconductor Notes: 1. The zener voltage (VZ) is tested under pulse condition of 30ms. 2. The device numbers listed have a standard tolerance on the nomial zener voltage of ±5%. 3. For detailed information on price, availability and delivery of nominal zener voltages between the voltages shown and tighter voltage tolerances, contact your nearest Taiwan Semiconductor representative. 4. The Zener impedance is derived from the 60-cycle ac voltage, which results when an ac current having an RMS value equal to 10% of the DC Zener current(IZT or IZK) is superimposed to IZT or IZK. ORDERING INFORMATION PART NO. (Note 1) PACKAGE PACKING BZX79Cxxx R0 DO-35 10K / 14" Reel BZX79Cxxx R0G DO-35 10K / 14" Reel BZX79Cxxx A0 DO-35 5K / Box (Ammo) BZX79Cxxx A0G DO-35 5K / Box (Ammo) Note: 1. "xxx" defines part no. from BZX79C2V0 to BZX79C75 3 Version:F1804 BZX79C2V0 - BZX79C75 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Power Dissipation VS. Fig. 2 Total Capacitance Ambient Temperature 1000 500 Total Capacitance (pF) PD-Power dissipation (mW) 600 400 300 200 VR=2V 100 VR=5V 10 100 VR=20V 0 VR=30V 1 0 40 80 120 160 200 0 20 40 60 VZ - Reverse Voltage (V) Temperature (oC) Fig. 3 Differential Impedance VS. Zener Voltage 80 Fig.4 Forward Current VS. Forward Voltage 1000 1000 IZ=1mA TA=25oC IZ=2mA 100 Forward Current (mA) Differential Zener Impedance(Ohm) f=1MHz TA=25oC VR=0V IZ=5mA 10 IZ=10mA 100 10 1 1 0.1 0 1 10 0.0 100 VZ - Reverse Voltage (V) 0.2 0.4 0.6 0.8 1.0 1.2 VF - Forward Voltage (mV) 4 Version:F1804 BZX79C2V0 - BZX79C75 Taiwan Semiconductor PACKAGE OUTLINE DIMENSION DO-35 DIM. 5 Unit (mm) Unit (inch) Min Max Min Max A 0.34 0.60 0.013 0.024 B 2.90 5.08 0.114 0.200 C 25.40 38.10 1.000 1.500 D 1.30 2.28 0.051 0.090 Version:F1804 BZX79C2V0 - BZX79C75 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version:F1804
BZX79C62 A0G 价格&库存
很抱歉,暂时无法提供与“BZX79C62 A0G”相匹配的价格&库存,您可以联系我们找货
