BZX585B20 RSG
BZX585B20 RSG
    TAIWANSEMICONDUCTOR(台半)
    SOD523
    DIODE ZENER 20V 200MW SOD523F
BZX585B20 RSG 数据手册
BZX585B2V4 - BZX585B51 Taiwan Semiconductor Small Signal Product Zener Diode, 2% Tolerance FEATURES - Surface mounted device - Zener voltage range from 2.4V-51V - Power dissipation 200mW - Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC - Halogen-free according to IEC 61249-2-21 MECHANICAL DATA SOD-523F - Case: SOD-523F package - Moisture sensitivity level (MSL): 1 - Pb free and RoHS compliant - High temperature soldering guaranteed: 260°C/10s - Weight: 1.36mg approx. MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25℃ unless otherwise noted) PARAMETER Power dissipation Thermal resistance (Junction to Ambient) Junction temperature Storage temperature SYMBOL PD RθJA TJ VALUE 200 680 150 TSTG - 65 to +150 UNIT mW o C/W o C o C Version: C1607 BZX585B2V4 - BZX585B51 Taiwan Semiconductor Small Signal Product ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted) Maximum Zener Impedance Zener Voltage Range Part Number Marking VZ @ IZT (V) IZT (mA) ZZT @ IZT (Ω) Maximum Reverse Currrent ZZK @ IZK IR (μA) VR (V) Typical Temperature Coefficent Tc @ IZT Test Current IZT o (mV/ C) Nom Min Max (Ω) (mA) Min Max mA BZX585B2V4 05 2.4 2.35 2.45 5 100 564 1.0 45 1 -3.5 0.0 5 BZX585B2V7 15 2.7 2.65 2.75 5 100 564 1.0 18 1 -3.5 0.0 5 BZX585B3V0 25 3.0 2.94 3.06 5 100 564 1.0 9 1 -3.5 0.0 5 BZX585B3V3 35 3.3 3.23 3.37 5 95 564 1.0 4.5 1 -3.5 0.0 5 BZX585B3V6 45 3.6 3.53 3.67 5 90 564 1.0 4.5 1 -3.5 0.0 5 BZX585B3V9 55 3.9 3.82 3.98 5 90 564 1.0 2.7 1 -3.5 0.0 5 BZX585B4V3 65 4.3 4.21 4.39 5 90 564 1.0 2.7 1 -3.5 0.0 5 BZX585B4V7 75 4.7 4.61 4.79 5 80 470 1.0 2.7 2 -3.5 0.0 5 BZX585B5V1 85 5.1 5.00 5.20 5 60 451 1.0 1.8 2 -2.7 1.2 5 BZX585B5V6 95 5.6 5.49 5.71 5 40 376 1.0 0.9 2 -2 2.5 5 BZX585B6V2 A5 6.2 6.08 6.32 5 10 141 1.0 2.7 4 0.4 3.7 5 BZX585B6V8 B5 6.8 6.66 6.94 5 15 75 1.0 1.8 4 1.2 4.5 5 BZX585B7V5 C5 7.5 7.35 7.65 5 15 75 1.0 0.9 5 2.5 5.3 5 BZX585B8V2 D5 8.2 8.04 8.36 5 15 75 1.0 0.63 5 3.2 6.2 5 BZX585B9V1 E5 9.1 8.92 9.28 5 15 94 1.0 0.45 6 3.8 7.0 5 BZX585B10 F5 10 9.80 10.20 5 20 141 1.0 0.18 7 4.5 8.0 5 BZX585B11 G5 11 10.78 11.22 5 20 141 1.0 0.09 8 5.4 9.0 5 BZX585B12 H5 12 11.60 12.24 5 25 141 1.0 0.09 8 6.0 10.0 5 BZX585B13 J5 13 12.74 13.26 5 30 160 1.0 0.09 8 7.0 11.0 5 BZX585B15 K5 15 14.70 15.30 5 30 188 1.0 0.045 10.5 9.2 13.0 5 BZX585B16 L5 16 15.68 16.32 5 40 188 1.0 0.045 11.2 10.4 14.0 5 BZX585B18 M5 18 17.64 18.36 5 45 212 1.0 0.045 12.6 12.4 16.0 5 BZX585B20 N5 20 19.60 20.40 5 55 212 1.0 0.045 14.0 14.4 18.0 5 BZX585B22 P5 22 21.56 22.44 5 55 235 1.0 0.045 15.4 16.4 20.0 5 BZX585B24 R5 24 23.52 24.48 5 70 235 1.0 0.045 16.8 18.4 22.0 5 BZX585B27 S5 27 26.46 27.54 2 80 282 0.5 0.045 18.9 21.4 25.3 2 BZX585B30 T5 30 29.40 30.60 2 80 282 0.5 0.045 21.0 24.4 29.4 2 BZX585B33 U5 33 32.34 33.66 2 80 306 0.5 0.045 23.0 27.4 33.4 2 BZX585B36 V5 36 35.28 36.72 2 90 329 0.5 0.045 25.2 30.4 37.4 2 BZX585B39 X5 39 38.22 39.78 2 130 329 0.5 0.045 27.3 33.4 41.2 2 BZX585B43 Y5 43 42.14 43.86 2 150 353 0.5 0.045 30.1 10.0 12.0 5 BZX585B47 Z5 47 46.06 47.94 2 170 353 0.5 0.045 33.0 10.0 12.0 5 BZX585B51 -5 51 49.98 52.02 2 180 376 0.5 0.045 35.7 10.0 12.0 5 Version: C1607 BZX585B2V4 - BZX585B51 Taiwan Semiconductor Small Signal Product RATINGS AND CHARACTERISTICS CURVES (TA=25°C unless otherwise noted) Fig. 2 Effect of Zener voltage on Zener impedance Fig.1 Typical forward characteristics 1000 1000 TJ=25°C Iz(AC)=0.1Iz(DC) F=1kHz Dynamic impedance (Ω) Forward Current (mA) Iz=1mA 100 150°C 10 25°C 75°C 100 5mA 20mA 10 5°C 1 0.4 0.5 0.6 0.7 0.8 0.9 1 1.1 1 1.2 1 10 Forward Voltage (V) 100 Normal Zener voltage (V) Fig. 4 Typical capacitance Fig.3 Power dissipation vs. ambient temp. 1000 250 TJ=25oC 200 1V BIAS Capacitance (pF) Power dissipation (mW) 0V BIAS 150 100 100 BIAS at 50% of Vz NOM 10 50 0 1 0 25 50 75 100 125 150 1 10 100 Norminal Zener voltage (V) Ambient temperature (oC) Fig.6 Zener breakdown characteristics Fig.5 Zener breakdown characteristics 100 100 25°C 25°C 10 Zener current (mA) Zener current (mA) 10 1 0.1 1 0.1 0.01 0.01 0 2 4 6 Zener voltage (V) 8 10 12 10 30 50 70 Zener voltage (V) Version: C1607 BZX585B2V4 - BZX585B51 Taiwan Semiconductor Small Signal Product ORDERING INFORMATION PART NO. PACKING CODE BZX585Bxxx (Note1, 2) RU PACKING CODE RS SUFFIX G PACKAGE SOD-523F PACKING 8,000 / 7" Reel 3,000 / 7" Reel Note 1: "xxx" defines voltage from 2.4V (BZX585B2V4) to 51V (BZX585B51) Note 2: Whole series with green compound EXAMPLE EXAMPLE P/N PART NO. PACKING CODE BZX585B51 RSG BZX585B51 RS PACKING CODE SUFFIX G DESCRIPTION Green compound Version: C1607 BZX585B2V4 - BZX585B51 Taiwan Semiconductor Small Signal Product PACKAGE OUTLINE DIMENSIONS SOD-523F DIM. Unit (mm) Unit (inch) Min Max Min Max A 0.70 0.90 0.028 0.035 B 1.50 1.70 0.059 0.067 C 0.25 0.40 0.010 0.016 D 1.10 1.30 0.043 0.051 E 0.50 0.77 0.020 0.030 F 0.07 0.20 0.003 0.008 SUGGESTED PAD LAYOUT DIM. Unit (mm) Unit (inch) X 0.6 0.024 X1 2.3 0.091 Y 0.8 0.031 Version: C1607 BZX585B2V4 - BZX585B51 Taiwan Semiconductor Small Signal Product Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Version: C1607
BZX585B20 RSG 价格&库存
很抱歉,暂时无法提供与“BZX585B20 RSG”相匹配的价格&库存,您可以联系我们找货
